- Joined
- Mar 25, 2018
- Messages
- 9
- Reaction score
- 10
- Location
- Brisbane, Australia
- VCDS Serial number
- C?ID=331752
All settings here are factory spec as per the car taken on delivery from a dealership. This car is fitted with the "Sound and Style" package and no sunroof.
Auto Scan
01-Engine
02-Auto Trans
2B-Steering. Col. Lock
03-ABS Brakes
3C-Lane Change
4B-Multifunc. Module
05-Acc/Start Auth.
5F-Information Elect.
6C-Back-up Cam.
6D-Trunk Elect.
08-Auto HVAC
09-Cent. Elect.
10-Park/Steer Assist
Auto Scan
Thursday,22,March,2018,16:05:26:60782
VCDS Version: 18.2.0.3 (x64) HEX-NET CB: 0.4411.4
VIN: WVWZZZ3HZJE507440 License Plate: 175FUN
Mileage: 4322km-2685mi Repair Order:
Chassis Type: 3H-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 29 2B 36 39 3C 42
44 47 4B 52 5F 6C 6D 82 A5 A9 BB BC CF D6 D7
VIN: WVWZZZ3HZJE507440 Mileage: 4322km-2685miles
Address 01: Engine (J623-DJHC) Labels:. 06K-907-425-V1.clb
Part No SW: 3G0 906 259 F HW: 06K 907 425 J
Component: R4 2.0l TFS H13 0004
Revision: --H13---
Coding: 092500322466050B3004
Shop #: WSC 05311 115 00306
ASAM Dataset: EV_ECM20TFS0203G0906259F 001006
ROD: EV_ECM20TFS0203G0906259F.rod
VCID: 2F2EE2F376F0223CB1-807A
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0GC 300 011 L HW: 0GC 927 711 G
Component: GSG DQ381 H06 1401
Revision: 00H06V07
ASAM Dataset: EV_TCMDQ381061 001
ROD: EV_TCMDQ381061.rod
VCID: 2B16F6E342E85E1C9D-807E
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000 Serial number: 62557000001567
Coding: 0DEC939454202373477B070440C369B0C92AC4E2E0029675384250B8C2A9420000000012121212B835351919323200
Shop #: WSC 00015 115 08193
ROD: EV_Brake1UDSContiMK100IPB_036_VW48.rod
VCID: 77BE1A93CE202AFC29-8022
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0906
Revision: 00037000 Serial number: 0454489816
Coding: 1F20200723
VCID: 3E30CFB7A19ADBB42A-806A
Subsystem 1 - Part No SW: 3G0 962 243 B HW: 3G0 962 243 B
Component: GEB.F.Heckoef H17 0904
Serial number: 58245281
Part No SW: 5G0 907 044 DP HW: 5G0 907 044 DP
Component: Climatronic H04 2001
Revision: 00001K10
Coding: 1412000420010001111550000010192A
ASAM Dataset: EV_ACClimaBHBVW37X 006146
ROD: EV_ACClimaBHBVW37X_006_VW27.rod
VCID: 78BC19AFC33E258420-802C
Part No SW: 5Q0 937 086 BM HW: 5Q0 937 086 BH
Component: BCM PQ37BOSCH 034 0242
Revision: -------- Serial number: 86583108170046
ROD: EV_BCMCONTI.rod
VCID: 06406757B9CA437422-8052
Subsystem 1 - Part No SW: 3G2 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 170813 043 0607
Serial number: 170901030426
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 047 0105
Serial number: S9Y17M09D15H17M22S02
Coding: 00A8DD
Light switch:
Subsystem 3 - Part No SW: 3G8 941 633 B HW: 3G8 941 633 B
Component: E1 - LDS MQB H01 0032
Serial number: 30 04 2017 10000224
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY172151G4U
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000070691177
551445 - Databus
[TSG_HFS_01 Datenbus fehlende Botschaft]
527872 - Transport Mode Active
U1105 00 [008] - -
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 C HW: 5QA 919 298 A
Serial number: 000308417617251
Coding: 0371267851
Shop #: WSC 05311 115 00060
ROD: EV_EPHVA2CAU3700000_009_VW37.rod
VCID: 50EC810F0B0E5DC4C8-8004
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 J HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0654
Coding: 320467D359FFC728949C812430400600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002006
0836 - Databus
[FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
Fault Frequency: 99
Reset counter: 136
Mileage: 3246 km
Date: 2018.03.06
Time: 17:34:52
Control Module temperature: 25 °C
Voltage terminal 15: 13.2 V
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 C HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0130
Serial number: 18081741350399
ROD: EV_DRCONTITEMIC_VW27.rod
VCID: 393ADCABB8B4FC8C1F-806C
Part No SW: 3Q0 959 655 BK HW: 3Q0 959 655 BK
Component: Airbag VW21 006 0703
Revision: -------- Serial number: 003W6PHGLJT$
Coding: 98FCC0C00C0000005C000000008840000065
Shop #: WSC 05314 000 00001
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 085C696FB3DE550450-805C
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1032
Serial number: 3G8857705B0233R00637
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1032
Serial number: 3G8857706B0234R00507
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 454 003 008 17
Serial number: 357000000000606DA82H
Subsystem 4 - Part No SW: ----------- HW: 454 003 008 17
Serial number: 35800000000ED770E82
Subsystem 5 - Part No SW: ----------- HW: 454 803 008 17
Component: SideSensor_Dr 301 0148
Serial number: 351007F3442110000003
Subsystem 6 - Part No SW: ----------- HW: 454 803 008 17
Component: SideSensor_Pr 301 0148
Serial number: 3520083264211000000.
Subsystem 7 - Part No SW: ----------- HW: 454 803 008 17
Component: FrontSensor_D 304 0149
Serial number: 355006311E110000000/
Pedestrian Protection Driver:
Subsystem 8 - Part No SW: ----------- HW: 454 802 308 17
Component: PedP_Sensor_D 304 0149
Serial number: 22800F72FC610000000R
Subsystem 9 - Part No SW: ----------- HW: 454 802 308 17
Component: PedP_Sensor_P 304 0149
Serial number: 22900C423C610000000A
Pedestrian Protection Center:
Subsystem 10 - Part No SW: ----------- HW: 454 802 308 17
Component: PedP_Sensor_C 304 0149
Serial number: 230008028C610000000%
Subsystem 11 - Part No SW: ----------- HW: 454 000 908 17
Component: PedP_Sens_D_2 008 0887
Serial number: I0M000000005629DC326
Subsystem 12 - Part No SW: ----------- HW: 454 000 908 17
Component: PedP_Sens_P_2 008 0887
Serial number: I0N000000002629DC324
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 AH HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF033033 Serial number: 20170909301967
Coding: 0810
Shop #: WSC 00015 115 00001
ASAM Dataset: EV_SMLSVALEOMQB 001016
ROD: EV_SMLSVALEOMQB.rod
Part No SW: 3G0 920 791 C HW: 3G0 920 791 C
Component: KOMBI 406 3193
Coding: 27A4101BFF88000801806B0B1001000080000000
VCID: 291A0CEB48144C0C6F-807C
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 518 5304
Serial number: 08091710522831
Coding: 0B0300347F085900FB00827E9C0F00010001070000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 3326EE839AD806DCD5-8066
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29170001971380017364
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1050
Serial number: 75886000001709081036
Power Converter DC AC:
Subsystem 4 - Part No SW: 5Q0 907 155 C HW: 5Q0 907 155 C
Component: U13DCAC H26 0780
Serial number: 0069725
Analog clock:
Subsystem 5 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Serial number: HA1-00024.07.17
Coding: 0301
VCID: 4AD89367ED52671486-801E
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 B HW: 8V0 907 399 B
Component: LCM_MLBevoH08 0014
VCID: 45C2A05BC44C886C6B-8010
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 17000249819013
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71AA248BA04474CCE7-8024
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 3Q0 959 760 B HW: 3Q0 959 760 B
Component: Sitzmemory H05 0022
Serial number: Y0006QI829520
Coding: 001400020000050081C281808080000000008181000000F400
VCID: 3A38C3A7BDB2F79416-806E
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 E HW: 3Q0 907 566
Component: MRR1Rear H20 0510
Revision: --------
Coding: 44C002
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 011 0032
Serial number: 0000276366657
Coding: 003F5A02D201028000001000
VCID: 47DEAA53FE409A7C99-8012
589825 - Local Data Bus
U10BA 00 [008] - No Communication
[Lokaler Datenbus 1 (LIN)]
Fault Frequency: 9
Mileage: 250 km
Date: 2018.01.03
Time: 11:53:09
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 9307
Shop #: WSC 00015 115 00306
ROD: EV_SteerAssisMQB_013.rod
Address 47: Sound System (J525) Labels:| 3Q0-035-466.clb
Part No SW: 3Q0 035 465 HW: 3Q0 035 465
Component: MIB2_amp_P_VW H60 0440
Revision: 00000001 Serial number: VWZ8Z1HJD00X2BM
Coding: 1284010001AA0A2AAA0000000000
ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001016
ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
VCID: 6B9636E382689E1CDD-803E
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 06091710522505
Coding: 000000050100045607106F05020000000000000000000000000000000000
Shop #: WSC 05311 000 08193
VCID: 72A82B87A5424FD41E-8026
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 011 0032
Serial number: 0000276506362
Coding: 003F5002DE01028200001000
VCID: 46C0A757F94A837462-8012
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 5NA 035 045 A HW: 5NA 035 045
Component: MU-H-N-RW H54 1161
Serial number: A849H0HS009568
Coding: 028403080000000051510002000808001F0106E601200402DF
VCID: 3620D79789AA13F4F2-8062
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H50 9130
Serial number: VWZ6ZJT2556387
Subsystem 2 - Part No SW: V03 959 801 EC HW: -----------
Component: ROW 2017 --- 0062
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 4012
1561 - predictive route data
B1630 02 [008] - Signal Failure
Reset counter: 136
Mileage: 3246 km
Date: 2018.03.06
Time: 17:34:51
Voltage terminal 30: 13.5 V
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 5Q0 907 556 C HW: 5Q0 907 556
Component: Areaview 2 H13 0608
Serial number: C854707JG018274
Coding: 01840301E20F200000204094
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 M HW: 5Q0 959 107 C
Component: HDSG-Modul H12 0261
Revision: -------- Serial number: 31537933200000
Coding: 0B28
ROD: EV_DeckLidCONTIAU736_VW27.rod
VCID: 42C8BB47D562BF544E-8016
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 3G0 919 608 B HW: 3G0 919 608 B
Component: HeadupDisplay 052 0302
Coding: 564060
ASAM Dataset: EV_HeadUpDisplContiVW481 001015
ROD: EV_HeadUpDisplContiVW481.rod
VCID: 2D12F8FB7CFC502C83-8078
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 J HW: 3Q0 980 654 A
Component: MQB_B_MFK H08 0273
Serial number: 29081712K10606
Coding: 000408040000010100022347C150A90084000E300040
ROD: EV_MFKBoschMQBB_VW27.rod
1123377 - Databus
[Timeout_Gateway_72_Anhaenger_01_alt]
Reset counter: 122
Mileage: 5 km
Date: 2011.01.01
Time: 04:13:39
Control Module temperature: 29 °C
Outside air temperature: 15.5 °C
Vehicle speed: 0.00 km/h
System run time: 85.8 s
Voltage terminal 15: 12.2 V
mid: 02 94
Status of camera: operational
Engine_Running_Info: 0
Software_Info_4: 3
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 0
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 3G8 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0003
Serial number: 170809201681
Part No SW: 5Q4 959 595 E HW: 5Q4 959 595 B
Component: TSG HFS 012 0032
Serial number: 0000275751630
Coding: 000A50020101028000001000
ASAM Dataset: EV_DCURearDriveMAXCONT 006001
VCID: 49DAAC6BE8546C0C8F-801C
Component: TSG HBFS 012 0032
Serial number: 0000275763507
ASAM Dataset: EV_DCURearPasseMAXCONT 006001
Address CF: Lane Chge Asst 2 (J770) Labels:. 3Q0-907-566.clb
Part No SW: 3Q0 907 590 E HW: 3Q0 907 590
Revision: --------
Coding: 44C002
VCID: 373EDA938EA0EAFCE9-8062
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
ROD: EV_LEDModLeftMELCOAU736_VW48.rod
VCID: 16603717E96AF3F4D2-8042
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H09 0003
End----------(Elapsed Time: 02:56, VBatt start/end: 12.3V/12.2V)-----------
01-Engine
;SW:3G0-906-259-F HW:06K-907-425-J --- Engine
;Component:R4 2.0l TFS H13 0004 Coding:092500322466050B3004
;EV_ECM20TFS0203G0906259F 1006 EV_ECM20TFS0203G0906259F.rod
;Thursday 22 March 2018 16:25:41:60782
;VCDS Version: Release 18.2.0 (x64) Data version: 20180212 DS287.0
;VCID: 2F2EE2F376F0223CB1-807A
IDE00001-Production mode 00 00 00 3
IDE00259-Idle RPM correction 0 /min 1
IDE01945-Engine run-in oil pressure not active 1
IDE02332-Deactivate production mode 00 00 00 3
IDE04158-Activation of start-stop function active 1
IDE04617-Protective function Enabled 1
IDE06425-Roller test bench mode: functional not activated 1
IDE06726-Timing deviation after chain replacement: intake bank 1 0.00 ° 2
IDE06728-Timing deviation after chain replacement: exhaust bank 1 -3.19 ° 2
IDE06730-Timing deviation after other repairs: intake bank 1 0.00 ° 2
IDE06732-Timing deviation after other repairs: exhaust bank 1 0.00 ° 2
IDE06734-Timing deviation: current value intake bank 1 0.00 ° 2
IDE06736-Timing deviation: current value exhaust bank 1 -3.25 ° 2
IDE06738-Chain elongation: no. of valid initial values: intake bank 1 0 1
IDE06740-Chain elongation: no. of valid initial values: exhaust bank 1 5 1
IDE06742-Chain elongation: initial values valid: intake bank 1 not active 1
IDE06744-Chain elongation: initial values valid: exhaust bank 1 not active 1
IDE10261-MAS10172-Operating mode selec.-DI operation not activated 4
IDE10261-MAS10174-Operating mode selec.-CNG operation not activated 4
IDE10261-Operating mode selec.- not activated 4
Elapsed Time: 00:04
02-Auto Trans
;SW:0GC-300-011-L HW:0GC-927-711-G --- Auto Trans
;Component:GSG DQ381 H06 1401 Coding:0014
;EV_TCMDQ381061 1 EV_TCMDQ381061.rod
;Thursday 22 March 2018 16:25:58:60782
;VCID: 2B16F6E342E85E1C9D-807E
IDE00001-Production mode not activated 3
Elapsed Time: 00:01
;SW:3Q0-905-861 HW:3Q0-905-861 --- Steer. Col. Lock
;Component:ELV-MQBB H05 0032 Coding:0800000000000000
;EV_ELVMarquMQBB 1007 EV_ELVMarquMQBB.rod
;Thursday 22 March 2018 16:34:27:60782
;VCID: 71AA248BA04474CCE7-8024
IDE00820-Activating and deactivating all development messages not active 1
IDE07566-Steering column lock unlocked unlock 1
ENG128823-functional_check_manufacturer tested 1
ENG128824-functional_check_steering_column_supplier tested 1
Elapsed Time: 00:01
03-ABS Brakes
;SW:5Q0-614-517-CF HW:5Q0-614-517-AD --- ABS Brakes
;Component:ESC H25 0513 Coding:0DEC939454202373477B070440C369B0C92AC4E2E0029675384250B8C2A9420000000012121212B835351919323200
;EV_Brake1UDSContiMK100IPB 36010 EV_Brake1UDSContiMK100IPB_036_VW48.rod
;Thursday 22 March 2018 16:26:08:60782
;VCID: 77BE1A93CE202AFC29-8022
IDE00001-Production mode not active 3
IDE00252-Brake system vacuum pump 5 1
IDE00820-Activating and deactivating all development messages 0 1
IDE01763-Dimming activated 1
IDE02332-Deactivate production mode Deactivating 3
IDE03493-Driver door status activated 1
IDE03659-Roller test bench mode Manual activation: possible 1
IDE04456-Brake disk drying Medium 1
IDE04508-Hydraulic brake booster 8 1
IDE04643-Overboost in brake system activated 1
IDE04645-Electromechanical parking brake not activated 1
IDE04774-Vehicle and trailer stabilization not activated 1
IDE04871-Dynamic starting assist normal 1
IDE04939-Tire pressure monitoring display 2 1
IDE04944-Brake pedal evaluation activated 1
IDE04949-Engine drag torque control activated 1
IDE04951-Brake booster 4 1
IDE04952-Braking torque boost for distance regulation 3 1
IDE05055-Hydraulic brake assistant normal 1
IDE05057-Brake prefill activated 1
IDE05161-Straight ahead brake stabilization activated 1
IDE05263-AUTO HOLD functionality not activated 1
IDE05264-AUTO HOLD increase threshold: reduced tensioning force 0% 1
IDE05265-AUTO HOLD increase threshold: full tensioning force 10% 1
IDE05286-Expanded electronic differential lock Standard 1
IDE05337-Starting vibration reduction- Strong 1
IDE05337-MAS02653-Starting vibration reduction-Torque limitation Deactivated 1
IDE05711-Automatic application during engine stalling activated 1
IDE06137-IDE04772-Monitoring of functional lights-Indicator light in the button for electromech. parking brake 7 2
IDE06137-IDE05333-Monitoring of functional lights-Indicator light in AUTO HOLD button 7 2
IDE06139-AUTO HOLD slippage recognition activated 1
IDE06505-Electromechanical parking brake: delay level 6 1
IDE07006-Tire pressure monitoring display: tire selection 1 1
IDE07292-Brake pre-filling completed successfully 1
IDE07565-ABS in lower speed range activated 1
IDE07848-Thresholds for brake performance activated 1
IDE12030-Rough road optimization activated 1
MAS00122-Electronic Stability Program not activated 1
MAS00970-Running manufacturer number activated 1
MAS01180-AUTO HOLD functional status Last setting 1
MAS01299-Offroad 0 1
MAS02080-XCP calibration protocol not activated 1
MAS02138-Hill-start assistant normal 1
MAS02666-Seat belt buckle scan activated 1
MAS09008-MAS00988-Plausibility check-Reverse gear activated 3
MAS09008-MAS09009-Plausibility check-Neutral gear sensor activated 3
MAS09008-MAS10668-Plausibility check-Clutch movement activated 3
MAS11606-Electromechanical parking brake: emergency braking activated 1
ENG118148-Developer_Function_1 0 1
ENG130301-Developer_Function_121 not activated 1
ENG122844-ENG101574-dimming_characteristic_1-X1 0 12
ENG122844-ENG99557-dimming_characteristic_1-X2 10 12
ENG122844-ENG102140-dimming_characteristic_1-X3 50 12
ENG122844-ENG102936-dimming_characteristic_1-X4 100 12
ENG122844-ENG103548-dimming_characteristic_1-X5 220 12
ENG122844-ENG113992-dimming_characteristic_1-X6 253 12
ENG122844-ENG99777-dimming_characteristic_1-Y1 6 12
ENG122844-ENG100480-dimming_characteristic_1-Y2 6 12
ENG122844-ENG100773-dimming_characteristic_1-Y3 8 12
ENG122844-ENG100631-dimming_characteristic_1-Y4 12 12
ENG122844-ENG102174-dimming_characteristic_1-Y5 80 12
ENG122844-ENG113993-dimming_characteristic_1-Y6 100 12
ENG122845-ENG101574-dimming_characteristic_2-X1 0 12
ENG122845-ENG99557-dimming_characteristic_2-X2 10 12
ENG122845-ENG102140-dimming_characteristic_2-X3 50 12
ENG122845-ENG102936-dimming_characteristic_2-X4 100 12
ENG122845-ENG103548-dimming_characteristic_2-X5 220 12
ENG122845-ENG113992-dimming_characteristic_2-X6 253 12
ENG122845-ENG99777-dimming_characteristic_2-Y1 6 12
ENG122845-ENG100480-dimming_characteristic_2-Y2 6 12
ENG122845-ENG100773-dimming_characteristic_2-Y3 8 12
