2000 Audi A6 Quattro: No Rear Braking
nhaas
H10-002020
Here's my autoscan:
Tuesday,06,March,2018,19:34:17:20629
VCDS Version: 17.8.1.0 (x64)  HEX-V2 CB: 0.4409.4
Mileage: 121708   Repair Order: Brake Bleed
Chassis Type: 4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005)
          75 76 77
Address 01: Engine        Labels: 078-907-551-AZA.lbl
   Part No: 4B0 907 551 L
   Component: 2.7l V6/5VT     G   0003
   Coding: 06652
   Shop #: WSC 02325
   VCID: 2D040351A404373FC17-513C
17862 - Exhaust Gas Temp Sensor 1 (G235)
            P1454 - 35-10 - Short to Ground - Intermittent
17521 - Oxygen (Lambda) Sensor; B1 S1
            P1113 - 35-10 - Internal Resistance too High - Intermittent
17883 - EVAP Leak Detection Pump
            P1475 - 35-10 - Malfunction / No Signal - Intermittent
17539 - Oxygen (Lambda) Sensor; B2 S1
            P1131 - 35-10 - Internal Resistance too High - Intermittent
   Part No: 4B0 927 156 BD
   Component: AG5 01V 2.7l5VT USA 3131
   Coding: 00002
   VCID: 6A8EC84D556AE007E45-513C
Address 03: ABS Brakes        Labels: 8E0-614-111-EDS.lbl
   Part No: 8E0 614 111 A
   Component: ABS/EDS 5.3 QUATTRO D10
   Shop #: BB 24334
   VCID: 1C62DE95CFBECEB7A69-51CE
Address 08: Auto HVAC        Labels: 4B0-820-043-MY1.lbl
   Part No: 4B0 820 043 L
   Component: A6-Klimavollautomat D64
   Coding: 00160
   Shop #: WSC 02325
   VCID: 2310E569F2C0F14F673-2596
Address 15: Airbags        Labels: 4B0-959-655-AI8.lbl
   Part No: 4B0 959 655 F
   Component: Airbag Front+Kopf  1002
   Coding: 00406
   Shop #: WSC 02325
   VCID: 33301529422061CF973-5118
01211 - Belt Tensioner Igniter; Rear Driver Side (N196)
Address 16: Steering wheel        Labels: 4B0-907-487.lbl
   Part No: 4B0 907 487
   Component: E Lenkrad Elektronik D03
   VCID: 698CB741506CEB1FEDF-4BBA
   Part No: 4B0 920 980 M
   Component: C5-KOMBIINSTR. VDO D11
   Coding: 02264
   VCID: 2F381959AE08452FF3B-513C
Address 35: Centr. Locks        Labels:. 4B0-962-258.lbl
   Part No: 4B0 962 258 J
   Component: Central Lock/Alarm  D33
   Coding: 15885
   Shop #: WSC 02325
   VCID: 303A1A25B3365AD7EA1-4EC8
11 Faults Found:
            35-00 -  -
            35-00 -  -
            35-00 -  -
01370 - Alarm triggered by Interior Monitoring
            35-00 -  -
01368 - Alarm triggered by Luggage Compartment Switch
            35-00 -  -
00955 - Key 1
            09-10 - Adaptation Limit Surpassed - Intermittent
00956 - Key 2
01574 - Alarm triggered by Door Contact Switch; Rear Right
            35-00 -  -
01573 - Alarm triggered by Door Contact Switch; Rear Left
            35-00 -  -
01586 - Locking Cylinder Contact Switch; Passenger Side (F242); Close
            29-00 - Short to Ground
01585 - Locking Cylinder Contact Switch; Passenger Side (F242); Open
   Part No: 4B0 959 760 A
   Component: Sitzmemory          D05
   VCID: 2B000D499A10390FDF3-4B00
Address 37: Navigation        Labels: 4B0-919-887-BNS3.lbl
   Part No: 4B0 919 887 B
   Component: Navigation     BNO 0001
   VCID: 323E102DBD3A68C79C5-4AE0
            00-00 -  -
Address 45: Inter. Monitor        Labels: 4B0-951-178.lbl
   Part No: 4B0 951 178 A
   Component: Innenraumueberw.    D04
   Coding: 00101
   Shop #: WSC 02325
   VCID: 2616FC7D81F2046700D-51A8
Address 56: Radio        Labels: 8D0-035-1xx-56.lbl
   Part No: 4B0 035 195 A
   Component:  Radio              D00
   Coding: 00205
   Shop #: WSC 02325
   VCID: 1E66D49DD9A2DCA748D-4B1E
Address 76: Park Assist        Labels: 4B0-919-283.lbl
   Part No: 8D0 919 283
   Component: Parkingsystem A6 USA D05
   Coding: 01126
   Shop #: WSC 02325
   VCID: 6C82CE555F9EFE37969-51F2
End----------(Elapsed Time: 04:29, VBatt start/end: 12.3V/12.3V)-----------
