- Joined
- Mar 9, 2015
- Messages
- 475
- Reaction score
- 336
- Location
- Australia
- VCDS Serial number
- C?ID=241363
2018 Q7 3.0 TDI 200kw CRT - Australia
The only PR codes of note were:
PRCode: 1BA = Standard suspension/shock absorption
PRCode: 3FU = Big roof system
PRCode: 4I3 = Central locking system Keyless Entry without deadlock
PRCode: 5TT = Decorative inserts
PRCode: 9VD = Speaker (active)
PRCode: I8H = Radio High (Japan)
PRCode: TS8 = 6-cylinder diesel engine 3.0 l unit 059.L
Autoscan:
Autoscan:
Friday,23,March,2018,14:51:30:58930
VCDS Version: 18.2.0.3 (x64) HEX-V2 CB: 0.4411.4
VIN: WAUZZZ4M8JD01xxxx License Plate:
Mileage: 366km-227mi Repair Order:
Chassis Type: 4M-AU73 (4M4)
Scan: 01 02 03 08 09 13 15 16 17 19 28 29 36 39 3C 42 44 46 50 52
5F 65 6C 6D 81 8B A5 AC BB BC CA CF
VIN: WAUZZZ4M8JD01xxxx Mileage: 366km-227miles
50-Seat Adj. 3rd row -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CRTC) Labels: Redir Fail!
Part No SW: 4M0 907 401 HW: 059 907 309 B
Component: 3.0TDI EDC17 H46 0006
Revision: 91H46---
Coding: 2A2A40320566050334380000000000000000000000000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0114M0907401 001010
ROD: EV_ECM30TDI0114M0907401.rod
VCID: 6695485398E9AE17E84-8032
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4M0 927 158 J HW: 0D5 927 156 H
Component: 0D5 30TDIRdW H05 1016
Revision: --H05---
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002010
ROD: EV_TCMALX52011.rod
VCID: 3B23C927B3EBC3FF67A-806E
Address 03: ABS Brakes (J104) Labels:. 4M0-907-379-PRE-V1.clb
Part No SW: 4M0 907 379 Q HW: 4M0 907 379 N
Component: ESP9 Premium H09 0657
Coding: 289830B230A30A9E91A25894007E12A2E6A6DA140C0C50891A00484567655B
ASAM Dataset: EV_ESP9BOSCHAU536K 012013
ROD: EV_ESP9BOSCHAU536K.rod
VCID: 45D7AFDFC52F850F01E-8010
36 Faults Found:
345856 - Databus
U1121 00 [032] - Missing Message
[ComScl:_PDU_BCM_Taster_01_-_Timeout_error]
171264 - Databus
[ComScl:_PDU_Dimmung_01-_Timeout_error]
268544 - Databus
[ComScl:_PDU_Klima_Sensor_02-_Timeout_error]
496896 - Databus
[ComScl:_PDU_Kombi_01-_Timeout_error]
16384 - Databus
[ComScl:_PDU_Kombi_02-_Timeout_error]
16640 - Databus
[ComScl:_PDU_Kombi_03-_Timeout_error]
199936 - Databus
[ComScl:_PDU_LWR_AFS_01-_Timeout_error]
475904 - Databus
[ComScl:_PDU_Licht_hinten_01-_Timeout_error]
488448 - Databus
[ComScl:_PDU_Motor_01_-_Timeout_error]
356352 - Databus
[ComScl:_PDU_Motor_35-_Timeout_error]
12648455 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [032] - -
[ComScl:_PDU_OBD_01-_Timeout_error]
337664 - Databus
[ComScl:_Signal_Group_SG_ACC_07_-_Timeout_error]
271360 - Databus
[ComScl:_Signal_Group_SG_ACC_10-_Timeout_error]
15371776 - Databus
[ComScl:_Signal_Group_SG_AEB_01_-_Timeout_error]
272128 - Databus
[ComScl:_Signal_Group_SG_Airbag_01-_Timeout_error]
333312 - Databus
[ComScl:_Signal_Group_SG_Airbag_02-_Timeout_error]
272896 - Databus
[ComScl:_Signal_Group_SG_Airbag_03-_Timeout_error]
404480 - Databus
[ComScl:_Signal_Group_SG_FCW_02_-_Timeout_error]
12648705 - No Communication with Transmission Control Module
U0101 00 [032] - -
[ComScl:_Signal_Group_SG_Getriebe_11-_Timeout_error]
12648704 - No Communication with Transmission Control Module
U0101 00 [032] - -
[ComScl:_Signal_Group_SG_Getriebe_13-_Timeout_error]
473088 - Databus
[ComScl:_Signal_Group_SG_Getriebe_15-_Timeout_error]
278272 - Databus
[ComScl:_Signal_Group_SG_LH_EPS_02-_Timeout_error]
279040 - Databus
[ComScl:_Signal_Group_SG_LH_EPS_03-_Timeout_error]
12658176 - No Communications with Steering Angle Sender (G85)
U0126 00 [032] - -
[ComScl:_Signal_Group_SG_LWI_01-_Timeout_error]
12648454 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [032] - -
[ComScl:_Signal_Group_SG_Motor_11-_Timeout_error]
