VW amarok (Headlights)
Radiosolutions
C?ID=178437
posted autoscan attached. I have changed front lights. the new lights have daytime running lights which are not working. can someone look at coding attached to add daytime lights. thanks
VIN: WV1ZZZ2HZDH014104   License Plate: DE13NLT
Mileage: 86490km-53742mi   Repair Order: AMOROK
Chassis Type: 2H-VN81 (6N0)
Scan: 01 03 08 09 15 17 19 22 25 37 56
VIN: WV1ZZZ2HZDH014104   Mileage: 86490km-53742miles
Address 01: Engine (J623-CNEA)       Labels:. 03L-906-022-CFC.clb
   Part No SW: 03L 906 012 AD    HW: 03L 907 309 AC
   Component: R4 2,0L EDC   H24 5933
   Revision: 74H24---    Serial number: 00000000000000
   Coding: 01594012232600080000
   Shop #: WSC 87004 210 102191
   ASAM Dataset: EV_ECM20BTD01103L906012AD 001005
   ROD: EV_ECM20BTD01103L906012AD_001.rod
   VCID: 66C3673D99C1E37482-8032
11873 - Turbocharger Inlet Valve
          P22D2 00 [096] - Stuck Open
Address 03: ABS Brakes (-----)       Labels:. 2H0-907-37x-ESP.clb
   Part No SW: 2H0 907 379 L    HW: 2H0 907 379 D
   Component: ESP MK25A XT  H44 0110
   Revision: 00H44001
   Coding: C07324B69195039924A389A3AF5490
   Shop #: WSC 02739 790 49152
   VCID: 3979FC41B0FFBC8C1F-806C
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 2H0 907 040 E    HW: 2H0 907 040 E
   Component: ClimatronicT5 H19 0406
   Revision: 00001003
   Coding: 0000000002
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: 23453E292A73D65C25-8076
9473137 - Motor for Left Temperature Flap
          B108C 71 [008] - Actuator stuck
                    Reset counter: 221
                    Mileage: 86349 km
                    Date: 2018.04.15
                    Time: 20:58:57
   Part No SW: 6R7 937 087 M    HW: 6R7 937 087 M
   Component: PQ25 BCM      H30 0555
   Revision: -1------    Serial number: --------------
   Coding: 250002380C610400923008102C4B84C50080410E60020000300000000003
   Shop #: WSC 02739 790 00000
   VCID: 4E93BF9D19710B34DA-801A
   Subsystem 1 - Part No SW: 6R0 959 802 EJ    HW: 6R0 959 802 EJ  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  023 2332
   Serial number: 13202844170630232707
   Subsystem 2 - Part No SW: 6R0 959 801 EF    HW: 6R0 959 801 EF  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  023 2332
   Serial number: 13202847170701002649
   Subsystem 3 - Part No: 1K8 951 171 A
   Component: DWA-Sensor      001  001 0103
   Component: LIN BACKUP HORN H11  H11 9005
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 6R0 959 811 P    HW: 6R0 959 811 P
   Component: J388__TSG_HL  022 1334
   Serial number: 13202709170717182653
   Subsystem 7 - Part No SW: 6R0 959 812 P    HW: 6R0 959 812 P
   Component: J389__TSG_HR  022 1334
   Serial number: 13102708170717083728
   Part No SW: 2H0 959 655 B    HW: 2H0 959 655 B
   Component: VW10Airbag00M H07 0013
   Revision: --------    Serial number: 003HN00BM6YU
   Coding: 00000000000000000000000000000000304D
   VCID: 3365CE699A9346DCD5-8066
   Serial number: 3495RRB401250ET8CA43
   Serial number: 3505RRB401E50ET8D9VY
   Serial number: 3555YRB40024UPLG920V
   Serial number: 3565YRB40024UPLGOQ1T
9439771 - Front Passenger's Side Airbag Igniter
          B100A 1B [136] - Resistance Too High
                    Mileage: 86336 km
                    Date: 2018.04.14
                    Time: 18:40:32
   Part No SW: 2H0 920 963 C    HW: 2H0 920 963 C
   Component: KOMBI         H03 0307
   Serial number: 00000015008707
