Hiya got a problem with my friends Q7 the rear sunroof and rear blind works fine, the problem is with the front sunroof, the front blinds open and closes OK, the sunroof it self doesnt raise or lower. It is in the lower position or close position.
When i look at the front sunroof selective output test, its says 127.0 in the first box, If im correct should this number be 100.0?
Friday,13,April,2018,13:33:42:10786
VCDS Version: 18.2.0.3
VIN: WAUZZZ4L7BD027761 License Plate: White-Q7
Mileage: 139220km-86507mi Repair Order: Front Sunroof Fault
Chassis Type: 4L-AU56 (4F0)
Scan: 01 02 03 05 08 09 15 16 17 18 19 34 3D 42 46 47 4F 52 55 56
57 5F 62 69 6C 6D 6F 72 76
VIN: WAUZZZ4L7BD027761 Mileage: 139220km-86507miles
3D-Special Function -- Status: OK 0000
Address 01: Engine (J623-CJGA) Labels:. 059-907-401-V2.clb
Part No SW: 4L1 910 401 H HW: 4L0 907 401 C
Component: 3.0TDI EDC17 H37 0005
Revision: 53H37--- Serial number:
Coding: 2A2A4012A52701020000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0114L1910401H 001010
ROD: EV_ECM30TDI0114L1910401H.rod
VCID: 285F222853D9390470-807C
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 AE HW: 0C8 927 750 AE
Component: AL1000 AISIN 001 1815
Coding: 001578
Shop #: WSC 40568 001 1048576
ASAM Dataset: EV_TCMAL991031 001001
ROD: EV_TCMAL991031_001_AU56.rod
VCID: 6FED0934B6B72E3CF1-803A
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 2200673
Shop #: WSC 00658 210 91781
VCID: 3467C65857114DE4CC-8060
Part No SW: 4F0 910 852 B HW: 4F0 905 852 F
Component: FBSAUDIC6 ELV H05 0130
Revision: 00H05000 Serial number: 10603401768188
Coding: 0000211
VCID: 25412B1CECCB246C4B-8070
Subsystem 1 - Part No: 4F0 910 132 E
Component: FBSAUDIC6 EZS H03 0020
Component: FBSAUDIC6 IDG H01 0054
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AE
Component: KLIMA 4 ZONEN H13 0060
Revision: 00---022 Serial number: 00000000266888
Coding: 01009416
VCID: 25412B1C2CCB246C4B-8070
01273 - Fresh Air Blower (V2)
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 3
Mileage: 139221 km
Date: 2018.04.13
Time: 13:13:29
Temperature: 25.0°C
(no units): 72.0
Load: 127.0 %
02874 - Control Module 2 for Central Convenience (J773)
008 - Implausible Signal
Fault Status: 01101000
Reset counter: 3
Mileage: 139221 km
Date: 2018.04.13
Time: 13:13:29
Part No SW: 4F0 910 279 AH HW: 4F0 907 279 D
Component: ILM Fahrer H29 0390
Coding: 0033121
VCID: 6FED09347EB72E3CF1-803A
Subsystem 1 - Part No: 4L2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H12 0100
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 D HW: 4L0 959 655 C
Component: 71 AIRBAG AUDI8RH43 0230
Revision: 04H43000 Serial number: 00399D07KN75
Coding: 0014129
VCID: 2E53D430B93D6734BA-807A
Subsystem 1 - Serial number: 6332QSME4C012C50B
Subsystem 2 - Serial number: 6342QSME4C012962C
Subsystem 3 - Serial number: 6352QSME750053669
Subsystem 4 - Serial number: 6362QSME49060E76O
Subsystem 5 - Serial number: 63734SME6602056E/
Subsystem 6 - Serial number: 63834SME22030666R
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0530
Revision: 00H05000 Serial number: 90026110300674
Coding: 0102142
VCID: 275D211496C7367C79-8072
Component: E0221 H02 0100
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 983 T HW: 4L0 920 983 T
Component: KOMBIINSTR. H10 0209
Revision: 00000000 Serial number: FLN03E42C
Coding: 2F56630400012600010400
VCID: 43859584C2BFFA5C45-8016
Address 18: Aux. Heat Labels: None
Part No SW: 4L0 910 105 HW: 4L0 815 071 G
Component: Heizgeraet H09 0140
Revision: 0000000C Serial number: 00000009021078
Coding: 0000101
VCID: 60CF7A08B369814478-8034
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 P HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0047
Revision: LB200032 Serial number: 3200L111160008
Coding: 00CF07
VCID: 3C77EE78BF4185A404-8068
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 00000000002790386353
