2016 Audi A3 E-tron Technik (top-spec in Canada)
Nuje
Canada
C?ID=120875
We also have a Mk7 Golf Sportwagen (same MQB architecture), and while it doesn't have all of the lane sensing / parking assist stuff that this top-spec E-tron has, it *does* have High Beam Assist.
Given that the E-tron seems to have the same camera built into the rear view mirror, I've gotta think it's possible to enable HBA on the e-tron.
Anyone successfully do that?
Looking at some other VW group MQB threads, it seems do-able; I followed those instructions best I could, but didn't get anything showing up in my MMI settings. (and it's not dark enough yet to go for a drive and test).
(Update: Tried it tonight and doesn't work - high beams come on and stay on, regardless of traffic in front of me.)
Regardless, here are the auto-scan maps.
Tuesday,10,April,2018,13:16:33:51218
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 18.2.0.3 (x64)  HEX-NET CB: 0.4411.4
VIN: WAUSPBFF2GAxxxxxx   License Plate:
Mileage: 36988km-22983mi   Repair Order:
Chassis Type: FF-AU37 (5QE)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 23 2B 3C 42 44 47 51 52
          55 5F 6C 8C A5 BB BC C6
VIN: WAUSPBFF2GA106947   Mileage: 36988km-22983miles
Address 01: Engine (J623-CXUA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 023 H    HW: 04E 907 309 F
   Component: R4 1.4l TFSI  H22 9130
   Revision: X3H22---
   Coding: 021D0012636401083000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM14TFS01104E906023H 006003
   ROD: EV_ECM14TFS01104E906023BD.rod
   VCID: 25023D882429146C4B-8071
   Part No SW: 0DD 300 045 P    HW: 0DD 927 770 B
   Component: GSG DQ400E    H31 1122
   Revision: 00031033    Serial number: TFK01512100179
   Shop #: WSC 00099 780 00200
   ROD: EV_TCMDQ400021.rod
   VCID: 3424D0CC9FF37DE4CC-8061
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 907 379 AK    HW: 5Q0 907 379 H
   Component: ESC           H31 0809
   Revision: 00000000    Serial number: 63435000000603
   Coding: 12FF4092382032720180020481CA2948021C4C80408194F4F8A150588608
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
   ROD: EV_Brake1UDSContiMK100OMG_001_AU37.rod
   VCID: 05425D0884E9346C2B-8051
16401 - Tire Pressure Warning
          C102D 00 [032] -  -
   Revision: 00021000    Serial number: 0389181661
   Coding: 030C0C
   VCID: 3A38FEF4BD978B9416-806F
   Part No SW: 8V0 820 043 J    HW: 8V0 820 043 J
   Component: AC Automat    H06 0510
   Revision: 20012000    Serial number: 00000000802829
   Coding: 0300001001000000000000000000140001000000
   ASAM Dataset: EV_AirCondiFrontNARAU37X 001015
   ROD: EV_AirCondiFrontNARAU37X.rod
   VCID: 393AE1F8B891808C1F-806D
   Subsystem 1 - Part No SW: 4M0 959 603     HW: 4M0 959 603
   Component: G395 pT-Sens1  H61 0006
   Subsystem 2 - Part No SW: 12E 963 231 F    HW: 12E 963 231 F
   Component: J848 HV-PTC  H09 0206
   Serial number: LM153503003807000093
   Subsystem 3 - Part No SW: 4H0 907 658 A    HW: 4H0 907 658 A
   Component: AQ_Hum_Sensor  H01 0003
   Serial number: BA398CD7000000000001
   Subsystem 4 - Part No SW: 12E 820 803 D    HW: 12E 820 803 D
   Component: J842 eKK  H02 0004
   Serial number: IADD00000K000000007F
27831 - Internal Temperature Sensor for Electric A/C Compressor
          P0D71 00 [096] - Implausible Signal
27839 - No Communications with Electric A/C Compressor
          U016B 00 [032] - -
          [EKK_Kommunikationsfehler]
   Part No SW: 5Q0 937 085 AH    HW: 5Q0 937 085 AE
   Component: BCM MQBAB MNA H24 0175
   Serial number: 01061600900672
   Coding: 04151C46C25106FD41CC5004531407A80800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 7F4ECFE0E6356EBC61-802B
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 151120  043 0580
   Serial number:         151127033118
   Coding: 0A47F7
   Serial number: 61158701
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AA    HW: 8V0 941 531 AA
   Serial number: 19 09 2015  00000038
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000064481988
   Sun Roof:
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST000PNEA000000
   Coding: 101F00
204290 - Remote key 1
          B1479 18 [008] - Current Too Low
                    Reset counter: 107