   Coding: 450A00
   ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01720
   ROD: EV_DashBoardUDSJCIPQ25_A01_VN81.rod
   VCID: 2A5BD30D4D59071466-807E
   Part No SW: 6N0 909 901     HW: 6R7 937 087 M
   Component: GW-K-CAN TP20 H30 0555
   Revision: -1------
   Coding: 742300
   VCID: 70EF0165A3053DC4E8-8024
   Part No SW: 2H0 927 755 C    HW: 2H0 927 755 C
   Component: SG offroad VTG      0155
   Revision: 00H07000    Serial number: T1IYC313232V2V
   Coding: 0000013
   VCID: 306FC165A3857DC4A8-8064
Address 25: Immobilizer (J285)       Labels:. 5K0-920-xxx-25.clb
   Component: IMMO          H03 0015
   ASAM Dataset: EV_ImmobUDSJCIPQ25 A01003
   ROD: EV_ImmobUDSJCIPQ25.rod
   Part No SW: 3C8 035 279 A    HW: 3C8 035 279 A
   Component: RNS315-EU   H62 0319
   Serial number: VWZAZ2N0134767
   Coding: 000004110200160000031002
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 29592C01485F0C0C6F-807C
   Component: EUR_W_V4  0050
7 Faults Found:
1048593 - Front Left Bass Speaker
          B105F 13 [008] - Open Circuit
                    Reset counter: 220
                    Mileage: 86336 km
                    Date: 2018.04.14
                    Time: 16:53:30
1048594 - Front Right Bass Speaker
          B1062 13 [008] - Open Circuit
                    Reset counter: 220
                    Mileage: 86336 km
                    Date: 2018.04.13
                    Time: 17:14:16
1048595 - Rear Left Bass Speaker
          B1065 13 [008] - Open Circuit
                    Reset counter: 220
                    Mileage: 86336 km
                    Date: 2018.04.14
                    Time: 16:53:30
1048596 - Rear Right Bass Speaker
          B1067 13 [008] - Open Circuit
                    Reset counter: 220
                    Mileage: 86336 km
                    Date: 2018.04.14
                    Time: 16:50:25
1048632 - Antenna 1 for Radio
          B1119 13 [008] - Open Circuit
                    Reset counter: 220
                    Mileage: 86336 km
                    Date: 2018.04.14
                    Time: 16:53:30
1048634 - Antenna 2 for radio
          B111A 13 [008] - Open Circuit
                    Reset counter: 220
                    Mileage: 86336 km
                    Date: 2018.04.13
                    Time: 17:14:16
1048582 - GPS Antenna
          B1054 13 [008] - Open Circuit
                    Reset counter: 220
                    Mileage: 86336 km
                    Date: 2018.04.13
                    Time: 17:14:16
End-------------------------(Elapsed Time: 02:14)--------------------------
iichel
Netherlands, eastern part
C?ID=284912
what lights did you put in? and which ones were in there?
iichel
C?ID=284912
PS, can we get a title change to something a bit more informative? And fix the typo in Amarok so it's a bit more easy to find later on by google :)
You bet!
And a move to Retrofits at no extra charge! :D
Radiosolutions
C?ID=178437
Lights which were originally in car are. 2h2 941 016h. 2h2 941 015h.
New lights are. 2h4 941 032. 2h4 941 031.
iichel
C?ID=284912
so you went from original halogen to original bi-xenon. unfortunately it's not possible without parameterisation of the BCM to bi-xenon.
in this case you even need a new BCM with the correct PR codes and wiring to accommodate the new 7E0937090x BCM in your car. your current BCM doesn't have the hardware and software to regulate the xenon headlights.