ENG122845-ENG100631-dimming_characteristic_2-Y4 12 12
ENG122845-ENG102174-dimming_characteristic_2-Y5 80 12
ENG122845-ENG113993-dimming_characteristic_2-Y6 100 12
Elapsed Time: 00:16
3C-Lane Change
;SW:3Q0-907-566-E HW:3Q0-907-566 --- Lane Change
;Component:MRR1Rear H20 0510 Coding:44C002
;EV_RearRadarS1BoschVW48X 1007 EV_RearRadarS1BoschVW48X.rod
;Thursday 22 March 2018 16:35:06:60782
;VCID: 3A38C3A7BDB2F79416-806E
IDE00001-MAS15623-Production mode-Deactivation of lane change assistance and exit warning not active 3
IDE00001-MAS15624-Production mode-Deactivation of Cross traffic assistant rear and pre sense rear not active 3
IDE00820-Activating and deactivating all development messages not activated 1
IDE02332-Deactivate production mode 0 3
IDE05394-Brightness characteristic of warning display normal 1
Elapsed Time: 00:03
;SW:3Q0-907-338 HW:3Q0-907-338 --- Multifunc. Module
;Component:FCM MQB Low 002 0286 Coding:000000050100045607106F05020000000000000000000000000000000000
;EV_MultiModulContiVW48X 1010 EV_MultiModulContiVW48X.rod
;Thursday 22 March 2018 16:36:17:60782
;VCID: 72A82B87A5424FD41E-8026
IDE01996-MAS14455-Installation list: specified installations-Multifunction module on the second bus connection Yes 1
IDE01996-SFT00041-Installation list: specified installations-Light Control Left Yes 1
IDE01996-SFT00057-Installation list: specified installations-Light Control Right Yes 1
IDE01996-SFT00075-Installation list: specified installations-Multifunction module Yes 1
IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2 Yes 1
IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2 Yes 1
IDE03641-Presentation run dynamic AFS light active 1
IDE03642-Presentation mode not active 1
IDE03679-Adaptive light functions active 1
IDE03787-Activate left/right hand drive switch-over not active 1
IDE08418-Matrix light: total dimming 100% 1
IDE09156-Matrix headlamp: function at standstill not active 1
IDE09568-MAS09833-Bit pattern of individual segment activation: left headlight-LED 1 OFF 6
IDE09568-MAS09834-Bit pattern of individual segment activation: left headlight-LED 2 OFF 6
IDE09568-MAS09835-Bit pattern of individual segment activation: left headlight-LED 3 OFF 6
IDE09568-MAS09836-Bit pattern of individual segment activation: left headlight-LED 4 OFF 6
IDE09568-MAS09837-Bit pattern of individual segment activation: left headlight-LED 5 OFF 6
IDE09568-MAS09838-Bit pattern of individual segment activation: left headlight-LED 6 OFF 6
IDE09568-MAS09839-Bit pattern of individual segment activation: left headlight-LED 7 OFF 6
IDE09568-MAS09840-Bit pattern of individual segment activation: left headlight-LED 8 OFF 6
IDE09568-MAS09841-Bit pattern of individual segment activation: left headlight-LED 9 OFF 6
IDE09568-MAS09842-Bit pattern of individual segment activation: left headlight-LED 10 OFF 6
IDE09568-MAS09843-Bit pattern of individual segment activation: left headlight-LED 11 OFF 6
IDE09568-MAS09844-Bit pattern of individual segment activation: left headlight-LED 12 OFF 6
IDE09568-MAS09845-Bit pattern of individual segment activation: left headlight-LED 13 OFF 6
IDE09568-MAS09846-Bit pattern of individual segment activation: left headlight-LED 14 OFF 6
IDE09568-MAS09847-Bit pattern of individual segment activation: left headlight-LED 15 OFF 6
IDE09568-MAS09848-Bit pattern of individual segment activation: left headlight-LED 16 OFF 6
IDE09568-MAS09849-Bit pattern of individual segment activation: left headlight-LED 17 OFF 6
IDE09568-MAS09850-Bit pattern of individual segment activation: left headlight-LED 18 OFF 6
IDE09568-MAS09851-Bit pattern of individual segment activation: left headlight-LED 19 OFF 6
IDE09568-MAS09852-Bit pattern of individual segment activation: left headlight-LED 20 OFF 6
IDE09568-MAS09853-Bit pattern of individual segment activation: left headlight-LED 21 OFF 6
IDE09568-MAS09854-Bit pattern of individual segment activation: left headlight-LED 22 OFF 6
IDE09568-MAS09855-Bit pattern of individual segment activation: left headlight-LED 23 OFF 6
IDE09568-MAS09856-Bit pattern of individual segment activation: left headlight-LED 24 OFF 6
IDE09568-MAS09857-Bit pattern of individual segment activation: left headlight-LED 25 OFF 6
IDE09568-MAS09858-Bit pattern of individual segment activation: left headlight-LED 26 OFF 6
IDE09568-MAS09859-Bit pattern of individual segment activation: left headlight-LED 27 OFF 6
IDE09568-MAS09860-Bit pattern of individual segment activation: left headlight-LED 28 OFF 6
IDE09568-MAS09861-Bit pattern of individual segment activation: left headlight-LED 29 OFF 6
IDE09568-MAS09862-Bit pattern of individual segment activation: left headlight-LED 30 OFF 6
IDE09568-MAS09863-Bit pattern of individual segment activation: left headlight-LED 31 OFF 6
IDE09568-MAS09864-Bit pattern of individual segment activation: left headlight-LED 32 OFF 6
IDE09568-MAS09865-Bit pattern of individual segment activation: left headlight-LED 33 OFF 6
IDE09568-MAS09866-Bit pattern of individual segment activation: left headlight-LED 34 OFF 6
IDE09568-MAS09867-Bit pattern of individual segment activation: left headlight-LED 35 OFF 6
IDE09568-MAS09868-Bit pattern of individual segment activation: left headlight-LED 36 OFF 6
IDE09568-MAS09869-Bit pattern of individual segment activation: left headlight-LED 37 OFF 6
IDE09568-MAS09870-Bit pattern of individual segment activation: left headlight-LED 38 OFF 6
IDE09568-MAS09871-Bit pattern of individual segment activation: left headlight-LED 39 OFF 6
IDE09568-MAS09872-Bit pattern of individual segment activation: left headlight-LED 40 OFF 6
IDE09568-MAS09873-Bit pattern of individual segment activation: left headlight-LED 41 OFF 6
IDE09568-MAS09874-Bit pattern of individual segment activation: left headlight-LED 42 OFF 6
IDE09568-MAS09875-Bit pattern of individual segment activation: left headlight-LED 43 OFF 6
IDE09568-MAS09876-Bit pattern of individual segment activation: left headlight-LED 44 OFF 6
IDE09568-MAS09877-Bit pattern of individual segment activation: left headlight-LED 45 OFF 6
IDE09569-MAS09833-Bit pattern of individual segment activation: right headlight-LED 1 OFF 6
IDE09569-MAS09834-Bit pattern of individual segment activation: right headlight-LED 2 OFF 6
IDE09569-MAS09835-Bit pattern of individual segment activation: right headlight-LED 3 OFF 6
IDE09569-MAS09836-Bit pattern of individual segment activation: right headlight-LED 4 OFF 6
IDE09569-MAS09837-Bit pattern of individual segment activation: right headlight-LED 5 OFF 6
IDE09569-MAS09838-Bit pattern of individual segment activation: right headlight-LED 6 OFF 6
IDE09569-MAS09839-Bit pattern of individual segment activation: right headlight-LED 7 OFF 6
IDE09569-MAS09840-Bit pattern of individual segment activation: right headlight-LED 8 OFF 6
IDE09569-MAS09841-Bit pattern of individual segment activation: right headlight-LED 9 OFF 6
IDE09569-MAS09842-Bit pattern of individual segment activation: right headlight-LED 10 OFF 6
IDE09569-MAS09843-Bit pattern of individual segment activation: right headlight-LED 11 OFF 6
IDE09569-MAS09844-Bit pattern of individual segment activation: right headlight-LED 12 OFF 6
IDE09569-MAS09845-Bit pattern of individual segment activation: right headlight-LED 13 OFF 6
IDE09569-MAS09846-Bit pattern of individual segment activation: right headlight-LED 14 OFF 6
IDE09569-MAS09847-Bit pattern of individual segment activation: right headlight-LED 15 OFF 6
IDE09569-MAS09848-Bit pattern of individual segment activation: right headlight-LED 16 OFF 6
IDE09569-MAS09849-Bit pattern of individual segment activation: right headlight-LED 17 OFF 6
IDE09569-MAS09850-Bit pattern of individual segment activation: right headlight-LED 18 OFF 6
IDE09569-MAS09851-Bit pattern of individual segment activation: right headlight-LED 19 OFF 6
IDE09569-MAS09852-Bit pattern of individual segment activation: right headlight-LED 20 OFF 6
IDE09569-MAS09853-Bit pattern of individual segment activation: right headlight-LED 21 OFF 6
IDE09569-MAS09854-Bit pattern of individual segment activation: right headlight-LED 22 OFF 6
IDE09569-MAS09855-Bit pattern of individual segment activation: right headlight-LED 23 OFF 6
IDE09569-MAS09856-Bit pattern of individual segment activation: right headlight-LED 24 OFF 6
IDE09569-MAS09857-Bit pattern of individual segment activation: right headlight-LED 25 OFF 6
IDE09569-MAS09858-Bit pattern of individual segment activation: right headlight-LED 26 OFF 6
IDE09569-MAS09859-Bit pattern of individual segment activation: right headlight-LED 27 OFF 6
IDE09569-MAS09860-Bit pattern of individual segment activation: right headlight-LED 28 OFF 6
IDE09569-MAS09861-Bit pattern of individual segment activation: right headlight-LED 29 OFF 6
IDE09569-MAS09862-Bit pattern of individual segment activation: right headlight-LED 30 OFF 6
IDE09569-MAS09863-Bit pattern of individual segment activation: right headlight-LED 31 OFF 6
IDE09569-MAS09864-Bit pattern of individual segment activation: right headlight-LED 32 OFF 6
IDE09569-MAS09865-Bit pattern of individual segment activation: right headlight-LED 33 OFF 6
IDE09569-MAS09866-Bit pattern of individual segment activation: right headlight-LED 34 OFF 6
IDE09569-MAS09867-Bit pattern of individual segment activation: right headlight-LED 35 OFF 6
IDE09569-MAS09868-Bit pattern of individual segment activation: right headlight-LED 36 OFF 6
IDE09569-MAS09869-Bit pattern of individual segment activation: right headlight-LED 37 OFF 6
IDE09569-MAS09870-Bit pattern of individual segment activation: right headlight-LED 38 OFF 6
IDE09569-MAS09871-Bit pattern of individual segment activation: right headlight-LED 39 OFF 6
IDE09569-MAS09872-Bit pattern of individual segment activation: right headlight-LED 40 OFF 6
IDE09569-MAS09873-Bit pattern of individual segment activation: right headlight-LED 41 OFF 6
IDE09569-MAS09874-Bit pattern of individual segment activation: right headlight-LED 42 OFF 6
IDE09569-MAS09875-Bit pattern of individual segment activation: right headlight-LED 43 OFF 6
IDE09569-MAS09876-Bit pattern of individual segment activation: right headlight-LED 44 OFF 6
IDE09569-MAS09877-Bit pattern of individual segment activation: right headlight-LED 45 OFF 6
IDE12110-ENG154832-Rear seat fan: characteristic curve-Level_1_seat_backrest 0% 12
IDE12110-ENG154833-Rear seat fan: characteristic curve-Level_1_seat_cushion 0% 12
IDE12110-ENG154834-Rear seat fan: characteristic curve-Level_2_seat_backrest 0% 12
IDE12110-ENG154835-Rear seat fan: characteristic curve-Level_2_seat_cushion 0% 12
IDE12110-ENG154836-Rear seat fan: characteristic curve-Level_3_seat_backrest 0% 12
IDE12110-ENG154837-Rear seat fan: characteristic curve-Level_3_seat_cushion 0% 12
IDE12110-ENG154838-Rear seat fan: characteristic curve-Level_4_seat_backrest 0% 12
IDE12110-ENG154839-Rear seat fan: characteristic curve-Level_4_seat_cushion 0% 12
IDE12110-ENG154840-Rear seat fan: characteristic curve-Level_5_seat_backrest 0% 12
IDE12110-ENG154841-Rear seat fan: characteristic curve-Level_5_seat_cushion 0% 12
IDE12110-ENG154842-Rear seat fan: characteristic curve-Level_6_seat_backrest 0% 12
IDE12110-ENG154843-Rear seat fan: characteristic curve-Level_6_seat_cushion 0% 12
ENG124608-Order_Reference_Run_Activation_Effect No dependency 1
ENG124607-Reference_Run_Activation_Effect Activation effect disabled 1
ENG103979-Reference_Run_Start_Condition Engine start 1
Elapsed Time: 00:08
05-Acc/Start Auth.
;SW:3Q0-959-435-G HW:3Q0-959-435-G --- Acc/Start Auth.
;Component:VWKESSYMQB 037 0906 Coding:1F20200723
;EV_KessyHellaMQBAB 4041 EV_KessyHellaMQBAB_004_VW37.rod
;Thursday 22 March 2018 16:26:37:60782
;VCID: 3E30CFB7A19ADBB42A-806A
IDE00001-MAS12708-Production mode-Deactivation of automatic shutdowns of terminal 15 not active 3
IDE00001-MAS12709-Production mode-Deactivation of automatic rear lid opening not active 3
IDE00001-MAS12710-Production mode-Deactivation of terminal 50 request not active 3
IDE03251-Stop release for start-stop function According to function requirements 1
IDE04159-Deactivation of start-stop function not active 1
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module 20 min 2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus 30 min 2
IDE09735-CU tailgate opener: sensor 1: threshold value 1 69 1
IDE09736-CU tailgate opener: sensor 1: threshold value 2 16 1
IDE09737-CU tailgate opener: sensor 1: threshold value 3 16 1
IDE09738-CU tailgate opener: sensor 1: threshold value 4 16 1
IDE09739-CU tailgate opener: sensor 1: threshold value 5 16 1
IDE09740-CU tailgate opener: sensor 2: threshold value 1 2 1
IDE09741-CU tailgate opener: sensor 2: threshold value 2 31 1
IDE09742-CU tailgate opener: sensor 2: threshold value 3 2 1
IDE09743-CU tailgate opener: sensor 2: threshold value 4 31 1
IDE09744-CU tailgate opener: sensor 2: threshold value 5 224 1
IDE09745-CU tailgate opener: sensor 1: timer value 1 170 1
IDE09746-CU tailgate opener: sensor 1: timer value 2 0 1
IDE09747-CU tailgate opener: sensor 1: timer value 3 9 1
IDE09748-CU tailgate opener: sensor 1: timer value 4 34 1
IDE09749-CU tailgate opener: sensor 1: timer value 5 47 1
IDE09750-CU tailgate opener: sensor 2: timer value 1 11 1
IDE09751-CU tailgate opener: sensor 2: timer value 2 165 1
IDE09752-CU tailgate opener: sensor 2: timer value 3 147 1
IDE09753-CU tailgate opener: sensor 2: timer value 4 204 1
IDE09754-CU tailgate opener: sensor 2: timer value 5 37 1
IDE09755-CU tailgate opener: sensor 1: burst length 16 1
IDE09756-CU tailgate opener: sensor 1: active screening 16 1
IDE09757-CU tailgate opener: sensor 2: burst length 2 1
IDE09758-CU tailgate opener: sensor 2: active screening 31 1
IDE09760-CU for tailgate opener: check sum 170 1
IDE09829-CU tailgate opener: foot gestic recognition: timer value 1 2 1
IDE09830-CU tailgate opener: foot gestic recognition: timer value 2 31 1
IDE09831-CU for tailgate opener: play protection increments 6 1
IDE09832-CU for tailgate opener: play protection decrements 25 1
IDE09833-CU for tailgate opener: play protection threshold active 255 1
IDE09834-CU for tailgate opener: play protection threshold inactive 5 1
IDE09835-CU for tailgate opener: play protection decrement interval 60 1
IDE09836-CU tailgate opener: sensor 1: control parameter 16 1
IDE09837-CU tailgate opener: sensor 2: control parameter 16 1
IDE09838-CU tailgate opener: foot gestic recognition: evaluation 0 1
IDE09839-CU for tailgate opener: parameter set version 30 2
IDE10844-Control module rear lid opening: duration status query 4960 ms 1
IDE10845-Control module rear lid opening: vehicle type 2F 1
ENG153713-ENG129122-Byte12_diverse-environment_scan_step1 not activated 1
ENG153713-ENG126978-Byte12_diverse-environment_scan_step2 not activated 1
ENG153713-ENG154598-Byte12_diverse-exeption_drivers_doors_interior_scan activated 1
ENG153713-ENG154691-Byte12_diverse-interior_scan_clamp_15_new_concept activated 1
ENG153713-ENG154710-Byte12_diverse-open_cabrio_canopy_interior_scan not activated 1
ENG153713-ENG154787-Byte12_diverse-suppression_access_detection_for_remotestart not activated 1
ENG244871-ENG245027-Byte13_vit_lf-lock_via_toggle_by_closed_vehicle_skin not activated 1
ENG244871-ENG245033-Byte13_vit_lf-toggle_active not activated 1
ENG244871-ENG245019-Byte13_vit_lf-toggle_at _open_door not activated 1
ENG244871-ENG129126-Byte13_vit_lf-vit_evaluate_inversbit not activated 1
ENG244871-ENG129125-Byte13_vit_lf-vit_exit not activated 1
ENG126956-ENG126976-Byte9_VIP-active_vip activated 1
ENG126956-ENG154580-Byte9_VIP-Coding_easyclose_locking not activated 1
ENG126956-ENG154581-Byte9_VIP-Coding_kick and_close_function not activated 1
ENG126956-ENG129121-Byte9_VIP-Hitch_trailer_installation not activated 1
ENG126956-ENG142121-Byte9_VIP-vip_activation_on_clamp15 not activated 1
ENG126956-ENG126977-Byte9_VIP-vip_deactivation_on_running_engine not activated 1
ENG129011-CAN_signal_transmitting_delay_of_car_roll _away_warning 1.00 s 1
ENG126957-CAN_signal_transmitting_duration_of_automatic_Terminal_15_shutoff 1.00 s 1
ENG129010-CAN_signal_transmitting_duration_of_comfort_switch_off 10.00 s 1
ENG105462-CAN-timeout service-key message 260 ms 1
ENG105634-Correction value LED dimming 1 1
ENG114301-Cycletime for voltage monitoring during sleepmode 100 ms 1
ENG120046-Cyclic interior scan during clamp 15 on 10 s 1
ENG126961-deactivation_time_vip_slidingdoor 15 s 1
ENG126960-Debounce_time_detection 500 ms 2
ENG126959-Debounce_time_driver_presence 200 ms 1
ENG126948-delay_time_Terminal_15_S_Shut_down_after_leaving_vehicle 300 ms 1
ENG129004-delay_time_Terminal_15_S_Shut_down_by_BEM 60.00 s 1
ENG105791-Delta value LED dimming curve first point 40 percent dimming 30.00% 1
ENG105792-Delta value LED dimming curve forth point 100 percent dimming 5.00% 1
ENG105793-Delta value LED dimming curve second point 60 percent dimming 15.00% 1
ENG105794-Delta value LED dimming curve third point 80 percent dimming 10.00% 1
ENG105809-ENG100524-DeveloperCoding: Passiv Go-GO only via antenna IN1 if sliding door open not activated 1
ENG105809-ENG102049-DeveloperCoding: Passiv Go-GO only via antenna IN1 if tailgate open not activated 1
ENG105809-ENG121990-DeveloperCoding: Passiv Go-Impairment go on a low key battery not activated 1
ENG105809-ENG102152-DeveloperCoding: Passiv Go-Passive Go activated 1
ENG105809-ENG99072-DeveloperCoding: Passiv Go-Passive Go: tailgate authorized to start activated 1
ENG123038-ENG104126-DeveloperCoding: Proximity Sensor-AUDI doorknobs mounted not activated 1
ENG123038-ENG102457-DeveloperCoding: Proximity Sensor-Detection of an repeated failed doorknob actuation activated 1