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Serial number: 11028000641021200181
Address 34: Level Control Labels: None
Part No SW: 4L0 910 553 H HW: 4L0 907 553 E
Component: LUFTFDR.-CDC H04 7870
Revision: --H04001 Serial number: 15.1528-0150.2
Coding: 0015510
VCID: 2F6DC934BE376E3CB1-807A
Address 3D: Special Function Labels: 8K0-907-440.clb
Part No SW: 8K0 907 440 HW: 8K0 907 440
Component: STS H04 0040
Revision: S0H04000 Serial number: 00000000033088
Coding: 01010101000000000000000202
VCID: 6BD51D244AAFD21CDD-803E
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0004000214782
Coding: 011F06205061440004
VCID: 489F82A8FB99D90490-801C
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 H HW: 4L0 907 289 H
Component: Komfortgeraet H10 0110
Revision: 0110 --- Serial number: 01429642110000
Coding: 4071675
VCID: 3561FB5C5C6B54ECFB-8060
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H03 0160
Revision: CH003000 Serial number: 00000000023094
Coding: 030000
Shop #: WSC 00658 210 99123
VCID: 2959272C40D3000C6F-807C
Part No SW: 4F0 910 280 HW: 4F0 907 280 E
Component: ILM Beifahrer H14 0100
Revision: Serial number: 00000000205177
Coding: 0011101
VCID: 5EB344F0891DB7B44A-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0361
Revision: Serial number: 0004000207374
VCID: 479D8194F687D67C99-8012
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H02 0010
Coding: 0000008
VCID: 3F8D99746E579EBC21-806A
Part No SW: 4G0 035 053 D HW: 4G0 035 053
Component: Radio U Basic H52 0094
Revision: AB001007 Serial number: 496B 0B7643416
Coding: 010003010000000000
VCID: 1F4D39F40E97FEBC01-804A
Address 57: TV Tuner Labels: None
Part No SW: 4F0 919 129 G HW: 4F0 919 129
Shop #: WSC 06335 000 00000
VCID: 306FCA48630971C4A8-FFFE
No Faults Found
Part No SW: 4L0 035 666 F HW: 4L0 035 666 A
Component: H-BN-EU H51 0174
Revision: -------- Serial number: 473BY0B7541186
Coding: 010101060004D3EF01002315EF6300030000
VCID: 306FCA48630971C4A8-8064
Subsystem 1 - Part No: 8R0 060 884 N
Component: EUR 2011 1205
Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H43 0098
Serial number: 9466BS0B0441807
Subsystem 3 - Part No SW: 4L0 910 609 HW: 4L0 919 611 B
Component: E0380 Bedient H05 0060
Serial number: 00000001778584
Subsystem 4 - Part No: 8R0 060 961 A
Component: CD-Database 2712
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0004000213420
Coding: 010E06204061230004
VCID: 46838C90F18DCF7462-8012
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H09 0100
Revision: 2A001001 Serial number: 00000142342930
Coding: 0100000000000000
VCID: 3169CF4C680378CCA7-8064
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 B HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H05--- Serial number: 525PA8-J11414U
Coding: 1021001
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Component: ValeoHeckdeckel H56 0500
Revision: --H56001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6CD71E384FA1D524D4-8038
Subsystem 3 - Serial number: RD07.02.11--H56001001A0119ÿ
Subsystem 4 - Serial number: 1A0119ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H07 0080
Revision: AAH07080 Serial number: 112844401-----
Coding: 0003587
VCID: 26432C1091CD2F7442-8072
Component: J_245_EE16_SKB10H11 0220
Subsystem 2 - Part No: 4L0 910 591 A
Component: J_394_EE16_SKB10H11 0220
Subsystem 3 - Part No: 4L0 910 591 A
Component: J_392_EE16_SKB10H11 0220
01512 - Control Module for Sliding Roof
Fault Status: 01100101
Reset counter: 3
Mileage: 139221 km
Date: 2018.04.13
Time: 13:14:40
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0004000213424
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4L0 910 283 E HW: 4L0 919 283 E
Component: Parkhilfe 8-Kan H03 0100
Revision: 00H03000 Serial number: 37331102103547
Coding: 0221066
VCID: 2C57DE388F21152494-8078
End-------------------------(Elapsed Time: 04:23)--------------------------