                    Mileage: 28716 km
                    Date: 2017.11.23
                    Time: 20:49:37
204546 - Remote key 2
                    Reset counter: 43
                    Mileage: 34268 km
                    Date: 2018.02.23
                    Time: 17:00:36
   Revision: --------    Serial number: 39391534503825
   Coding: 0070150011
   ROD: EV_EPHVA18AU3700000_002_AU37.rod
   VCID: 43C68310CA5DCA5C45-8017
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 N    HW: 5Q0 907 567 N
   Component: ACC3          H10 0400
   Serial number: 17121503074873
   Coding: 01261701FE0309
   ASAM Dataset: EV_ACCBoschMQB 001024
   ROD: EV_ACCBoschMQB_AU37.rod
   VCID: 46C09A04F96FFF7462-8013
   Serial number: 003GCR045NDH
   Coding: 9DFCFCC0002000009000001AC24800000065
   VCID: 47DE9700FE65E67C99-8013
   Belt Pretensioner left:
   Serial number: 34230167A06011650142
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34230168A07011641035
   Coding: 333135
   Occupant Detection:
   Serial number: 694000000000001FG0CK
   Coding: 303334
   Subsystem 4 - Part No SW: -----------    HW: 480 000 801 16
   Serial number: 3570000000064D38A81P
   Subsystem 5 - Part No SW: -----------    HW: 480 000 801 16
   Serial number: 358000000002C028A81G
   Subsystem 6 - Part No SW: -----------    HW: 480 401 412 15
   Serial number: 3510002A11E3EAA1C29C
   Subsystem 7 - Part No SW: -----------    HW: 480 401 412 15
   Serial number: 3520002A91E3EAA1A23D
   Subsystem 8 - Part No SW: -----------    HW: 480 400 611 15
   Serial number: 3550002C91D25F03C012
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 400 611 15
   Serial number: 3560002C91D25F0091EB
   Part No SW: 8V0 953 521 GK    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 12121508490338
   Coding: EC18
   ASAM Dataset: EV_SMLSKLOMQB 020001
   VCID: 095A5138A8F1500C4F-805D
   Part No SW: 8V0 920 872 K    HW: 8V0 920 872 K
   Component: KOMBI         H03 6423
   Coding: 0B040C196F8800080283E8101A00000000000000
   VCID: 45C29D08C469F46C6B-8011
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 5QE 907 530 E    HW: 5QE 907 530 A
   Component: GW MQB EV     312 3244
   Revision: --------    Serial number: 24111510800081
   Coding: 0201001726F200005B00121C580000000001010100010000000000000000
   ASAM Dataset: EV_GatewEVConti 013020
   ROD: EV_GatewEVConti_013.rod
   VCID: 48DC943CF37BE90490-801D
   Subsystem 1 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 12 12 2015  E0041462
   Subsystem 2 - Part No SW: 5QE 915 181     HW: 5QE 915 181
   Serial number: 5921298203
Address 23: Brake Booster (J539)       Labels:* None
   Part No SW: 5QE 909 059 D    HW: 5QE 909 059 B
   Component: EBKV          H14 0182
   Serial number:   085430010673
   Coding: 03720100331A00030002050500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 003001
   ROD: EV_BrakeBoostBoschMQBOMG_003_VW37.rod
   VCID: 4FEEBF2016153E3CD1-801B
   Brake Assistance Sub:
   Subsystem 1 - Part No SW: 5QE 909 057 C    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0152
   Serial number: 05802861080116134451
   Revision: 00000000    Serial number: 15000269386009
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
   Component: SWA Master    H07 0080
   Serial number: 0388716771
   Coding: 030211
   VCID: 383CE4FC839B9984E0-806D
   Subsystem 1 - Part No SW: 5Q0 907 568 A    HW: 8T0 907 568 B
   Component: SWA Slave  H06 0080
   Serial number: 0388509321
   Coding: 030211
   Serial number: 141015BJD10396
   Coding: 005D1F204000048000000003
   Component: EPS_MQB_ZFLS  125 1063
   Coding: D102
   VCID: 44C4800CCF53CD647C-8011
   Part No SW: 8V0 035 465 D    HW: 8V0 035 465
   Component: MIBAMP1ALPINE H11 0420
   Serial number: AUZ8ZAFN901VNHW
   Coding: 01030300AAAA2AAA01
0574 - Rear Left Bass Speaker
          B1065 F0 [008] - Short Circuit Between Poles
          [Verbindungen zu Lautsprechern Kanal 9: elektrischer Fehler im Stromkreis]
                    Reset counter: 118
                    Mileage: 36772 km
                    Date: 2018.03.31
                    Time: 20:07:30
                    Voltage terminal 30: 13.5 V
   Part No SW: 5G0 907 080 D    HW: 5G0 907 080 D