ENG123038-ENG129119-DeveloperCoding: Proximity Sensor-energized_doorhandles_at_stateKL15on_when_opening_door activated 1
ENG123038-ENG102353-DeveloperCoding: Proximity Sensor-No turn off for driver doorknob while passive activated 1
ENG123038-ENG99826-DeveloperCoding: Proximity Sensor-Proximity Sensor: sensor stays active after fault detection not activated 1
ENG123038-ENG102252-DeveloperCoding: Proximity Sensor-Suppress fault manager entry "Falschverbau aktiv" activated 1
ENG123036-ENG102436-DeveloperCoding: Search lights-Standardisation of ZAT activated 1
ENG123036-ENG99363-DeveloperCoding: Search lights-ZAT active during clamp 58t on activated 1
ENG123036-ENG120038-DeveloperCoding: Search lights-ZAT detecting open load not activated 1
ENG123036-ENG154826-DeveloperCoding: Search lights-ZAT_illumination_concept_mybeat_clamp58xt not activated 1
ENG123036-ENG154827-DeveloperCoding: Search lights-ZAT_illumination_modus_mybeat_clamp58xt not activated 1
ENG123037-ENG98487-DeveloperCoding: vehicle environment-Convertible not activated 1
ENG123037-ENG100924-DeveloperCoding: vehicle environment-Pre Catch for Trunk not activated 1
ENG123037-ENG129114-DeveloperCoding: vehicle environment-reactivate_all_doorhandles not activated 1
ENG123037-ENG103200-DeveloperCoding: vehicle environment-Steering wheel right-hand drive 1
ENG105825-Diagnostic: wait time after power on 500 ms 1
ENG126943-Display_duration_emergency_off 3000 ms 1
ENG126944-Display_duration_error_mode_2_SPN 10 s 1
ENG126941-Display_duration_please_engage_P 10 s 1
ENG105898-Doorknob contact sensor disconnecting time 5400 min 1
ENG244875-duration_A-CAN_wake_up_for_Engine_ECU_wake_up 2000 ms 1
ENG126955-duration_to_ZAT_continuous_actuation_detection 1000 ms 1
ENG129005-duration_to_ZAT_multi_actuation_detection 3000 ms 1
ENG126950-duration_ZAT_debounce 50 ms 1
ENG129029-ENG142128-Easy_close_alignment-max_threashold_reopen_EasyClose 10% 9
ENG129029-ENG142127-Easy_close_alignment-Max_time_IDGeber_rear 2.00 s 9
ENG129029-ENG142129-Easy_close_alignment-max_time_reentry_EasyClose 7.00 s 9
ENG129029-ENG142130-Easy_close_alignment-min_rssi_values_hysteresis_EasyClose 150 9
ENG129029-ENG142126-Easy_close_alignment-Min_threashold_trunk 50% 9
ENG129029-ENG129138-Easy_close_alignment-RSSI_ sample_rate 500 ms 9
ENG129029-ENG129139-Easy_close_alignment-Timeframe_scan_active 20.00 s 9
ENG129028-ENG142124-Easy_close_detection_areas-Easy_close_antenna_current_step 5 5
ENG129028-ENG142125-Easy_close_detection_areas-Easy_close_open_door_antenna_current_step 3 5
ENG129028-ENG142032-Easy_close_detection_areas-Value_area_4 220 mV/m 5
ENG129028-ENG142033-Easy_close_detection_areas-Value_area_leaving_area 40 mV/m 5
ENG126966-environment_scan_cyclic_step1 700 ms 1
ENG126967-environment_scan_cyclic_step2 2000 ms 1
ENG126965-environment_scan_duration_step1 300 min 1
ENG126971-environment_scan_duration_step2 24 H 1
ENG126969-environment_scan_level_bem 2 1
ENG126968-environment_scan_responselevel_reduction 500 1
ENG126970-environment_scan_startdelay_time 5 s 1
ENG126958-Ignition_For_Immobilizer Default 1
ENG129016-Initialization_diagnostics_switching_terminal not activated 4
ENG107050-Interior scan: deceleration after comfort closing 3200 ms 1
ENG107051-Interior scan: max. engine speed for standing engine 10 km/h 1
ENG107052-Interior scan: opening threshold sliding roof 1% 1
ENG107053-Interior scan: opening threshold window lifter 5.00% 1
ENG107054-Interior scan: Speed - threshold 20 km/h 1
ENG153724-Interior_scans_clamp15_break_at_active_message 5000 ms 1
ENG153725-Interior_scans_clamp15_retry_at_active_message 5 1
ENG98656-internal 0 B 1
ENG129022-ENG142120-internal_keyminder_byte1-aktivate_function_trigger_access_leaving_elv not activated 1
ENG129022-ENG129115-internal_keyminder_byte1-allowa_remotestart_to_disable_keys not activated 1
ENG129022-ENG120037-internal_keyminder_byte1-Cyclic interior scan during active warning message "Key not found" not activated 1
ENG129022-ENG100928-internal_keyminder_byte1-Seat Memory: scan after driver door opening activated 1
ENG129022-ENG99649-internal_keyminder_byte1-Seat Memory: scan after driver door opening no KESSY unlocking activated 1
ENG129022-ENG99417-internal_keyminder_byte1-Softtouch mounted installed 1
ENG129023-ENG99123-internal_keyminder_byte2-Inhibit ID-transmitter for passive go activated 1
ENG129023-ENG102581-internal_keyminder_byte2-Lock prevention tailgate activated 1
ENG129023-ENG101018-internal_keyminder_byte2-No locking with ID-transmitter last used interior activated 1
ENG129023-ENG103451-internal_keyminder_byte2-Re-open after passive comfort closing activated 1
ENG129023-ENG99711-internal_keyminder_byte2-Re-open last handling not activated 1
ENG129023-ENG103237-internal_keyminder_byte2-Re-open tailgate activated 1
ENG129020-ENG121989-internal_passive_entry_exit_byte1-Impairment Entry / Exit key on low battery not activated 1
ENG129020-ENG125240-internal_passive_entry_exit_byte1-lf_crc not activated 1
ENG129020-ENG99763-internal_passive_entry_exit_byte1-Passive Exit: access door not open activated 1
ENG129020-ENG103722-internal_passive_entry_exit_byte1-Passive Exit: all doors not open not activated 1
ENG129020-ENG126975-internal_passive_entry_exit_byte1-passive_exit_door_slam_lock not activated 1
ENG129021-ENG155267-internal_passive_entry_exit_byte2-lf_shutdown activated 1
ENG129021-ENG155268-internal_passive_entry_exit_byte2-lf_shutdown_gotrigger not activated 1
ENG129021-ENG100246-internal_passive_entry_exit_byte2-Passive Entry bei Tuer verriegelt/gesafed ODER ZV ist gesafed activated 1
ENG129021-ENG123039-internal_passive_entry_exit_byte2-Passive Entry Exit activated 1
ENG129021-ENG103289-internal_passive_entry_exit_byte2-Passive Entry Exit: control by pulling door handle during active DSL activated 1
ENG129021-ENG103620-internal_passive_entry_exit_byte2-Passive Entry Exit: retry with antennastep 1 not activated 1
ENG129021-ENG103529-internal_passive_entry_exit_byte2-Passive Entry: second control concept not activated 1
ENG107211-Key Minder: delay reunlocking tailgate 500 ms 1
ENG107212-Key Minder: p_keyless_eventsearch_holding_time 10 s 1
ENG107213-Key Minder: p_keyless_eventsearch_retries 2 1
ENG107363-LED dimming curve first point 20 percent dimming 40.00% 1
ENG153886-lf_shutdown_timeout_2nd_operation 5 s 1
ENG107592-MCTX Pause 1 B 1
ENG107593-MCTX pause for Go / Key Minder 20 ms 1
ENG107594-MCTX pause for Go authentification 7 B 1
ENG107595-MCTX settling phase 7 B 1
ENG129013-min_receptiontime_vit 0 ms 1
ENG126945-min_time_for_Terminal_50_request 200 ms 1
ENG129003-Number_of_Multiple_ZAT_activations_to_emergency_shutoff 2 1
ENG126940-Number_of_ZAT_activations_to_DTC 10 1
ENG129015-Passive Entry Exit: control by pulling the door handle during active DSL_timeout 2.00 s 1
ENG108166-Passive Entry Exit: entry request e-sliding door active time 500 ms 1
ENG108167-Passive Entry Exit: minimum activity time locking sensor 140 ms 1
ENG108168-Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY 220 ms 1
ENG108169-Passive Entry Exit: T_ACT_OP_2 5000 ms 1
ENG108297-Proximity Sensor: Comfort Exit-Enlargement 200 ms 1
ENG108298-Proximity Sensor: duration of proximity Signal 10 s 1
ENG108299-Proximity Sensor: lower limit Impuls 2000 µs 1
ENG108300-Proximity Sensor: lower limit proximity-Impuls 12200 µs 1
ENG108301-Proximity Sensor: max Vehiclespeed for a standing vehicle 10.0 km/h 1
ENG108302-Proximity Sensor: max. Impulslength 75 ms 1
ENG108303-Proximity Sensor: max. Impulslength of proximity-Impuls 20400 µs 1
ENG108304-Proximity Sensor: max. intermission-length Diagnostic 14 ms 1
ENG108305-Proximity Sensor: max. length of Diagnosticimpuls 71 ms 1
ENG108306-Proximity Sensor: max. length of Entryimpuls 10400 µs 1
ENG108307-Proximity Sensor: max. length of Exitimpuls 40400 µs 1
ENG108308-Proximity sensor: max. length of signal hall sensor 100 s 1
ENG108309-Proximity Sensor: max. signal-length 120 s 1
ENG108310-Proximity sensor: max. tolerance data bit length 200 µs 1
ENG108311-Proximity Sensor: min Vehiclespeed for a driving vehicle 20.0 km/h 1
ENG108312-Proximity Sensor: min. enginespeed for a running engine 300 /min 1
ENG108313-Proximity Sensor: min. length of Diagnosticimpuls 42 ms 1
ENG108314-Proximity Sensor: min. length of Entryimpuls 6200 µs 1
ENG108315-Proximity Sensor: min. length of Exitimpuls 24200 µs 1
ENG108316-Proximity sensor: min. tolerance data bit length 120 µs 1
ENG108317-Proximity Sensor: SP_X2 10 min 1
ENG108318-Proximity Sensor: SP_X3 1 1
ENG108319-Proximity Sensor: SP_X4 80 1
ENG108320-Proximity Sensor: SP_X5 1 1
ENG108321-Proximity Sensor: SP_X6 30 min 1
ENG108322-Proximity Sensor: SP_X7 1 1
ENG108323-Proximity Sensor: Time Power On 1960 ms 1
ENG123035-Proximity Sensor: Timervalue for ExitReverseOption 0 ms 1
ENG108325-Proximity sensor: turn-off limit from battery-manager 2 1
ENG108326-Proximity Sensor: upper limit intermission-length 10 ms 1
ENG153707-IDE00047-Rear_lid_power_opening_control_unit_data_set_upload-Parameter set version 0 37
ENG153707-IDE80001-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 1 1 37
ENG153707-IDE80002-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 2 1 37
ENG153707-IDE80003-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 3 0 37
ENG153707-IDE80004-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 4 1 37
ENG153707-IDE80005-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 5 16 37
ENG153707-IDE80006-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 6 16 37
ENG153707-IDE80007-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 7 16 37
ENG153707-IDE80008-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 8 16 37
ENG153707-IDE80009-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 9 2 37
ENG153707-IDE80010-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 10 31 37
ENG153707-IDE80011-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 11 2 37
ENG153707-IDE80012-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 12 31 37
ENG153707-IDE80013-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 13 224 37
ENG153707-IDE80014-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 14 10 37
ENG153707-IDE80015-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 15 10 37
ENG153707-IDE80016-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 16 0 37
ENG153707-IDE80017-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 17 0 37
ENG153707-IDE80018-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 18 9 37
ENG153707-IDE80019-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 19 0 37
ENG153707-IDE80020-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 20 not active 37
ENG153707-IDE80021-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 21 active 37
ENG153707-IDE80022-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 22 not active 37
ENG153707-IDE80023-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 23 Bottom 37
ENG153707-IDE80024-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 24 Dynamic 37
ENG153707-IDE80025-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 25 3 37
ENG153707-IDE80026-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 26 not active 37
ENG153707-IDE80027-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 27 Dynamic 37
ENG153707-IDE80028-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 28 5 37
ENG153707-IDE80029-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 29 6 37
ENG153707-IDE80030-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 30 active 37
ENG153707-IDE80031-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 31 19 37
ENG153707-IDE80032-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 32 2 37
ENG153707-IDE80033-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 33 12 37
ENG153707-IDE80034-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 34 4 37
ENG153707-IDE80035-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 35 Do not reset 37
ENG153707-IDE80036-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 36 16 37
ENG153707-IDE80037-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 37 16 37
ENG153707-IDE80038-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 38 16 37
ENG153707-IDE80039-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 39 16 37
ENG153707-IDE80040-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 40 2 37
ENG153707-IDE80041-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 41 31 37
ENG153707-IDE80042-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 42 2 37
ENG153707-IDE80043-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 43 31 37
ENG153707-IDE80044-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 44 224 37
ENG153707-IDE80045-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 45 10 37
ENG153707-IDE80046-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 46 10 37
ENG153707-IDE80047-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 47 0 37
ENG153707-IDE80048-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 48 0 37
ENG153707-IDE80049-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 49 0 37
ENG153707-IDE80050-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 50 0 37
ENG153707-IDE80051-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 51 6 37
ENG153707-IDE80052-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 52 25 37
ENG153707-IDE80053-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 53 255 37
ENG153707-IDE80054-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 54 5 37
ENG153707-IDE80055-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 55 60 37
ENG153707-IDE80056-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 56 37 37
ENG153707-MAS01078-Rear_lid_power_opening_control_unit_data_set_upload-Vehicle type 47 37
ENG153707-MAS14087-Rear_lid_power_opening_control_unit_data_set_upload-time delay activation Activation after 2s 37
ENG120045-Reduced current for transponder-ID request 0 Step 1
ENG126939-rpm_threshold_engine_runnning 100 /min 1
ENG108575-Scan Procedure: current limiting on undervoltage at Go-protocol 5 Step 1
ENG108576-Scan Procedure: cycle convenience coverage limiting 65 ms 1
ENG108577-Scan Procedure: Number of Repeats 1 1
ENG108578-Scan Procedure: p_keyless_eventsuche_retries_pause 100 ms 1
ENG108579-Scan Procedure: Timeout Authentification Result 150 ms 1
ENG129017-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Go 190 ms 1
ENG129018-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Kombi 700 ms 1
ENG108582-Scan Procedure: Timeout LF Repetition 100 ms 1
ENG108585-ScanProcedure: Timeout Entry Response 260 ms 1
ENG108586-ScanProcedure: Timeout Response 100 ms 1
ENG126963-settime_trigger_entry_vehicle 500 ms 1
ENG126962-settime_trigger_exit_vehicle 500 ms 1
ENG129024-ENG120039-Sonstiges_byte1-Backdoor TSG not activated 1
ENG129024-ENG103075-Sonstiges_byte1-Battery manager mounted activated 1
ENG129024-ENG102728-Sonstiges_byte1-Diagnostic: service 86 - response on event not activated 1
ENG129024-ENG98656-Sonstiges_byte1-internal not activated 1
ENG129024-ENG102591-Sonstiges_byte1-Response extension for scan procedure not activated 1
ENG129024-ENG99430-Sonstiges_byte1-Scan Procedure: Timeoutcontrol active activated 1
ENG129024-ENG104010-Sonstiges_byte1-Use default antenna data not activated 1
ENG129025-ENG129137-sonstiges_byte2-interiorscan_clamp15_reach_trashhold not activated 1
ENG129025-ENG142122-sonstiges_byte2-sad_existing not activated 1
ENG129025-ENG142123-sonstiges_byte2-trunk_ecu_existing activated 1
ENG129007-Speed_threshold_for_driving_cycle_detection 3.0 km/h 1
ENG129006-Speed_threshold_for_moving_vehicle_detection 1.0 km/h 1
ENG129008-Speed_threshold_for_terminal_15_emergency_shutoff 7.0 km/h 1
ENG109053-Standard dimming value ZAT 80% 1
ENG126938-Terminal_15_adaption_body_control_module Default 1
ENG126946-Terminal_S_Timeout 30 min 1
ENG102207-Time Sensor Power Off Group 2 3600 min 1
ENG129027-Time_frame_VIP_kick_forecast 5 1
ENG126942-time_to_drive_cycle_detection 1.00 s 1
ENG126947-time_to_ignore_ignition_trigger 35 s 1
ENG126954-time_to_ZAT_Open_circuit_detection 1000 ms 1
ENG126951-time_to_ZAT_Short_circuit_fault_detection 60 s 1
ENG126949-time_ZAT_actuation_detection 3000 ms 1
ENG126952-time_ZAT_lock_after emergency_shutoff 1000 ms 1
ENG126953-time_ZAT_lock_after_normal_shutoff 500 ms 1
ENG129009-Timeframe_request_immobilizer_terminal_approval 10000 ms 1
ENG129019-timeout_convenience_coverage_limiting 75 s 1
ENG129014-Timeout_trigger_terminal_deactivation_central_locking 1.00 s 1
ENG109974-Voltage monitoring: overvoltage Delta 500 mV 1
ENG109975-Voltage monitoring: overvoltage for KESSY ECU 16000 mV 1
ENG109976-Voltage monitoring: overvoltage for Keyless Go 27000 mV 1
ENG109977-Voltage monitoring: overvoltage Jumpstart 2 Delta 0 mV 1
ENG109978-Voltage monitoring: undervoltage Delta 500 mV 1
ENG109979-Voltage monitoring: undervoltage for KESSY ECU 9000 mV 1
ENG109980-Voltage monitoring: undervoltage for Keyless Go 6000 mV 1
ENG109981-Voltage monitoring: undervoltage Jumpstart 1 Delta 0 mV 1
ENG120047-ZAT init value 0% 1
ENG110364-ZAT nominal voltage 13.0 V 1
ENG110365-ZAT post-carridge during clamp 15 off 10 min 1
ENG153750-ZAT_clamp58xt_signal_factor 0.2 1
ENG153751-ZAT_clamp58xt_signal_offset 3 1
ENG153752-ZAT_first_fall_time_high_low_state 900 ms 1
ENG153753-ZAT_first_rise_time_low_high_state 100 ms 1
ENG153754-ZAT_motor_signal_timer_1 3000 ms 1
ENG153755-ZAT_motor_signal_timer_2 3000 ms 1
ENG153756-ZAT_pwm_offset_1_lower_limit 5% 1
ENG153757-ZAT_pwm_offset_2_lower_limit 10% 1
ENG153758-ZAT_pwm_peak1_upper_limit 90% 1
ENG153759-ZAT_pwm_peak2_upper_limit 100% 1
ENG153760-ZAT_second_fall_time_high_low_state 2000 ms 1
Elapsed Time: 00:55
;SW:5NA-035-045-A HW:5NA-035-045 --- Information Electr.