12648449 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [032] - -
[ComScl:_Signal_Group_SG_Motor_12-_Timeout_error]
12648450 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [032] - -
[ComScl:_Signal_Group_SG_Motor_14-_Timeout_error]
12648451 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [032] - -
[ComScl:_Signal_Group_SG_Motor_20-_Timeout_error]
15386112 - Databus
[ComScl:_PDU_Motor_28-_Timeout_error]
12648452 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [032] - -
[ComScl:_Signal_Group_SG_Motor_Code_01-_Timeout_error]
451328 - Databus
[ComScl:_Signal_Group_SG_RCTA_01_-_Timeout_error]
12669184 - No Communications with Airbag Control Module
U0151 00 [032] - -
[ComScl:_Signal_Group_SG_SARA_06-_Timeout_error]
449792 - Databus
[ComScl:_Signal_Group_SG_TSG_FT_02-_Timeout_error]
288512 - Databus
[ComScl:_Signal_Group_SG_TSK_06-_Timeout_error]
360960 - Databus
[ComScl:_Signal_Group_SG_TSK_08-_Timeout_error]
494080 - Unknown Error Code
C1254 F0 [032] - Unknown Error Elaboration
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 4M0 820 043 AD HW: 4M0 820 043 AD
Component: Klima Zone 4 H52 0100
Coding: 661809BC5544441112200180800000000000000000000000000000000000
ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
ROD: EV_AirCondiFrontBHTCAU736.rod
VCID: 678B45579FE3B71FD32-8032
Subsystem 1 - Part No SW: 4M2 820 021 A HW: 4M2 820 021 A
Component: J126 FLuftV H08 0003
Serial number: 00000000000001808959
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H02 0007
Serial number: 6A801BC800PAG0MUFU02
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Coding: C2501942C17900CD050D57185B2F0CF913033101900000000000000060001A01004100AB22B70A
VCID: 025D74C39481723764C-8056
Subsystem 1 - Part No SW: 4M2 955 119 A HW: 4H1 955 119 C Labels: 1KX-955-119.CLB
Component: WWS536 170721 044 0893
Serial number: 90125300401720200391
Coding: 1BC7F7
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 20414550X81A955547A0
Coding: 02006E
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 AA HW: 4M0 941 531 AA
Component: E1 - LDS H06 0008
Serial number: 15 08 2017 01087000
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE128061723611041
Coding: 210000
Interior Light Module:
Subsystem 5 - Part No SW: 4M0 947 135 AB HW: 4M0 947 135
Component: J528-Dachele H14 0130
Serial number: Q00483998
Electrically Adjustable Steering Column:
Subsystem 6 - Part No SW: 80A 907 705 HW: 80A 907 705
Component: J866-EVLS-SG H03 0080
Serial number: WA129274000038880874
Coding: 0A0100
Subsystem 7 - Part No SW: 4M0 925 301 L HW: 4M0 925 301 L
Component: SL-Q7NF/AU736 H10 0013
Serial number: 00000000000000065107
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 4M0 907 561 E HW: 4M0 907 561
Component: LRR4 H10 0220
Coding: 3476E7F358FFEC0A949880A0
ASAM Dataset: EV_ACCBOSCHAU736 002018
ROD: EV_ACCBOSCHAU49X_002.rod
VCID: 323DE40364A102B7B4C-8066
Address 15: Airbags (J234) Labels:* None
Part No SW: 4M0 959 655 E HW: 4M0 959 655 E
Component: Airbag10.44 H01 0106
Serial number: 003UL001ESNY
Coding: AAFCF0D80C80000098F65033D0CC00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006015
ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
VCID: 3D27C73FADFFCDCF59E-8068
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 HW: 4M0 980 945
Component: BeltPretRevFL 205 2033
Serial number: 4M0857705M0258R00631
Coding: 88001B
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 HW: 4M0 980 946
Component: BeltPretRevFR 205 2033
Serial number: 4M0857706L0258R01033
Coding: 88001B
Subsystem 3 - Part No SW: ----------- HW: 442 063 107 17
Serial number: 3577Y00A72474D52237-
Subsystem 4 - Part No SW: ----------- HW: 442 063 107 17
Serial number: 3587Y00B92474D43B310
