Audi S5 seat coding for Audi A5 install
winter599
Eastern Pennsylvania USA
C?ID=33972
Hi all, hopefully someone with better coding skills than I can point me in the right direction on this swap. I have a 2011 A5q, 2.0t in which I just swapped in front S5 seats from I believe was a 2009. As expected, everything pretty much plugged and played well, save for the SRS light and parking brake warning being activated. The only difference from car to car was the S5 may have had memory seat capability where my A5 did not. So... is it possible to re-code the seats to work? Id try recoding from the old autoscan I have but given the nature of the sensitivity of the airbags, i'm hesitant. The current autoscan is pasted below. I have a pre-swap autoscan which is on paper so I'll just type in the basics:
Pre swap:
Airbags P#SW:8k0959655K HW:8k0959655K Component airbagVW-au10h440610 serial# 003gld0ndjdz Coding 303338334330304a55304c38543053 Shop# WSC0632500000000 ASAM dataset:EV_airbaECUVWAUDI010003010 ROD:EV_airbaECUVWAUDI010_003_AU48.rod VCID: 458a4efac47dc569a6-8010
If there are any other bits of info needed, I can provide that quickly.
Current Autoscan:
VIN: WAULFAFR5BA075973 License Plate:
Mileage: 187540km-116531mi Repair Order:
Chassis Type: FR-AU48 (8T0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56
5F 6C
VIN: WAULFAFR5BA075973 Mileage: 187540km-116531miles
Address 01: Engine (0-----CAEB) Labels:| 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AG HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H19 0002
Revision: E1H19---
Coding: 0114010A290F0160
Shop #: WSC 41681 000 1048576
ASAM Dataset: EV_ECM20TFS0118K2907115AG 001002
ROD: EV_ECM20TFS0118K2907115AG.rod
VCID: 74ECC33EDF670CE40C-8020
Readiness: 0010 0101
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 8K0 927 158 S HW: 0BK 927 156 R
Component: 0BK 20TFSIUSA H08 1003
Revision: --H08---
Coding: 000002
ASAM Dataset: EV_TCMAL551211 002018
VCID: 468849F6F97BCE7462-8012
Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
Component: ESP8 quattro H04 0060
Coding: 1D0D18
Shop #: WSC 06324 000 00000
VCID: 020095E69DD332540E-8056
013 - Check DTC Memory
Part No SW: 8K0 907 064 CF HW: 8K0 907 064 CF
Component: BCM2 2.0 H05 0435
Coding: 090000
Shop #: WSC 06325 000 00000
VCID: 76E8F936C11B1EF432-8022
Subsystem 1 - Part No SW: 8K0 959 754 B HW: 8K0 959 754 B
Component: FBSAUDIB8 IDG H71 0083
Serial number: 0815000146713007
Component: J764 ELV MLB H37 0042
Serial number: 2311000061352006
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 B HW: 8T0 959 760 B
Component: MEM-BFS H09 0043
Revision: AA000000 Serial number: 00001001217832
Coding: 00017025002C00000000
VCID: 428055E6DD53F2544E-8016
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0180
Revision: C1000000 Serial number: 01100420110224
Coding: 64122000
VCID: 00049FEE93DF204418-8054
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000000860800
Coding: 26001091043CAF010000080300003D3D0F1C528802010161000000
Shop #: WSC 06325 123 12345
VCID: 3C7C2B1EBFB784A404-8068
Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 250311 H15 0070
Serial number: SWF11030255964
Coding: 00FD11
Component: RLS H04 0003
Serial number: 11368978
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 BA HW: 8K0 941 531 BA
Component: E1 - LDS H03 0031
Serial number: 00000000002203113739
Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
Component: HOMELINK H01 0010
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 T HW: 8P0 919 475 M
Component: PARKHILFE 4K H01 0080
Revision: 11001001 Serial number: 36891109470312
Coding: 200101
VCID: 4A907DC6E5632A1486-801E
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 K HW: 8K0 959 655 K
