My 2008 Audi A6 isn't responding to the key when I try to start the car. I turn the key, and the dash stays off, but the MMI turns on. It may be the ignition module reset or replacement is needed, but looking for others' opinions.
I scanned the car, and deleted the codes, twice -- first without override, and second with the hazards/highbeam/brake override, but no luck. Car still not cranking, dash doesn't turn on, but MMI does.
Here are the two scans. Can someone assist? Thanks in advance.
SCAN 1:
SCAN 2:
SCAN 1:
Sunday,15,April,2018,12:59:48:01374
VCDS Version: 18.2.0.3 (x64) HEX-V2 CB: 0.4411.4
Chassis Type: 4L0
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 42 46 47 4F 52 53
55 56 61 62 65 72 77
Mileage: 196000km-121788miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
53-Parking Brake -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0230
Revision: 09010701 Serial number: 10601500898293
Coding: 0000003
Shop #: WSC 02323 758 00200
VCID: 6390A6DFB755EDFF0FA-8036
Subsystem 1 - Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H45 0080
00288 - Steering Column Lock Actuator (N360)
014 - Defective
Fault Status: 01111110
Reset counter: 40
Mileage: 196002 km
Date: 2018.04.13
Time: 14:12:52
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 C HW: 4E0 035 729
Component: Interfacebox H43 4140
Revision: 00000000 Serial number: 303IY077557466
Coding: 0000003
Shop #: WSC 02335 758 00200
VCID: 2310E6DFF7D5ADFF4FA-8076
Subsystem 2 - Serial number: 00000000881406
Subsystem 3 - Serial number: 0102.10.070000000100010508ÿ
Subsystem 4 - Serial number: 010508ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000053 Serial number: 00000030291060
Coding: 0524326
Shop #: WSC 02325 758 00200
VCID: 1C62DD23CAAB92078E0-8048
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H18 0250
Coding: 0012123
VCID: 313C1C97BD290F6FCD6-8064
Subsystem 1 - Component: Fehler Lin-Slave 01
Subsystem 2 - Component: Fehler Lin-Slave 02
Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
Component: MP3-Changer H46 0350
Revision: 00046006 Serial number: AUZ5ZBG3485349
VCID: 186AC1333E93FE27AA8-804C
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 K HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0140
Revision: 00000000 Serial number: AUZ4Z7G0169202
Coding: 0000100
VCID: 2F381AEFAB1D199FDB2-807A
Reset counter: 7
Mileage: 195462 km
Date: 2018.03.09
Time: 20:14:34
Address 15: Airbags
Address 16: Steering wheel
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 C HW: 4F0 920 951 A
Component: KOMBIINSTR. M73 H16 0240
Revision: 00200000 Serial number: 64858GT97
Coding: 2065288
Shop #: WSC 40674 067 57207
VCID: 201AE9D3E6C3B6E7528-8074
00532 - Supply Voltage B+
Reset counter: 65
Mileage: 195802 km
Date: 2018.04.04
Time: 09:37:44
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B079268404
Coding: E5D59E77301A0600
VCID: 2D0400E7A1116B8FE9E-8078
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082946
VCID: 619CACD7AD49FFEF1D6-8034
Address 46: Central Conv.
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H10 0240
Revision: PROD_01 Serial number: 00000000051573
Coding: 0000016
Shop #: WSC 02324 758 00200
VCID: 2514F8C7F9E153CF21E-8070
Part No SW: 4F0 910 280 HW: 4F0 907 280 C
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000076127
Coding: 0002014
VCID: 5EE6972B9C37C017204-800A
Address 52: Door Elect, Pass.
Address 53: Parking Brake
Address 55: Headlight Range
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Revision: 00000000 Serial number: 394J4077817856
VCID: 2E0607EBAC171097D04-807A
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000147098
Shop #: WSC 00000 512 00290
Component: von VA0 0709271154
Coding: 344630393135313035442056413030373039323731313534
Address 62: Door, Rear Left
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000700056800
Coding: 0062221
VCID: 221EE3DBE8CFA4F744C-8076
02214 - Tire Pressure Warning
Reset counter: 61
Mileage: 195760 km
Date: 2018.03.24
Time: 22:33:02
(no units): 47.0
Temperature: 0.0°C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 72: Door, Rear Right
Part No SW: 4F0 910 336 E HW: 4E0 862 335
Component: Handyvorb2 H18 0950
Revision: 00000000 Serial number: 00000005009903
Coding: 0010900
End----(Elapsed Time: 01:29, VBatt start/end: 12.1V/12.1V. VIgn 0.0V)------
SCAN 2:
Sunday,15,April,2018,13:02:23:01374
Chassis Type: 4L0
Address 01: Engine
Coding: 0000003
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H01 0040
014 - Defective
Reset counter: 40
Mileage: 196002 km
Date: 2018.04.13
Time: 14:12:52
Coding: 0000003
Coding: 0524326
Coding: 0012123
Coding: 0000100
Reset counter: 7
Mileage: 195462 km
Date: 2018.03.09
Time: 20:14:34
Address 15: Airbags
Coding: 2065288
Reset counter: 65
Mileage: 195802 km
Date: 2018.04.04
Time: 09:37:44
Coding: 0082946
Coding: 0000016
Coding: 0002014
Coding: 0062221
Reset counter: 61
Mileage: 195760 km
Date: 2018.03.24
Time: 22:33:02
(no units): 47.0
Temperature: 0.0°C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 0010900
End----(Elapsed Time: 01:29, VBatt start/end: 11.5V/11.8V. VIgn 0.0V)------
