Results 11 to 20 of 27
Thread: New member - going to need some help
    New User
    Mar 2018
    Quote Originally Posted by MasterTommy View Post
    Trickle chargers (or any chargers i know of) don’t ‘test’ the condition of the battery. They show battery status based on the voltage they read. But even a dead battery will usually charge to 13 something volts which a battery charger will award with a green light. There are some exceptions to the dead battery and the charger story, but to keep it simple; for testing a battery you’ll need a dedicated battery tester.
    Confirming my suspicions, the next step is to renew the battery (preferably OEM), adapt new battery to battery regulator if one is installed in your car, remove the auto trans module from the installion list and clear all DTC’s. It’s pointless to diagnose supply voltage faults (if any of those are real) with a dead battery. And a dead battery can definately still have enough juice to power the dash and interior illumination but not enough to even make the starter move.
    Last night I put the multimeter on the battery and it was reading 12.3V and that's after having not been charged since Thursday 3/29/18. But to your point, I'll take this battery to a local auto parts store and have them check the status. FYI - the car cranks like a champ - but I'm getting no spark.
    Thanks for your help; I'll post the results of the battery test.
    Is there a chance that these readings are the result of a broken wire somewhere?
  2. #12
    Dec 2016
    NL
    Quote Originally Posted by 25Tjetta View Post
    Then i incorrectly assumend it didnt crank. My bad. Ill have a further look at your scan later today.
    Current:
  3. #13
    New User
    Mar 2018
    I took the battery to autozone, but the kid working was less than knowledgeable. We were not sure of the CCA of the OEM bosch battery as the battery only states 61Ah and 330A. He cross referenced to his battery and used 615 CCA for his test. Can anyone confirm the correct CCA for these batteries?
    Based on 615 CCA it was reading low... 65%.
  4. #14
    The battery states 330A, so that's the CCA rating that should be used.
  5. Likes 25Tjetta liked this post
  6. #15
    New User
    Mar 2018
    Thanks, PetrolDave. Was not sure if those were indeed one and the same. Time for a RETEST!
  7. #16
    New User
    Mar 2018
    OK all. The battery I was using was bad per test at Autozone. I installed a brand new battery and a new (G28) Crankshaft Position Sensor, and I removed Auto Trans from my gateway installation list. I am still seeing the same results; can you take a took at this scan and give me an idea of what is causing these issues? FYI headlights, front driver seat, and ambient temp sensor have not been reinstalled at this time.
    Saturday,14,April,2018,18:19:17:15384
    VCDS Version: 18.2.0.3 (x64)
    VIN: 3VWJM71K28M056478   License Plate:
    Mileage: 284730km-176923mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
    VIN: 3VWJM71K28M056478   Mileage: 284730km-176923miles
    Address 01: Engine        Labels: None
       Part No SW: 07K 906 032 UM    HW: 07K 906 032 Q
       Component: United.342      G   19
       Revision: --H01---    Serial number: VWX7Z0G824R0JF
       Coding: 0000001
       Shop #: WSC 00001 000 00000
       VCID: 0831555D7B0F230450-805C
    005699 - Please check DTC Memory of Electric Load Controller
                   P1643 - 001 -
                        Fault Status: 01100001
                        Mileage: 284739 km
                        Time: 03:57:24
                        Load: 0.0 %
                        Temperature: 24.0°C
                        Temperature: 26.0°C
                        Absolute Pres.: 960.0 mbar
                        Voltage: 11.938 V
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
       Part No: 1K0 907 379 P
       Component: ASR FRONT MK70      0105
       Coding: 0017025
       Shop #: WSC 00066 000 00000
       VCID: 3FA38E816E41A4BC21-806A
    18020 - Engine Control Module Incorrectly Coded
                P1612 - 000 -  - Intermittent
       Part No SW: 1K0 820 047 GF    HW: 1K0 820 047 GF
       Component: Climatic PQ35   141 0909
       Revision: 00141027    Serial number: 00000000000000
       VCID: 6EFD03C579AB1D34FA-803A
    00532 - Supply Voltage B+
    00229 - Refrigerant Pressure
                013 - Check DTC Memory
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-M.lbl
       Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