;Component:MU-H-N-RW H54 1161 Coding:028403080000000051510002000808001F0106E601200402DF
;EV_MUHig4CGen2HBAS 1001 EV_MUHig4CGen2HBAS_VW37.rod
;Thursday 22 March 2018 16:36:57:60782
;VCID: 3620D79789AA13F4F2-8062
IDE00346-Summertime-automatic manual 1
IDE00759-Base volume of speech output 50% 1
IDE00760-Microphone sensitivity 0 dB 1
IDE00768-Country identification: country of sale -- 2
IDE00769-Number 1 for Info call 5E 05 A1 81 00 60 90 63 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 23
IDE00770-Number 1 for roadside assistance 5E 05 A1 81 00 06 87 22 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 23
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages OFF 1
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages OFF 1
IDE00845-Wheel circ. 0 mm 2
IDE01996-MAS00076-Installation list: specified installations-Instrument cluster control module Yes 3
IDE01996-MAS00839-Installation list: specified installations-TV Tuner No 3
IDE01996-MAS00844-Installation list: specified installations-Radio No 3
IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control Module Yes 3
IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1 Yes 3
IDE01996-MAS00850-Installation list: specified installations-Information electronics control module 2 No 3
IDE01996-MAS04300-Installation list: specified installations-DVD changer No 3
IDE01996-MAS14306-Installation list: specified installations-Windshield projection head up display control module No 3
IDE01996-SFT271943-Installation list: specified installations-Multimedia Operating Unit No 3
IDE01996-ENG154341-Installation list: specified installations-Reserved_8 No 3
IDE01996-ENG152491-Installation list: specified installations-Smart Control Carrier 1 No 3
IDE01996-ENG152490-Installation list: specified installations-Smart Control Carrier 2 No 3
IDE01996-ENG152488-Installation list: specified installations-Smart Display Carrier 1 No 3
IDE01996-ENG152492-Installation list: specified installations-Smart Display Carrier 2 No 3
IDE01996-ENG152493-Installation list: specified installations-Wireless Charger 1 No 3
IDE01996-ENG152489-Installation list: specified installations-Wireless Charger 2 No 3
IDE02121-CD eject button Enabled 1
IDE02122-Developer mode not activated 1
IDE02330-Number 2 for Info call FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 23
IDE02331-Number 2 for roadside assistance FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 23
IDE02476-MAS03001-Electrical test of loudspeakers-Mode automatic 49
IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency 19000 Hz 49
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume 22 49
IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency 19000 Hz 49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume 22 49
IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency 19000 Hz 49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume 22 49
IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency 19000 Hz 49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume 22 49
IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency 19000 Hz 49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume 22 49
IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency 19000 Hz 49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume 22 49
IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency 19000 Hz 49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume 22 49
IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency 19000 Hz 49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume 22 49
IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency 19000 Hz 49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume 22 49
IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency 19000 Hz 49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume 22 49
IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency 19000 Hz 49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume 22 49
IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency 19000 Hz 49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume 22 49
IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency 19000 Hz 49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume 22 49
IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency 19000 Hz 49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume 22 49
IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency 19000 Hz 49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume 22 49
IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency 19000 Hz 49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume 22 49
IDE02502-Confirmation of installation change 28 94 2
IDE02506-MAS03229-Copy multimedia data-Data medium On 1
IDE02506-MAS03230-Copy multimedia data-Optical drive On 1
IDE02607-Wheel pulse 0 2
IDE02699-Number 1 for roadside assistance 5E 02 A1 00 F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 23
IDE02701-Number 1 (roaming) for roadside assistance 5E 02 A1 00 F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 23
IDE03471-ENG117847-Vehicle configuration-advanced_range_display OFF 30
IDE03471-ENG142146-Vehicle configuration-allow_message_editing On 30
IDE03471-ENG130249-Vehicle configuration-Apple_DIO On 30
IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless OFF 30
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life OFF 30
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios OFF 30
IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless OFF 30
IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless OFF 30
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb blocked 30
IDE03471-ENG142151-Vehicle configuration-conditioning_variant 0 30
IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call On 30
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support OFF 30
IDE03471-ENG185778-Vehicle configuration-FoD SWaP 30
IDE03471-ENG130248-Vehicle configuration-Google_GAL On 30
IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless OFF 30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts On 30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other On 30
IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts OFF 30
IDE03471-ENG117849-Vehicle configuration-gracenote_online_other OFF 30
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data not activated 30
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender Deactivated 30
IDE03471-ENG125049-Vehicle configuration-Joker_button_1 Not Present 30
IDE03471-ENG125050-Vehicle configuration-Joker_button_2 Not Present 30
IDE03471-ENG127492-Vehicle configuration-LGI OFF 30
IDE03471-ENG130246-Vehicle configuration-LTE_modul Deactivated 30
IDE03471-ENG142142-Vehicle configuration-map_email_support OFF 30
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support OFF 30
IDE03471-ENG142141-Vehicle configuration-map_sms_support On 30
IDE03471-ENG142152-Vehicle configuration-Map_Style 1 30
IDE03471-ENG152537-Vehicle configuration-media_control not activated 30
IDE03471-ENG138662-Vehicle configuration-Mirror_link On 30
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code MIB_AUS 30
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference RGB888 30
IDE03471-ENG117843-Vehicle configuration-my_audi OFF 30
IDE03471-ENG117845-Vehicle configuration-online_dictation OFF 30
IDE03471-ENG127495-Vehicle configuration-online_media OFF 30
IDE03471-ENG117840-Vehicle configuration-online_navigation OFF 30
IDE03471-ENG117837-Vehicle configuration-online_POI OFF 30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice OFF 30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services OFF 30
IDE03471-ENG152553-Vehicle configuration-online_radio Deactivated 30
IDE03471-ENG117841-Vehicle configuration-online_street_view OFF 30
IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit OFF 30
IDE03471-ENG167521-Vehicle configuration-perso_v_threshold 0 30
IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis 0 30
IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy 0 30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode only data service act. 30
IDE03471-ENG117844-Vehicle configuration-picture_navi On 30
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking not activated 30
IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use not activated 30
IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest 0 30
IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi OFF 30
IDE03471-ENG137646-Vehicle configuration-ProbeCar_vzo OFF 30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version PSD_1.5 30
IDE03471-ENG117846-Vehicle configuration-remote_HMI OFF 30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component activated 30
IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open not activated 30
IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold not activated 30
IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe not activated 30
IDE03471-ENG126143-Vehicle configuration-RVC_video_input FBAS 30
IDE03471-ENG152556-Vehicle configuration-scon_telephony not activated 30
IDE03471-ENG142081-Vehicle configuration-sd_slot_deactivation no restriction 30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag REGION_ROW_AUSTRALIA 30
IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch not activated 30
IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch present 30
IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support On 30
IDE03471-ENG138663-Vehicle configuration-Smartphone_interface_for_rhmi activated 30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode 0 30
IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold OFF 30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling OFF 30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone On 30
IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location OFF 30
IDE03471-ENG126994-Vehicle configuration-TPEG_availability OFF 30
IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving blocked 30
IDE03471-ENG137647-Vehicle configuration-UOTA OFF 30
IDE03471-ENG167532-Vehicle configuration-UOTA_2 OFF 30
IDE03471-ENG117852-Vehicle configuration-UPnP On 30
IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound not activated 30
IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound not activated 30
IDE03471-ENG152558-Vehicle configuration-voice_over_lte not activated 30
IDE03471-ENG117836-Vehicle configuration-VZAPro OFF 30
IDE03471-ENG127494-Vehicle configuration-VZO OFF 30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI On 30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot On 30
IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch not activated 30
IDE03902-Automatic ring break diagnostic No automatic start 1
IDE04295-Bluetooth: Preferred connection profile for phone book data PBAP 1
IDE04298-MAS01779-Vehicle dimensions-Length 0 mm 6
IDE04298-MAS01780-Vehicle dimensions-Width 0 mm 6
IDE04298-MAS02230-Vehicle dimensions-Height 0 mm 6
IDE04331-Selection of release codes for a SWaP function FF FF FF FF 4
IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code 2 2
IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code 4 2
IDE04521-Sporadic ring break detection Visual 1
IDE04522-Awakening ability on optical databus OFF 1
IDE04550-Bluetooth: Sniff mode OFF 1
IDE05111-Fee-based traffic information (TMC) 1024 2
IDE05113-Infotainment Recorder activated 1
IDE06697-Audio management mute function Muting of audio sources 1
IDE07399-ENG142045-Engine type-Engine_type_adaption_1 Petrol 1
IDE07399-ENG142046-Engine type-Engine_type_adaption_2 Petrol 1
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass On 1
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default On 1
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS On 1
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo On 1
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass On 1
IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1 OFF 1
IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2 OFF 1
IDE10082-MAS09813-Telephone functions configuration-Entering Access Point Name On 1
IDE10082-MAS09814-Telephone functions configuration-Call Center Function On 1
IDE10082-MAS13846-Telephone functions configuration-Internet access via WiFi Available 1
IDE10082-MAS13847-Telephone functions configuration-Call center function on MIB: roadside assistance call On 1
IDE10082-MAS13848-Telephone functions configuration-Call center function on MIB: POI call On 1
IDE10082-MAS16726-Telephone functions configuration-Call center function on MIB: POI call regions OFF 1
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner -128 40
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio 5 40
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM) -128 40
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM) -128 40
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB) -128 40
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB -128 40
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP -128 40
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay -128 40
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter -128 40
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN -128 40
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray -128 40
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice -128 40
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA -128 40
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud -128 40
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD -128 40
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI -128 40
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP -128 40
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP -128 40
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink -128 40
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP -128 40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB -3 40
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice -128 40
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM -128 40
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep -128 40
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging -128 40
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen 6 40
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning -128 40
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav -128 40
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS -128 40
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online -128 40
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal -128 40
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI -128 40
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN -128 40
IDE10480-MAS10741-Interface for external media: activation-Connection 1 activated 4
IDE10480-MAS10742-Interface for external media: activation-Connection 2 activated 4
IDE10480-MAS10743-Interface for external media: activation-Connection 3 not activated 4
IDE10480-MAS10744-Interface for external media: activation-Connection 4 not activated 4
IDE10604-Menu entries for mobile online services not activated 1
IDE11104-ENG127502-FM tuner: mono/stereo setting-l_hf_stereo_lower_threshold 37 dBµV 3
IDE11104-ENG127503-FM tuner: mono/stereo setting-l_nf_max_stereo_channel_separation 32 dB 3
IDE11104-ENG127504-FM tuner: mono/stereo setting-t_hysteresis_mono_to_stereo 15.0 s 3
IDE11105-Brand-specific display of connect application 256
IDE11122-Country identification: country of sale HMI AU 2
IDE11153-ENG152487-Surroundings display: virtual camera positions-focallength 4294967295 330
IDE11153-ENG152457-Surroundings display: virtual camera positions-Pitchangle 65535 330
IDE11153-ENG152445-Surroundings display: virtual camera positions-Rollangle 65535 330
IDE11153-ENG147432-Surroundings display: virtual camera positions-xpos 32767 330
IDE11153-ENG152451-Surroundings display: virtual camera positions-Yawangle 65535 330
IDE11153-ENG147433-Surroundings display: virtual camera positions-ypos 32767 330
IDE11153-ENG147434-Surroundings display: virtual camera positions-zpos 32767 330
IDE11502-ENG127601-Locked menu contents-FB_CAR_0 non_blocked 21
IDE11502-ENG127602-Locked menu contents-FB_CAR_1 non_blocked 21
IDE11502-ENG127611-Locked menu contents-FB_CAR_10 non_blocked 21
IDE11502-ENG127612-Locked menu contents-FB_CAR_11 non_blocked 21
IDE11502-ENG127613-Locked menu contents-FB_CAR_12 non_blocked 21
IDE11502-ENG127614-Locked menu contents-FB_CAR_13 non_blocked 21
IDE11502-ENG127615-Locked menu contents-FB_CAR_14 non_blocked 21
IDE11502-ENG127616-Locked menu contents-FB_CAR_15 non_blocked 21
IDE11502-ENG127617-Locked menu contents-FB_CAR_16 non_blocked 21
IDE11502-ENG127618-Locked menu contents-FB_CAR_17 non_blocked 21
IDE11502-ENG127619-Locked menu contents-FB_CAR_18 non_blocked 21
IDE11502-ENG127620-Locked menu contents-FB_CAR_19 non_blocked 21
IDE11502-ENG127603-Locked menu contents-FB_CAR_2 non_blocked 21
IDE11502-ENG127621-Locked menu contents-FB_CAR_20 non_blocked 21
IDE11502-ENG127622-Locked menu contents-FB_CAR_21 non_blocked 21
IDE11502-ENG127623-Locked menu contents-FB_CAR_22 non_blocked 21
IDE11502-ENG127624-Locked menu contents-FB_CAR_23 non_blocked 21
IDE11502-ENG127604-Locked menu contents-FB_CAR_3 non_blocked 21
IDE11502-ENG127605-Locked menu contents-FB_CAR_4 non_blocked 21
IDE11502-ENG127606-Locked menu contents-FB_CAR_5 non_blocked 21
IDE11502-ENG127607-Locked menu contents-FB_CAR_6 non_blocked 21
IDE11502-ENG127608-Locked menu contents-FB_CAR_7 non_blocked 21
IDE11502-ENG127609-Locked menu contents-FB_CAR_8 non_blocked 21
IDE11502-ENG127610-Locked menu contents-FB_CAR_9 non_blocked 21
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0 non_blocked 21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1 non_blocked 21
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10 non_blocked 21
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11 non_blocked 21
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12 non_blocked 21
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13 non_blocked 21
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14 non_blocked 21
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15 non_blocked 21
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16 non_blocked 21
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17 non_blocked 21
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18 non_blocked 21
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19 non_blocked 21
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2 non_blocked 21
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20 non_blocked 21
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21 non_blocked 21
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22 non_blocked 21
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23 non_blocked 21
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3 non_blocked 21
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4 non_blocked 21
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5 non_blocked 21
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6 non_blocked 21
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7 non_blocked 21
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8 non_blocked 21
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9 non_blocked 21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0 non_blocked 21
IDE11502-ENG127626-Locked menu contents-FB_MISC_1 non_blocked 21
IDE11502-ENG127635-Locked menu contents-FB_MISC_10 non_blocked 21
IDE11502-ENG127636-Locked menu contents-FB_MISC_11 non_blocked 21
IDE11502-ENG127637-Locked menu contents-FB_MISC_12 non_blocked 21
IDE11502-ENG127638-Locked menu contents-FB_MISC_13 non_blocked 21
IDE11502-ENG127639-Locked menu contents-FB_MISC_14 non_blocked 21
IDE11502-ENG127640-Locked menu contents-FB_MISC_15 non_blocked 21
IDE11502-ENG127641-Locked menu contents-FB_MISC_16 non_blocked 21
IDE11502-ENG127642-Locked menu contents-FB_MISC_17 non_blocked 21
IDE11502-ENG127643-Locked menu contents-FB_MISC_18 non_blocked 21
IDE11502-ENG127644-Locked menu contents-FB_MISC_19 non_blocked 21
IDE11502-ENG127627-Locked menu contents-FB_MISC_2 non_blocked 21
IDE11502-ENG127645-Locked menu contents-FB_MISC_20 non_blocked 21
IDE11502-ENG127646-Locked menu contents-FB_MISC_21 non_blocked 21
IDE11502-ENG127647-Locked menu contents-FB_MISC_22 non_blocked 21
IDE11502-ENG127648-Locked menu contents-FB_MISC_23 non_blocked 21
IDE11502-ENG127649-Locked menu contents-FB_MISC_24 non_blocked 21
IDE11502-ENG127650-Locked menu contents-FB_MISC_25 non_blocked 21
IDE11502-ENG127651-Locked menu contents-FB_MISC_26 non_blocked 21
IDE11502-ENG127652-Locked menu contents-FB_MISC_27 non_blocked 21
IDE11502-ENG127653-Locked menu contents-FB_MISC_28 non_blocked 21
IDE11502-ENG127654-Locked menu contents-FB_MISC_29 non_blocked 21
IDE11502-ENG127628-Locked menu contents-FB_MISC_3 non_blocked 21
IDE11502-ENG127655-Locked menu contents-FB_MISC_30 non_blocked 21
IDE11502-ENG127656-Locked menu contents-FB_MISC_31 non_blocked 21
IDE11502-ENG127657-Locked menu contents-FB_MISC_32 non_blocked 21
IDE11502-ENG127658-Locked menu contents-FB_MISC_33 non_blocked 21
IDE11502-ENG127659-Locked menu contents-FB_MISC_34 non_blocked 21
IDE11502-ENG127660-Locked menu contents-FB_MISC_35 non_blocked 21
IDE11502-ENG127661-Locked menu contents-FB_MISC_36 non_blocked 21
IDE11502-ENG127662-Locked menu contents-FB_MISC_37 non_blocked 21
IDE11502-ENG127663-Locked menu contents-FB_MISC_38 non_blocked 21
IDE11502-ENG127664-Locked menu contents-FB_MISC_39 non_blocked 21
IDE11502-ENG127629-Locked menu contents-FB_MISC_4 non_blocked 21
IDE11502-ENG127665-Locked menu contents-FB_MISC_40 non_blocked 21
IDE11502-ENG127666-Locked menu contents-FB_MISC_41 non_blocked 21
IDE11502-ENG127667-Locked menu contents-FB_MISC_42 non_blocked 21
IDE11502-ENG127668-Locked menu contents-FB_MISC_43 non_blocked 21
IDE11502-ENG127669-Locked menu contents-FB_MISC_44 non_blocked 21
IDE11502-ENG127670-Locked menu contents-FB_MISC_45 non_blocked 21
IDE11502-ENG127671-Locked menu contents-FB_MISC_46 non_blocked 21
IDE11502-ENG127672-Locked menu contents-FB_MISC_47 non_blocked 21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5 non_blocked 21
IDE11502-ENG127631-Locked menu contents-FB_MISC_6 non_blocked 21
IDE11502-ENG127632-Locked menu contents-FB_MISC_7 non_blocked 21
IDE11502-ENG127633-Locked menu contents-FB_MISC_8 non_blocked 21
IDE11502-ENG127634-Locked menu contents-FB_MISC_9 non_blocked 21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0 non_blocked 21
IDE11502-ENG127562-Locked menu contents-FB_NAV_1 non_blocked 21
IDE11502-ENG127571-Locked menu contents-FB_NAV_10 non_blocked 21
IDE11502-ENG127572-Locked menu contents-FB_NAV_11 non_blocked 21
IDE11502-ENG127573-Locked menu contents-FB_NAV_12 non_blocked 21
IDE11502-ENG127574-Locked menu contents-FB_NAV_13 non_blocked 21
IDE11502-ENG127575-Locked menu contents-FB_NAV_14 non_blocked 21
IDE11502-ENG127576-Locked menu contents-FB_NAV_15 non_blocked 21
IDE11502-ENG127577-Locked menu contents-FB_NAV_16 non_blocked 21
IDE11502-ENG127578-Locked menu contents-FB_NAV_17 non_blocked 21
IDE11502-ENG127579-Locked menu contents-FB_NAV_18 non_blocked 21
IDE11502-ENG127580-Locked menu contents-FB_NAV_19 non_blocked 21
IDE11502-ENG127563-Locked menu contents-FB_NAV_2 non_blocked 21
IDE11502-ENG127581-Locked menu contents-FB_NAV_20 non_blocked 21
IDE11502-ENG127582-Locked menu contents-FB_NAV_21 non_blocked 21
IDE11502-ENG127583-Locked menu contents-FB_NAV_22 non_blocked 21
IDE11502-ENG127584-Locked menu contents-FB_NAV_23 non_blocked 21
IDE11502-ENG127585-Locked menu contents-FB_NAV_24 non_blocked 21
IDE11502-ENG127586-Locked menu contents-FB_NAV_25 non_blocked 21
IDE11502-ENG127587-Locked menu contents-FB_NAV_26 non_blocked 21
IDE11502-ENG127588-Locked menu contents-FB_NAV_27 non_blocked 21
IDE11502-ENG127589-Locked menu contents-FB_NAV_28 non_blocked 21
IDE11502-ENG127590-Locked menu contents-FB_NAV_29 non_blocked 21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3 non_blocked 21
IDE11502-ENG127591-Locked menu contents-FB_NAV_30 non_blocked 21
IDE11502-ENG127592-Locked menu contents-FB_NAV_31 non_blocked 21
IDE11502-ENG127593-Locked menu contents-FB_NAV_32 non_blocked 21
IDE11502-ENG127594-Locked menu contents-FB_NAV_33 non_blocked 21
IDE11502-ENG127595-Locked menu contents-FB_NAV_34 non_blocked 21
IDE11502-ENG127596-Locked menu contents-FB_NAV_35 non_blocked 21
IDE11502-ENG127597-Locked menu contents-FB_NAV_36 non_blocked 21
IDE11502-ENG127598-Locked menu contents-FB_NAV_37 non_blocked 21
IDE11502-ENG127599-Locked menu contents-FB_NAV_38 non_blocked 21
IDE11502-ENG127600-Locked menu contents-FB_NAV_39 non_blocked 21
IDE11502-ENG127565-Locked menu contents-FB_NAV_4 non_blocked 21
IDE11502-ENG127566-Locked menu contents-FB_NAV_5 non_blocked 21
IDE11502-ENG127567-Locked menu contents-FB_NAV_6 non_blocked 21
IDE11502-ENG127568-Locked menu contents-FB_NAV_7 non_blocked 21
IDE11502-ENG127569-Locked menu contents-FB_NAV_8 non_blocked 21
IDE11502-ENG127570-Locked menu contents-FB_NAV_9 non_blocked 21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0 non_blocked 21
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1 non_blocked 21
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10 non_blocked 21
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11 non_blocked 21
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12 non_blocked 21
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13 non_blocked 21
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14 non_blocked 21
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15 non_blocked 21
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2 non_blocked 21
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3 non_blocked 21
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4 non_blocked 21
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5 non_blocked 21
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6 non_blocked 21
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7 non_blocked 21
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8 non_blocked 21
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9 non_blocked 21
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0 non_blocked 21
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1 non_blocked 21
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10 non_blocked 21
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11 non_blocked 21
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12 non_blocked 21
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13 non_blocked 21
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14 non_blocked 21
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15 non_blocked 21
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2 non_blocked 21
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3 non_blocked 21
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4 non_blocked 21
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5 non_blocked 21
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6 non_blocked 21
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7 non_blocked 21
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8 non_blocked 21
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9 non_blocked 21
IDE11524-ENG142156-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42 not activated 192
IDE11524-ENG142157-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42_msg_bus not activated 192
IDE11524-ENG142158-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47 not activated 192
IDE11524-ENG142159-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47_msg_bus not activated 192
IDE11524-ENG152529-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51 not activated 192
IDE11524-ENG152530-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51_msg_bus not activated 192
IDE11524-ENG137043-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45 not activated 192
IDE11524-ENG137044-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45_msg_bus not activated 192
IDE11524-ENG185772-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D not activated 192
IDE11524-ENG185773-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D_msg_bus not activated 192
IDE11524-ENG142168-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D not activated 192
IDE11524-ENG142169-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D_msg_bus not activated 192
IDE11524-ENG142154-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41 not activated 192
IDE11524-ENG142155-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41_msg_bus not activated 192
IDE11524-ENG152535-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50 not activated 192
IDE11524-ENG152536-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50_msg_bus not activated 192
IDE11524-ENG185787-Vehicle function list BAP 2nd generation: expansion-mascot_0x83 not activated 192
IDE11524-ENG185788-Vehicle function list BAP 2nd generation: expansion-mascot_0x83_msg_bus not activated 192
IDE11524-ENG152569-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E not activated 192
IDE11524-ENG152570-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E_msg_bus not activated 192
IDE11524-ENG139202-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44 not activated 192
IDE11524-ENG139203-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44_msg_bus not activated 192
IDE11524-ENG127678-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40 not activated 192
IDE11524-ENG127679-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40_msg_bus not activated 192
IDE11524-ENG142162-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A not activated 192
IDE11524-ENG142163-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A_msg_bus not activated 192
IDE11524-ENG142164-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B not activated 192
IDE11524-ENG142165-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B_msg_bus not activated 192
IDE11524-ENG142166-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C not activated 192
IDE11524-ENG142167-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C_msg_bus not activated 192
IDE11524-ENG185817-Vehicle function list BAP 2nd generation: expansion-vas_0x54 not activated 192
IDE11524-ENG185818-Vehicle function list BAP 2nd generation: expansion-vas_0x54_msg_bus not activated 192
IDE11524-ENG142160-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48 not activated 192
IDE11524-ENG142161-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48_msg_bus not activated 192
IDE11638-Bluetooth Audio Codec FF 1
IDE12353-Configuration of traffic light online functions On 1
IDE12434-ENG152495-Vehicle menu operation: second generation: extension-menu_connection_manager not activated 60
IDE12434-ENG152499-Vehicle menu operation: second generation: extension-menu_connection_manager_after_disclaimer not activated 60
IDE12434-ENG152496-Vehicle menu operation: second generation: extension-menu_connection_manager_clamp_15_off not activated 60
IDE12434-ENG152497-Vehicle menu operation: second generation: extension-menu_connection_manager_over_threshold_high not activated 60
IDE12434-ENG152498-Vehicle menu operation: second generation: extension-menu_connection_manager_standstill not activated 60
IDE12434-ENG152548-Vehicle menu operation: second generation: extension-menu_daf_profile not activated 60
IDE12434-ENG152549-Vehicle menu operation: second generation: extension-menu_daf_profile_after_disclaimer not activated 60
IDE12434-ENG152550-Vehicle menu operation: second generation: extension-menu_daf_profile_clamp_15_off not activated 60
IDE12434-ENG152551-Vehicle menu operation: second generation: extension-menu_daf_profile_over_threshold_high not activated 60
IDE12434-ENG152552-Vehicle menu operation: second generation: extension-menu_daf_profile_stillstand not activated 60
IDE12434-ENG185793-Vehicle menu operation: second generation: extension-menu_engine_functions not activated 60
IDE12434-ENG185794-Vehicle menu operation: second generation: extension-menu_engine_functions_after_disclaimer not activated 60
IDE12434-ENG185795-Vehicle menu operation: second generation: extension-menu_engine_functions_clamp_15_off not activated 60
IDE12434-ENG185796-Vehicle menu operation: second generation: extension-menu_engine_functions_over_threshold_high not activated 60
IDE12434-ENG185797-Vehicle menu operation: second generation: extension-menu_engine_functions_stillstand not activated 60
IDE12434-ENG152515-Vehicle menu operation: second generation: extension-menu_fas_profile not activated 60
IDE12434-ENG152519-Vehicle menu operation: second generation: extension-menu_fas_profile_after_disclaimer not activated 60
IDE12434-ENG152516-Vehicle menu operation: second generation: extension-menu_fas_profile_clamp_15_off not activated 60
IDE12434-ENG152517-Vehicle menu operation: second generation: extension-menu_fas_profile_over_threshold_high not activated 60
IDE12434-ENG152518-Vehicle menu operation: second generation: extension-menu_fas_profile_standstill not activated 60
IDE12434-ENG185798-Vehicle menu operation: second generation: extension-menu_fod not activated 60
IDE12434-ENG185799-Vehicle menu operation: second generation: extension-menu_fod_after_disclaimer not activated 60
IDE12434-ENG185800-Vehicle menu operation: second generation: extension-menu_fod_clamp_15_off not activated 60
IDE12434-ENG185801-Vehicle menu operation: second generation: extension-menu_fod_over_threshold_high not activated 60
IDE12434-ENG185802-Vehicle menu operation: second generation: extension-menu_fod_stillstand not activated 60
IDE12434-ENG184478-Vehicle menu operation: second generation: extension-menu_mascot not activated 60
IDE12434-ENG184479-Vehicle menu operation: second generation: extension-menu_mascot_after_disclaimer not activated 60
IDE12434-ENG184480-Vehicle menu operation: second generation: extension-menu_mascot_clamp_15_off not activated 60
IDE12434-ENG184481-Vehicle menu operation: second generation: extension-menu_mascot_over_threshold_high not activated 60
IDE12434-ENG184482-Vehicle menu operation: second generation: extension-menu_mascot_stillstand not activated 60
IDE12434-ENG152562-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile not activated 60
IDE12434-ENG152563-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_after_disclaimer not activated 60
IDE12434-ENG152564-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_clamp_15_off not activated 60
IDE12434-ENG152565-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_over_threshold_high not activated 60
IDE12434-ENG152566-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_stillstand not activated 60
IDE12434-ENG152505-Vehicle menu operation: second generation: extension-menu_statistic not activated 60
IDE12434-ENG152509-Vehicle menu operation: second generation: extension-menu_statistic_after_disclaimer not activated 60
IDE12434-ENG152506-Vehicle menu operation: second generation: extension-menu_statistic_clamp_15_off not activated 60
IDE12434-ENG152507-Vehicle menu operation: second generation: extension-menu_statistic_over_threshold_high not activated 60
IDE12434-ENG152508-Vehicle menu operation: second generation: extension-menu_statistic_standstill not activated 60
IDE12434-ENG152510-Vehicle menu operation: second generation: extension-menu_sunroof not activated 60
IDE12434-ENG152514-Vehicle menu operation: second generation: extension-menu_sunroof_after_disclaimer not activated 60
IDE12434-ENG152511-Vehicle menu operation: second generation: extension-menu_sunroof_clamp_15_off not activated 60
IDE12434-ENG152512-Vehicle menu operation: second generation: extension-menu_sunroof_over_threshold_high not activated 60
IDE12434-ENG152513-Vehicle menu operation: second generation: extension-menu_sunroof_standstill not activated 60
IDE12434-ENG185803-Vehicle menu operation: second generation: extension-menu_vas not activated 60
IDE12434-ENG185804-Vehicle menu operation: second generation: extension-menu_vas_after_disclaimer not activated 60
IDE12434-ENG185805-Vehicle menu operation: second generation: extension-menu_vas_clamp_15_off not activated 60
IDE12434-ENG185806-Vehicle menu operation: second generation: extension-menu_vas_over_threshold_high not activated 60
IDE12434-ENG185807-Vehicle menu operation: second generation: extension-menu_vas_stillstand not activated 60
IDE12434-ENG152500-Vehicle menu operation: second generation: extension-menu_wireless_charging not activated 60
IDE12434-ENG152504-Vehicle menu operation: second generation: extension-menu_wireless_charging_after_disclaimer not activated 60
IDE12434-ENG152501-Vehicle menu operation: second generation: extension-menu_wireless_charging_clamp_15_off not activated 60
IDE12434-ENG152502-Vehicle menu operation: second generation: extension-menu_wireless_charging_over_threshold_high not activated 60
IDE12434-ENG152503-Vehicle menu operation: second generation: extension-menu_wireless_charging_standstill not activated 60
IDE13183-Deactivation/activation of the pop-up for active tracking services 00 00 00 00 4
MAS00951-Bluetooth On 1
MAS02809-MAS02870-Check tone frequency-High note frequency range 4000 Hz 6
MAS02809-MAS02871-Check tone frequency-Medium note frequency range 1000 Hz 6
MAS02809-MAS02872-Check tone frequency-Low note frequency range 100 Hz 6
MAS03782-WLAN On 1
ENG126140-ENG117811-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_On_Off OFF 12
ENG126140-ENG117813-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_Time 0.00 ms 12
ENG126140-ENG126188-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_On_Off OFF 12
ENG126140-ENG126189-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_Time 0.00 ms 12
ENG126140-ENG126190-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_On_Off OFF 12
ENG126140-ENG126191-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_Time 0.00 ms 12
