Several problems with VCDS-Mobile
n0vac
C?ID=321709
I've been testing VCDS-Mobile and its capabilities for a few weeks, and I've had some success with Auto-Scan, Advanced Measuring Values, Adaptations and Coding, but it really depends on the module being accessed. Several modules I'm interested are missing Adaptation Channels or Coding information. There are also other minor problems that I've encountered, see complete list below:
1. When I run Auto-Scan, it takes about 1 minute to scan module 08-Auto HVAC when I'm using VCDS-Mobile. With VCDS it takes about 20 seconds (which is still much longer than with any other module). If I remember correctly, it stayed long at the "Retrieving slaves..." stage. And if I directly access the 08 module with VCDS-Mobile, Functions-button is also greyed out for 1 minute, before I can select it.
2. Several modules are missing Adaptation Channels, for example 08, 09 and 17. They only show empty list with the text "Documented adaptations can be selected":
I haven't tested all modules, but at least 6D-Trunk has adaptation channels listed.
3. When I select module 5F and try to access "Cloud Functions", browser gets redirected to the VCDS Cloud login page instead of the Cloud Server Main Menu.
4. For some reason, several modules have duplicate measuring values:
5. 17-Instruments is missing Coding information/texts. I still tried to revert a change I did with VCDS (change Byte 1 from a5 back to a4 = disable Needle Sweep), but when I select "Do it!", page just hangs for about 20-30 seconds and then refreshes with the old value:
But I have successfully coded 08 module with VCDS-Mobile.
5. "Go Back" or "Continue" buttons in VCDS Cloud don't work with iPhone & Safari, but work with Windows & Firefox. When buttons are pressed, browser tries to open the following url, but immediately stops with error "Safari cannot open the page because the server cannot be found":
http://controllerfunc.shtml/?closeserver=true
So I guess it's missing the HEX-NET IP address. If I manually add the current HEX-NET IP address like this http://172.20.10.6/controllerfunc.shtml/?closeserver=true, I get the following 404 error page and I don't even see a bunny with a pancake on its head :(
I would really appreciate it if you could have a look into these problems. Thanks in advance!
Here's the Auto-Scan:
VCDS Mobile 0.4417.0.4
VIN: TMBJD9NE5J01xxxxx
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 2B 36 3C 42 44 47
	 4B 52 5F 6C 6D 75 A5 D6 D7
Address 01: Engine  (CJSA: J623)	Labels: 06K-907-425-V1.clb
	Part No SW: 8V0 906 264 H	HW: 06K 907 425 B
	Component: 1.8l R4 TFSI  H13 0005
	Revision: --H13---
	Coding: 0C25003A2464050B1000
	Shop #: WSC 73430 031 00000
	ASAM Dataset: EV_ECM18TFS0208V0906264H 001007
	ROD: EV_ECM18TFS0208V0906264H.rod
	VCID: 41C5D6076FC4429C068DCF1E11-8014
No fault codes found.
