I installed MK5 LED tail lights and coded them using http://forums.vwvortex.com/showthread.php?2289904 and http://forums.vwvortex.com/showthread.php?2289904 After doing everything, my driver side seems fine, but the passenger side does not. With the lights on, only the inner circle lights up. the blinker is only the red outer ring. Amber does not come on on the passenger side at all. The only thing I did differently is I did the wiring changes on the tail light side instead of the car side. I'm pretty confused.
05058E1140000000070A00000F000000000851035C00010C000000000000
Tuesday,17,April,2018,12:41:56:41190
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
VCDS Version 18.2.0.3 (x64) HEX-V2 CB: 0.4411.4
Chassis Type: 1K-VW35 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWEG71K57M125932 Mileage: 219570km-136434miles
Address 01: Engine Labels: 06A-906-032-BGP.lbl
Part No SW: 07K 906 032 Q HW: 07K 906 032 Q
Component: 2.5l R5/4V G 9650
Revision: --H01--- Serial number: VWZ7Z0G9019242
Coding: 0000003
VCID: 3728238D03478ADF832-8063
Part No SW: 09G 927 750 FL HW: 09G 927 750 FL
Component: AQ 250 6F 0920
Revision: 00H69000 Serial number:
Coding: 0000072
VCID: 005A885116090D67728-8055
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Revision: 00H11001
Coding: 0021122
VCID: 73B0D79D57BF26FF7FA-8027
Part No: 1K0 820 047 GS
Component: Climatic PQ35 120 0606
VCID: 7BA0FFBD7FEF6EBF27A-802F
Revision: 00H54000 Serial number: 00000007187910
Coding: 05058E1140000000070A00000F000000000851035C00010C000000000000
Shop #: WSC 09513 444 52621
VCID: 71BCDD952DA314EF8D6-8025
Component: Wischer 020207 020 0501
Coding: 00038805
Shop #: WSC 09513
Reset counter: 146
Mileage: 219571 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 14.05 V
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M00UX8R
Coding: 0013889
VCID: 6C82CCE10A81F907BE0-8039
Subsystem 2 - Serial number: 6332MSME15144A499
Subsystem 3 - Serial number: 6342MSME156E340DI
Subsystem 4 - Serial number: 6351HSME0C2B4F5DT
Subsystem 5 - Serial number: 6361HSME0C36602EB
Subsystem 6 - Serial number: 63727SME0B636C68C
Subsystem 7 - Serial number: 63827SME0B5D1C3EK
Part No SW: 1K0 953 549 CH HW: 1K0 953 549 CH
Component: J0527 056 0111
Coding: 0001731
VCID: 7AAEFAB970D557B73CC-802F
Subsystem 1 - Part No: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Coding: 00000130
Part No SW: 5K0 920 973 B HW: 5K0 920 973 B
Component: KOMBI H05 0705
Coding: 270F01
Shop #: WSC 00066 123 00120
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 303A1891EAA95DE7C28-8065
Part No SW: 7N0 907 530 M HW: 1K0 907 951
Component: J533 Gateway H42 1623
Revision: H42 Serial number: 260412F2003028
Coding: 351002
VCID: 3A2E3AB93C5597B77CC-806F
Component: IMMO H05 0705
VCID: 6A8ECAF90CF5E737CCC-803F
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1133
Revision: 32008001 Serial number: 00000108978115
Coding: 0001205
VCID: 3B203FBD3F6FAEBF67A-806F
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.070 H07 1806
VCID: 34321481123161C7A60-8061
Part No SW: 1K0 959 433 CD HW: 1K0 959 433 CD
Component: KSG PQ35 RDK 051 0215
Revision: 00051000 Serial number: 00000000000000
Coding: 13900F880186083F3F04058FB0880F0488DC40
Shop #: WSC 00066 123 12345
VCID: 74B2D48152B121C7660-8021
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1133
Revision: 32008001 Serial number: 00000576778105
Coding: 0001204
VCID: 3C223CA13A61A9876E0-8069
Fault Status: 00100101
Reset counter: 171
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 534 5314
Revision: -------- Serial number: VWZZZ4H6234825
Coding: 16000400040005
Shop #: WSC 00078 790 00217
VCID: 46D65E4978ADE357084-8013
00856 - Radio Antenna
Fault Status: 00111011
Reset counter: 173
Mileage: 219048 km
Date: 2018.04.10
Time: 13:38:42
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1120
Revision: 12006001 Serial number: 00000001060360
Coding: 0001168
VCID: 3E2636A92C7DBB97404-806B
Fault Frequency: 172
Reset counter: 146
Mileage: 218621 km
00934 - Electric Window Motor; Rear Left (V26)
Reset counter: 171
Component: RDK 0420
Coding: 0100101
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1120
Revision: 12006001 Serial number: 00000001047766
Coding: 0001168
VCID: 3FD84BAD2B77B29F4B2-806B
00935 - Electric Window Motor; Rear Right (V27)
Reset counter: 171
End----------(Elapsed Time: 01:13, VBatt start/end: 14.3V/14.3V)-----------
