- Jan 12, 2015
- 183
- 15
- Singapore
- C?ID=232348
Hi guys,
I bought second hand golf Mk5 2l Fsi and it keeps going in the limp mode. Also it seems when that happens the mill light (engine check light) does not come up on dash.. It seems the mill light has been disconnected (it never comes up or is it visible). The car starts and engine runs fine until you turn the car/key off. After that it can not be started until it has 1 hour break. There are other issues below listed and they have all been addressed, but Im stuck on :
00576 - Terminal 15
Also from address 46 on-wards , including Cent and doors can not be reached? dont know why?
Any help is appreciated.
Al
_________________________________________
00576 - Terminal 15
Al
Chassis Type: 1K (1K0)
Address 01: Engine Labels: None
Part No SW: 06F 906 056 DE HW: Hardware No
Component: MED9.5.10 G00 7224
Revision: 00000000 Serial number: VWZ7Z0D9987816
Coding: 0000072
Shop #: WSC 00046 412 00000
VCID: 6FEDE09C7E3E273E78-803B
Subsystem 1 - Part No: 06F 907 807 F
Component: NOX 1007100055 002 0409
06F907807F NOX 1007100055 002 0409
17811 - EGR System
P1403 - 008 - Regulation Deviation
16725 - Camshaft Position Sensor (G40)
P0341 - 004 - Implausible Signal - Intermittent
16414 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
P0030 - 004 - Malfunction / Open Circuit - Intermittent
16453 - Intake Manifold Pressure <-> Ambient Air Pressure
P0069 - 008 - Incorrect Correlation - Intermittent
Readiness: 1110 0101
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 N
Component: ASR FRONT MK70 0103
Coding: 0017025
VCID: 3D710AD464D285AEBA-8069
Part No: 1K0 820 047 CR
Component: Climatic PQ35 081 0404
VCID: 76E3D5F8016416F6BB-8023
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 S HW: 1K0 937 049 S*
Component: Bordnetz-SG 1.0 H30 0704
Revision: 00030000 Serial number: 00000000759775
Coding: E48D0F0600041800001400001400000000
VCID: 3F8D70DC6EDE97BEA8-806B
Subsystem 1 - Part No: 1K2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00049109
Subsystem 2 - Part No: 1K0 955 559 AE Labels: 1K0-955-559-AF.CLB
Component: RLS 270306 014 1201
Coding: 00208933
00576 - Terminal 15
01049 - Supply Voltage Term 50
01800 - Light Switch (E1)
Part No SW: 1K0 909 605 D HW: 1K0 909 605 D
Component: 04 AIRBAG VW8 022 0600
Revision: 05022000 Serial number: 0033JD0CPKZ1
Coding: 0012340
VCID: 2D513A94B4B2152E0A-8079
Subsystem 1 - Serial number: 6332MSME7D7D7C02
Subsystem 2 - Serial number: 6342MSME353D5C02
Subsystem 3 - Serial number: 6351HSME360E6201
Subsystem 4 - Serial number: 6361HSME464C2602
Part No SW: 1K0 953 549 B HW: 1K0 953 549 B
Component: Lenksäulenmodul 013 0010
Coding: 0002042
VCID: 316926E4A88A71CE2E-8065
Component: Lenkradmodul 004 0030
Part No: 1K0 920 861 A
Component: KOMBIINSTRUMENT VDD 0814
Coding: 0003703
Shop #: WSC 44300 067 57207
VCID: 275DC8BC964E3F7EF0-8073
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 21001043318B74
Coding: 3D3F0340070003
Address 25: Immobilizer
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K2 909 144 F
Component: EPS_ZFLS Kl.0 1301
VCID: 2F6D209CBEBE673E38-807B
Address 46: Central Conv.
Address 52: Door Elect, Pass.
Address 56: Radio
Address 62: Door, Rear Left
Address 72: Door, Rear Right
End-------------------------(Elapsed Time: 02:21)--------------------------
