Fuel level sender/sensor 1 and 2 ID
shurur9
C?ID=320200
So...does anyone know what fuel senders correspond to left/right, low/high, empty/full and sender1/sender2.?????
I can't seem to read sender 2 (ch 29) in VCDS
AND
There doesn't seem to be any place anywhere that spells it out.
Please NO requests for files!!!
This is a basic question that should not require a log file.
AND should be answered in this forum above all other forums.
Really? We're supposed to know what kind of car you're talking about, and exactly what cluster it has?
shurur9
C?ID=320200
2002 audi a4 B6 3.0 quattro MT6
Dana
Western PA, USA
The Auto-Scan would be helpful so we know which, if any, faults are stored in addition to the exact 17-Instrument cluster that's installed with the current coding shown. If you want assistance in our forum I would highly recommend posting the VCDS scan.
The repair manual has an entire section dedicated to fuel level sender checking. There are 4 splits based on production dates for AWD alone but yours should be "AWD through 06.03". I also stumbled across a TSB related to faulty G169 level senders specific to a VIN split that might apply.
  • Fuel Level Sensor 1 should be G in your wiring diagram, located on the Passenger side of the vehicle. (295 to 305 Ohms empty and 56 to 68 full)
  • Fuel Level Sensor 2 should be G169, located on the Driver's side of the vehicle. (275 to 296 Ohms empty and 47 - 65 full)
That's pretty close to the general 280 to 80 ohm scale most VW/Audi models form this era used.
We don't know if faults are currently stored but you may want to unplug one of them to see which (new) faults are stored while confirming locations.
Next, as far as VCDS goes, MVB 004 should be helpful if each sender is sending a signal to 17:
004,0,Fuel Level Sensor
004,1,Fuel Display,(1st Sensor)
004,2,Fuel Sensor,(1st Sensor)
004,3,Fuel Display,(2nd sensor),All-Wheel-Drive only
004,4,Fuel Sensor,(2nd sensor),All-Wheel-Drive only
I believe one shows Ohms and the other in Liters per fuel sender. You can use the [Add to Log] button to capture the text if you need assistance evaluating it.
The fuel level sensors are in the fuel tank & sensor 1 is on one side and sensor 2 is on the other. :rolleyes:
Removing an electrical connector at either sensor would create an open DTC & a value to be observed in blocks as Dana has specified so kindly & being too nice to you to identity the sensors.
I believe this a question more being your responsibility to back trace and determine by using the RTFB and WD if not wanting to post a scan to let others determine a configuration.
Maybe when requesting expectations as you have specified, you might consider a paid for consult with RT Tech support inquiry.
shurur9
C?ID=320200
Thank you for your thoughtful and useful post.
All I wanted from this forum was what the senders were numbered and their function.
I posted in the general forum for that reason and got the expected demands anyway.
888888888888888888888888888888888888888888888888888888888888
It turned out to be my tank got configured for FWD and ch 29 (full tank adjust) was reading nothing.
I must have changed it when I was silencing my seat belt warning.
Sender2 was broken somehow after tank got filled to the neck and gauge was pegged full for several fill ups
The thing broke much like one shown in an audizine post for the same problem.
I measured and replaced the right sender2 and checked the left sender 1 as well....along with hoses..etc.
My audi mechanic used to call them "high and low senders"..and my problem was the first half of the gauge floating around until the half tank was reached.
shurur9
C?ID=320200
https://www.audizine.com/forum/showthread.php/806120-fuel-level-sender-1-and-2-ID
Audi a4 B6 3.0 Q
code for proper quattro tank size/type
instruments 17 → code 07 → 01 <tank size/type quattro> 20 <usa>
Connects to Cluster
LEFT/high level/Sender2: 8E0919673AG/3B0919673S
instruments 17 → adaptation 10 → Ch 29 (adjust full gauge needle)
Connects to Cluster
RIGHT/low level/Sender1: 8E0919673AQ
instruments 17 → adaptation 10 → Ch 30 (Adjust empty gauge needle)
Tank characteristic (volume)
instruments 17 → adaptation 10 → Ch 32 (set to 1 for quattro?)
