- Joined
- Aug 22, 2014
- Messages
- 500
- Reaction score
- 231
- Location
- Maryland, USA
- VCDS Serial number
- C?ID=66650
Hi Folks,
I have this A8 with no sound system nor entertainment in car. The MMI unit does not work. Even the brown cover that flips off/open does not work too. Found the control head too does not work. I can read zeros for radio, DSP and others in Gateway MVBs as indicated in the diagnosis report. I am thinking I need to do the fibre optics line diagnosis to check but I have no idea and havent done this before.
Help would be appreciated.
Tuesday,13,March,2018,13:23:24:46890
VCDS Version: 18.2.0.3 (x64)
VIN: WAULL44E05N001531 License Plate: D3 DIAGNOSIS
Mileage: 378180km-234990mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
47 4F 52 53 55 56 61 62 65 72 75 76
VIN: WAULL44E05N001531 Mileage: 378180km-234990miles
07-Control Head -- Status: Cannot be reached 1100
0E-Media Player 1 -- Status: Cannot be reached 1100
75-Telematics -- Status: Cannot be reached 1100
Address 01: Engine Labels: 077-910-560-BFM.clb
Part No SW: 4E0 910 560 J HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: -------- Serial number: AUX3Z0D4742848
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 285431B99B44310470-807C
20 Faults Found:
16814 - Catalyst System; Bank 2
P0430 - 002 - Efficiency Below Threshold
18529 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
P2097 - 001 - Too Rich - Intermittent
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
16666 - Fuel Injector #8 (N86)
P0282 - 002 - Short to Ground - Intermittent
17833 - EVAP Purge Valve (N80)
P1425 - 002 - Short to Ground - Intermittent
16645 - Fuel Injector #1 (N30)
P0261 - 002 - Short to Ground - Intermittent
16654 - Fuel Injector #4 (N33)
P0270 - 002 - Short to Ground - Intermittent
16657 - Fuel Injector #5 (N83)
P0273 - 002 - Short to Ground - Intermittent
17880 - EVAP Leak Detection Pump
P1472 - 002 - Short to Ground - Intermittent
17843 - Secondary Air Pump Relay (J299)
P1435 - 002 - Short to Ground - Intermittent
16651 - Fuel Injector #3 (N32)
P0267 - 002 - Short to Ground - Intermittent
17829 - Secondary Air Injection Solenoid Valve (N112)
P1421 - 002 - Short to Ground - Intermittent
16660 - Fuel Injector #6 (N84)
P0276 - 002 - Short to Ground - Intermittent
16441 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
P0057 - 002 - Short to Ground - Intermittent
16421 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0037 - 002 - Short to Ground - Intermittent
17522 - Oxygen (Lambda) Sensor; B1 S2
P1114 - 002 - Internal Resistance too High - Intermittent
17548 - Oxygen (Lambda) Sensor; B2 S2
P1140 - 002 - Internal Resistance too High - Intermittent
18669 - Oxygen (Lambda) Sensor B1 S1
P2237 - 001 - Pump Current Open Circuit - Intermittent
16517 - Oxygen (Lambda) Sensor B1 S1
P0133 - 002 - Response too Slow
17983 - Right Engine Mount Solenoid Valve (N145)
P1575 - 001 - Short to Plus
Readiness: 0010 0001
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0110
Revision: 00000001 Serial number: 0026269
VCID: 244C2589E76CD5645C-8070
18156 - Transmission Control Unit
P1748 - 000 - Programming Error - Intermittent
(no units): 30.0
(no units): 24.0
Temperature: 27.0°C
T.B. Angle: 0.0°
Voltage: 12.32 V
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008597
Shop #: WSC 02313 000 00000
VCID: 22402391FD78DB542E-8076
02083 - Message for Delay Request
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 D
Component: FBS AUDID3 H03 0140
Revision: 01403903 Serial number: AUX3Z0D4742848
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58B44179EBA4418400-800C
Component: ELV XXXX
9 Faults Found:
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
Fault Frequency: 0
Reset counter: 206
