- Joined
- Feb 24, 2018
- Messages
- 141
- Reaction score
- 47
- Location
- Czech Republic
- VCDS Serial number
- C?ID=204559
I´ve bought a HEX-NET (unlimited) and successfully registered but I am little confused how to make the best configuration of "infrastructure" mode. The first problem (than can be solved in more ways...) is a conflict of IP adresses, cause my router has also 192.168.0.1 as a home page. I can change it in the router but probably with cooperation with my internet provider and imho better solution (also when I consider connecting into/through other networks, where the 192.168.0.1 is probably most common IP for router home page) is to change IP adress (and password) of the interface manually (lets say at least for sure bigger last number, e.g.192.168.0.111) - how to?
In the manual is notice that when I succesfuly connect to my home network (when router is also a DHCP server and gives IP automatically), what I did, there will be IP adress assigned automaticaly, but in VCIconfig is still 192.168.0.1 or zeros (0.0.0.0), what am I doing wrong? I´ve tried to change settings in VCDS but this seems to be just "informative" for the VCDS (which IP to search, not to assign it to the interface).
Other thing/question is if it isn´t more practical not to connect the interface to the router(´s network) but to in the notebook created network eventhough "easier" for me is to set the router than home network in Win7 (x64) but if I get it right, then when I want to connect to other source of internet, I must add the connection to "home group/home network" - am I right?
From the time when authorised dealers (VW group) go online, I´ve considered as one of the biggest advantages of the concept of VCDS "not necessarily" to be connected to the internet, but on the other way I understand reasons why You make it via cloud, so I am triyng to "go with time", thus any help would be appreciated... (I´ve also noticed, that NeTECH is working on the Toolbox, e.g. to make possible to check coding,etc. without a connection to car, what is great - fortune favors the prepared )
Btw. are there similar restrictions of online/offline connection via Windows as it is via android? (or let ask other way - are there many cases in which is for advanced functions the cloud "necessary" even with PC? I assume the number of these cases will be "growing" - am I right?)
Thanks in advance,
Fanda
Thanks in advance,
Fanda