Just coded cluster to proper 0120 for Quattro 3.0 and Ch 29 came to life!!!
Adjusted full gauge needle on ch 29 from default 128 to 116.
will see how it goes.
THANKS EuroxS4 for the clues!!
https://www.audizine.com/forum/showt...evel-Sender(s)
PetrolDave
Westbury, UK
C?ID=1423
Since this forum exists to help with the use of VCDS, posting a VCDS full scan is a pre-requisite - not only to tell how your car is configured but also so we can see if you have a genuine VCDS and not a rip-off copy.
Glad you've got it sorted.
FYI an auto-scan would of shown such a discrepancy in coding, but no,........ you still carry on about it to dismiss the request & further make " genius " statements.
shurur9
C?ID=320200
Problem solved in audizine.
And with no dumping...I think that says a lot about each of the forums..
AND with user(s) (Me) getting to understand the problem without submitting to VCDS forum authorities/sponsors...
If dumps are needed just to see whether users have an authorized copy of VCDS..well that gets verified initially now..and this is a forum is for verified members.
Thank you for your thoughtful response..as opposed to heavy handed responses with self promotional aggrandizements and upsells....
I initially got immediate likes from VCDS admin/sponsors when I first posted.....let's see how it goes for me proceeding forward, I.E. after this post.
Don't limit yourself to ross-tech forums for your VCDS readouts.
There are folk outside this forum who know the product better than the ross-tech jealous geniuses."
No gods..no kings..
shurur9
C?ID=320200
yawn...yawn..
Someone else in audizine had it figured it out and actually taught me something through two related threads...as opposed to you..who did nothing but strut and squawk.
You are not helping this forum or the VCDS product support...
newsflash; It is all about users learning and not your glorification.
no gods ..no kings
smirnoffrules
C?ID=269658
hi , which side is this sensor 2 ? in the uk , audi a6 c7 QUATTRO , thanks
9459739 - Fuel Level Sensor 2
B1058 1B [008] - Resistance Too High
Reset counter: 62
Mileage: 143558 km
Date: 2022.10.28
Time: 16:39:17
Thursday,17,November,2022,08:33:27:42713
VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
Data version: 20221026 DS344.0
Dealer/Shop Name: ashby car repairs
Workshop Code: 444 03743 000001
VIN: WAUZZZ4G1DN011376   License Plate: PRICE
Mileage: 144825km-89990mi   Repair Order:
Chassis Type: 4G-AU57 (4G5)
Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 5F 62 69
          72 47
VIN: WAUZZZ4G1DN011376   Mileage: 144825km-89990miles
Address 01: Engine (J623-CDUD)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 401 Q    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0002
   Revision: 53H37---    CVN: A07A8DF1
   Coding: 12254012053601020000
   Shop #: WSC 49865 001 1048576
   ASAM Dataset: EV_ECM30TDI0114G0907401Q 001003
   ROD: EV_ECM30TDI0114G0907401Q.rod
   VCID: 313EE3C391A3371354C-8064
   VINID: 9D196AAAA1170547800410C718A885D766
7144 - Please Check DTC Memory in CAN Gateway (J533)
          U1008 00 [032] - -
          [Data bus on board diagnostic interface -J533please read DTC]
8469 - Torque Restriction due to Coolant Temperature
          P102A 00 [096] - -
   Part No SW: 4G1 927 156 T    HW: 0B5 927 156 J
   Component: 0B5 30 TDIRdW H01 0003
   Revision: --H01---    Serial number: 0000000732 CVN: 000058BB
   Coding: 000001
   ASAM Dataset: EV_TCMDL501021 001009
   ROD: EV_TCMDL501021.rod
   VCID: 3E24C8FF50FDD86BD9E-806A