ENG126140-ENG117810-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_On_Off OFF 12
ENG126140-ENG117812-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_Time 0.00 ms 12
ENG117920-Audio_Managment_Soundset_Menu OFF 1
ENG117917-BAP_Debug_Mode_Release not_released 1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization not activated 60
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer not activated 60
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off not activated 60
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high not activated 60
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill not activated 60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation not activated 60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer not activated 60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off not activated 60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high not activated 60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill not activated 60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent not activated 60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer not activated 60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off not activated 60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high not activated 60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill not activated 60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC activated 60
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer not activated 60
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off not activated 60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high activated 60
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill not activated 60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key not activated 60
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer not activated 60
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off not activated 60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high not activated 60
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill not activated 60
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue not activated 60
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer not activated 60
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off not activated 60
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high not activated 60
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill not activated 60
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper not activated 60
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer not activated 60
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off not activated 60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high not activated 60
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill not activated 60
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination activated 60
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer not activated 60
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off not activated 60
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high activated 60
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill not activated 60
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope not activated 60
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer not activated 60
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off not activated 60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high not activated 60
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill not activated 60
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification not activated 60
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer not activated 60
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off not activated 60
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high not activated 60
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill not activated 60
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating not activated 60
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer not activated 60
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off not activated 60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high not activated 60
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill not activated 60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv activated 60
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer not activated 60
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off not activated 60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high activated 60
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill not activated 60
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management not activated 60
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer not activated 60
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off not activated 60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high not activated 60
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill not activated 60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE activated 60
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer not activated 60
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off not activated 60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high activated 60
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill not activated 60
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer activated 60
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer not activated 60
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off not activated 60
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high activated 60
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill not activated 60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function activated 60
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer not activated 60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off not activated 60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high activated 60
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill not activated 60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror activated 60
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer not activated 60
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off not activated 60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high activated 60
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill not activated 60
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking activated 60
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer not activated 60
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off not activated 60
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high activated 60
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill not activated 60
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master activated 60
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer not activated 60
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off not activated 60
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high activated 60
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill not activated 60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma activated 60
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer not activated 60
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off not activated 60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high activated 60
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill not activated 60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration activated 60
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer not activated 60
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off not activated 60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high activated 60
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill not activated 60
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock activated 60
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer not activated 60
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off not activated 60
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high activated 60
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill not activated 60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass not activated 60
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer not activated 60
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off not activated 60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high not activated 60
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill not activated 60
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist not activated 60
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer not activated 60
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off not activated 60
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high not activated 60
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill not activated 60
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration not activated 60
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer not activated 60
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off not activated 60
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high not activated 60
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill not activated 60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school not activated 60
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer not activated 60
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off not activated 60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high not activated 60
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill not activated 60
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall not activated 60
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer not activated 60
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off not activated 60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high not activated 60
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill not activated 60
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist not activated 60
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer not activated 60
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off not activated 60
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high not activated 60
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill not activated 60
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI not activated 60
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer not activated 60
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off not activated 60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high not activated 60
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill not activated 60
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination activated 60
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer not activated 60
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off not activated 60
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high activated 60
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill not activated 60
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display activated 60
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer not activated 60
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off not activated 60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high activated 60
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill not activated 60
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid not activated 60
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer not activated 60
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off not activated 60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high not activated 60
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill not activated 60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant activated 60
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer not activated 60
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off not activated 60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high activated 60
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill not activated 60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning activated 60
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer not activated 60
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off not activated 60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high activated 60
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill not activated 60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker not activated 60
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer not activated 60
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off not activated 60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high not activated 60
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill not activated 60
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision not activated 60
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer not activated 60
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off not activated 60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high not activated 60
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill not activated 60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level not activated 60
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer not activated 60
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off not activated 60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high not activated 60
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill not activated 60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc activated 60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer not activated 60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off not activated 60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high activated 60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill not activated 60
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist not activated 60
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer not activated 60
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off not activated 60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high not activated 60
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill not activated 60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk activated 60
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer not activated 60
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off not activated 60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high activated 60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill not activated 60
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment not activated 60
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer not activated 60
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off not activated 60
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high not activated 60
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill not activated 60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load activated 60
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer not activated 60
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off not activated 60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high activated 60
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill not activated 60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification not activated 60
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer not activated 60
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off not activated 60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high not activated 60
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill not activated 60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration activated 60
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer not activated 60
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off not activated 60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high activated 60
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill not activated 60
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic not activated 60
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer not activated 60
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off not activated 60
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high not activated 60
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill not activated 60
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia activated 60
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer not activated 60
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off not activated 60
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high activated 60
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill not activated 60
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view not activated 60
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer not activated 60
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off not activated 60
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high not activated 60
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill not activated 60
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions not activated 60
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer not activated 60
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off not activated 60
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high not activated 60
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill not activated 60
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler not activated 60
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer not activated 60
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off not activated 60
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high not activated 60
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill not activated 60
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI not activated 60
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer not activated 60
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off not activated 60
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high not activated 60
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill not activated 60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons activated 60
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer not activated 60
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off not activated 60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high activated 60
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill not activated 60
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant not activated 60
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer not activated 60
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off not activated 60
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high not activated 60
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill not activated 60
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner not activated 60
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer not activated 60
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off not activated 60
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high not activated 60
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill not activated 60
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo not activated 60
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer not activated 60
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off not activated 60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high not activated 60
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill not activated 60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating activated 60
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer not activated 60
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off not activated 60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high activated 60
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill not activated 60
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin activated 60
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer not activated 60
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off not activated 60
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high activated 60
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill not activated 60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition activated 60
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer not activated 60
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off not activated 60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high activated 60
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill not activated 60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows activated 60
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer not activated 60
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off not activated 60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high activated 60
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill not activated 60
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper activated 60
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer not activated 60
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off not activated 60
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high activated 60
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill not activated 60
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol not activated 60
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer not activated 60
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off not activated 60
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high not activated 60
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill not activated 60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05 activated 64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus Databus extended 64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06 not activated 64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus Suspension data bus 64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D not activated 64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus Databus Infotainment 64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24 not activated 64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus not activated 64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03 not activated 64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus Comfort data bus 64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B activated 64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus Terminal 15 64
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25 not activated 64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus Databus drivetrain 64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23 activated 64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus Databus Infotainment 64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26 activated 64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus Suspension data bus 64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D activated 64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus Comfort data bus 64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17 activated 64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus Databus Infotainment 64
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16 not activated 64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus Comfort data bus 64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01 activated 64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus Comfort data bus 64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02 activated 64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus Comfort data bus 64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11 activated 64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus Comfort data bus 64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15 not activated 64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus not activated 64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10 activated 64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus Comfort data bus 64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33 not activated 64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus Comfort data bus 64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C not activated 64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C not activated 64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37 not activated 64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus Comfort data bus 64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38 not activated 64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus Comfort data bus 64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09 activated 64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus Comfort data bus 64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04 activated 64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus Comfort data bus 64
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D not activated 64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus Databus drivetrain 64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08 activated 64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus Comfort data bus 64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19 activated 64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus Databus extended 64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F activated 64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus Comfort data bus 64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34 not activated 64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34 Databus Infotainment 64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E activated 64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus Comfort data bus 64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18 not activated 64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus not activated 64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A activated 64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus Terminal 15 64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20 not activated 64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus Comfort data bus 64
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A not activated 64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A Databus extended 64
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39 not activated 64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39 Databus Infotainment 64
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E not activated 64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus Comfort data bus 64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F activated 64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus Databus drivetrain 64
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B not activated 64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B Comfort data bus 64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F not activated 64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F Comfort data bus 64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E not activated 64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E Comfort data bus 64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12 activated 64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus Comfort data bus 64
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E not activated 64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus not activated 64
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35 not activated 64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35 Comfort data bus 64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27 activated 64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus Databus Infotainment 64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A activated 64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus Databus extended 64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07 activated 64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus Suspension data bus 64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21 not activated 64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus Databus extended 64
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36 not activated 64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36 Comfort data bus 64
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C not activated 64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus Comfort data bus 64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14 not activated 64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus Terminal 15 64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13 activated 64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus Comfort data bus 64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B activated 64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus Suspension data bus 64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22 activated 64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus Databus Infotainment 64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C activated 64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus Comfort data bus 64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key Not available 8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus Comfort data bus 8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school Not available 8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus Databus Infotainment 8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL Available 8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus Databus Infotainment 8
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level Not available 8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus Databus drivetrain 8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering Available 8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus Suspension data bus 8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved Not available 8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1 Comfort data bus 8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2 Comfort data bus 8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3 Not available 8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN Available 8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus Comfort data bus 8
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps OFF 10
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture On 10
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart On 10
ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode RLE 10
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution resolution_1 10
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode OFF 10
ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon 0 10
ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most OFF 10
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode H264 10
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution resolution_1 10
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode MOST_streaming 10
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart On 10
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1 0 6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2 50 6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3 100 6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1 0 6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2 50 6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3 100 6
ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1 0 6
ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2 50 6
ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3 100 6
ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1 0 6
ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2 50 6
ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3 100 6
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1 0 12
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2 10 12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3 50 12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4 100 12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5 150 12
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6 253 12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1 1% 12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2 1% 12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3 3% 12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4 6% 12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5 44% 12
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6 100% 12
ENG141636-ENG142049-Key_code_monitoring-monitoring_keycode_0x00_0x07 FF 32
ENG141636-ENG142050-Key_code_monitoring-monitoring_keycode_0x08_0x0F FF 32
ENG141636-ENG142051-Key_code_monitoring-monitoring_keycode_0x10_0x17 FF 32
ENG141636-ENG142052-Key_code_monitoring-monitoring_keycode_0x18_0x1F FF 32
ENG141636-ENG142053-Key_code_monitoring-monitoring_keycode_0x20_0x27 FF 32
ENG141636-ENG142054-Key_code_monitoring-monitoring_keycode_0x28_0x2F FF 32
ENG141636-ENG142055-Key_code_monitoring-monitoring_keycode_0x30_0x37 FF 32
ENG141636-ENG142056-Key_code_monitoring-monitoring_keycode_0x38_0x3F FF 32
ENG141636-ENG142057-Key_code_monitoring-monitoring_keycode_0x40_0x47 FF 32
ENG141636-ENG142058-Key_code_monitoring-monitoring_keycode_0x48_0x4F FF 32
ENG141636-ENG142059-Key_code_monitoring-monitoring_keycode_0x50_0x57 FF 32
ENG141636-ENG142060-Key_code_monitoring-monitoring_keycode_0x58_0x5F FF 32
ENG141636-ENG142061-Key_code_monitoring-monitoring_keycode_0x60_0x67 FF 32
ENG141636-ENG142062-Key_code_monitoring-monitoring_keycode_0x68_0x6F FF 32
ENG141636-ENG142063-Key_code_monitoring-monitoring_keycode_0x70_0x77 FF 32
ENG141636-ENG142064-Key_code_monitoring-monitoring_keycode_0x78_0x7F FF 32
ENG141636-ENG142065-Key_code_monitoring-monitoring_keycode_0x80_0x87 FF 32
ENG141636-ENG142066-Key_code_monitoring-monitoring_keycode_0x88_0x8F FF 32
ENG141636-ENG142067-Key_code_monitoring-monitoring_keycode_0x90_0x97 FF 32
ENG141636-ENG142068-Key_code_monitoring-monitoring_keycode_0x98_0x9F FF 32
ENG141636-ENG142069-Key_code_monitoring-monitoring_keycode_0xA0_0xA7 FF 32
ENG141636-ENG142070-Key_code_monitoring-monitoring_keycode_0xA8_0xAF FF 32
ENG141636-ENG142071-Key_code_monitoring-monitoring_keycode_0xB0_0xB7 FF 32
ENG141636-ENG142072-Key_code_monitoring-monitoring_keycode_0xB8_0xBF FF 32
ENG141636-ENG142073-Key_code_monitoring-monitoring_keycode_0xC0_0xC7 FF 32
ENG141636-ENG142074-Key_code_monitoring-monitoring_keycode_0xC8_0xCF FF 32
ENG141636-ENG142075-Key_code_monitoring-monitoring_keycode_0xD0_0xD7 FF 32
ENG141636-ENG142076-Key_code_monitoring-monitoring_keycode_0xD8_0xDF FF 32
ENG141636-ENG142077-Key_code_monitoring-monitoring_keycode_0xE0_0xE7 FF 32
ENG141636-ENG142078-Key_code_monitoring-monitoring_keycode_0xE8_0xEF FF 32
ENG141636-ENG142079-Key_code_monitoring-monitoring_keycode_0xF0_0xF7 FF 32
ENG141636-ENG142080-Key_code_monitoring-monitoring_keycode_0xF8_0xFF FF 32
ENG107658-ENG126192-mobile phone voice control availability-apple_device not installed 1
ENG107658-ENG126193-mobile phone voice control availability-other_devices not installed 1
ENG167428-ENG167502-nhtsa_properties-limitation_dependency Speed_threshold 5
ENG167428-ENG167510-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_limit_displayed_message_length activated 5
ENG167428-ENG167511-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_setup_configuration activated 5
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input not activated 5
ENG167428-ENG167513-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_video_playback activated 5
ENG167428-ENG167514-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_voice _input not activated 5
ENG167428-ENG167515-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_musicLists not activated 5
ENG167428-ENG167516-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_nonMusicLists not activated 5
ENG167428-ENG167517-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_japanMaps not activated 5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard not activated 5
ENG167428-ENG167519-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softPhoneKeypad not activated 5
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation 01 01 28 02 50 02 50 02 28 02 50 02 64 02 6E 02 78 02 3C 02 3C 02 3C 02 50 02 1E 02 1E 02 1E 02 1E 02 02 02 02 14 05 48 40
ENG117809-p_damping_Display 5 ms 1
ENG117808-p_HMI_Display 13% 1
ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset 0 2
ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset 0 2
ENG117919-Startup_Screen_Sticker_HMI 00 02 2
ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN 0 3
ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit 0 km/h 3
Elapsed Time: 00:50
6C-Back-up Cam.
;SW:5Q0-907-556-C HW:5Q0-907-556 --- Back-up Cam.
;Component:Areaview 2 H13 0608 Coding:01840301E20F200000204094
;EV_CamSysRVAV2ARCE2MQBAB 6017 EV_CamSysRVAV2ARCE2MQBAB.rod
;Thursday 22 March 2018 16:37:57:60782
;VCDS Version: Release 18.2.0 (x64) Data version: 20180212 DS287.0
;VCID: 393ADCABB8B4FC8C1F-806C
Elapsed Time: 00:25
6D-Trunk Elect.
;SW:5Q0-959-107-M HW:5Q0-959-107-C --- Trunk Elect.