Subsystem 5 - Part No SW: ----------- HW: 442 0B2 508 17
Component: SideSensor_Dr 1C7 0148
Serial number: 3517700A327ACA05718C
Subsystem 6 - Part No SW: ----------- HW: 442 0B2 508 17
Serial number: 3527700B5270C084A2FE
Subsystem 7 - Part No SW: ----------- HW: 442 0C2 007 17
Component: FrontSensor_D 1C5 014A
Serial number: 35575009D2777811212%
Front Sensor Passenger:
Subsystem 8 - Part No SW: ----------- HW: 442 0C1 407 17
Component: FrontSensor_P 1C5 014A
Serial number: 3567500A327778260372
Pedestrian Protection Center:
Subsystem 9 - Part No SW: ----------- HW: 442 0C0 109 17
Component: PedP_Sensor_C 1C5 014A
Serial number: 2307500A7279CC5342FJ
Subsystem 10 - Part No SW: ----------- HW: 442 420 708 17
Component: PedPSensor_D2 21E 0887
Serial number: I0M8U00C3249F6C0D26X
Subsystem 11 - Part No SW: ----------- HW: 442 420 708 17
Component: PedPSensor_P2 21E 0887
Serial number: I0N8U00BB249F6C2525Y
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 HL HW: 4M0 907 129 HL
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 015F7BCF9187692F7D6-8054
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 4M0 920 790 C HW: 4M0 920 790 C
Component: FBenRDW H18 0370
Coding: 258400C06C9800080183E9601000000000000000
ASAM Dataset: EV_DashBoardAU736 001027
VCID: 2F3BED7777932F5FDB2-807A
Part No SW: 4M4 907 468 E HW: 4M4 907 468 E
Component: Gateway H22 0119
Revision: 6Y060004 Serial number: 0446Y003C17912
Coding: 03010001000086407F07000000590032DC1A0007100000000100000000000000
ASAM Dataset: EV_GatewCONTIAU736 003092
ROD: EV_GatewCONTIAU736_VW53.rod
VCID: 3C21CA3BB6E5C4C76E0-8068
Subsystem 1 - Part No SW: 4M0 951 523 HW: 4M0 951 523
Component: J453 MFL H06 0002
Serial number: 20170915002316 00056
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 0482895204
131723 - Body Control Module (Central Electric 2)
U0141 00 [008] - No Communications
[Timeout_Node_0x8B_DiagAdress_46_BCM2]
Reset counter: 40
Mileage: 26 km
Date: 2018.03.15
Time: 18:35:26
Address 28: HVAC, Rear (E265) Labels:* None
Part No SW: 4M0 919 158 C HW: 4M0 919 158 C
Component: Klima Zone 2 H52 0103
Coding: 000000000000040100800080000000000000000000000000000000000000
ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
ROD: EV_AirCondiFondBHTCAU736.rod
VCID: 3537DF1F95CF158F91E-8060
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AA HW: 4M0 907 397 A
Component: LCM_MLBevoH05 0024
VCID: 76B51813C8495E97584-8022
Address 36: Seat Mem. Drvr (J136) Labels:* None
Part No SW: 4M1 959 760 HW: 4M1 959 760
Component: MEM-FS 008 0031
Serial number: 00000277974102
Coding: 00781B000000B0010000010101010000000000000000000000000000000000
ROD: EV_SCMDriveSideCONTIAU736.rod
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4M0 907 566 D HW: 4M0 907 566
Component: MRR1Rear H18 0410
Revision: --------
Coding: 4EC002
ASAM Dataset: EV_RearRadarS1BoschAU736 001022
ROD: EV_RearRadarS1BoschAU736.rod
VCID: 3635D81388C91E97984-8062
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M0 959 793 H HW: 4M0 959 793 F
Component: TSG FS 005 0125
Serial number: 0000278218093
Coding: 001D9B005E010080000130B0
ROD: EV_DCU2DriveSideMAXHCONT.rod
VCID: 43D3B1C7CB1BBB3F2FA-8016
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 4M0 909 144 H HW: 4M0 909 144 B
Component: EPS_MLBEVO1BS H22 0005
Serial number: 0000134161
Coding: B0110101000101
ASAM Dataset: EV_EPSVWBSAU736 009023
ROD: EV_EPSVWBSAU736_009.rod
VCID: 3431E21B9EB50C87A60-8060
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 8W0 907 064 DD HW: 8W0 907 064 DD
Component: BCM2 MLBevo 019 0366
Coding: 01351E00002000C0630980006E00180203024000804F00502F0400000504803F001F0001000000
ASAM Dataset: EV_BCM2HellaAU736 013013
ROD: EV_BCM2HellaAU736_013_AU73.rod