18051 - Shift Fork 2
          P284A 00 [096] - Stuck
                    Fault Frequency: 0
                    Reset counter: 0
                    Time: 00:00:00
                    Engine RPM: 0 /min
                    Transmission input speed: 0 /min
                    Transmission output speed: 0 /min
                    Engine torque: -100 Nm
                    ATF temperature: -40 °C
                    Accelerator pedal position: 0.0 %
                    Clutch status: Beide Kupplungen offen
                    Unlearning counter according OBD: 0
   Coding: 27A68701E465E180EB00
   VCID: 3634D0DF78CD102B01E-8062
   Part No SW: 4H0 907 064 CG    HW: 4H0 907 064 CG
   Component: BCM2 2.0      H32 0421
   Coding: 01B93046000000000000
   VCID: 70B826C75AA97E1B1B2-8024
   Serial number: 2312000099476001
   Part No SW: 4G0 820 043 AC    HW: 4G0 820 043 AC
   Component: KLIMA 2 ZONEN H11 0070
   Serial number: 30051200111342
   Coding: 3622000821
   ASAM Dataset: EV_AirCondiBasisUDS 002040
   VCID: 609856878AC9CE9B8B2-8034
0019 - Motor for Fresh Air / Recirculated Air Flap
          B11AF 07 [008] - Mechanical Failure
                    Reset counter: 35
                    Mileage: 141922 km
                    Date: 2022.08.14
                    Time: 15:34:01
                    Voltage terminal 30: 13.54 V
                    Outside temperature: 34.0 °C
                    Inside temperature: 42.63 °C
                    Fresh air door motor-Act.val.: 11393
                    Fresh air door motor-Target value: 9889
                    Fresh air door motor-Stop open: 11384
                    Fresh air door motor-Stop closed: 10000
   Part No SW: 4H0 907 063 CB    HW: 4H0 907 063 B
   Revision: 13012002    Serial number: 00000001507556
   Coding: 690000108034A7E00105008300005F5F0F9DE60827080201000004406000
   VCID: 6A8C34AF7C7584CB556-803E
   Component: WWS57X 120405  H35 0080
   Serial number:         120418213657
   Coding: 0045F7
   Serial number: 20298405
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531     HW: 4G0 941 531
   Component: E1 - LDS  H07 0044
   Serial number: 17 05 2012  00001543
   Serial number: 5D388A26000000000001
                    Fault Status: 00101100
                    Fault Frequency: 101
                    Reset counter: 73
                    Mileage: 133681 km
                    Date: 2022.02.01
                    Time: 16:47:00
                    Reset counter: 70
                    Mileage: 143157 km
                    Date: 2022.10.27
                    Time: 13:01:00
   Part No SW: 4H0 919 475 AG    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0072
   Revision: 11001001    Serial number: 61061214400242
   Coding: 09C307
   ASAM Dataset: EV_EPHVA18AU57X0000 003008
   VCID: 77AA1DDB3F472923DA8-8022
   Revision: --------    Serial number: 003JG008P4NC
   Coding: 30323436313330303537554A305234473053
   Serial number: 3575HRB405F1D5MK6G1B
   Serial number: 3585HRB404V1CAICEPME
   Serial number: 3515JRB40571ADPCMH5K
   Serial number: 3525JRB404V19KD2CGU%
   Serial number: 3554VRB401A4UE20AA54
   Serial number: 3564VRB401E4UE20LGI$
9443861 - Driver's Front Airbag Crash Sensor
          B101A 15 [136] - Open or Short to Plus
                    Mileage: 133676 km
                    Date: 2021.09.28
                    Time: 08:53:40
   Revision: 00000000    Serial number: 20120526000310
   Coding: 000035
   VCID: 3038E6C79A293E1B5B2-8064
   Subsystem 1 - Part No SW: 4G0 951 528 E    HW: 4G0 951 528 E