Address 02: Auto Trans  (J743)	Labels: 0C-02.clb
	Part No SW: 0CW 300 041 G	HW: 0AM 927 769 E
	Component: GSG DQ200G2_M H05 1003
	Revision: 00005026
	ROD: EV_TCMDQ200021_SK37.rod
	VCID: 3935BEE707141A5C4E3D77BEA9-806C
Address 03: ABS Brakes  (J104)	Labels: 5Q-03.clb
	Part No SW: 5Q0 614 517 CF	HW: 5Q0 614 517 AD
	Revision: 00000000
	Coding: 25076A913428216F4077060440C629A4562C8402600294743641F0F0C0A2430000000012121212B8586C384E4484EE
	ROD: EV_Brake1UDSContiMK100IPB_036.rod
	VCID: 77B178DF7180CC2C78A921864F-8022
Address 05: Acc/Start Auth.  (J518)	Labels: 5Q0-959-435.clb
	Part No SW: 5Q0 959 435 C	HW: 5Q0 959 435
	Component: VWKESSYMQB    021 0803
	Revision: 00021000
	Coding: 032C0C
	Shop #: WSC 73430 790 00063
	ASAM Dataset: EV_KessyHellaMQBAB 002020
	VCID: 3C3BA7F308262F74555B96C24E-8069
Address 08: Auto HVAC  (J255)	Labels: 5G0-907-044.clb
	Part No SW: 5E0 907 044 AT	HW: 5E0 907 044 AT
	Component: Climatronic   H04 2001
	Revision: 00001K00
	Coding: 02010004004111011005000D0010102A
	Shop #: WSC 73430 031 00063
	ASAM Dataset: EV_ACClimaBHBVW37X 006146
	Subsystem 1 -
	Subsystem 2 -
	Subsystem 3 -
Address 09: Cent. Elect.  (J519)	Labels: 5Q-09.clb
	Part No SW: 5Q0 937 086 BM	HW: 5Q0 937 086 BH
	Component: BCM PQ37BOSCH 034 0242
	Revision: --------
	Shop #: WSC 73430 790 00000
	ROD: EV_BodyContrModul1UDSBosc_018.rod
	VCID: 864F851B866A25A4F33FC45A90-80D3
	Subsystem 1 - 	Part No SW: 5E1-955-119-A	Labels: 5Qx-955-119-V1.clb
	Component: MÝ
	Subsystem 2 -
	Subsystem 3 -
Address 10: Park/Steer Assist  (J791)	Labels: 5Q0-919-298.clb
	Part No SW: 5QA 919 298 C	HW: 5QA 919 298 A
	Component: PLA 3.0 12K
	Coding: 0271167051
	ROD: EV_EPHVA2CAU3700000_009_SK37.rod
	VCID: 50E3E343B4AEBB14992372D252-8005
Address 13: Auto Dist. Reg  (J428)	Labels: 5Q0-907-572.clb
	Part No SW: 5Q0 907 572 J	HW: 3QF 907 572
	Component: ACC BOSCH MQB H10 0654
	Coding: 330060C141FFC728949C810520400600000000000000000000
	ASAM Dataset: EV_ACCBOSCHVW416 002006
	ROD: EV_ACCBOSCHVW416_002.rod
	VCID: 3E3FADFB1E3A3D647B6FACFA68-806B
Address 14: Susp. Elect.  (J250)	Labels: 5Q0-907-376.clb
	Part No SW: 5Q0 907 376 B	HW: 5Q0 907 376 A
	Shop #: WSC 00000 000
	ROD: EV_DRCONTITEMIC_SK37.rod
	VCID: 3833BBE33C1E0354B1336AB29A-806D
Address 15: Airbags  (J234)	Labels: 5Q0-959-655.clb
	Part No SW: 3Q0 959 655 BJ	HW: 3Q0 959 655 BJ
	Component: Airbag VW21   006 0703
	Revision: --------
	Coding: 98FCC000000000005C5400CC000840000065
	ROD: EV_AirbaVW21TS6VW48X.rod
	VCID: 8751881F81603CAC8849D1469F-80D2
	Subsystem 1 - 	Part No SW: --------------
	Component: ---
	Subsystem 2 - 	Component: ---
	Subsystem 3 - 	Component: ---
	Subsystem 4 - 	Component: ---
Address 16: Steering wheel  (J524)	Labels: 5Q-16.lbl
	Part No SW: 5Q0 953 521 LA	HW: 5Q0 953 569 B
	Component: Lenks.Modul   100 0245
	Revision: FF036036
	Coding: 6414
	ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
	ROD: EV_SMLSVALEOMQBLRH.rod
	VCID: 7CBB67F348A6EF7415DB56C20E-8029