Mileage: 366896 km
Date: 2007.07.30
Time: 11:39:08
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
Fault Frequency: 0
Reset counter: 206
Mileage: 366896 km
Date: 2007.07.30
Time: 11:39:08
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
Fault Frequency: 0
Reset counter: 206
Mileage: 366896 km
Date: 2007.07.30
Time: 11:39:08
00182 - Luggage Compartment Access/Start Authorization Antenna (R137)
Fault Frequency: 0
Reset counter: 206
Mileage: 366896 km
Date: 2007.07.30
Time: 11:39:08
00183 - Interior Access/Start Authorization Antenna 1 (R138)
Fault Frequency: 0
Reset counter: 206
Mileage: 366896 km
Date: 2007.07.30
Time: 11:39:08
00957 - Key 3
002 - Lower Limit Exceeded
Fault Status: 01100010
Fault Frequency: 0
Reset counter: 234
Mileage: 369344 km
Date: 2007.07.30
Time: 00:00:50
00956 - Key 2
Fault Frequency: 0
Reset counter: 216
Mileage: 369344 km
Date: 2007.07.30
Time: 00:01:10
01176 - Key
Reset counter: 216
Mileage: 371968 km
Date: 2007.08.30
Time: 14:23:24
Reset counter: 213
Mileage: 378080 km
Date: 2007.07.30
Time: 00:00:16
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H08 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940448
Shop #: WSC 00000 785 00200
VCID: 234E2695E262D25C25-8076
Reset counter: 213
Date: 2004.01.01
Time: 00:00:00
Address 07: Control Head
Part No SW: 4E0 910 043 A HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 016 0300
Revision: 00000025 Serial number: 00000000043337
Coding: 1052993
VCID: 1B3E1E75DA12EA9CED-804E
01844 - Control Module for Fresh Air Blower (J126)
Reset counter: 184
Mileage: 378141 km
Date: 2007.07.31
Time: 18:46:58
Temperature: 3.0°C
(no units): 66.0
(no units): 171.0
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 J HW: 4E0 907 279 J
Component: ILM Fahrer H12 0190
Coding: 0123113
VCID: 2F66DAA5BEAA663CB1-807A
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000034
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0040
Coding: 00139548
Shop #: WSC 02313
01024 - Rain Sensor (G213)
Reset counter: 213
Mileage: 378136 km
Date: 2007.08.03
Time: 15:24:34
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 186
Mileage: 378183 km
Date: 2007.08.05
Time: 21:54:46
Fault Frequency: 16
Reset counter: 213
02071 - Local Databus
Fault Status: 00101110
Reset counter: 210
Mileage: 378090 km
Date: 2007.07.30
Time: 00:00:14
Address 0E: Media Player 1
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
01743 - Igniter for Knee Airbag; Pass. Side (N296)
001 - Upper Limit Exceeded - Intermittent - MIL ON
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Coding: 0012141
VCID: 65CA788DACD6EC6C8B-8030
Component: Lenkradmodul H05 0080
Reset counter: 213
Date: 2063.15.31
Time: 31:63:18
00532 - Supply Voltage B+
Reset counter: 213
Date: 2063.15.31
Time: 31:63:18
Reset counter: 213
Date: 2063.15.31
Time: 31:63:18
Reset counter: 213
Reset counter: 213
Mileage: 378090 km
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 G HW: 4E0 920 950 GX
Component: KOMBIINSTR. VDO H55 0220
Revision: D08 Serial number: AUDID3ID100048
Coding: 0000228
Shop #: WSC 09110 444 100751
01704 - Terminal 58 (Dimming)
007 - Short to Ground
Fault Status: 00000011
Reset counter: 206
Mileage: 366901 km
Date: 2007.07.30
Time: 06:51:27
Address 19: CAN Gateway Labels:. 4E0-910-468.clb
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0040
Revision: 07 Serial number: 05005045131C26
Coding: FCFE7BDD1B2304
VCID: 26483F819150277442-8072
00384 - Optical Databus
Reset counter: 186
Mileage: 366910 km
Date: 2007.07.30
Time: 07:00:34
00465 - Control Module for Telephone/Telematic (J526)
Reset counter: 186
Mileage: 369352 km
Date: 2007.07.30
Time: 00:11:48
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
9 Faults Found:
Fault Frequency: 0