   Component: E221 - MFL  H09 0009
01748 - Switch for Tiptronic in Steering Wheel (E438); Up
                    Fault Status: 00100111
                    Reset counter: 57
                    Mileage: 143126 km
                    Date: 2022.10.22
                    Time: 13:22:48
   Part No SW: 4G8 920 950 N    HW: 4G8 920 950 N
   Component: MDieGb        H34 0306
   Revision: 26450232    Serial number: 658210512592032
   Coding: 33A6100003412600010000
   ASAM Dataset: EV_RBC7KMID 004045
   ROD: EV_RBC7KMID.rod
   VCID: 3A2CC4EF4CD5F44BE56-806E
                    Reset counter: 62
                    Mileage: 143558 km
                    Date: 2022.10.28
                    Time: 16:39:17
Address 19: CAN Gateway (J533)       Labels:| 4H0-907-468.clb
   Part No SW: 4G5 907 468 A    HW: 4G5 907 468
   Component: J533--Gateway H10 0028
   Revision: --------    Serial number: 00000000539869
   Coding: 00CD077D00
   GVL: FDA1C800D86460010000
   ASAM Dataset: EV_GatewPkoUDS 001013
   VCID: 3332E9CB6BBF0503260-8066
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790435037
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
   Serial number: 20031200000000000201
   Part No SW: 4G0 907 637     HW: 4G0 907 637
   Component: SARA 3D       H02 0009
   Revision: --------    Serial number: EJ1BPA3202PLJN0
   ASAM Dataset: EV_SARA 009017
   ROD: EV_SARA_009.rod
   VCID: 6B8231AB730F9DC32E0-803E
   Component: TSG FA        H03 0506
   Coding: 011C16004001620002080002
   VCID: 47CAAD1B0FA799A36A8-8012
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0024534288
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323CECCF94A50C0B2D6-8066
   Revision: 00002001    Serial number: 0177132023
   Coding: 013B062220B90000832009042001040F0000000000000000000000000000
   Component: TSG BF        H03 0506
   VCID: 46D4A01F08AD80AB91E-8012
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000352252
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2B02F1ABB38F5DC36E0-807E
   Part No SW: 4G0 035 193 E    HW: 4G0 035 193 D
   Component: RMC Cnct Nav  H52 0775
   Coding: 0101010001415B47083B060301010000010000
   VCID: 25160793D5EB6BB3B84-8070
   Subsystem 1 - Part No: 8X0 919 884 D
   Component: P13-50-11.06  0002
   Subsystem 2 - Part No SW: 4G0 919 603     HW: 4G0 919 603
   Component: DU6 Basic  H42 0084
   Serial number: 9464E50C2528889
   Subsystem 3 - Part No SW: 4G2 919 610 B    HW: 4G2 919 610 B
   Serial number: 90349LEN000VG
   Component: TSG HL        H03 0506
   VCID: 49CEAB2319B36FD37CC-801C
Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
   Part No SW: 4G8 907 383     HW: 4G8 907 383
   Component: Anhaenger     H11 0100
   Revision: 5G001001    Serial number: 00008200755468
   Coding: 0109080000000000
   VCID: 71BE23C351A3771314C-8024
02564 - Trailer; Left Tail Lamps (M60)
                    Fault Status: 11101010
                    Reset counter: 100
                    Mileage: 133561 km
                    Date: 2021.09.25
                    Time: 12:50:39
   Component: TSG HR        H03 0506
End----------(Elapsed Time: 01:45, VBatt start/end: 11.9V/12.1V)-----------
Address 15: DTCs cleared
VCDS Release 22.10.0:  SRI Reset-SRI1.CLB
Control Module Part Number: 4G8 920 950 N       Labels:  .*4H0-920-xxx-17.clb-SRI1
Component:MDieGb        H34 0306, Coding:33A6100003412600010000
Channel        Description                                                     Current val.                                                    New val.