291104 - Temperature Sensor for Heated Steering Wheel
	B1455 01 [008] - Electrical Failure
		Fault Status: 01110001
		Reset Counter: 1
		Mileage: 4457021 km
		Time: 00:00:00
Address 17: Instruments  (J285)	Labels: 5G0-920-XXX-17.clb
	Part No SW: 5E0 920 750 E	HW: 5E0 920 750 E
	Component: KOMBI         303 0310
	Coding: 07A509187D840008018B6B0B5001000800000000
	ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
	VCID: 260F659BE6AA85A4137FA4DAB0-8073
Address 18: Aux. Heat  (J364)	Labels: 5Q0-963-272.clb
	Part No SW: 5Q0 963 272 H	HW: 5Q0 963 272 H
	Component: STH-MQB       008 0075
	Coding: 9309
	ASAM Dataset: EV_AuxilParkiHeateWOS 002018
	VCID: 3B39A4EF0D28284C5C518DD643-806E
Address 19: CAN Gateway  (J533)	Labels: 3Q-19.clb
	Part No SW: 3Q0 907 530 G	HW: 3Q0 907 530 C
	Component: GW MQB High   436 4304
	Revision: --------
	Coding: 0B0100047F085900EB00025A9C0F00010001070000000000000000000000
	ROD: EV_GatewNF_SK37.rod
	VCID: 33298CCF2578E00C84013576DB-8066
	Subsystem 1 -
	Subsystem 2 -
	Subsystem 3 -
	Subsystem 4 -
Address 2B: Steer. Col. Lock  (J764)	Labels: 5Q0-905-861.clb
	Part No SW: 5Q0 905 861 A	HW: 5Q0 905 861 A
	Revision: 00000000
	Coding: 5D00000000000000
	ROD: EV_ELVMarquMQB_004.rod
	VCID: 342B8FD32076E7349D0B3E62E6-8061
Address 36: Seat Mem. Drvr  (J810)	Labels: None
	Part No SW: 5Q0 959 760 B	HW: 5Q0 959 760 B
	Component: Sitzmemory    H08 0022
	Coding: 0010000000000500018280808080000000008181000000D400
	ROD: EV_SeatMemorDriveSide_002.rod
Address 3C: Lane Change  (J1086)	Labels: 5Q0-907-686.clb
	Part No SW: 5Q0 907 686 C	HW: 5Q0 907 686 C
	Component: HRE_Master    H12 0080
	Coding: 02011103
	ROD: EV_HREntryHella.rod
	VCID: 3D3DAAF7133C267C6265A3CE5D-8068
Address 42: Door Elect, Driver  (J386)	Labels: 5Q-42.clb
	Part No SW: 5Q4 959 593 E	HW: 5Q4 959 593 B
	Coding: 001D0920DE00040000001100
	VCID: 47D1C81F41E07CACC8C91146DF-8012
Address 44: Steering Assist  (J500)	Labels: 5Q0-909-144.clb
	Part No SW: 5Q0 909 144 T	HW: 5Q0 909 144 R
	Component: EPS_MQB_ZFLS  129 1072
	Coding: 9307
	ROD: EV_SteerAssisMQB_013.rod
	VCID: 45CDC2177BEC6EBC3AB5FB2EC5-8010
Address 47: Sound System  (J525)	Labels: 81-47.clb
	Part No SW: 81A 035 223	HW: 81A 035 223
	Component: MIB2_amp_P_SK H10 0410
	Revision: 00000001
	Coding: 0373020000AA002AAA0000000000
	ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001001
	ROD: EV_AMPMst16C4Gen2ALPI.rod
	VCID: D9F59E6767547A5CEE7D573E49-808C
Address 4B: Multifunc. Module  (J745)	Labels: None
	Part No SW: 3Q0 907 338	HW: 3Q0 907 338
	Coding: 000000070100046A06003D01010000000000000000000000000000000000
	VCID: F2A7C9CB9AE22904CF77684A0C-80A7
Address 52: Door Elect, Pass.  (J387)	Labels: 5Q-52.clb
	Part No SW: 5Q4 959 592 E	HW: 5Q4 959 592 B
	Coding: 001D0120DE00040000001100
	VCID: 46CFC51B46EA65A433BF045AD0-8013
Address 5F: Information Electr.  (J794)	Labels: 56-5f.clb
	Part No SW: 565 035 043 A	HW: 565 035 043
	Component: MU-H-N-EU     H54 1163
	Coding: 037302010000000051110002000802232F0103E401200500BE