Reset counter: 206
Mileage: 366896 km
Date: 2007.07.30
Time: 11:39:08
Fault Frequency: 0
Reset counter: 206
Mileage: 366896 km
Date: 2007.07.30
Time: 11:39:08
Fault Frequency: 0
Reset counter: 206
Mileage: 366896 km
Date: 2007.07.30
Time: 11:39:08
Fault Frequency: 0
Reset counter: 206
Mileage: 366896 km
Date: 2007.07.30
Time: 11:39:08
Fault Frequency: 0
Reset counter: 206
Mileage: 366896 km
Date: 2007.07.30
Time: 11:39:08
00957 - Key 3
Fault Frequency: 0
Reset counter: 234
Mileage: 369344 km
Date: 2007.07.30
Time: 00:00:50
00956 - Key 2
Fault Frequency: 0
Reset counter: 216
Mileage: 369344 km
Date: 2007.07.30
Time: 00:01:10
01176 - Key
Reset counter: 216
Mileage: 371968 km
Date: 2007.08.30
Time: 14:23:24
Reset counter: 213
Mileage: 378080 km
Date: 2007.07.30
Time: 00:00:16
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
Shop #: WSC 09110 444 11712
01400 - Suspension Level Control
Fault Status: 00100001
Reset counter: 198
01398 - Signal Conductor for Central Locking; Doors Open
Reset counter: 210
Mileage: 378090 km
Date: 2007.07.30
Time: 00:00:37
01780 - Sensor for Vehicle Leveling
Fault Status: 00100011
Reset counter: 217
Mileage: 377307 km
Date: 2007.10.25
Time: 01:54:55
01577 - Turn-Off due to Over-Temp
Reset counter: 211
Mileage: 378091 km
Date: 2007.07.30
Time: 03:11:22
Component: Sitzmemory FS H08 0060
Coding: 4071530
Reset counter: 213
Date: 2004.01.01
Time: 00:00:00
01445 - Sensor for Driver Seat Fore/Aft (G227)
Fault Frequency: 62
Reset counter: 186
Mileage: 69928 km
Date: 2007.08.04
Time: 15:27:07
Address 37: Navigation
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H01 0090
Serial number: 00000411300234
Coding: 0003477
VCID: 1D3A106DC406E4AC13-8048
Reset counter: 213
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRMH01 0060
Coding: 0032364
VCID: 20442999F374C94438-8074
02124 - Exterior Door Handle Switch
Fault Frequency: 0
Reset counter: 206
Mileage: 366832 km
Date: 2007.07.30
Time: 04:47:26
01308 - Control Module for Roof Electronics (J528)
Fault Frequency: 0
Reset counter: 213
Fault Frequency: 0
Reset counter: 213
02111 - Motor for Window Regulator
Fault Frequency: 0
Reset counter: 213
Fault Frequency: 0
Reset counter: 213
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040406020004
Coding: 0065086
VCID: 27563285965A3E7C79-8072
Component: Heckdeckel P27H08 0090
Component: Neigungssensor H03 0020
01134 - Alarm Horn (H12)
Reset counter: 184
Mileage: 368657 km
Date: 2007.08.06
Time: 06:30:03
02107 - Trunk or Luggage Compartment Opening Motor (V254)
Reset counter: 218
Mileage: 377596 km
Date: 2007.10.29
Time: 16:38:24
Reset counter: 184
Mileage: 368657 km
Date: 2007.08.06
Time: 06:30:03
Address 47: Sound System
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000040696
Coding: 0010111
VCID: 1E381761C900FFB40A-804A
Fault Status: 00110010
Reset counter: 213
Mileage: 262140 km
Date: 2018.07.10
Time: 20:19:00
Fault Frequency: 34
Reset counter: 210
Mileage: 262136 km
Date: 2007.07.30
Time: 00:00:00
Reset counter: 210
Mileage: 262136 km
Date: 2007.07.30
Time: 00:01:00
Reset counter: 213
Mileage: 262140 km
Date: 2018.07.10
Time: 20:19:00
02258 - Door Opener Transmitter
Reset counter: 186
Mileage: 262136 km
Date: 2007.07.30
Time: 04:48:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRMH01 0060
Coding: 0032364
Fault Frequency: 0
Reset counter: 213
Fault Frequency: 0
Reset counter: 213
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000532
02596 - Rear Brake Pads Worn
Fault Status: 01111000
Reset counter: 173
Voltage: 11.90 V
Count: 61
01487 - System Function Test
Reset counter: 213
Voltage: 0.00 V
Count: 184
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
VCID: 62C06391BDF89B546E-8036
Address 56: Radio
