Interchanging automatic transmissions ME7
Brkeuro
Central Wisconsin
C?ID=320951
Hey all, first post here. Always creeping around here and always find what I need. Sadly this project is a little bit less cut and dry. Let me begin by saying I am not a professional by any means, I do alot of side work for people and this is a job I probably should have advised against. A guy brought me a blown up 2000 s4 and requested that we maintain his tip transmission, while swapping the engine with a freshly rebuilt awm 1.8 from a 2001 a4. Car starts and drives, the big issue here is that the AWM ecu wont talk to the s4 tcu. I can communicate with the transmission and all modules all day long, throw no codes in the transmission. The second the car starts up she goes into limp mode and states no communication with ecu. After I drove it down the road and back it also showed a speed sensor code and ecu/tcu incompatible. The other issues are worked out in this scan but the ones Im referring to are out of my element. Ive been trying to access the transmission data from each ecu to see if I can either just straight flash over the old files or adjust the torque/gear ratio values in the current ecu to match up with what the tcu wants to see. This is way out of my element, the local tuner wont mess with vdubs. I need advice from someone that has taken a shot in the dark at a similar deal. Not many people maintain their autos when doing this much work but guy insisted on this over a manual swap. Hoping this can be done with flashing and no more physical labor as car is mechanically set.
I appreciate any time taken to read, respond, or critique.
Christopher
 #hndoc:?docid=00003BCB&xt=hnh:F76236A7ED0C796470011CDA40573A4EFF96ED6BBBE83AA55821C63DB8391CFE
VCDS Mobile 0.4407.0.4
Chassis Type:8D
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine	Labels: 06B-906-018-AWM.clb
	Part No SW: 4B0 906 018 CH
	Component: 1.8L R4/5VT     G   0001
	Coding: 16251
	Shop #: WSC 63351 000
	VCID: 69952EA7378BE39ECC1D87FE6F-513C
10 Faults Found:
18058 - Powertrain Data Bus
	P1650 - 35-00 - Missing Message from Instrument Cluster
17837 - Circuit for Brake Vacuum Pump
	P1429 - 35-00 - Open Circuit
18032 - MIL Request Signal Active (Check TCM for errors too!)
	P1624 - 35-10 - - - Intermittent
18320 - Pressure Sensor for Brake Boost (G294)
	P1912 - 35-00 - Short to Plus
16496 - Intake Air Temp. Sensor (G42)
	P0112 - 35-00 - Signal too Low
17633 - Fuel Injector for Cylinder 1 (N30)
	P1225 - 35-00 - Short to Ground
17635 - Fuel Injector for Cylinder 3 (N32)
	P1227 - 35-00 - Short to Ground
17636 - Fuel Injector for Cylinder 4 (N33)
	P1228 - 35-00 - Short to Ground
17634 - Fuel Injector for Cylinder 2 (N31)
	P1226 - 35-00 - Short to Ground
18034 - Powertrain Data Bus
	P1626 - 35-10 - Missing Message from TCU - Intermittent
Address 02: Auto Trans	Labels: 01V-927-156.lbl
	Part No SW: 8D0 927 156 BS
	Component: AG5 01V 2.7l5VT USA 3132
	Coding: 01002
	Shop #: WSC 06325 000
	VCID: 7F4190FF590F7D2E02F979E641-5160
18249 - Engine Control Module / Transmission Control Module Incompatible
	P1841 - 35-00 - -
18258 - Powertrain Data Bus
	P1850 - 35-10 - Missing Message from ECU - Intermittent
17100 - Transmission Input Speed Sensor (G182)
	P0716 - 35-00 - Implausible Signal
Address 03: ABS Brakes	Labels: 8E0-614-111-EDS.lbl
	Part No SW: 8E0 614 111 A
	Component: ABS/EDS 5.3 QUATTRO D1002
	Shop #: WSC 00000 000
	VCID: 1C7B4773A859C636871B364258-51CE
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
Address 08: Auto HVAC	Labels: 8D0-820-043-1D.lbl
	Part No SW: 8D0 820 043 P
	Component: A4     KLIMAAUTOMAT D57
	Coding: 00160
	VCID: 2D1D9AB7C3E33FBEE0C5F30E7B-2596
01272 - Positioning Motor for Central Flap (V70)
00792 - A/C Pressure Switch (F129)
01582 - Signal for Coolant Temperature
Address 15: Airbags	Labels: 8D0-959-655-AI8.lbl
	Part No SW: 8D0 959 655 G
	Component: Airbag Front+Kopf  1002
	Coding: 00304
	VCID: 3A37A1EB02AD9806754780AAC2-5118
01217 - Side Airbag Igniter; Driver Side (N199)
	32-10 - Resistance Too High - Intermittent
Address 17: Instruments	Labels: 8D0-920-xxx-17.lbl
	Part No SW: 8D0 920 980 Q
	Component: B5-KOMBIINSTR. VDO D12
	Coding: 00244
	Shop #: WSC 40205 000
	VCID: 3935BEE707AB931E7C3D77BEDF-5160
No fault codes found.