;Component:HDSG-Modul H12 0261 Coding:0B28
;EV_DeckLidCONTIAU736 1014 EV_DeckLidCONTIAU736_VW27.rod
;Thursday 22 March 2018 16:38:42:60782
;VCID: 42C8BB47D562BF544E-8016
IDE00001-IDE03415-Production mode-Tone sensor not active 3
IDE00001-IDE10408-Production mode-Opening height in production mode not active 3
IDE00001-MAS10733-Production mode-Activation due to excessive pressure on rear lid not active 3
IDE00001-MAS10734-Production mode-Activation of rear lid with reduced speed not active 3
IDE00001-MAS10735-Production mode-Calibration not active 3
IDE00001-MAS10736-Production mode-Checking the rear lid button not active 3
IDE00001-MAS10738-Production mode-Opening and closing rear lid not active 3
IDE00820-Activating and deactivating all development messages not active 1
IDE02158-Program opening stop 1456 2
IDE02332-Deactivate production mode 0 3
IDE03435-Detection area upper 20 2
IDE03776-Offset for maximum programmable opening stop 16 2
IDE09510-IDE02111-Tailgate reverse path-Reverse path when opening 1 4
IDE09510-IDE02113-Tailgate reverse path-Reverse path when closing 287 4
IDE09511-Minimum opening height of tailgate 265 2
IDE09512-Deactivation of tailgate active 1
IDE09514-MAS01871-Deactivation of tailgate while in trailer operation-Rear lid lock button in luggage compartment active 2
IDE09514-MAS06265-Deactivation of tailgate while in trailer operation-Release button in rear lid handle active 2
IDE09514-MAS09010-Deactivation of tailgate while in trailer operation-Sensor for rear lid opening active 2
IDE09514-MAS09042-Deactivation of tailgate while in trailer operation-Using button to close lock. mechanism in tailgate handle active 2
IDE09514-MAS09043-Deactivation of tailgate while in trailer operation-Remote ctrl: opening with button for tailgate unlock. mechan. not active 2
IDE09514-MAS09044-Deactivation of tailgate while in trailer operation-Remote ctrl: closing with button for tailgate unlock. mechan. not active 2
IDE09514-MAS09045-Deactivation of tailgate while in trailer operation-Using sensor to open tailgate not active 2
IDE09514-MAS09046-Deactivation of tailgate while in trailer operation-Using sensor to close tailgate not active 2
IDE09514-MAS09063-Deactivation of tailgate while in trailer operation-Opening with button for remote unlocking of tailgate not active 2
IDE09514-MAS09064-Deactivation of tailgate while in trailer operation-Closing with remote unl.button of tailgate when using a trailer not active 2
IDE09514-MAS11625-Deactivation of tailgate while in trailer operation-Button for opening rear lid in luggage compartment active 2
IDE09514-MAS13754-Deactivation of tailgate while in trailer operation-Opening with button 2 for remote unlocking of rear lid not active 2
IDE09514-MAS13755-Deactivation of tailgate while in trailer operation-Closing with remote unlock.butt.2 of rear lid when using trail. not active 2
IDE09520-Offset for opening height after basic setting 0 2
IDE10408-Opening height in production mode 60% 2
IDE10695-Dectivation of the luggage compartment cover not active 1
IDE10703-Luggage compartment cover: tolerance of the block counter 0 2
IDE10704-Luggage compartment cover: maximum no. of block drives 0 2
IDE10705-Luggage compartment cover: number bloom drives 0 2
IDE10706-MAS01875-Luggage compartment cover: reverse path after obstacle recogn.-Open 0 4
IDE10706-MAS01876-Luggage compartment cover: reverse path after obstacle recogn.-Close 0 4
IDE10707-IDE03434-Luggage compartment cover: detection area-Detection area lower 0 4
IDE10707-IDE03435-Luggage compartment cover: detection area-Detection area upper 0 4
IDE10708-Luggage compartment cover: adjust. track tolerance 0 2
IDE10709-Luggage compartment cover: excess limitation in exclusion area not active 1
ENG131232-MAS01911-Ausstattungen aktivieren-Tone sensor active 2
ENG131232-MAS01947-Ausstattungen aktivieren-Clamping strip 1 not active 2
ENG131232-MAS01948-Ausstattungen aktivieren-Clamping strip 2 not active 2
ENG131232-MAS01949-Ausstattungen aktivieren-Clamping strip 3 not active 2
ENG131232-MAS01950-Ausstattungen aktivieren-Clamping strip 4 not active 2
ENG131232-MAS04266-Ausstattungen aktivieren-Temperature sensor 1 active 2
ENG131232-MAS04267-Ausstattungen aktivieren-Temperature sensor 2 active 2
ENG131232-MAS08212-Ausstattungen aktivieren-Engine 2 active 2
ENG131232-MAS09001-Ausstattungen aktivieren-Closing Assist Motor active 2
ENG131232-MAS11624-Ausstattungen aktivieren-Motor 2: sensor system active 2
Elapsed Time: 00:05
08-Auto HVAC
;SW:5G0-907-044-DP HW:5G0-907-044-DP --- Auto HVAC
;Component:Climatronic H04 2001 Coding:1412000420010001111550000010192A
;EV_ACClimaBHBVW37X 6146 EV_ACClimaBHBVW37X_006_VW27.rod
;Thursday 22 March 2018 16:27:58:60782
;VCID: 78BC19AFC33E258420-802C
IDE00001-Production mode Deactivating 3
IDE01067-Retention of driver's seat heater level active for 10 minutes 1
IDE01478-Ignore compressor switch-off by Engine Control Module Do not ignore 1
IDE01479-Gear ratio of engine - A/C compressor 0 1
IDE01483-Blower voltage for voice operation not activated 1
IDE01488-Retrofitting of parking heater without CAN not installed 1
IDE01493-Air quality sensor sensitivity Maximum 1
IDE01503-Runtime for compressor run-in basic setting 10 s 1
IDE01536-Post-heating of parking heater 0 min 1
IDE02155-Reset all counters not activated 1
IDE03176-Duration of compressor run in 0 s 1
IDE03251-Stop release for start-stop function According to function requirements 1
IDE04159-Deactivation of start-stop function not active 1
IDE06097-Target temperature of A/C - heater function via remote control 22.0 °C 1
IDE06544-Speed switch-off threshold for compressor run-in (engine speed) 1500 /min 1
IDE06545-Blower voltage for production routines 6.0 V 1
IDE06546-Interior target temperature for production routines 22 °C 1
IDE06547-Air distribution for production routines No effect 1
IDE06593-Recirculation air for production routines No effect 1
IDE07108-Climate modes Matching coding 1
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module 20 min 2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus 30 min 2
IDE07301-Remote start function: activation of seat heating Seat heater front 1
IDE07302-Remote start function: interior climate control status Remote start function with fixed rated temperature active 1
IDE07303-Rem.start funct.:activ.temper. of windshield defrost.heat. 4 °C 1
IDE07304-Remote start function: activation of seat ventilation activated 1
IDE07305-Rem. start funct.: activat.temper. of seat heating 15 °C 1
IDE07306-Rem. start funct.: activat.temper. of seat ventilation 20 °C 1
IDE07307-Remote start function: activation stage of seat heating 2 1
IDE07308-Remote start function: activation stage of seat ventilation 2 1
IDE07398-Blower logic for manual adjustment Matching coding 1
IDE07585-Hand heater function during cold start active 1
IDE07865-Automatic Activation of front windshield heater at MAX-Defrost not active 1
IDE07948-Retention of frt.pass. seat heater level not active 1
IDE12229-Filtering of interior air: store Service life-dependent store 1
IDE80006-Analysis 6 not activated 1
IDE80007-Analysis 7 00000000 00000000 2
IDE80008-Analysis 8 not active 1
MAS05739-CO2 compressor on-time reduction Matching coding 1
MAS06564-Window condensation exterior reduction at high humidity Matching coding 1
MAS07251-Cut-in behavior Matching coding 1
MAS14860-Remote start function: windshield defogger takeover activated 1
MAS14861-Remote start function: windshield defogger activated 1
ENG122844-ENG101574-dimming_characteristic_1-X1 0 12
ENG122844-ENG99557-dimming_characteristic_1-X2 6 12
ENG122844-ENG102140-dimming_characteristic_1-X3 40 12
ENG122844-ENG102936-dimming_characteristic_1-X4 60 12
ENG122844-ENG103548-dimming_characteristic_1-X5 80 12
ENG122844-ENG113992-dimming_characteristic_1-X6 100 12
ENG122844-ENG99777-dimming_characteristic_1-Y1 0% 12
ENG122844-ENG100480-dimming_characteristic_1-Y2 6% 12
ENG122844-ENG100773-dimming_characteristic_1-Y3 40% 12
ENG122844-ENG100631-dimming_characteristic_1-Y4 60% 12
ENG122844-ENG102174-dimming_characteristic_1-Y5 80% 12
ENG122844-ENG113993-dimming_characteristic_1-Y6 100% 12
ENG122845-ENG101574-dimming_characteristic_2-X1 0 12
ENG122845-ENG99557-dimming_characteristic_2-X2 10 12
ENG122845-ENG102140-dimming_characteristic_2-X3 50 12
ENG122845-ENG102936-dimming_characteristic_2-X4 100 12
ENG122845-ENG103548-dimming_characteristic_2-X5 220 12
ENG122845-ENG113992-dimming_characteristic_2-X6 253 12
ENG122845-ENG99777-dimming_characteristic_2-Y1 2% 12
ENG122845-ENG100480-dimming_characteristic_2-Y2 2% 12
ENG122845-ENG100773-dimming_characteristic_2-Y3 10% 12
ENG122845-ENG100631-dimming_characteristic_2-Y4 21% 12
ENG122845-ENG102174-dimming_characteristic_2-Y5 85% 12
ENG122845-ENG113993-dimming_characteristic_2-Y6 100% 12
ENG122846-ENG101574-dimming_characteristic_3-X1 0 12
ENG122846-ENG99557-dimming_characteristic_3-X2 10 12
ENG122846-ENG102140-dimming_characteristic_3-X3 50 12
ENG122846-ENG102936-dimming_characteristic_3-X4 100 12
ENG122846-ENG103548-dimming_characteristic_3-X5 220 12
ENG122846-ENG113992-dimming_characteristic_3-X6 253 12
ENG122846-ENG99777-dimming_characteristic_3-Y1 3% 12
ENG122846-ENG100480-dimming_characteristic_3-Y2 3% 12
ENG122846-ENG100773-dimming_characteristic_3-Y3 6% 12
ENG122846-ENG100631-dimming_characteristic_3-Y4 12% 12
ENG122846-ENG102174-dimming_characteristic_3-Y5 100% 12
ENG122846-ENG113993-dimming_characteristic_3-Y6 100% 12
ENG122847-ENG101574-dimming_characteristic_4-X1 0 12
ENG122847-ENG99557-dimming_characteristic_4-X2 10 12
ENG122847-ENG102140-dimming_characteristic_4-X3 50 12
ENG122847-ENG102936-dimming_characteristic_4-X4 100 12
ENG122847-ENG103548-dimming_characteristic_4-X5 220 12
ENG122847-ENG113992-dimming_characteristic_4-X6 253 12
ENG122847-ENG99777-dimming_characteristic_4-Y1 2% 12
ENG122847-ENG100480-dimming_characteristic_4-Y2 2% 12
ENG122847-ENG100773-dimming_characteristic_4-Y3 5% 12
ENG122847-ENG100631-dimming_characteristic_4-Y4 10% 12
ENG122847-ENG102174-dimming_characteristic_4-Y5 85% 12
ENG122847-ENG113993-dimming_characteristic_4-Y6 100% 12
ENG122848-ENG101574-dimming_characteristic_5-X1 0 12
ENG122848-ENG99557-dimming_characteristic_5-X2 10 12
ENG122848-ENG102140-dimming_characteristic_5-X3 50 12
ENG122848-ENG102936-dimming_characteristic_5-X4 100 12
ENG122848-ENG103548-dimming_characteristic_5-X5 220 12
ENG122848-ENG113992-dimming_characteristic_5-X6 253 12
ENG122848-ENG99777-dimming_characteristic_5-Y1 2% 12
ENG122848-ENG100480-dimming_characteristic_5-Y2 2% 12
ENG122848-ENG100773-dimming_characteristic_5-Y3 5% 12
ENG122848-ENG100631-dimming_characteristic_5-Y4 10% 12
ENG122848-ENG102174-dimming_characteristic_5-Y5 85% 12
ENG122848-ENG113993-dimming_characteristic_5-Y6 100% 12
ENG130577-Knockout_timer_activation not activated 1
Elapsed Time: 00:13
09-Cent. Elect.
;SW:5Q0-937-086-BM HW:5Q0-937-086-BH --- Cent. Elect.
;Component:BCM PQ37BOSCH 034 0242 Coding:
;EV_BodyContrModul1UDSBosc 18001 EV_BCMCONTI.rod
;Thursday 22 March 2018 16:28:23:60782
;VCID: 06406757B9CA437422-8052
IDE00001-ENG99061-Production mode-Access control not active 3
IDE00001-ENG115730-Production mode-Aussenbeleuchtung not active 3
IDE00001-ENG112304-Production mode-Heckwischer not active 3
IDE00001-ENG98647-Production mode-Interior lighting not active 3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung not active 3
IDE00001-ENG115731-Production mode-Virtuel_pedal not active 3
IDE00002-Transport mode active 1
IDE01550-Service position 153.296551 ° 2
IDE02152-Characteristics in production mode 2000 ms 4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking Decelerate 10
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln not active 10
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global not active 10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn not active 10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln not active 10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn short 10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung not active 10
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte active 10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen active 10
IDE02269-ENG133344-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl not active 10
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl not active 10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit 200 ms 10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit 200 ms 10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit 200 ms 10
IDE02488-DWA Interior monitoring 100% 1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen not active 8
IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen not active 8
IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1 8 s 8
IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2 16 s 8
IDE02711-ENG112304-Rear Window Wiper-Heckwischer not installed 8
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf not active 8
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck active 8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1 5 s 8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2 3 s 8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik 7 s 8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall 7 s 8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW active 8
IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer Keine_Spannungsanforderung 8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck active 8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck 0 ms 8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset 0.3 ° 16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit 50.0 %/s 16
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt both sides 16
IDE03638-ENG116675-static AFS light-Lower speed threshold 0.0 km/h 16
IDE03638-ENG116682-static AFS light-Maximaltemperatur 100.0 °C 16
IDE03638-ENG116679-static AFS light-obere Grenztemperatur 95.0 °C 16
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel 120 ° 16
IDE03638-ENG116680-static AFS light-untere Grenztemperatur 80.0 °C 16
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel 80 ° 16
IDE03638-ENG116676-static AFS light-Upper speed threshold 40.0 km/h 16
IDE03638-ENG116674-static AFS light-Vorschrift ECE R119 16
IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht 15 min 16
IDE03787-Activate left/right hand drive switch-over not active 1
IDE04927-IDE01446-Window heater-Running time of heated front window 240 s 11
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung 35.0 °C 11
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung 35.0 °C 11
IDE04927-ENG142251-Window heater-Frontscheibenheizung _maximale_Dauer 0 s 11
IDE04927-ENG142035-Window heater-Frontscheibenheizung_LED_direkt not installed 11
IDE04927-ENG142018-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus not installed 11
IDE04927-ENG126845-Window heater-FSH Automatik active 11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert 320 s 11
IDE04927-ENG141955-Window heater-heizbare Heckscheibe installed 11
IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe not installed 11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH active 11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH active 11
IDE04927-ENG141962-Window heater-Waschduesenheizung installed 11
IDE04927-ENG154810-Window heater-window heating front activation time pause 240 s 11
IDE04928-MAS01577-Anti-theft device-Parking heater not installed 8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn not active 8
IDE04928-ENG115864-Anti-theft device-Alarmsignal frequency modulated 8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system active 8
IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick not_active 8
IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI activ 8
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung not active 8
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus not active 8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder Sounder_verbaut 8
IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor not installed 8
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet No 8
IDE04928-ENG142249-Anti-theft device-OBD Alarm activ 8
IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm not_active 8
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv) No 8
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung Yes 8
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl 10 Alarme 8
IDE04928-ENG142008-Anti-theft device-tilt_sensor Yes 8
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel not active 8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm 2 sekunden verzoegerung 8
IDE05143-MAS02985-Writing parameter-Value 130 5
IDE05143-MAS04381-Writing parameter-Parameter address FE 00 00 5
IDE05144-Read parameter address FE 00 00 3
IDE05145-Light configuration 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 36 00 1A 0B 00 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 00 7F 00 00 00 00 00 00 00 00 00 05 44 00 4A 46 00 7F 08 0A 7F 00 00 00 00 00 00 05 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 224
IDE05822-DWA Vehicle inclination sensor 100% 1
IDE05823-DWA Interior monitoring parameter set 01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C FF 00 00 01 82 06 06 00 0F 1F 00 84 07 3B F7 65 23 55 42 57 9B 25 44 3F 3A 69 58 85 2D 0A A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 03 08 0A A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 03 08 0A A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 02 05 0A A3 05 29 04 19 15 0C 12 18 84 09 26 33 6A 23 45 42 57 9B 25 24 0C FA 0A 34 85 2D 0A A3 21 03 00 02 02 02 02 02 02 B1 11 81 27 BD 172
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN Heizmatten am BCM 30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss 1 s 30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss 0.00 °C 30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle 23.00 °C 30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle 22.00 °C 30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle 23.00 °C 30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle 22.00 °C 30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle 36.00 °C 30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle 35.50 °C 30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle 36.00 °C 30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle 35.50 °C 30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle 54.00 °C 30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle 53.00 °C 30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle 54.00 °C 30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle 53.00 °C 30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI Keine_Spannungsanforderung 30
IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO Keine_Spannungsanforderung 30
IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe not installed 30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75 15.0 V 30
IDE06425-Roller test bench mode: functional not active 1
IDE06507-MAS13125-Button in center console-Function of button 1 Start-stop 8
IDE06507-MAS13129-Button in center console-Function of button 2 not coded/not installed 8
IDE06507-MAS13132-Button in center console-Function of button 3 Driving program 8
IDE06507-MAS13135-Button in center console-Function of button 4 not coded/not installed 8
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED LED installed 8
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich active 8
IDE07007-ENG142252-A/C heater function via remote control-Abbruch_Hupen_RSt not active 8
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige active 8
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik active 8
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt active 8
IDE07007-ENG115720-A/C heater function via remote control-Remote Start not installed 8
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung active 8
IDE07356-Position during interval mode 24.890085 ° 2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit 6
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit 30 min 6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein active 6
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen active 9
IDE08786-ENG141956-Assistance light functions-Humidity sensor installed 9
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit normal 9
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe active 9
IDE08786-ENG142228-Assistance light functions-Maskierung_Regenfunktion not active 9
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor LIN_REGEN_LICHT_SENSOR 9
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor not installed 9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual 7 19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation not active 19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung not active 19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default active 19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit 0.25 s 19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1 2 19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2 4 19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3 5 19
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig not active 19
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig not active 19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach 30% 19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe 4 19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum 80% 19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole 80% 19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer 10% 19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn 10% 19
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen active 19
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen active 19
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen active 19
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen active 19
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen active 19
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen active 19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen active 19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen active 19
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen active 19
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen active 19
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen active 19
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen active 19
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen active 19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen not active 19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten not active 19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig active 19
IDE09731-ENG98648-Int. light: 2nd generation-Interior light Keine_Spannungsanforderung 19
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM not active 19
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig not active 19
IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht installed 19
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig not active 19
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren not active 19
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig not active 19
IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel not installed 19
IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel not installed 19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig active 19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G installed 19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel active 19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default 0 5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI active 5
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel installed 5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel installed 5
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher not installed 5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen active 5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus active 5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung not installed 5
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung installed 5
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil not installed 5
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI not installed 5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting installed 5
IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI not active 5
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar not active 5
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung not installed 5
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung not installed 5
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne 30% 17
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz 30% 17
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne 30% 17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz 30% 17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne 50% 17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz 50% 17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne 50% 17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz 50% 17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne 75% 17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz 75% 17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne 80% 17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz 80% 17
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung not installed 17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar installed 17
IDE09761-ENG142025-Seat fan charac. curve-Sitzpneumatik not installed 17
IDE10298-Alternating park position 1 8.296695 ° 2
IDE10299-Alternating park position 2 24.890085 ° 2
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit 1 256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach 0.4 256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum 0.4 256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel 0.6 256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher 1 256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko 1 256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd 1 256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer 0.6 256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI 101 256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2 111100 256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3 10 256
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4 0 256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI 0 256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2 11100 256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3 0 256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4 0 256
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab 1 256
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf 1 256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI 11010 256
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay 0 256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit 100% 256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach 127% 256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum 70% 256
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht 100% 256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel 96% 256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher 100% 256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko 100% 256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd 100% 256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren 96% 256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit 100% 256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach 127% 256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum 70% 256
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht 100% 256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel 96% 256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher 100% 256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko 100% 256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd 100% 256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren 96% 256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit 100% 256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach 127% 256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum 70% 256
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht 100% 256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel 96% 256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher 100% 256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko 100% 256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd 100% 256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren 96% 256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit 100% 256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach 127% 256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum 70% 256
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht 100% 256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel 96% 256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher 100% 256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko 100% 256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd 100% 256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren 96% 256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit 100% 256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach 127% 256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum 70% 256
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht 100% 256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel 96% 256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher 100% 256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko 100% 256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd 100% 256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren 96% 256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit 100% 256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach 127% 256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum 0% 256
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht 100% 256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel 0% 256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher 100% 256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko 100% 256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd 100% 256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren 0% 256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit 100% 256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach 127% 256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum 70% 256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht 100% 256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel 96% 256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher 100% 256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko 100% 256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd 100% 256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren 96% 256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit 100% 256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach 127% 256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum 127% 256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht 100% 256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel 127% 256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher 100% 256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko 100% 256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd 100% 256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren 127% 256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit 126% 256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach 126% 256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum 126% 256
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht 0% 256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel 126% 256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher 126% 256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko 126% 256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd 126% 256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren 126% 256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit 100% 256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach 127% 256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum 127% 256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht 100% 256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel 127% 256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher 100% 256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko 100% 256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd 100% 256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren 127% 256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit 100% 256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach 126% 256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum 126% 256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht 100% 256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel 126% 256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher 100% 256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko 100% 256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd 100% 256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren 126% 256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit 100% 256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach 60% 256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum 70% 256
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht 100% 256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel 96% 256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher 100% 256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko 100% 256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd 100% 256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren 96% 256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit 100% 256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach 127% 256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum 70% 256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht 100% 256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel 96% 256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher 100% 256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko 100% 256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd 100% 256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren 96% 256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit 100% 256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach 127% 256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum 70% 256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht 100% 256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel 96% 256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher 100% 256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko 100% 256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd 100% 256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren 96% 256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit 100% 256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach 127% 256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum 70% 256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht 100% 256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel 96% 256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher 100% 256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko 100% 256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd 100% 256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren 96% 256
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte 200 ms 256
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit 0.0 s 256
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach 0.0 s 256
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum 0.0 s 256
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht 0.0 s 256
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko 0.0 s 256
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren 0.0 s 256
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit 2.0 s 256
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach 0.0 s 256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum 2.0 s 256
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht 0.0 s 256
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko 0.0 s 256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren 0.5 s 256
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit 0.0 s 256
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach 0.0 s 256
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum 0.0 s 256
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht 0.0 s 256
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko 0.0 s 256
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren 0.0 s 256
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit 0.0 s 256
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach 0.0 s 256
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum 0.0 s 256
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht 0.0 s 256
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko 0.0 s 256
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren 0.0 s 256
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit 0.0 s 256
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach 0.0 s 256
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum 0.0 s 256
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht 0.0 s 256
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko 0.0 s 256
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren 0.0 s 256
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit 0.0 s 256
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach 0.0 s 256
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum 0.0 s 256
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht 0.0 s 256
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko 0.0 s 256
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren 0.0 s 256
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit 0.0 s 256
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach 0.0 s 256
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum 0.0 s 256
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht 0.0 s 256
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko 0.0 s 256
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren 0.0 s 256
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen 0 256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1 0 30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10 0 30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2 64 30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3 200 30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4 0 30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5 0 30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6 0 30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7 0 30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8 0 30
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9 0 30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1 198 30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10 0 30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2 255 30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3 255 30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4 0 30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5 0 30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6 0 30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7 0 30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8 0 30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9 0 30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1 255 30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10 0 30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2 175 30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3 32 30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4 0 30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5 0 30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6 0 30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7 0 30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8 0 30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9 0 30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung installed 3
IDE11944-ENG141948-Keyless access and start authorization-Kessy installed 3
IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen not active 3
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen active 3
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung not active 3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung not active 3
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin 0 30
IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin 0 30
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin 0 30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin 0 30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin 0 30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin 0 30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin 0 30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin 0 30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin 0 30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin 0 30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin 0 30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin 0 30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin 0 30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin 0 30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin 0 30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin 0 30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin 0 30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin 0 30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin 0 30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin 0 30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin 0 30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin 0 30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin 0 30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin 0 30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin 0 30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin 0 30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin 0 30
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin 0 30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin 0 30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin 0 30
MAS01490-ENG142027-Energy management-Energiemanagement Abschaltung active 5
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation Energy management active 5
MAS01490-ENG142256-Energy management-Hochvoltfahrzeug not installed 5
MAS01490-ENG141950-Energy management-Hybrid vehicle No 5
MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement not active 5
MAS01490-ENG141978-Energy management-Recuperation active 5
MAS01490-ENG142037-Energy management-Zweitbatterie not installed 5
MAS05055-lower turn position 26.296677 ° 2
MAS05056-upper turn position 171.296533 ° 2
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze 1200 lx 24
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze 2200 lx 24
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle 1000 lx 24
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO 600 lx 24
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten 1200 lx 24
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten 2200 lx 24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red 00 50 24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell 2000 lx 24
MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway not active 24
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain not active 24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity frueh 24
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF not active 24
MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe not active 24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung 4500 mV 24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke 6000 lx 24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung 2000 mV 24
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke 0 lx 24
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung 2 24
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status not active 9
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC 00 00 00 9
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC First_dtc 9
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren not active 4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT not active 4
ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoiler not installed 4
ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11 0 60
ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12 0 60
ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13 0 60
ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14 0 60
ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15 0 60
ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16 0 60
ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17 0 60
ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18 0 60
ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19 0 60
ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20 0 60
ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21 0 60
ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22 0 60
ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23 0 60
ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24 0 60
ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25 0 60
ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26 0 60
ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27 0 60
ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28 0 60
ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29 0 60
ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30 0 60
ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11 0 60
ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12 0 60
ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13 0 60
ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14 0 60
ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15 0 60
ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16 0 60
ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17 0 60
ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18 0 60
ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19 0 60
ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20 0 60
ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21 0 60
ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22 0 60
ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23 0 60
ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24 0 60
ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25 0 60
ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26 0 60
ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27 0 60
ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28 0 60
ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29 0 60
ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30 0 60
ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11 0 60
ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12 0 60
ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13 0 60
ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14 0 60
ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15 0 60
ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16 0 60
ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17 0 60
ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18 0 60
ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19 0 60
ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20 0 60
ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21 0 60
ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22 0 60
ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23 0 60
ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24 0 60
ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25 0 60
ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26 0 60
ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27 0 60
ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28 0 60
ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29 0 60
ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30 0 60
ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin 0 60
ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin 0 60
ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin 0 60
ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin 0 60
ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin 0 60
ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin 0 60
ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin 0 60
ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin 0 60
ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin 0 60
ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin 0 60
ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin 0 60
ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin 0 60
ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin 0 60
ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin 0 60
ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin 0 60
ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin 0 60
ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin 0 60
ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin 0 60
ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin 0 60
ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin 0 60
ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin 0 60
ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin 0 60
ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin 0 60
ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin 0 60
ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin 0 60
ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin 0 60
ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin 0 60
ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin 0 60
ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin 0 60
ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin 0 60
ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin 0 60
ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin 0 60
ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin 0 60
ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin 0 60
ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin 0 60
ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin 0 60
ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin 0 60
ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin 0 60
ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin 0 60
ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin 0 60
ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin 0 60
ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin 0 60
ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin 0 60
ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin 0 60
ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin 0 60
ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin 0 60
ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin 0 60
ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin 0 60
ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin 0 60
ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin 0 60
ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin 0 60
ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin 0 60
ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin 0 60
ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin 0 60
ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin 0 60
ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin 0 60
ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin 0 60
ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin 0 60
ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin 0 60
ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin 0 60
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1 1 30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10 1 30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11 1 30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12 1 30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13 1 30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14 1 30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15 1 30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2 1 30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3 1 30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4 1 30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5 1 30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6 1 30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7 1 30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8 1 30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9 1 30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1 door 30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10 door 30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11 door 30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12 door 30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13 door 30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14 door 30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15 door 30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2 I-panel 30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3 door 30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4 door 30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5 door 30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6 door 30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7 door 30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8 door 30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9 door 30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1 multicolor 30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10 not installed 30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11 not installed 30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12 not installed 30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13 not installed 30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14 not installed 30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15 not installed 30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2 multicolor 30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3 not installed 30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4 not installed 30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5 not installed 30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6 not installed 30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7 not installed 30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8 not installed 30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9 not installed 30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12 0 60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1 1 60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10 0 60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11 0 60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13 0 60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14 0 60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15 0 60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16 0 60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17 0 60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18 0 60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19 0 60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2 2 60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20 0 60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3 3 60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4 4 60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5 5 60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6 6 60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7 0 60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8 0 60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9 0 60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1 4 60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10 0 60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11 0 60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12 0 60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13 0 60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14 0 60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15 0 60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16 0 60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17 0 60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18 0 60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19 0 60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2 8 60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20 0 60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3 12 60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4 16 60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5 20 60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6 21 60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7 0 60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9 0 60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8 0 60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1 installed 60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10 not installed 60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11 not installed 60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12 not installed 60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13 not installed 60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14 not installed 60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15 not installed 60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16 not installed 60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17 not installed 60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18 not installed 60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19 not installed 60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2 installed 60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20 not installed 60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3 installed 60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4 installed 60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5 installed 60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6 installed 60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7 not installed 60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9 not installed 60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8 not installed 60
ENG126650-ENG126926-Ambiente_light-Dimmung_auf_Zielwert deaktivieren_Suchbeleuchtung not active 13
ENG126650-ENG126927-Ambiente_light-Dimmung_auf_Zielwert_deaktivieren_Innen_und_Leselicht not active 13
ENG126650-ENG126922-Ambiente_light-Korrekturfaktor_ Flaechenlicht_vorne_Farbe_1 1 13
ENG126650-ENG126924-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_1 1 13
ENG126650-ENG126925-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_2 0.78 13
ENG126650-ENG126923-Ambiente_light-Korrekturfaktor_Flaechenlicht_vorne_Farbe_2 0.17 13
ENG126650-ENG126921-Ambiente_light-Korrekturfaktor_Funktionsbeleuchtung 1 13
ENG126650-ENG126918-Ambiente_light-Korrekturfaktor_Leselicht_hinten 1 13
ENG126650-ENG126919-Ambiente_light-Korrekturfaktor_Leselicht_Reihe_3 1 13
ENG126650-ENG126917-Ambiente_light-Korrekturfaktor_Leselicht_vorne 1 13
ENG126650-ENG126920-Ambiente_light-Korrekturfaktor_Schalter_und_Suchbeleuchtung 1 13
ENG128378-ENG115658-Ambiente_Light_Kennlinie_Hochdimmen-x0 0 ms 22
ENG128378-ENG101574-Ambiente_Light_Kennlinie_Hochdimmen-X1 200 ms 22
ENG128378-ENG115664-Ambiente_Light_Kennlinie_Hochdimmen-x10 2000 ms 22
ENG128378-ENG99557-Ambiente_Light_Kennlinie_Hochdimmen-X2 400 ms 22
ENG128378-ENG102140-Ambiente_Light_Kennlinie_Hochdimmen-X3 600 ms 22
ENG128378-ENG102936-Ambiente_Light_Kennlinie_Hochdimmen-X4 800 ms 22
ENG128378-ENG103548-Ambiente_Light_Kennlinie_Hochdimmen-X5 1000 ms 22
ENG128378-ENG113992-Ambiente_Light_Kennlinie_Hochdimmen-X6 1200 ms 22
ENG128378-ENG115661-Ambiente_Light_Kennlinie_Hochdimmen-x7 1400 ms 22
ENG128378-ENG115662-Ambiente_Light_Kennlinie_Hochdimmen-x8 1600 ms 22
ENG128378-ENG115663-Ambiente_Light_Kennlinie_Hochdimmen-x9 1800 ms 22
ENG128378-ENG115659-Ambiente_Light_Kennlinie_Hochdimmen-y0 0.00% 22
ENG128378-ENG99777-Ambiente_Light_Kennlinie_Hochdimmen-Y1 0.50% 22
ENG128378-ENG115668-Ambiente_Light_Kennlinie_Hochdimmen-y10 100.00% 22
ENG128378-ENG100480-Ambiente_Light_Kennlinie_Hochdimmen-Y2 2.00% 22
ENG128378-ENG100773-Ambiente_Light_Kennlinie_Hochdimmen-Y3 5.00% 22
ENG128378-ENG100631-Ambiente_Light_Kennlinie_Hochdimmen-Y4 10.00% 22
ENG128378-ENG102174-Ambiente_Light_Kennlinie_Hochdimmen-Y5 20.00% 22
ENG128378-ENG113993-Ambiente_Light_Kennlinie_Hochdimmen-Y6 40.00% 22
ENG128378-ENG115665-Ambiente_Light_Kennlinie_Hochdimmen-y7 80.00% 22
ENG128378-ENG115666-Ambiente_Light_Kennlinie_Hochdimmen-y8 95.00% 22
ENG128378-ENG115667-Ambiente_Light_Kennlinie_Hochdimmen-y9 99.00% 22
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente Keine_Spannungsanforderung 23
ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0 1 23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1 1 23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10 1 23
ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11 1 23
ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12 1 23
ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13 1 23
ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14 1 23
ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15 1 23
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2 1 23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3 1 23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4 1 23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5 1 23
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6 1 23
ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7 1 23
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8 1 23
ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9 1 23
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken not active 10
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken active 10
ENG141649-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger separte 10
ENG141649-ENG121966-Außenlicht_Blinker-Crash flashing not active 10
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken active 10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung active 10
ENG141649-ENG142194-Außenlicht_Blinker-dynamisch_blinken_10 active 10
ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay 50 ms 10
ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken not active 10
ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen Warnblinke_zulaessig 10
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken active 10
ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen 3 10
ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken not active 10
ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2 not active 10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing active 10
ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS PreCrash_aktiv 10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links active 10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts active 10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken active 10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing active 10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken active 10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken active 10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz not active 10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS active 10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN active 10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf active 10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu active 10
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp H7 9
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze 350 km/h 9
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze 350 km/h 9
ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag Daytime running lights 9
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL 5 km/h 9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich not active 9
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht not active 9
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument not active 9
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut not installed 9
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht active 9
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich not active 9
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten not active 9
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO not active 9
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht not active 9
ENG141647-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte not active 9
ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit not active 9
ENG141647-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge active 9
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren in Betrieb lassen 9
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht No 5
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit 0 km/h 5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA active 5
ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion not active 5
ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappe not installed 5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights installed 18
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung abschaltbar über Energiemanagement 18
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung abschaltbar über Energiemanagement 18
ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes Standlicht Aktive Begrenzung 18
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten Low beam 18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus manual 18
ENG141656-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis Driver door 18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach active 18
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig Hinweis_in_LDS-Stellung_Null_und_SL 18
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer Faktor fuer x5 Minuten 18
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH Sollspannungsanforderung 13.5 18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light Sollspannungsanforderung 13.5 18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung 46400 lx 18
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung 12 lx 18
ENG141656-ENG142189-Außenlicht_uebergreifend-HVLM_Ladezustandsanzeige No 18
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht integriert in Suchbeleuchtung 18
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker false 18
ENG141656-ENG141992-Außenlicht_uebergreifend-LDS_mit_AFL Yes 18
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht Yes 18
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht Yes 18
ENG141656-ENG141993-Außenlicht_uebergreifend-LDS_mit_Standlichtstellung Yes 18
ENG141656-ENG115657-Außenlicht_uebergreifend-Leaving-Home Verbausstatus Enabled 18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS) LIN 18
ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten klemmenabhaengig 18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module installed 18
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam Sollspannungsanforderung 13.5 18
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO Menuesteuerung Zeit aktivieren 18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome 10 seconds 18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP 10 seconds 18
ENG141656-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung active 18
ENG141656-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP active 18
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert One-sided 18
ENG141656-ENG126816-Außenlicht_uebergreifend-Standlicht aus active 18
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht active 18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit 24 s 18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal Sollspannungsanforderung 13.5 18
ENG141656-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte not active 18
ENG126647-ENG98399-debug_light_function-Activation 0 11
ENG126647-ENG101417-debug_light_function-Adresse 0 11
ENG126647-ENG126820-debug_light_function-Bitmask 0 11
ENG126647-ENG126821-debug_light_function-Divisor 0 11
ENG126647-ENG98827-debug_light_function-Offset 0 11
ENG126647-ENG126822-debug_light_function-Polaritaet 0 11
ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0 0.00% 6
ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1 50.00% 6
ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2 100.00% 6
ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0 0.00% 6
ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1 50.00% 6
ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2 100.00% 6
ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP present 6
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung AFS: FLA: Fernlicht (GLW:MDF) 6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset active 6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent present 6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung present 6
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA active 6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung 800 ms 6
ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm active 6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf active 6
ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig Keine_Spannungsanforderung 6
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition not active 6
ENG141682-ENG141966-Front_wiper-Frontwischertyp LIN 6
ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung active 6
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer not active 6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer 0 ms 6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren Deactivating 6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay 300 ms 6
ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz active 6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status not active 6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung not active 6
ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant not active 6
ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube not active 6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus not active 6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube active 6
ENG99457-ENG117394-Head area heater-blower_speed 1 2
ENG99457-ENG98971-Head area heater-Temperature -2 2
ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid installed 8
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid installed 8
ENG141645-MAS00213-HW_Verbau-Insufficient coolant installed 8
ENG141645-MAS00214-HW_Verbau-Brake pad wear installed 8
ENG141645-ENG142026-HW_Verbau-Druckklappe not installed 8
ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv not active 8
ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung not installed 8
ENG141645-ENG141952-HW_Verbau-Exterior temp. sensor installed 8
ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube installed 8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung not installed 8
ENG141645-ENG142036-HW_Verbau-PTC Zuheizer not installed 8
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15 active 8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung not active 8
ENG126651-ENG115658-Kennlinie Abdimmen-x0 0 22
ENG126651-ENG101574-Kennlinie Abdimmen-X1 200 22
ENG126651-ENG115664-Kennlinie Abdimmen-x10 2000 22
ENG126651-ENG99557-Kennlinie Abdimmen-X2 400 22
ENG126651-ENG102140-Kennlinie Abdimmen-X3 600 22
ENG126651-ENG102936-Kennlinie Abdimmen-X4 800 22
ENG126651-ENG103548-Kennlinie Abdimmen-X5 1000 22
ENG126651-ENG113992-Kennlinie Abdimmen-X6 1200 22
ENG126651-ENG115661-Kennlinie Abdimmen-x7 1400 22
ENG126651-ENG115662-Kennlinie Abdimmen-x8 1600 22
ENG126651-ENG115663-Kennlinie Abdimmen-x9 1800 22
ENG126651-ENG115659-Kennlinie Abdimmen-y0 100 22
ENG126651-ENG99777-Kennlinie Abdimmen-Y1 99 22
ENG126651-ENG115668-Kennlinie Abdimmen-y10 0 22
ENG126651-ENG100480-Kennlinie Abdimmen-Y2 95 22
ENG126651-ENG100773-Kennlinie Abdimmen-Y3 80 22
ENG126651-ENG100631-Kennlinie Abdimmen-Y4 40 22
ENG126651-ENG102174-Kennlinie Abdimmen-Y5 20 22
ENG126651-ENG113993-Kennlinie Abdimmen-Y6 10 22
ENG126651-ENG115665-Kennlinie Abdimmen-y7 5 22
ENG126651-ENG115666-Kennlinie Abdimmen-y8 2 22
ENG126651-ENG115667-Kennlinie Abdimmen-y9 0.5 22
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0 -100.00% 30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1 -100.00% 30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2 -100.00% 30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3 -100.00% 30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4 -100.00% 30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5 -100.00% 30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6 -100.00% 30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7 -100 30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8 -100.00% 30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9 -100.00% 30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0 100.00% 30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1 90.00% 30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2 80.00% 30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3 70.00% 30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4 60.00% 30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5 50.00% 30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6 40.00% 30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7 30.00% 30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8 15.00% 30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9 0.00% 30
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0 maximize 16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0 maximize 16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0 maximize 16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0 0 16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0 0 16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0 0 16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0 0 16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0 0 16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0 0 16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0 not active 16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0 Always 16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0 not active 16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0 not active 16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0 not active 16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0 not active 16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0 not active 16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0 not active 16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0 not active 16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0 not active 16
ENG141657-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15 maximize 16
ENG141657-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15 maximize 16
ENG141657-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15 maximize 16
ENG141657-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15 100 16
ENG141657-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15 0 16
ENG141657-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15 0 16
ENG141657-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15 0 16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15 63 16
ENG141657-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15 0 16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15 41 - LED Kleinleistung 16
ENG141657-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15 Always 16
ENG141657-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15 not active 16
ENG141657-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15 not active 16
ENG141657-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15 not active 16
ENG141657-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15 not active 16
ENG141657-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15 not active 16
ENG141657-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15 not active 16
ENG141657-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15 not active 16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10 maximize 16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10 maximize 16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10 maximize 16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10 0 16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10 0 16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10 0 16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10 0 16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10 0 16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10 0 16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10 not active 16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10 Always 16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10 not active 16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10 not active 16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10 not active 16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10 not active 16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10 not active 16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10 not active 16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10 not active 16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10 not active 16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11 maximize 16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11 maximize 16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11 maximize 16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11 0 16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11 0 16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11 0 16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11 0 16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11 0 16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11 0 16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11 not active 16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11 Always 16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11 not active 16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11 not active 16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11 not active 16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11 not active 16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11 not active 16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11 not active 16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11 not active 16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11 not active 16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12 maximize 16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12 maximize 16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12 maximize 16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12 0 16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12 0 16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12 0 16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12 0 16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12 0 16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12 0 16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12 not active 16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12 Always 16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12 not active 16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12 not active 16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12 not active 16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12 not active 16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12 not active 16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12 not active 16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12 not active 16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12 not active 16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13 maximize 16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13 maximize 16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13 maximize 16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13 0 16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13 0 16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13 0 16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13 0 16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13 0 16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13 0 16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13 not active 16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13 Always 16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13 not active 16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13 not active 16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13 not active 16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13 not active 16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13 not active 16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13 not active 16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13 not active 16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13 not active 16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16 maximize 16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16 maximize 16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16 maximize 16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16 127 16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16 0 16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16 0 16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16 0 16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16 41 16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16 8 16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16 38 - LED Blinkleuchten 16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16 Always 16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16 Blinken links Hellphase 16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16 not active 16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16 not active 16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16 not active 16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16 not active 16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16 not active 16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16 not active 16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16 not active 16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17 maximize 16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17 maximize 16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17 maximize 16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17 127 16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17 0 16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17 0 16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17 0 16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17 42 16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17 18 16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17 38 - LED Blinkleuchten 16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17 Always 16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 Blinken rechts Hellphase 16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17 not active 16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17 not active 16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17 not active 16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17 not active 16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17 not active 16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17 not active 16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17 not active 16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18 maximize 16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18 maximize 16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18 maximize 16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18 127 16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18 0 16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18 0 16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18 0 16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18 16 16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18 8 16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18 38 - LED Blinkleuchten 16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18 Always 16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18 Blinken links Hellphase 16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18 not active 16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18 not active 16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18 not active 16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18 not active 16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18 not active 16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18 not active 16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18 not active 16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19 maximize 16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19 maximize 16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19 maximize 16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19 127 16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19 0 16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19 0 16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19 0 16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19 18 16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19 18 16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19 38 - LED Blinkleuchten 16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19 Always 16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19 Blinken rechts Hellphase 16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19 not active 16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19 not active 16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19 not active 16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19 not active 16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19 not active 16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19 not active 16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19 not active 16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1 maximize 16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1 maximize 16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1 maximize 16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1 0 16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1 0 16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1 0 16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1 0 16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1 0 16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1 0 16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1 not active 16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1 Always 16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1 not active 16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1 not active 16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1 not active 16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1 not active 16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1 not active 16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1 not active 16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1 not active 16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1 not active 16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20 maximize 16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20 maximize 16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20 maximize 16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20 127 16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20 0 16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20 0 16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20 0 16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20 2B 16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20 9 16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20 34 - LED Bremsleuchten 16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20 Always 16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20 Brake light 16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20 not active 16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20 not active 16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20 not active 16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20 not active 16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20 not active 16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20 not active 16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20 not active 16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21 maximize 16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21 maximize 16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21 maximize 16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21 127 16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21 0 16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21 0 16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21 0 16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21 2D 16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21 19 16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21 34 - LED Bremsleuchten 16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21 Always 16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21 Brake light 16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21 not active 16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21 not active 16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21 not active 16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21 not active 16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21 not active 16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21 not active 16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21 not active 16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22 maximize 16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22 maximize 16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22 maximize 16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22 127 16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22 0 16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22 0 16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22 0 16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22 2C 16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22 29 16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22 42 - LED dritte Bremsleuchte 16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22 Always 16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22 Brake light 16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22 Quittierungsfunktion 1 16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22 not active 16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22 not active 16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22 not active 16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22 not active 16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22 not active 16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22 not active 16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23 maximize 16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23 maximize 16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23 maximize 16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23 127 16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23 0 16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23 0 16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23 0 16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23 35 16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23 0A 16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23 32 - allgemeine LED bis 12W 16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23 Always 16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23 not active 16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23 not active 16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23 not active 16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23 not active 16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23 not active 16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23 not active 16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24 maximize 16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24 maximize 16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24 maximize 16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24 127 16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24 0 16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24 0 16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24 0 16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24 36 16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24 1A 16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24 32 - allgemeine LED bis 12W 16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24 Always 16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24 Parking light right 16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24 not active 16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24 not active 16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24 not active 16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24 not active 16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24 not active 16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24 not active 16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25 maximize 16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25 maximize 16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25 maximize 16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25 127 16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25 0 16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25 0 16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25 0 16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25 30 16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25 28 16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25 43 - allgemeine LED 16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25 Always 16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25 not active 16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25 not active 16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25 not active 16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25 not active 16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25 not active 16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25 not active 16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25 not active 16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26 maximize 16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26 maximize 16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26 maximize 16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26 127 16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26 0 16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26 0 16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26 0 16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26 2F 16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26 1C 16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26 43 - allgemeine LED 16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26 only_if_closed 16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26 Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr 16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26 not active 16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26 not active 16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26 not active 16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26 not active 16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26 not active 16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26 not active 16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26 not active 16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27 minimize 16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27 maximize 16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27 maximize 16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27 127 16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27 0 16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27 0 16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27 0 16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27 62 16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27 0 16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27 36 - LED Kleinleistung 16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27 Always 16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27 Aktive Blinkfunktion hat ein auf 1 gesetztes zugeordnetes Bit in pa_dynamisch_blinken 16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27 not active 16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27 not active 16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27 not active 16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27 not active 16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27 not active 16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27 not active 16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27 not active 16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28 maximize 16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28 maximize 16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28 maximize 16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28 127 16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28 0 16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28 0 16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28 0 16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28 31 16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28 0B 16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28 32 - allgemeine LED bis 12W 16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28 only_if_closed 16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28 Rueckfahrlicht 16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28 not active 16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28 not active 16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28 not active 16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28 not active 16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28 not active 16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28 not active 16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28 not active 16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29 minimize 16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29 maximize 16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29 maximize 16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29 127 16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29 0 16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29 0 16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29 0 16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29 32 16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29 1B 16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29 32 - allgemeine LED bis 12W 16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29 only_if_closed 16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29 