IDE00342-ESI: Resetting ESI        ESI: Service Reminder Status                                    no warning                                                      ---
IDE00510-ESI: distance driven from inspection                                                           ESI: Distance since Inspection                                  6500 km                                                         ---
IDE00511-ESI: time from inspection        ESI: Time since Inspection                                      239 d                                                           ---
IDE00515-ESI: oil quality        ESI: Oil Quality                                                poor oil quality                                                ---
IDE00517-ESI: soot entry        ESI: Soot Quantity                                              12200 km                                                        ---
IDE00518-ESI: thermal load        ESI: Thermal Load                                               6400 km                                                         ---
IDE01153-SIA: maximum value of distance to service                                                      SIA: Maximum Distance to Service                                14500 km                                                        ---
IDE01154-SIA: maximum value of time to service                                                          SIA: Maximum Time to Service                                    365 d                                                           ---
IDE03349-FIX:Max. distance driven until next mileage-related inspection                                 FIX: Maximum Distance to Inspection                             30100 km                                                        ---
IDE03350-FIX: Maximum time until next time-dependent inspection                                         FIX: Maximum Time to Inspection                                 730 d                                                           ---
IDE03351-FIX: Distance covered since last mileage-dependent inspection                                  FIX: Distance since Inspection                                  47500 km                                                        ---
IDE03352-FIX: Time since last time-dependent inspection                                                 FIX: Time since Inspection                                      1310 d                                                          ---
IDE00512-ESI: minimum value km-driving distance/inspection                                              ESI: Minimum Distance to Service                                14500 km                                                        ---
IDE00513-ESI: maximum value km-driving distance/inspection                                              ESI: Maximum Distance to Inspection                             30600 km                                                        ---
IDE00514-ESI: maximum value of time between inspections                                                 ESI: Maximum Time to Service                                    730 d                                                           ---
IDE00827-ESI: minimum value of time between inspections                                                 ESI: Minimum Time to Service                                    730 d                                                           ---
Operation: Reset FIX&ESI / INSP,(North America) or (Rest of World second service and later)
IDE00342-ESI: Resetting ESI        ESI: Service Reminder Status                                    no warning                                                      0
IDE03351-FIX: Distance covered since last mileage-dependent inspection                                  FIX: Distance since Inspection                                  47500 km                                                        0
IDE03352-FIX: Time since last time-dependent inspection                                                 FIX: Time since Inspection                                      1310 d                                                          0
Address 17,4G8 920 950 N,channel IDE00342-ESI: Resetting ESI,adapted from,no warning ,to,Resetting ,
Address 17,4G8 920 950 N,channel IDE03351-FIX: Distance covered since last mileage-dependent inspection,adapted from,47500 km,to,0 km,
Address 17,4G8 920 950 N,channel IDE03352-FIX: Time since last time-dependent inspection,adapted from,1310 d,to,0 d,
Operation: Reset ESI / OIL,(North America) or (Rest of World second service and later)
IDE00342-ESI: Resetting ESI        ESI: Service Reminder Status                                    Resetting                                                       0
IDE00510-ESI: distance driven from inspection                                                           ESI: Distance since Inspection                                  0 km                                                            ---
IDE00511-ESI: time from inspection        ESI: Time since Inspection                                      0 d                                                             ---
IDE00517-ESI: soot entry        ESI: Soot Quantity                                              0 km                                                            ---
IDE00518-ESI: thermal load        ESI: Thermal Load                                               0 km                                                            ---
IDE03351-FIX: Distance covered since last mileage-dependent inspection                                  FIX: Distance since Inspection                                  0 km                                                            ---
IDE03352-FIX: Time since last time-dependent inspection                                                 FIX: Time since Inspection                                      0 d                                                             ---
Address 17,4G8 920 950 N,channel IDE00342-ESI: Resetting ESI,adapted from,Resetting ,to,Resetting ,
