seat ibiza 2013 (G85 Calibration)
zeeshan
C?ID=327143
got seat ibiza 2013 cant do the basic setting
Monday,16,April,2018,17:58:50:56296
VCDS Version: Release 18.2.0 Running on Windows 7 x86
Address 03: ABS Brakes Labels: 6R0-907-37x-ESP90.clb
Control Module Part Number: 6R0 907 379 AS HW: 6R0 907 379 AS
Component and/or Version: ESP9.0i front H03 0003
Software Coding: 13DD287D212500C5C815146E845A00880804
Work Shop Code: WSC 00049 770 00142
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020 (SE25)
ROD: EV_Brake1ESP90iBOSCH_003_VW21.rod
VCID: 0F7A443D17D0D2FFFB2-805A
0990 - Steering angle sensor
Reset counter: 2
Mileage: 60699 km
Date: 2018.04.16
Time: 00:39:26
0993 - Steering angle sensor
Reset counter: 2
Mileage: 60699 km
Date: 2018.04.16
Time: 00:38:51
"Cant do the basic setting" is not a very detailed problem description.
What have you tried?
What happens?
zeeshan
C?ID=327143
this car is damage repair had power steering pump changed and airbags everything works fine but the problem is the traction light is not going off and in the fault it says no basic setting when try to do the basic it comes up with ABORTED FOR SAFETY REASON.
PetrolDave
Westbury, UK
C?ID=1423
Posting a full Auto-Scan might be a good idea...
iichel
Netherlands, eastern part
C?ID=284912
i agree. would be good to see a full scan
set the car still
make sure there are no errors in 03 and 44
ignition on
03 ABS
security access, enter the security access displayed
steering straight ahead and wheel centered
basic settings
basic setting of steering angle sensor
go
see what it does
zeeshan
C?ID=327143
HI HERE
Tuesday,17,April,2018,16:03:57:56296
VCDS Version: 18.2.0.3  HEX-V2 CB: 0.4411.4
VIN: VSSZZZ6JZER025159   License Plate:
Mileage: 60710km-37723mi   Repair Order:
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZER025159   Mileage: 60710km-37723miles
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GR    HW: 03F 907 309 AE
   Component: SIMOS10.22AH10 5485
   Revision: --H10---    Serial number:
   Coding: 001100D6202400080000
   Shop #: WSC 00049 770 00142
   ASAM Dataset: EV_ECM12TFS02103F906070GR 004007
   ROD: EV_ECM12TFS02103F906070FP.rod
   VCID: 78A81FE1025EF5474A8-802C
Readiness: 0010 0101
   Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0003
   Serial number: --------------
                    Reset counter: 6
                    Mileage: 60714 km
                    Date: 2018.04.17
                    Time: 22:05:21
                    Reset counter: 6
                    Mileage: 60714 km
                    Date: 2018.04.17
                    Time: 22:03:42
   Component: LENKW.SENSOR  H07 0070
   Serial number: 02021504650339
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA409F9207ACB77004-802A
Address 08: Auto HVAC        Labels: 6J0-820-045.clb
   Part No SW: 6J0 820 045 A    HW: 6J0 820 045 A
   Component: J301  Klimaanlage   0330
   Revision: 00 26 08    Serial number: 0000002685754-
   VCID: 24101B91E2D641A7360-8070
   Part No SW: 6R0 937 087 P    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H34 0411
   Revision: BF034001    Serial number: 0581 179133162
   Coding: 24882BE888612500922008F06E4B9CC800C043E9608C0000200000000000
   VCID: 4ACC95292CB2B7D7ECC-801E
   Subsystem 1 - Part No SW: 6R0 959 802 AN    HW: 6R0 959 802 AN  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  006 5110
   Serial number: 13202556130701133904
   Coding: 030000
   Subsystem 2 - Part No SW: 6R0 959 801 AL    HW: 6R0 959 801 AL  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  006 5110
   Serial number: 13102561130702043643
   Coding: 020000
   Subsystem 3 - Part No: 1K8 951 171 A
   Component: DWA-Sensor 00  001 0103
   Subsystem 5 - Part No: 1K8 951 171 A
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10AirbagA0D H09 0020
   Revision: --------    Serial number: 003GX006525R
   Coding: 003044
   Shop #: WSC 06401 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACC95292C32B7D7ECC-801E
   Serial number: 3495RRB400Q50KB8F1UY
   Serial number: 3505RRB401G50KB2KGOP
   Part No SW: 6J0 920 906 P    HW: 6J0 920 906 P
   Component: KOMBI         H01 0709
   Coding: 410A00
   ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
   VCID: 3A2CC5E97CD227577CC-806E
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H34 0411
   Revision: BF034001
   Coding: 022300
   VCID: 70B827C16AAEAD07828-8024
   Component: IMMO          H01 0709
   VCID: 6A8C35A94CF257D7CCC-803E
   Part No: 6R0 423 156 A
   Component: LenkhilfeTRW        V275
   Coding: 11221
   Shop #: WSC 06403
   VCID: 2E04F9B9B95AFBF7D04-807A
Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
   Part No: 6J0 959 441 A
   Component: MF-Modul       0007 0001
   Shop #: WSC 77005 000 00000
   VCID: 313EE2C5AD24E40FCD6-8064
   Part No SW: 6J0 035 156     HW: 6J0 035 156
   Component: Radio         H07 0012
   Revision: R0000000    Serial number: SEZAZ1N6313626
   Coding: 010004080203
   VCID: 64905B91AE5601A7F60-8030
End----------(Elapsed Time: 01:16, VBatt start/end: 12.3V/12.2V)-----------