Component: AirbagVW-AU10 H44 0610
Serial number: 003GLD0NDJDZ
Coding: 303338334330303030304A55304C38543053
VCID: 458A4EFAC47DC56C6B-8010
Subsystem 1 - Part No SW: 8K0 959 339 HW: 8K0 959 339
Component: BF-Gewichtss. H01 0050
Serial number: 5810000R08000030HZ
Serial number: 6334MSME5D55023FL
Serial number: 6344MSME5D55051DL
Serial number: 6352QSME7C041B6CU
Serial number: 6362QSME392E0362H
Serial number: 63732SME761C505E6
Serial number: 63832SME11083760Q
9445973 - Seat occupied recognition control module
B1022 55 [137] - Not configured
Part No SW: 8R0 953 568 K HW: 8R0 953 568 K
Component: Lenks.Modul H07 0156
Revision: 00000000 Serial number: 20110408000833
Coding: 000036
VCID: 499242CAE065210C8F-801C
Component: E221 - MFL H02 0003
Part No SW: 8T0 920 983 A HW: 8T0 920 983 A
Component: KOMBIINSTR. H41 0258
Revision: 00000000 Serial number: EHW67EY3C
Coding: 8B1701000300D705020000
Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0117
Revision: EC000056 Serial number: 5600E113160299
Coding: 00C303
VCID: 030E90E282C93B5C05-8056
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Serial number: 1101274F220311
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Component: MEM-FS H09 0043
Revision: AA000000 Serial number: 00001001218050
Coding: 40197821202C00000000
03329 - Seat Bottom Heating
010 - Open or Short to Plus
03328 - Seat Flank Heating
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: TSG FA H08 1501
Coding: 011C03224000120102
VCID: 53AE60A232296BDCF5-8006
Revision: 00002001 Serial number: 0146535589
Coding: 0106029A00FA440480B0003200000000
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0070
Serial number: 00000000000000381558
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H02 0220
02771 - Bulb for Left Brake / Turn Signal / Tail Lamp (M69)
03532 - Left Brake / Signal Light Lamp 2
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK
Component: DSP Prem H10 0190
Revision: 00010001 Serial number: 34804005096001
VCID: 7AF0ED06F5037A9456-802E
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1501
VCID: 52A065A60D3362D4FE-8006
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000774273
VCID: 346C033E97E74CE4CC-8060
Part No: 8K5 907 357 B
Component: Dynamische LWR H02 0010
VCID: 3972320A7085B18C1F-806C
Part No SW: 4G0 035 082 HW: 4G0 035 082
Component: Radio U SIRIU H51 0052
Revision: AB001007 Serial number: 471D40B7570998
Coding: 020007010000000001
VCID: 5DBA869A44EDADAC53-8008
Part No SW: 8T1 035 664 C HW: 8T1 035 664 B
Component: H-BN-NA H51 0116
Revision: -------- Serial number: 490DX0B7613553
Coding: 010200020006A1EF41000B0E000000030000
VCID: 3874370E8B8FA884E0-806C
Subsystem 1 - Part No: 8R0 060 884 P
Component: NAR 2010 0407
Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H43 0084
Serial number: 9466CP0B0552035
Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
Component: E0380 Bedient H08 0100
Serial number: 00000000794344
Component: CD-Database 1886
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H05--- Serial number: 525PA8-J1190J2
Coding: 1000008
VCID: 3874370E4B8FA884E0-806C
End-------------------------(Elapsed Time: 03:30)--------------------------
I'm not sure what's involved in matching a different PODS module to the Airbag module in that car.
If anyone does know, please chime in.
winter599
C?ID=33972
Thanks NEtech! his link above was where I needed to go. I had to do the reset procedure twice for it to take but the seat recognition fault is gone and all is working well. The seat module is looking for the memory function but it's not throwing any lights. I'll get back in there to turn that off next. Thanks again!
