I borrowed my brothers A3 which was a bad move as it has cratered more or less as soon as I got it.
I was driving down the road normally and all the warning lights started to come on: Low Oil Pressure, ESP, Steering Assist etc. I did and auto scan and saw that there were module communication errors, cleared the codes and it started and ran normally. Later in the day I went out in it again . After a few miles the same happened again. I stopped off and the car restarted and drove back with all the lights on. When I got the car back on my drive I turned off the engine and then went to start it again. Unfortunately now it wont start!
I have checked all the fuses and none are blown and as far as I can tell the relays are all fine.
The autoscan shows that most of the modules aren't communicating.
Please can anyone shed some light on this??
I believe the Relay codes in the Central Electric Module are from me removing the relays to test them.
Tuesday,13,March,2018,18:26:38:22812
VCDS Version: 18.2.0.3 (x64)
VIN: WAUZZZ8P24A048518 License Plate: EDS1
Mileage: 151850km-94355mi Repair Order: 003
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: WAUZZZ8P24A048518 Mileage: 151850km-94355miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100
01-Engine -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
44-Steering Assist -- Status: Cannot be reached 1100
Address 01: Engine
Address 03: ABS Brakes
Part No SW: 8P0 820 043 HW: 8P0 820 043
Component: KlimavollautomatH11 0130
Shop #: WSC 06435 000 00000
VCID: 69D9A3314020FE0CAF-803C
Fault Status: 00101010
Reset counter: 153
Mileage: 162154 km
Date: 2016.10.29
Time: 00:00:17
Temperature: 6.5°C
007 - Short to Ground
Fault Status: 01100111
Fault Frequency: 119
Reset counter: 113
Mileage: 158263 km
Date: 2017.11.23
Time: 08:17:08
Temperature: 7.5°C
008 - Implausible Signal
Fault Status: 01101000
Reset counter: 113
Mileage: 151854 km
Date: 2013.05.09
Time: 00:14:48
Address 09: Cent. Elect. Labels:. 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H27 0401
Revision: 00000000 Serial number: 00000000113579
Coding: 018C4F00A0141000000000000000000000
VCID: 3B7529797A3CBC9C0D-806E
Subsystem 1 - Part No: 8P2 955 119 C Labels: 1TX-955-119.CLB
Component: Wischer WWS Audi350 0180
Coding: 16711696
00188 - Control Circuit 1; Relay for Supply Voltage Terminal 50
00187 - Control Circuit; Relay for Supply Voltage Terminal 75X
Address 15: Airbags
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 009 0030
Coding: 0000012
VCID: 306F0E55A37A4FC4A8-8064
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 980 E HW: 8P0 920 980 E
Component: KOMBIINSTR. VDO H25 0070
Revision: D04 Serial number: 2246CD04001561
Coding: 0004403
Shop #: WSC 80093 222 69422
VCID: 3979337170008E8C1F-806C
00003 - Control Module
014 - Defective
Fault Status: 00000011
Mileage: 86113 km
Date: 2008.09.07
Time: 12:11:12
Reset counter: 105
Mileage: 1844 km
Date: 2009.05.29
Time: 09:41:42
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0070
Revision: 08 Serial number: 2000103626775F
Coding: 3D0F0340070101
VCID: 2643E80D91BE117442-8072
Fault Frequency: 34
Reset counter: 153
Mileage: 151854 km
Date: 2013.05.09
Time: 00:15:14
01316 - ABS Control Module
Fault Frequency: 20
Reset counter: 113
Mileage: 151854 km
Date: 2013.05.09
Time: 00:15:14
Fault Frequency: 39
Reset counter: 153
Mileage: 151854 km
Date: 2013.05.09
Time: 00:15:14
Fault Frequency: 22
Reset counter: 113
Mileage: 151854 km
Date: 2013.05.09
Time: 00:15:14
Fault Frequency: 34
Reset counter: 153
Mileage: 151854 km
Date: 2013.05.09
Time: 00:15:14
01312 - Powertrain Data Bus
Fault Status: 00101110
Fault Frequency: 9
Reset counter: 153
Mileage: 151854 km
Date: 2013.05.09
Time: 00:26:41
Revision: D04 Serial number: AUX7Z0C6FNM0AE
02241 - Engine Control Module; Immobilizer Data not Adapted
01176 - Key
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H10 0010
Coding: 0000048
Address 44: Steering Assist
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H02 0030
Coding: 008800186D288505485AC63000
VCID: 79F9F37130804E8C5F-802C
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Part No: 1K0 907 719
Component: Neigungssensor 002 0002
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H01 0010
01134 - Alarm Horn (H12)
013 - Check DTC Memory
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Component: Tuer-SG 020 0050
Coding: 0000512
VCID: 41895B9118D0D64C57-8014
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 HW: 8P0 035 186
Component: concert II EU H52 0060
Revision: 05S Serial number: AUZ2Z3C1294378
Coding: 0000201
VCID: 6FEDCD297EC4103CF1-803A
End-------------------------(Elapsed Time: 01:39)--------------------------