       Revision: 00H54000    Serial number: 00000000750036
       Coding: 04050E234004150007140000001400000008730B5C000100000000000000
       Shop #: WSC 00066 123 12345
       VCID: 6FC31EC17EA1143CF1-803A
       Component: Wischer 260907 020  0501
       Coding: 00038805
       Shop #: WSC 00066
    10 Faults Found:
                        Fault Status: 01101100
                        Reset counter: 103
                        Mileage: 284739 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.10 V
                        Fault Status: 01111100
                        Reset counter: 103
                        Mileage: 284739 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.10 V
                        Reset counter: 103
                        Mileage: 284739 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.00 V
                        Reset counter: 103
                        Mileage: 284739 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.00 V
                        Reset counter: 143
                        Mileage: 284739 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 8.85 V
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Fault Frequency: 13
                        Reset counter: 103
                        Mileage: 271509 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 13.95 V
                        Reset counter: 103
                        Mileage: 191222 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.15 V
    02404 - Vehicle Exterior Illumination
                        Reset counter: 103
                        Mileage: 278591 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 14.10 V
    00154 - Windshield Wiper Motor;  Passenger Side (V217)
                        Reset counter: 143
                        Mileage: 284739 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 9.70 V
    02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
                        Reset counter: 143
                        Mileage: 284739 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 9.70 V
       Component: 6A AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6M0330NS
       Coding: 0013889
       VCID: 6CF909CD4FB7EF24D4-8038
       Subsystem 2 - Serial number: 6332MSME147F3A06H
       Subsystem 3 - Serial number: 6342MSME1B3F1472G
       Subsystem 4 - Serial number: 6351HSME0F7B400AE
       Subsystem 5 - Serial number: 6361HSME0F7A035BJ
       Subsystem 6 - Serial number: 63727SME0F11146D1
       Subsystem 7 - Serial number: 63827SME0E11457C5
                002 - Lower Limit Exceeded - Intermittent - MIL ON
    01221 - Crash Sensor Side Airbag; Driver Side (G179)
                008 - Implausible Signal - Intermittent - MIL ON
                010 - Open or Short to Plus - Intermittent - MIL ON
    00591 - Seat Belt Switch; Driver (E24)
       Part No SW: 1K0 953 549 AP    HW: 1K0 953 549 AP
       Component: Lenksäulenmodul 036 0070
       Coding: 0010021
       VCID: 00214D7D533F1B4418-8054
    00002 - Transmission Control Unit
    02413 - Switch for Selector Lever Position P Lock (F319)
       Part No SW: 1K0 920 954 F    HW: 1K0 920 954 F
       Component: KOMBIINSTRUMENT 3HL 1212
       Revision: V0002000    Serial number: VWX7Z0G824R0JF
       Coding: 0021203
       VCID: 2F43DEC1BE21543CB1-807A
                        Reset counter: 103
                        Mileage: 274490 km
                        Time: 10:41:32
                        Fault Frequency: 22
                        Reset counter: 143
                        Mileage: 284739 km
                        Time: 21:45:33
                        Reset counter: 103
                        Mileage: 274490 km
                        Time: 10:41:32
                        Reset counter: 143
                        Reset counter: 143
                        Mileage: 284739 km
                        Time: 00:07:58
       Part No SW: 1K0 907 530 L    HW: 1K0 907 951
       Component: J533  Gateway   H07 0052
       Revision:   H07 01    Serial number: 290707F1000176
       Coding: E9807F070002021002
       VCID: 3041DDBDA31F4BC4A8-8064
                        Fault Status: 00110100
                        Reset counter: 143
                        Mileage: 284739 km
                        Time: 00:08:00
                        Reset counter: 103
                        Mileage: 284739 km
                        Time: 01:18:56
                        Fault Status: 00101110