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H11 0510
Revision: 00000000 Serial number: 00000000001448
Shop #: WSC 06412 444 59079
Subsystem 1 - Part No: 4E0 915 105 AV
Component: von A00 405110307
Coding: 344530393135313035415641303034303531313033303700
Shop #: WSC 00000 128 00289
02274 - Quiescent Current Stage 3
Fault Frequency: 28
Mileage: 368697 km
Date: 2007.08.11
Time: 00:43:45
Fault Frequency: 39
Date: 2007.07.30
Time: 00:00:22
Fault Frequency: 9
Mileage: 369357 km
Date: 2007.08.01
Time: 11:12:35
02276 - Quiescent Current Stage 5
Fault Frequency: 9
Mileage: 378089 km
Date: 2007.11.04
Time: 22:51:12
02256 - Quiescent Current
Fault Status: 00110001
Fault Frequency: 166
Reset counter: 224
Mileage: 369357 km
Date: 2007.07.30
Time: 17:05:45
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM002 0060
Coding: 0032364
Fault Frequency: 0
Reset counter: 213
Fault Frequency: 0
Reset counter: 213
Fault Frequency: 0
Reset counter: 213
Fault Frequency: 0
Reset counter: 213
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010027 Serial number: 00000600025268
Coding: 0232125
Shop #: WSC 06412 444 84040
VCID: 5FC66A658E8AB6BC41-800A
Fault Status: 10100010
Reset counter: 40
Mileage: 378090 km
Date: 2007.07.30
Time: 00:01:34
Voltage: 6.80 V
(no units): 42.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Fault Frequency: 221
Reset counter: 0
Mileage: 366834 km
Date: 2007.07.30
Time: 04:49:14
Temperature: 9.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM002 0060
Coding: 0032364
Fault Frequency: 0
Reset counter: 213
Fault Frequency: 0
Reset counter: 213
Fault Frequency: 0
Reset counter: 213
Fault Frequency: 0
Reset counter: 213
Address 75: Telematics
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08730413301386
Coding: 0001208
VCID: 21422C9DF87EC04C37-8074
7 Faults Found:
01629 - Sensor for Parking-Aid; Front Left (G255)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 208
Mileage: 366971 km
Date: 2007.07.30
Time: 22:19:34
01626 - Sensor for Parking-Aid; Front Right (G252)
Reset counter: 16
Mileage: 366859 km
Date: 2007.07.30
Time: 05:28:58
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
Reset counter: 225
Mileage: 366859 km
Date: 2007.07.30
Time: 05:28:58
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
Reset counter: 206
Mileage: 366859 km
Date: 2007.07.30
Time: 05:28:58
Fault Frequency: 32
Reset counter: 210
Mileage: 378090 km
Date: 2007.07.30
Time: 00:00:21
02070 - Rear Parking Aid Sensors
Reset counter: 206
Mileage: 366834 km
Date: 2007.07.30
Time: 04:55:19
02069 - Front Parking Aid Sensors
Reset counter: 12
Mileage: 366834 km
Date: 2007.07.30
Time: 04:55:19
End-------------------------(Elapsed Time: 04:11)--------------------------
Address 19: CAN Gateway Labels: 4E0-910-468.clb
Control Module Part Number: 4E0 910 468 A HW: 4E0 907 468 C
Component and/or Version: Gateway H07 0040
Software Coding: FCFE7BDD1B2304
Work Shop Code: WSC 02313 785 00200
Reset counter: 186
Mileage: 366910 km
Date: 2007.07.30
Time: 07:00:34
Reset counter: 186
Mileage: 369352 km
Date: 2007.07.30
Time: 00:11:48
Address 19: CAN Gateway (4E0 910 468 A)
13:25:40 Group 130: CAN-Databus Comfort (Communication)
2-Wire CAN-Comfort Status
Cent. Elect. 1 Central Electronics (J519)
Central 1 Comfort System (J393)
Dr. Door 1 Door Electronics Driver (J386)
13:26:06 Group 140: MOST-Databus (Communication)
Radio 0 Radio (analog) (R)
Navigation 0 Navigation System (J401)
Telephone Electronics (R36)
Voice Control (J507)
13:26:14 Group 141: MOST-Databus (Communication)
Dig.Soundp. 0 Digital Soundsystem (J525)
TV-Tuner (J415/R78)
Telemat 0 Telematic (J526)
Disp/Ctrl/F 0 Display/Control Head Front (J523)
13:26:22 Group 142: MOST-Databus (Communication)
Media P.1 0 Media Player 1
