Hello All
look for advice
after retrofit blind spot i have 2 faults in module 3C lane change
i can't activate the bind spot from 5F information i receive massage "this function i currently not available"
do i need to calibration the sensor with spastic tool ?
attach log
Thanks Foe Advance
look for advice
attach log
Thanks Foe Advance
Tuesday,10,April,2018,17:25:39:27363
VCDS Version: 18.2.0.3 (x64)
VIN: WVWZZZAUZHW106039 License Plate:
Mileage: 34629km-21517mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 3C 42 44 47 52 55
5F A9
VIN: WVWZZZAUZHW106039 Mileage: 34629km-21517miles
Address 01: Engine (J623-CJXB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 F HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00122426050B3004
ASAM Dataset: EV_ECM20TFS0205G0906259F 001004
ROD: EV_ECM20TFS0205G0906259F.rod
VCID: 3169364D6043B9CCA7-8064
Readiness: 1010 0001
Part No SW: 0D9 300 012 HW: 02E 927 770 AQ
Component: DQ250-6A MQB H54 4938
Revision: 06354004 Serial number: TFK01608310023
ROD: EV_TCMDQ250021.rod
VCID: 53A55CC53A9FABDCF5-8006
P1734 00 [002] - -
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 BJ HW: 5Q0 614 517 AG
Component: ESC H62 0636
Revision: 00000000 Serial number: 62706000000489
Coding: 01FA6BA1542019724777070341CC6980D62A98E2E0829677004200F8C28803
ROD: EV_Brake1UDSContiMK100IPB_035_VW27.rod
VCID: 7AFBD161FDB5BA9456-802E
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0420197146
Coding: 032C0C
VCID: 3B751465B20F439C0D-806E
Part No SW: 5G0 907 044 BK HW: 5G0 907 044 BK
Component: Climatronic H04 1601
Revision: 00001K08
Coding: 00020004200110001005000012101422
VCID: 71E9F64DA0C3F9CCE7-8024
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 CL HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061628103832
Coding: 00011A42C24122F30BA44000000C07281800000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 0407AF998F71FC643C-8050
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 160918 043 0551
Serial number: 160930132954
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S7Y16M10D13H12M49S07
Coding: 00A8DD
204290 - Remote key 1
B1479 18 [009] - Current Too Low
Reset counter: 150
Mileage: 34629 km
Date: 2018.04.10
Time: 17:10:15
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39361628900672
Coding: 0031151011
ROD: EV_EPHVA18AU3700000_002_VW27.rod
VCID: 43856C85CAFF3B5C45-8016
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 15091641350326
ROD: EV_DRCONTITEMIC_VW27.rod
VCID: 387F0B6983396884E0-806C
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 015 0388
Serial number: 003MLR256516
VCID: 7F0D2075E6979FBC61-802A
Belt Pretensioner left:
Component: BeltPretRevFL H37 0350
Serial number: 34169667D11101650264
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H37 0350
Serial number: 34169668D11101640749
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 000 610 16
Serial number: 35767000000150A84E1S
Subsystem 4 - Part No SW: ----------- HW: 480 000 610 16
Serial number: 35867000000BAC81CE1C
Subsystem 5 - Part No SW: ----------- HW: 480 402 209 16
Serial number: 3516502AB229A30471D8
Subsystem 6 - Part No SW: ----------- HW: 480 402 209 16
Serial number: 3526502992076365012U
Subsystem 7 - Part No SW: ----------- HW: 480 402 909 16
Serial number: 3556502AD21A3712C056
Part No SW: 5Q0 953 507 HL HW: 5Q0 953 549 E
Revision: -------- Serial number: 26091604220649
Coding: 0410
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 071DB895BE47D77C59-8052
Part No SW: 5G1 920 758 B HW: 5G1 920 758 B
Component: KOMBI 304 8311
Coding: 07AD08183B88000801082B001400000000000000
VCID: 2E532D31717DA634BA-807A
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 F
Component: GW MQB High 128 1265
Revision: -------- Serial number: 0005417616
Coding: 030100043F085900FB00026E9C0F00010001050000000000000000000000
VCID: 7CF7D779F78184A444-8028
Subsystem 2 - Part No SW: 5G0 959 442 M HW: 5G0 959 442 M Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0103
Serial number: 29160001889990096384
Coding: 29FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 1963101604
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Serial number: HA1-00002.09.16
Coding: 0001
VCID: 4A9B41A1EDD5EA1486-801E
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000157787001
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 34673F599F518CE4CC-8060
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H11 0071
Serial number: 0372464141
Coding: 02031103
ROD: EV_HREntryHella_VW37.rod
VCID: 3C771779B70144A404-8068
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H11 0071
Serial number: 0371542900
Coding: 020311
267776 - Data Set Implausible
B2012 00 [009] - -
Reset counter: 150
338048 - Databus
Reset counter: 150
Mileage: 34629 km
Date: 2018.04.10
Time: 17:04:40
Component: TSG FS 020 0041
Serial number: 170916EIC06759
Coding: 003F1220D000048000001000
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000011813232
Coding: 110000
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 8107
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A7B1161BD357A9416-806E
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H30 0150
Revision: 00000001 Serial number: VWZ8Z1GBA02KGBD
Coding: 12000000008AAA8A000000000000
ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
ROD: EV_AMPMst11CGen2ALPI.rod
VCID: 6DD1EA3DBCFB1D2CC3-8038
Component: TSG BFS 020 0041
Serial number: 220916EIL32839
Coding: 003F1020DE00048000801000
VCID: 428B6981D5E532544E-8016
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000011866264
Coding: 090000
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 02A202000B000200
VCID: 408F6389DBE9204458-8014
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Part No SW: 3Q0 035 840 B HW: 3Q0 035 840 B
Component: MU-S--ER 710 0751
Coding: 027300000000000051110002000938001F0207B40120010002
ROD: EV_MUStd4CDELP_VW27.rod
VCID: 2A5B21214D95CA1466-807E
Subsystem 1 - Part No SW: 3G0 919 605 B HW: 3G0 919 605 B
Component: ABT_Std-2 H53 1031
Serial number: VWZ8Z9SJT01BPM
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 160808200783
VCID: 2F6D30357677AF3CB1-807A
End-------------------------(Elapsed Time: 05:02)--------------------------