                        Mileage: 191322 km
                        Time: 23:33:36
                        Reset counter: 103
                        Mileage: 191222 km
                        Time: 08:18:12
                        Reset counter: 143
                        Mileage: 284739 km
                        Time: 22:43:36
       Component: IMMO            3HL 1212
    02241 - Engine Control Module; Immobilizer Data not Adapted
                000 -  -
       Component: J386  TUER-SG FT    1133
       Revision: 32008001    Serial number: 00000606478827
       Coding: 0001205
       VCID: 3B5BFA917A59B89C0D-806E
    01811 - Supply Voltage for Door Controller; Drivers Side (J386)
                        Reset counter: 143
                        Mileage: 284739 km
                        Fault Status: 01100101
                        Reset counter: 103
                        Fault Status: 00111000
                        Reset counter: 139
                        Mileage: 284273 km
                        Fault Frequency: 18
                        Reset counter: 143
                        Mileage: 283441 km
       Part No: 1K1 909 144 M
       Component: EPS_ZFLS Kl.070 H08 1901
       Shop #: WSC 02069 000 90108
       VCID: 354FECA95C7D6EECFB-8060
                        Mileage: 284730 km
                        Temperature: 22.0°C
                        Voltage: 5.50 V
                        Voltage: 5.30 V
                000 -  -
                        Mileage: 284730 km
                        Temperature: 9.0°C
                        Voltage: 13.00 V
                        Voltage: 12.80 V
                        Mileage: 284730 km
                        Temperature: 9.0°C
                        Voltage: 6.00 V
                        Voltage: 5.80 V
       Component:    KSG PQ35 RDK 052 0221
       Coding: 1B900F880186083F3F04058FB0880F0488DCA0
       VCID: 0429416D472707643C-8050
                000 -  -  - Intermittent
                        Fault Status: 00110000
                        Reset counter: 143
                        Mileage: 284238 km
                        Time: 23:17:09
                        Reset counter: 143
       Component: J387  TUER-SG BT    1133
       Revision: 32008001    Serial number: 00000561678827
       Coding: 0001204
       VCID: 3C59F98D7F57BFA404-8068
    01812 - Supply Voltage for Door Controller; Pass. Side (J387)
                        Reset counter: 143
                        Mileage: 284739 km
                        Fault Status: 00100101
                        Reset counter: 129
    Address 56: Radio
       Component: J388   TUER-SG HL   1120
       Revision: 12006001    Serial number: 00000002155425
       Coding: 0001168
       VCID: 3E5DF385694BADB42A-806A
       Component:    RDK              0450
       Coding: 0100101
                        Fault Frequency: 51
                        Reset counter: 143
                        Mileage: 284392 km
    00667 - Ambient Temperature Signal
                        Fault Status: 01101000
                        Reset counter: 101
                        Mileage: 284701 km
    00625 - Vehicle Speed Signal
                        Fault Frequency: 16
                        Reset counter: 143
                        Mileage: 284739 km
                        Time: 22:21:52
       Component: J389   TUER-SG HR   1120
       Revision: 12006001    Serial number: 00000002151119
       Coding: 0001168
    End-------------------------(Elapsed Time: 01:18)--------------------------
  8. #17
    Did you clear all the fault codes after replacing the battery?
  9. #18
    New User
    Mar 2018
    Yes, correct.
  10. #19
    Given that so many modules are reporting under voltage and this fault code is present:
    005699 - Please check DTC Memory of Electric Load Controller                 P1643 - 001 -
                        Mileage: 284739 km
                        Time: 03:57:24
                        Load: 0.0 %
                        Temperature: 24.0°C
                        Temperature: 26.0°C
                        Voltage: 11.938 V
    I wonder if the Battery Management system is shutting down power because it hasn't been told about the new battery?
  11. #20
    New User
    Mar 2018
    Dave, I will try doing the battery adaptation and see where that gets me. In my history with the car I never had to do this when switching batteries - but its worth a shot.
    What else do you think it could be?
