Hi, I need reprogram Airbag Unit,
Please.
Please.
Monday,26,March,2018,14:15:10:49232
VCDS Version: 18.2.0.3 (x64)
Dealer/Shop Name: crosswagen
Workshop Code: 935 01530 000006
VIN: 9BWAL45Z9H4021191 License Plate:
Chassis Type: 5Z-VW21 (5Z - VW Fox (2004 >))
Scan: 01 03 08 09 15 17 19 44 46 56
VIN: 9BWAL45Z9H4021191 Mileage: 800km-497miles
Address 01: Engine (J623-CWSA) Labels: None
Part No SW: 04E 906 032 J HW: 04E 907 425
Component: 1.6l R4 MPI H07 2806
Revision: --H07---
Coding: 00190012020480000000
Shop #: WSC 01530 935 00200
ASAM Dataset: EV_ECM16MPI02104E906032J 001006
ROD: EV_ECM16MPI02104E906032A.rod
VCID: 275DDA075E2D447C79-8072
14875 - No Communications with Airbag Control Module
U0151 00 [039] - -
Mileage: 809 km
Date: 2012.14.12
Time: 01:52:43
Coolant temperature: 37 °C
Intake air temperature: 29 °C
Ambient air pressure: 740 mbar
Voltage terminal 30: 12.207 V
Time since engine start: 0 s
Engine torque: 1.87500 Nm
Accelerator pedal travel-Accelerator position: 0.00 %
Ignition angle of current cylinder: actual value-Ignition angle: actual: 0.000 °
Part No SW: 5U0 907 379 C HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0004
Serial number: --------------
Coding: F1DC908D222503C18F1509724452C0408900
ASAM Dataset: EV_Brake1ESP90iBOSCH 004034
ROD: EV_Brake1ESP90iBOSCH_004.rod
VCID: 408F619BDB43934458-8014
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 089 HW: 7E0 937 089
Component: BCM PQ25 MMI4 H80 0736
Revision: BB080001 Serial number: 17007143161388
Coding: 3A8CCB3A4C3BC600103A00C02C08B880B000629C60802000240580020000
VCID: 70EFF15BA36343C4E8-8024
Subsystem 1 - Part No SW: 5Z0 959 800 B HW: 5Z0 959 800 B
Component: ZFH_Cross H08 0015
Serial number: 3982FL00001606090252
Coding: 006B54
Subsystem 2 - Part No SW: 5Z0 959 800 B HW: 5Z0 959 800 B
Coding: 006B54
Subsystem 3 - Part No: 5Z0 951 171 E
Component: DWA-Sensor 00 004 0008
Subsystem 4 - Part No SW: 18D 959 442 HW: 18D 959 442
Component: E221__MFL-YLG H01 0110
Serial number: 000000000A0510160616
Coding: 200000
Subsystem 5 - Part No SW: 5Z0 959 800 B HW: 5Z0 959 800 B
Coding: 006B54
Subsystem 6 - Part No SW: 5Z0 959 800 B HW: 5Z0 959 800 B
Coding: 006B54
Address 17: Instruments (J285) Labels:* 5Zx-920-xxx-17.lbl-SRI1
Part No SW: 5Z0 920 865 C HW: 5Z0 920 865 C
Component: KOMBI H08 0014
Coding: 850A0A
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04726
ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
12669184 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 71
Mileage: 809 km
Date: 2012.14.12
Time: 01:52:44
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 089
Component: GW-K-CAN TP20 H80 0736
Revision: BB080001
Coding: 002200
VCID: 68DF993B9BB38B04B0-803C
Reset counter: 71
Mileage: 809 km
Date: 2012.14.12
Time: 01:52:43
03075 - Parallel Parking Assistance Control Module (J791)
Reset counter: 71
Mileage: 809 km
Date: 2012.14.12
Time: 01:05:18
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 5Z1 909 144 F HW: 5Z1 909 144
Component: EPS_ECU 402 4050
Coding: 004F
ASAM Dataset: EV_SteerAssisNSKGen2 005109
ROD: EV_SteerAssisNSKGen2_005.rod
VCID: 4189649FD0499A4C57-8014
0178 - Databus
Reset counter: 71
Mileage: 809 km
Date: 2012.14.12
Time: 01:52:44
Single Additional Freeze Frame:
Address 46: Central Conv. Labels: None
Part No: 5Z0 959 800 B
Component: Z F H GOL/FOX H08 0015
VCID: 408F619B1043934458-4B00
Address 56: Radio (J503) Labels: None
Part No SW: 6RF 035 187 HW: 6RF 035 187
Component: Radio 019 0120
Revision: -------- Serial number: VWZGZ1S1950768
Coding: 0000041002000E
VCID: 0603B783B1E77D7422-8052
01327 - Control Module for Parking Aid (J446)
Reset counter: 71
Mileage: 809 km
Date: 2012.00.12
Time: 01:05:53
End-------------------------(Elapsed Time: 02:29)--------------------------