Rueckfahrlicht 16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29 not active 16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29 Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr 16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29 not active 16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29 not active 16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29 not active 16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29 not active 16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29 not active 16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2 maximize 16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2 maximize 16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2 maximize 16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2 0 16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2 0 16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2 0 16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2 0 16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2 0 16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2 0 16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2 not active 16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2 Always 16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2 not active 16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2 not active 16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2 not active 16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2 not active 16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2 not active 16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2 not active 16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2 not active 16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2 not active 16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30 maximize 16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30 maximize 16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30 maximize 16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30 89 16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30 0 16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30 0 16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30 0 16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30 2 16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30 0 16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30 36 - LED Kleinleistung 16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30 Always 16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30 Footwell light 16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30 not active 16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30 not active 16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30 not active 16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30 not active 16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30 not active 16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30 not active 16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30 not active 16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31 maximize 16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31 maximize 16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31 maximize 16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31 0 16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31 0 16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31 0 16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31 0 16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31 0 16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31 0 16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31 not active 16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31 Always 16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31 not active 16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31 not active 16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31 not active 16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31 not active 16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31 not active 16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31 not active 16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31 not active 16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31 not active 16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32 maximize 16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32 maximize 16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32 maximize 16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32 0 16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32 0 16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32 0 16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32 0 16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32 0 16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32 0 16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32 not active 16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32 Always 16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32 not active 16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32 not active 16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32 not active 16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32 not active 16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32 not active 16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32 not active 16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32 not active 16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32 not active 16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33 maximize 16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33 maximize 16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33 maximize 16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33 0 16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33 0 16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33 0 16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33 0 16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33 0 16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33 0 16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33 not active 16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33 Always 16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33 not active 16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33 not active 16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33 not active 16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33 not active 16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33 not active 16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33 not active 16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33 not active 16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33 not active 16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34 maximize 16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34 maximize 16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34 maximize 16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34 0 16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34 0 16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34 0 16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34 0 16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34 0 16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34 0 16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34 not active 16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34 Always 16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34 not active 16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34 not active 16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34 not active 16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34 not active 16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34 not active 16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34 not active 16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34 not active 16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34 not active 16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3 maximize 16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3 maximize 16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3 maximize 16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3 0 16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3 0 16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3 0 16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3 0 16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3 0 16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3 0 16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3 not active 16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3 Always 16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3 not active 16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3 not active 16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3 not active 16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3 not active 16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3 not active 16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3 not active 16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3 not active 16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3 not active 16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4 maximize 16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4 maximize 16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4 maximize 16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4 0 16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4 0 16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4 0 16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4 0 16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4 0 16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4 0 16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4 not active 16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4 Always 16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4 not active 16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4 not active 16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4 not active 16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4 not active 16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4 not active 16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4 not active 16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4 not active 16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4 not active 16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5 maximize 16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5 maximize 16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5 maximize 16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5 0 16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5 0 16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5 0 16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5 0 16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5 0 16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5 0 16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5 not active 16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5 Always 16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5 not active 16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5 not active 16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5 not active 16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5 not active 16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5 not active 16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5 not active 16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5 not active 16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5 not active 16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6 maximize 16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6 maximize 16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6 maximize 16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6 127 16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6 0 16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6 0 16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6 0 16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6 1A 16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6 36 16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6 5 - LED Abblendlicht 16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6 Always 16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6 Abblendlicht links 16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6 not active 16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6 not active 16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6 not active 16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6 not active 16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6 not active 16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6 not active 16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6 not active 16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7 maximize 16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7 maximize 16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7 maximize 16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7 127 16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7 0 16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7 0 16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7 0 16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7 1B 16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7 40 16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7 5 - LED Abblendlicht 16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7 Always 16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7 Abblendlicht rechts 16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7 not active 16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7 not active 16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7 not active 16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7 not active 16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7 not active 16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7 not active 16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7 not active 16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8 maximize 16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8 maximize 16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8 maximize 16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8 127 16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8 127 16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8 0 16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8 0 16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8 4A 16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8 44 16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8 5 - LED Abblendlicht 16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8 Always 16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8 Versorgungsbedarf der LCM Module 16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8 not active 16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8 Parking light right 16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8 not active 16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8 not active 16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8 not active 16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8 not active 16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9 maximize 16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9 maximize 16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9 maximize 16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9 127 16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9 127 16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9 0 16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9 0 16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9 49 16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9 3A 16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9 5 - LED Abblendlicht 16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9 Always 16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9 Versorgungsbedarf der LCM Module 16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9 not active 16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9 not active 16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9 not active 16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9 not active 16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9 not active 16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck 26 08 00 16 02 00 7F 00 00 00 00 00 00 00 00 00 26 18 00 18 04 00 7F 00 00 00 00 00 00 00 00 00 22 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 22 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 2A 29 00 2C 18 24 7F 00 00 00 00 00 00 00 00 00 20 0A 00 35 08 09 7F 00 00 00 00 00 00 00 00 00 20 1A 00 36 08 0A 7F 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 1C 00 2F 1C 00 FF 00 00 00 00 00 00 00 00 00 24 00 00 62 3F 00 7F 00 00 80 00 00 00 00 00 00 20 0B 00 31 19 00 FF 00 00 00 00 00 00 00 00 00 20 1B 00 32 19 00 FF 1C 00 80 00 00 00 00 00 00 192
ENG141662-Leuchtenkonfiguration_Sonstiges 26 08 00 41 02 00 7F 00 00 00 00 00 00 00 00 00 26 18 00 42 04 00 7F 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 59 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 128
ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR 1-Sensor_LWR 62
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges 0 mm 62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe not active 62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze 90.00% 62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze 10.00% 62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung -114.3 ms 62
ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz 15% 62
ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe 10.0 s 62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1 -8.00 mm/% 62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2 -8.00 mm/% 62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3 -8.00 mm/% 62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1 -8.00 mm/% 62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2 -8.00 mm/% 62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3 -8.00 mm/% 62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante Variante_1 62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR 0.00% 62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf 0.00 Hz 62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung normal 62
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal Negative 62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1 0 mm 62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2 0 mm 62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3 0 mm 62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4 0 mm 62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand 0 mm 62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe 0 mm 62
ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle 95.00% 62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle 5.00% 62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr 0 km/h 62
ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr 100 Hz 62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung 0.00 Hz 62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte CAN_Daempferregelung 62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed not installed 62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht active 62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese 20.00% 62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart not active 62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad 0.0 %/s 62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht -100.00% 62
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut not installed 62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR 0.00 s 62
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1 not active 1
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2 not active 1
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3 not active 1
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4 not active 1
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5 not active 1
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6 not active 1
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ not active 1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0 0.00% 12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1 5.00% 12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2 50.00% 12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3 75.00% 12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4 110 12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5 126.5 12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0 0.00% 12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1 6.00% 12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2 16.00% 12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3 30.00% 12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4 60.00% 12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5 100.00% 12
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0 -5.00% 20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1 -5.00% 20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2 -5.00% 20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3 -5.00% 20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4 -5.00% 20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0 -5 20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1 -5 20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2 -5 20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3 -5 20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4 -5 20
ENG122979-ENG141954-Networking-A/C electronics installed 8
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet not installed 8
ENG122979-ENG141974-Networking-Bremsen_Steuergeraet installed 8
ENG122979-ENG141953-Networking-Getriebesteuergeraet installed 8
ENG122979-ENG99457-Networking-Head area heater not installed 8
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG not installed 8
ENG122979-ENG141969-Networking-UGDO not installed 8
ENG124714-ENG142044-OCU-DWA_push not active 8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare active 8
ENG124714-OCU- not installed 8
ENG124714-ENG142261-OCU-Remote HuF Abbruch 20 km/h 8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz 3 Hz 8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1 80 s 8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3 2000 ms 8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock not_active 8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar active 16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten 4 16
ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung not active 16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar active 16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv active 16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion profiles_active 16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar active 16
ENG98831-ENG142030-Personalization-Profil_Variante Konto (v. 1.x) 16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1 active 16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2 active 16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3 active 16
ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4 not active 16
ENG141646-MAS01065-Querschnitts_funktionen-Brand VW 5
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll active 5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung active 5
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung not active 5
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21 active 5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus Pin A31 5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe Sollspannungsanforderung 13.5 5
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben active 5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme not_installed 5
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem not active 5
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment Right 5
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side Left 5
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung 10 10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system installed 10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel not active 10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit 2000 ms 10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit 370 ms 10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit 0 ms 10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit 0 ms 10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit 370 ms 10
ENG115729-ENG154424-Scheinwerferreinigung-Waschen Keine_Spannungsanforderung 10
ENG141684-SFT271873-Slave_systems_identification-Control Unit For Wiper Motor Not available 6
ENG141684-SFT271874-Slave_systems_identification-Rain Light Recognition Sensor Not available 6
ENG141684-SFT271875-Slave_systems_identification-Light switch Not available 6
ENG141684-SFT271876-Slave_systems_identification-Garage door opener control module Not available 6
ENG141684-SFT271877-Slave_systems_identification-Garage Door Opener Operating Unit Not available 6
ENG141684-SFT271894-Slave_systems_identification-Sensor For Anti Theft Alarm System Not available 6
ENG141684-SFT271896-Slave_systems_identification-Alarm horn Not available 6
ENG141684-SFT271904-Slave_systems_identification-Sun Roof Not available 6
ENG141684-SFT271910-Slave_systems_identification-Ceiling Light Module Not available 6
ENG141684-SFT271928-Slave_systems_identification-Roof Blind Not available 6
ENG141684-SFT271947-Slave_systems_identification-Relative Air Humidity Interior Sender Not available 6
ENG141684-SFT271966-Slave_systems_identification-Neck Heating Left Not available 6
ENG141684-SFT271967-Slave_systems_identification-Neck Heating Right Not available 6
ENG141684-SFT272065-Slave_systems_identification-Seat Backrest Fan 1 Front Left Not available 6
ENG141684-SFT272067-Slave_systems_identification-Seat Cushion Fan 1 Front Left Not available 6
ENG141684-SFT272069-Slave_systems_identification-Seat Backrest Fan 1 Front Right Not available 6
ENG141684-SFT272071-Slave_systems_identification-Seat Cushion Fan 1 Front Right Not available 6
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker MFG 4
ENG116588-Sonderfunktionen- not enabled 4
ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1 not installed 4
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen active 5
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus by look command via remote control key 5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen active 5
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung active 5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung active 5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel active 5
ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung active 5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt active 5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung active 5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron active 5
ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt 250 10
ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel 10 km/h 10
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter CAN 10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel 10.0 min 10
ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen 40 ms 10
ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0 0.0 lx 10
ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1 8.0 lx 10
ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2 50.0 lx 10
ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3 80.0 lx 10
ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4 100.0 lx 10
ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0 6 10
ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1 6 10
ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2 20 10
ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3 50 10
ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4 100 10
ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0 0.0 lx 10
ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1 8.0 lx 10
ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2 50.0 lx 10
ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3 80.0 lx 10
ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4 100.0 lx 10
ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0 6 10
ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1 6 10
ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2 20 10
ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3 50 10
ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4 100 10
ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x0 0 ms 22
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1 200 ms 22
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10 2000 ms 22
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2 400 ms 22
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3 600 ms 22
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4 800 ms 22
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5 1000 ms 22
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6 1200 ms 22
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7 1400 ms 22
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8 1600 ms 22
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9 1800 ms 22
ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0 100.00% 22
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1 100.00% 22
ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10 0.00% 22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2 95.00% 22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3 80.00% 22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4 40.00% 22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5 20.00% 22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6 10.00% 22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7 5.00% 22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8 3.00% 22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9 1.00% 22
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM 0.00 s 21
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM 0.00 s 21
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM 0.00 s 21
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM 0.00 s 21
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM 0.00 s 21
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung HMI 21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen 20.0 s 21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen 3.0 s 21
ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe not active 21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten not_active 21
ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung active 21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS 2 21
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM 0.00 s 21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert 50% 21
ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl Fotosensor_Kombi 21
ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung Always active 21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor 0.1 21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert 10.00% 21
ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0 0 22
ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1 50 22
ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10 0 22
ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2 100 22
ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3 200 22
ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4 253 22
ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5 0 22
ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6 0 22
ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7 0 22
ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8 0 22
ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9 0 22
ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y0 0 lx 22
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1 50 lx 22
ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y10 0 lx 22
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2 100 lx 22
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3 200 22
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4 500 22
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5 0 22
ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y6 0 lx 22
ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y7 0 lx 22
ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y8 0 lx 22
ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y9 0 lx 22
ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x0 0 ms 22
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1 200 ms 22
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10 2000 ms 22
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2 400 ms 22
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3 600 ms 22
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4 800 ms 22
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5 1000 ms 22
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6 1200 ms 22
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7 1400 ms 22
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8 1600 ms 22
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9 1800 ms 22
ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0 0.00% 22
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1 1.00% 22
ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10 100.00% 22
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2 3.00% 22
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3 5.00% 22
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4 11.00% 22
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5 22.00% 22
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6 40.00% 22
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7 80.00% 22
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8 95.00% 22
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9 100.00% 22
ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x0 0 lx 8
ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X1 8 lx 8
ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X2 50 lx 8
ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3 500 lx 8
ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0 100 8
ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1 100 8
ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2 100 8
ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3 100 8
ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x0 0 lx 8
ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X1 8 lx 8
ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X2 50 lx 8
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3 500 lx 8
ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0 6 8
ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1 6 8
ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2 100 8
ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3 100 8
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0 0.00% 12
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1 6.00% 12
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2 16.00% 12
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3 30.00% 12
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4 60.00% 12
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5 100.00% 12
ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0 10 12
ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1 10 12
ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2 100 12
ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3 150 12
ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4 220 12
ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5 253 12
ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x0 0 lx 10
ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X1 8 lx 10
ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2 200 lx 10
ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3 300 lx 10
ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4 500 lx 10
ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0 16 10
ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1 16 10
ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2 100 10
ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3 100 10
ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4 100 10
ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x0 0 lx 10
ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1 50 lx 10
ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2 220 lx 10
ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3 300 lx 10
ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4 500 lx 10
ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0 6 10
ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1 16 10
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2 25 10
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3 30 10
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4 50 10
ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0 0 12
ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1 10 12
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2 50 12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3 100 12
ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4 220 12
ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5 253 12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0 2.00% 12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1 2.00% 12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2 6.00% 12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3 10.00% 12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4 80.00% 12
ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5 100.00% 12
ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x0 0 lx 8
ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X1 8 lx 8
ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X2 50 lx 8
ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3 500 lx 8
ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0 6 8
ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1 6 8
ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2 100 8
ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3 100 8
ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x0 0 lx 8
ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X1 8 lx 8
ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X2 50 lx 8
ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3 500 lx 8
ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0 100 8
ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1 100 8
ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2 100 8
ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3 100 8
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0 0.00% 6
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1 50.00% 6
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2 100.00% 6
ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0 0.00% 6
ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1 50.00% 6
ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2 100.00% 6
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0 0 lx 12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1 10 lx 12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2 100 lx 12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3 500 lx 12
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4 800 lx 12
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5 1020 lx 12
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0 0 12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1 20 12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2 80 12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3 180 12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4 300 12
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5 500 12
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0 0 ms 10
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1 2000 ms 10
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2 3000 ms 10
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3 4000 ms 10
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4 5100 ms 10
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0 1.00% 10
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1 5 10
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2 15 10
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3 40 10
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4 100 10
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen not active 4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen not active 4
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen tilting 4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1 not installed 4
ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3 not installed 4
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo not installed 4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule LIN 4
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck not_installed 9
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck active 9
ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv active 9
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb not active 9
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close not installed 9
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global active 9
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen active 9
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen active 9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf not active 9
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen active 9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung nur wenn mind. 1 Raste zu 9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden Always 9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit installed 9
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach not active 9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung active 9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy active 9
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder active 9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung active 9
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy active 9
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder active 9
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal active 9
ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba active 9
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau installed 9
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1 00 00 20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2 00 00 20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3 00 00 20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4 00 00 20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1 00 00 20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2 00 00 20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3 00 00 20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4 00 00 20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5 00 00 20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6 00 00 20
ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB not active 7
ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern not active 7
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster active 7
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein active 7
ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein not active 7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt not installed 7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster not installed 7
ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktion not active 7
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung active 7
ENG141651-ENG115755-ZV allgemein-Notschließfunktion active 7
ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessung not active 7
ENG141651-ENG141957-ZV allgemein-Radio freq. 434.42MHz 7
ENG141651-ENG141958-ZV allgemein-Tankschloss Bidirectional 7
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum Freigabe_Softtouch 7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung Einzeltuerentriegelung 7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion not installed 7
ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck active 3
ENG141654-ENG116621-ZV Autolock-automatisches Entriegeln active 3
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit not active 3
ENG141654-ENG116706-ZV Autolock-Autounlock NAR not active 3
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung not active 3
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock adjustable 3
ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren active 4
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen active 4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash not active 4
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels active 7
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang not active 7
ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster not active 7
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster via_CAN 7
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung not active 7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen not active 7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste Yes 7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung Kontaktsteuerung mit Mindestansteuerzeit 7
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster 0.0 s 7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt not active 7
ENG141653-ENG141982-ZV Heck-Tausch_Tank_Hecktreiberausgang No 7
ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel active 7
ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen not active 7
ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp 1 or 2 notch rear actuator 7
ENG141681-IDE02021-ZV Komfort-Comfort closing active 8
ENG141681-IDE02022-ZV Komfort-Comfort opening not active 8
ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hinten Yes 8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen active 8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen active 8
ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit 600 s 8
ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus active 8
ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen active 8
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen active 8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen active 8
ENG141681-ENG115670-ZV Komfort-Komfortbedienung global active 8
ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer not active 8
ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar adjustable 8
ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen not active 8
ENG141681-ENG125656-ZV Komfort-Regenschliessen_art once 8
ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus not active 8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen not active 8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen not active 8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss Tuersteuergeraet im Fond verbaut oder keine Fondtuer 5
ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal nicht invertiert 5
ENG141652-ENG142039-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite not installed 5
ENG141652-ENG142038-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite not installed 5
ENG141652-ENG142001-ZV Türkonfiguration-Schiebetuer_links No 5
ENG141652-ENG142002-ZV Türkonfiguration-Schiebetuer_rechts No 5
ENG141652-ENG142041-ZV Türkonfiguration-Schiebetueren_Crafter not installed 5
ENG141652-ENG142244-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCM Driver side 5
ENG141652-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe not active 5
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR No 5
ENG141652-ENG141959-ZV Türkonfiguration-Viertuerer Yes 5
Elapsed Time: 01:53
10-Park/Steer Assist
;SW:5QA-919-298-C HW:5QA-919-298-A --- Park/Steer Assist
;Component:PLA 3.0 12KH07 0045 Coding:0371267851
;EV_EPHVA2CAU3700000 9037 EV_EPHVA2CAU3700000_009_VW37.rod
;Thursday 22 March 2018 16:30:29:60782
;VCDS Version: Release 18.2.0 (x64) Data version: 20180212 DS287.0
;VCID: 50EC810F0B0E5DC4C8-8004
IDE00001-Production mode Deactivating 3
IDE00820-ENG118120-Activating and deactivating all development messages-Dev_Id_High_Nibble not activated 1
IDE00820-ENG118119-Activating and deactivating all development messages-Dev_Id_Low_Nibble not activated 1
IDE00845-Wheel circ. 2100 mm 2
IDE01165-Park assist activation tone On 1
IDE01167-Convertible offset for volume level 1 255 1
IDE01168-Increment for convertible volume levels 255 1
IDE01169-Audio reduction request On 1
IDE02328-Distance to curb 15 cm 1
IDE02332-Deactivate production mode 0 3
IDE03782-Switch-off speed for parking assist 14 km/h 1
IDE03783-Switch-on speed for parallel parking assist 37 km/h 1
IDE04159-Deactivation of start-stop function Start-stop function in control module active 1
IDE05274-Acoustic warning for rear lid assistant not active 1
IDE06425-Roller test bench mode: functional not activated 1
IDE11215-Automatic Activation activated 1
MAS01426-Speaker volume for rear park assist Stage 6 1
MAS01427-Speaker frequency for rear park assist Stage 4 1
MAS01428-Speaker volume for front park assist Stage 4 1
MAS01429-Speaker frequency for front park assist Stage 6 1
MAS10106-MAS10103-ARA angle control parameter-Max. controllable corners 0.180 1/m 6
MAS10106-MAS10104-ARA angle control parameter-Max. selectable corners 1.308 1/m 6
MAS10106-MAS10105-ARA angle control parameter-Vehicle overhang 1.112 m 6
MAS12129-Customer-oriented off-road trip not activated 1
MAS12843-Maneuvering brake function activated 1
Elapsed Time: 00:09