   Component: VW370P3815010 H07 4492
   Revision: 00H07000
   Coding: 40020000000000000000
   ASAM Dataset: EV_DMCM09550115G0907080D 001018
   ROD: EV_DMCM09550115G0907080D.rod
   VCID: 281C34BC533B090470-807D
   Serial number: 221015BJL13692
   Coding: 005D17204000048000000003
   VCID: 42C88614D547C3544E-8017
   Coding: 011A000123200400
   VCID: 3FCE8FE0A6B5AEBC21-806B
   Coding: E00100
   Coding: E00100
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Coding: E00100
   Part No SW: 8V0 035 047 C    HW: 8V0 035 047 B
   Component: MU-H-NS-US    H44 0403
   Serial number: A052J0F7510073
   Coding: 017393020000000021220002041A00002F000124010001047E
   ROD: EV_MUHig6C3HBAS_AU37.rod
   Subsystem 1 - Part No SW: V03 959 800 T    HW: -----------
   Component: NAR 2016  --- 0048
   Component: DU High  H49 0014
   Serial number: AUZ8Z9FY204MT3
   Multimedia Operating Unit:
   Serial number: ALJAL104111500030038
   Component: Gracenote  --- 3006
          B11CF 53 [009] - Deactivated
                    Reset counter: 76
                    Mileage: 36647 km
                    Date: 2018.03.31
                    Time: 13:31:16
                    Voltage terminal 30: 13.3 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-Channel selection for satellite radio: 0
                    Satellite radio tuner status-Audio Signal: Available
                    Satellite radio tuner status-Antenna current: 0 mA
                    Satellite radio tuner status-Reception quality: optimum_signal
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
   Coding: 027300010201000300
   ROD: EV_2CamSysRearPASE.rod
   VCID: 302CDCDC6BEB41C4A8-8065
Address 8C: Hybrid Battery (J840)       Labels: None
   Part No SW: 5Q0 915 182 C    HW: 5Q0 915 182 C
   Component: BECM          H05 0752
   Serial number: T9020094
   Coding: 00000000
   ASAM Dataset: EV_BECM09620115Q0915182 006037
   ROD: EV_BECM06020115C6915182_VW37.rod
   VCID: 3326D3D09AFD7ADCD5-8067
   Battery Junction Box:
   Subsystem 1 - Part No SW: 5Q0 915 250 D    HW: 5Q0 915 250 D
   Component: BJB  H27 0240
   Subsystem 2 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D1  H14 0472
   Serial number: V013C1591830844
   Subsystem 3 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D2  H14 0472
   Serial number: V013C1591830843
   Subsystem 4 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D3  H14 0472
   Serial number: V013C1591831071
   Subsystem 5 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D4  H14 0472
   Serial number: V013C1591831067
   Subsystem 6 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D5  H14 0472
   Serial number: V013C1591830790
   Subsystem 7 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D6  H14 0472
   Serial number: V013C1591830789
   Subsystem 8 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D7  H14 0472
   Serial number: V013C1591830841
   Subsystem 9 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D8  H14 0472
   Serial number: V013C1591830842
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0060
   Serial number: 10000477989
   Coding: 0100000000010303000500010100000100
   ROD: EV_MFKBoschAU370.rod
   VCID: 3C34F8ECB7A3B5A404-8069
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 181115BKH2058C
   Coding: 004D17204000048000000002
   Serial number: 181115BKH21018
Address C6: Batt. Chrg. (J1050)       Labels:* None
   Part No SW: 5QE 915 682 AB    HW: 5QE 915 682 AB
   Component: OBC KOSTAL    H61 3012
   Revision: --------    Serial number: 1612150LB000TZ
   Coding: 105168003000
   ASAM Dataset: EV_OBCSinglPhaseKLOVW3709 004001
   ROD: EV_OBCSinglPhaseKLOVW3709_004.rod
   VCID: 0D526528DC994C2C63-8059
End------(Elapsed Time: 16:43, VBatt start/end: 13.2V/13.3V, Deb=2)--------
Nuje
Canada
C?ID=120875
I took a look, but your Module 9 (Central Convenience) "coding" is all zeroes.
(Which doesn't seem right...)
It's right. In the newer BCMs, all the stuff that used to be in Coding has moved to Adaptation channels.
Nuje
Canada
C?ID=120875
So...Andy's scan from his 2018 probably won't help me out a whole lot, given that my BCM still has the "long coding" thing for most of that stuff...(?)