Address 35: Centr. Locks	Labels: 8D0-862-257.lbl
	Part No SW: 8L0 862 257 N
	Component: CV-Pump             D11
	Coding: 16140
	VCID: 40C3D3036471C2D63B83C21274-4F2E
	35-00 - -
01370 - Alarm triggered by Interior Monitoring
	35-00 - -
00955 - Key 1
	09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor	Labels: 4B0-951-173.lbl
	Part No SW: 4B0 951 173
	Component: Innenraumueberw.    D03
	Coding: 00101
	VCID: E083B38344B122D69BC3A29254-4AA4
Address 55: Xenon Range	Labels: 4B0-907-357-AUT.lbl
	Part No SW: 4B0 907 357
	Component: LEUCHTWEITEREGLER  D003
	Coding: 00012
	VCID: E58DA2975B9347FE68F5DBAE93-5160
Address 56: Radio	Labels: 8D0-035-1xx-56.lbl
	Part No SW: 8D0 035 195 A
	Component:  Radio              D00
	Coding: 00115
	VCID: 240B7F939029FEF63F6B8EA2E0-4B5C
00856 - Radio Antenna
ME7 ECUs (or more specifically the software in them) are generally not interchangeable between manual trans and auto trans applications. That ECU (4B0 906 018 CH) looks to be a manual trans ECU.
Then there's the added complication that the software in the TCU expects a 2.7T engine.. "AG5 01V 2.7l5VT USA" and I'm not sure how happy it will be with anything else.
OP:
What Uwe stated, the stall speed of the TQ converter is different too and it's tampering!
Brkeuro
Central Wisconsin
C?ID=320951
I very much appreciate the understanding and not flaming me for lack of knowledge. In essence I either must swap in the proper 1.8 auto trans, ecu, and tcu, or go manual? Would it be worth sourcing an auto ecu to try? or is it essentially just prolonging the agony at that point. I definitely had a large lapse in judgement on this whole deal. Just want to get the car driving the easiest way possible at this point, without swapping half the driveline and pedals on my dime with my parts. Good thing I love a good learning experience:rolleyes:
If only my youthful confidence came with a bit of old man wisdom.
Retrofits......
Not a qualified repair.
ME7.1 came in the 2.7T S4 and the 1.8T used ME7.5
This is very bad FOD!
I'm reasonably confident the ECU could have auto software put in it, but... I rather doubt that's enough to make the TCU happy. Of course, you could also a matching 1.8T TCU, but then you run into the question of mechanical differences in the transmission; Jack already mentioned a different torque converter stall speed.
Some AWM Audi ECU's for 1.8T of this time frame, support an alternate coding table for selection of the transmission type and other powertrain components.
Brkeuro
Central Wisconsin
C?ID=320951
Thank you two for the conversation, it is all very interesting. Yes, I do realize it was not a professional deal. It was for a more so friend and we were toying with things, I have ordered a rebuild kit for a trans he has and will manual swap the car it looks like. I had known of the software update and the hard wiring differences, I was a fool to think we could make the trans work with a different motor. I do understand that through and through as well. I am always learning, I would not have taken on a job like this for anyone else, i can confidently say that. At least with taking a random shot in the dark at anything, much less something as large as the one thing that transfers power to the wheels. that is interesting about the possible alternate coding, although Im sure that would only extend so far. Using an s4 transmission seems beyond the realm. To access the "alternate coding table" would I have to be using the bench flashing setup and try to dig somewhere im not so comfortable, or is that something that is all accessible and editable with vcds? Again this is strictly for me to learn at this point, car is going manual. and again, not a standard rate customer off the street. Just a decent acquaintance that has a blown s4 and a rebuilt awm engine, figured I would try it in the background and ended up being a lesson learned.
I really appreciate all the information and Im here to soak up as much more as possible. Thank you guys.
Dana
Western PA, USA
This S4 transmission probably just isn't going to play nice but I agree with Jack. Unlike the Golf/Jetta/Beetle (transverse driveline cars) some of the ECMs in Passat and A4 models will support coding for both transmission types and even FWD/AWD in some cases. When using VCDS on a PC you will see a pop-up balloon with all of the various options. This is an example from an older TDI:
http://www.ross-tech.com/vcds/tour/screenshots/coding-balloon.png
In cases where modified coding is rejected - that's where you need high powered tools or a tuner to step in and tweak things that are not possible with VCDS or the factory level scan tool.