Ignition key:
Subsystem 1 - Part No SW: 4M0 959 754 T HW: 4M0 959 754 T
Component: ID-Geber H40 0105
Serial number: 3617000167634009
Subsystem 2 - Part No SW: 3AA 962 243 F HW: 3AA 962 243 F
Component: GEB.F.Heckoef H16 0816
Serial number: 94242918
Address 50: Seat Adj. 3rd row (J857) Labels:* None
Part No SW: 4M1 959 760 G HW: 4M1 959 760 G
Component: MEM-SR3 008 0016
Serial number: 00000279361534
Coding: FF201020F1000000000F000000000900000021210900000000000000440000
ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
ROD: EV_SCM3rdRowCONTIAU736.rod
Part No SW: 4M0 959 792 H HW: 4M0 959 792 F
Component: TSG BFS 005 0125
Serial number: 0000278375352
ROD: EV_DCU2PasseSideMAXHCONT.rod
VCID: 42DDB4C3D401B23724C-8016
Part No SW: 4M1 035 041 A HW: 4M1 035 041
Component: MU-P-LND-RW 034 1117
Serial number: A747I0HB002817
Coding: 01370608FF0A000013511101000A00102F001BE601700104DE
ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
VCID: 20191E4B3A4D8027528-8074
Subsystem 1 - Part No SW: V03 959 801 PT HW: -----------
Component: ROW 2017/2018 --- 0065
Subsystem 2 - Part No SW: 4M0 919 605 HW: 4M0 919 605
Component: AU536_DU_HIGH H43 0008
Serial number: AUZ8Z9HJ404ZZP
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4M0 919 615 H HW: 4M0 919 615 H
Component: ControlUnit_P H15 0209
Serial number: 19091700000000000535
Component: Gracenote2 --- 4012
Address 65: Tire Pressure (J502) Labels: None
Part No SW: 4M0 907 273 B HW: 4M0 907 273 B
Component: RDKHUFAU736 H05 0010
Serial number: 30000000012454
ASAM Dataset: EV_RDKHUFAU736 002007
ROD: EV_RDKHUFAU736_AU37.rod
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4M0 907 428 F HW: 4M0 907 428
Component: Areaview 2 H13 0318
Serial number: C854607JG022439
Coding: 02350601BE0FA10008404084
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 005015
ROD: EV_CamSysRVAV2CE2MLBEv_005.rod
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 4M0 959 107 B HW: 4M0 959 107 A
Component: HDSG-Modul H13 0163
Revision: -------- Serial number: 31543371400000
Coding: 0070
ASAM Dataset: EV_DeckLidCONTIAU736 001015
ROD: EV_DeckLidCONTIAU736_VW27.rod
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 4M2 713 041 E HW: 4M2 713 041 F
Component: GSM-LL H09 0077
Revision: 0L0D5012 Serial number: 17081143714958
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 2809066B527D78671A8-807C
Address 8B: Adaptive Cruise 2 (J850) Labels: 4M0-907-541.clb
Part No SW: 4M0 907 541 E HW: 4M0 907 541
ASAM Dataset: EV_ACC2BOSCHAU736 002018
ROD: EV_ACC2BOSCHAU736_002_AU73.rod
VCID: 3039EE0B6AAD30A7C28-8064
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 4M0 907 217 E HW: 4M0 907 217 E
Component: BVS H16 0050
Coding: 0407030600000401024023A6C50000B4A0F0C010C020
ROD: EV_BVSMLBevKOSTAAU736.rod
Address AC: Reductant Control (J880) Labels: 4M0-907-355.clb
Part No SW: 4M0 907 355 D HW: 4M0 907 355 B
Component: SCR-Stg-G3H04 0006
ASAM Dataset: EV_RDCMINERGAU736 005012
ROD: EV_RDCMINERGAU736.rod
Part No SW: 4M0 959 795 H HW: 4M0 959 795 F
Component: TSG HFS 005 0125
Serial number: 0000278327791
Coding: 000D990000010080000030A0
ROD: EV_DCU2RearDriveMAXHCONT.rod
Component: TSG HBFS 005 0125
Serial number: 0000278327845
ROD: EV_DCU2RearPasseMAXHCONT.rod
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 G HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 7A8000053602
ROD: EV_SunRoofCONTIAU736.rod
VCID: 3A2DCC23BCD1FAF77CC-806E
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 4M0 907 590 D HW: 4M0 907 590
Revision: --------
Coding: 4EC002
ASAM Dataset: EV_RearRadarS2BoschAU736 001022
ROD: EV_RearRadarS2BoschAU736.rod
VCID: 3333E1079BBB0BBFBFA-8066
End----------(Elapsed Time: 02:21, VBatt start/end: 12.2V/12.2V)-----------