So I’m baffled by the lack of rear breaking on my 2000 Audi A6 (and so is the Audi dealer). 90% of the breaking is on the front and the right rear rotor is only wearing ½ of the disk surface since it’s barely putting any pressure on the pad. It’s generally annoying and unsafe. I acquired this car from a colleague and it’s a great car otherwise. They took pretty good care of it except they never flushed the brake system in 17 years. Here’s the history over the last year since I acquired it:
• Jan-2017: Acquired ‘totaled’ car since owner couldn’t justify $4000 estimate for control arms/subframe damage estimate from Audi. I’m a DIY mechanic so I replaced front control arms, wheel rim and had it aligned. Subframe was fine. Drives perfect, except brakes are spongy and all in the front.
• Jan-2017: I replaced rear calipers (Napa reman), rotors and pads since rear brakes appeared to be ‘frozen’ and not functioning. Bled rear brakes manually using two person method.
• Jan-2017: Had neighborhood Goodyear flush brake system, since I assumed I didn’t bleed them properly. Still spongy and feels like air in system.
• Feb-2017: Goodyear flushed brakes again since they were still spongy. No real improvement but they don’t have VCDS so perhaps air still in the ABS pump?
• Feb-2017: I replaced the master cylinder (OEM) guessing it must be shot after 17 years. Bled master cylinder and system using 2 person manual method. During bleeding, my wife put the pedal to the floor, but that shouldn’t damage a new master cylinder, right?
• Mar-2017: Replaced front calipers (Napa reman), rotors and pads. Why? Because, at this point after 17 years of neglect who knows what debris is in the system and the pads and rotors were shot. Purchased a Motive bleeder and used that to bleed system. Brakes still spongy and all in front.
• Mar-2017: Had Audi dealer flush brake system since I didn’t have VCDS at the time to properly bleed. Drove pretty well for about 3 days, but then went spongy and all in front again.
• July-2017: Replaced RR caliper which was leaking during overnight brake pressure test. Also replaced all brake hoses going to calipers. Bled system using Motive bleeder.
• Aug-2017: Asked Audi to bleed system and officially diagnose lack of rear braking. They agreed braking was mostly in front and claimed it was due to ‘aftermarket’ rear brake pads! They pressure tested and found no leaks and no air in system. That doesn’t explain right rear rotor barely getting pressure! Horseshit.
• Dec-2017: Applied another overnight brake pressure test and found small leak around brake hose caliper bolt. Tightened bolt and Bled system using Motive bleeder, VCDS and WIS procedure (sequence RF, LF, RR, LR). No air in system. New pressure test revealed no leaks. But brakes still spongy and all in front.
• Jan-2018: Maybe the ABS pump seals are shot, so I replaced ABS pump with salvage yard pump. Bled system using Motive bleeder and VCDS using WIS procedure.
• Feb-2018: Asked Midas to look at brakes. They said they found no issues. But brakes still spongy and all in front.
• Mar-2018: Bled system using VDCS, Motive bleeder and WIS procedure. No air bled out. No improvement in braking, still all in front and spongy.
So you can see that Goodyear, Audi, Midas have all looked at this and no one can figure it out. I’m about to replace the master cylinder AGAIN thinking perhaps it was damaged in install and/or all this pressure bleeding has damaged seals between front and back?
Any ideas what could keep the rear brakes from getting pressure and why the brakes are so spongy?
Frustrated!!
Norbert
Norbert.........
Did you check the throw of the brake pedal to master cylinder & for complete stroke?
Is correct part number installed?
Are cams run out using e-brake cables to initiate the rear offset lash of caliper and are they returning 100% ?