	VCID: 10632343742EFB14D9A3B2D292-8045
	Subsystem 1 - 	Part No SW: 5E0-919-606-D
	Component: ABT_High-2
	Subsystem 2 -
	Subsystem 3 -
Address 6C: Back-up Cam.  (J772)	Labels: 5Q0-980-556.clb
	Part No SW: 5Q0 980 556 B	HW: 5Q0 980 556 B
	Coding: 047302012600201F000040
	ROD: EV_CamSysRVRVCPANAMQBAB_006.rod
Address 6D: Trunk Elect.  (----)	Labels: 7N0-959-107.clb
	Part No SW: 5E0 959 107 A	HW: 5E0 959 107
	Component: HDSG-Modul    H01 0746
	Revision: 42001001
	Coding: 1233074002
	ASAM Dataset: EV_HDSGSk462 301136
	ROD: EV_HDSGSk462_SK37.rod
	VCID: 2A1791ABF2B2A1C437A7D0EA64-807F
Address 75: Telematics  (J949)	Labels: 5N-75.clb
	Part No SW: 5NA 035 284 B	HW: 5NA 035 284 B
	Component: OCULowMQBLGE  H17 0717
	Revision: --------
	Coding: 03730201EA421A0D3B1CBE000045400382E608
	ASAM Dataset: EV_OCULowMQBLGE 004044
	ROD: EV_OCULowMQBLGE_004_SK37.rod
Address A5: Frt Sens. Drv. Assist  (R242)	Labels: 3Q-a5.clb
	Part No SW: 3QD 980 654	HW: 3Q0 980 654 A
	Component: MQB_B_MFK     H08 1272
	Coding: 020307020000040100222354C150A90094000E200020
	ROD: EV_MFKBoschMQBB_SK37.rod
	VCID: 08530B230C7EB3D401535A722A-805D
Address D6: Light Ctrl Left 2  (A31)	Labels: 7P5-941-591.clb
	Part No SW: 7P5 941 591 AD	HW: 7P5 941 591 A
	Component: LED1L         H06 0005
	ROD: EV_LED_PLUS_L_KEBODAVW416.rod
	VCID: 7EBF6DFB5EBAFD643BEF6CFA28-802B
Address D7: Light Ctrl Right 2  (A27)	Labels: 7P5-941-591.clb
	Component: LED1R         H06 0005
	ROD: EV_LED_PLUS_R_KEBODAVW416.rod
Shaun
n0vac as for the measuring values, those redundant listings should be fixed in the beta dataset, but it might be you are looking at a cached list there. Try going to [Options] -> [Clear dataset cache]
This should force it to regenerate the list the next time you go to measuring values, which might give you better results.
n0vac
C?ID=321709
I chose "Clear Dataset Cache", and then it went to the Main Screen. I didn't get any confirmation, did it still succeed?
Then I tested 18 and 01 modules, and I still see redundant listings:
Shaun
Can you try "Clear rod Files" below that?
n0vac
C?ID=321709
I tried that too, but it's still the same:
Or is it because it didn't reinstall ASAM data?
Shaun
I think you must be seeing old cached data somehow, because it didn't download a new rod. Can you try plugging in to VCIConfig and checking for updates like that, to see if you can get the rods that way.
n0vac
C?ID=321709
I used VCIConfig to install the updates, but I still see redundant listings:
Douglasdraeger
Peoria, IL, USA
C?ID=271715
I have a similar issue. Using VCDS cloud, there were no adaptations in the drop down list for 19 - CAN-Gateway. I ended up needed to use my laptop with a USB connection to code the new battery. Is there a way to download these? Is The intention for VCDS mobile/could to be able to do everything the PC version can? Please move this post if this is not the right place for it.
Shaun
Can you post an Autoscan showing what gateway you mean?
