Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: High Tickover
    Feb 2015
    High Tickover
    Hi Folks.
    My T5 2.5l has a high tickover. It started to climb some time ago, and is now just under 1000 rpm. I will post scans later, but do you guys have any obvious things I can check first please?
    Intake air leaks.
    Feb 2015
    ah, OK. Those probably wan't show up on a scan anyway I'd guess. I'll take a look, thanks
    Wait, you said T5. That's presumably a diesel. My head is in Petrol land...
    Please post a scan so we're not guessing what you've got.
    Feb 2015
    Yes, 5 pot diesel. Do you need a full vehicle scan or just engine?
    We much prefer a complete Auto-Scan.
  7. Likes Jack@European_Parts liked this post
    Feb 2015
    Tuesday,13,March,2018,14:35:39:63214
    VCDS Version: 18.2.0.3 (x64)
    VIN: WV2ZZZ7HZ9H020288   License Plate: T5 MARCH 18
    Mileage: 145660km-90508mi   Repair Order:
    Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
    Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
              57 6E 76 77 78 7D
    VIN: WV2ZZZ7HZ9H020288   Mileage: 145660km-90508miles
    Address 01: Engine        Labels: 070-906-016-BPC.clb
       Part No SW: 070 906 016 EC    HW: 070 906 016 EC
       Component: R5 2,5L EDC  000SG  2539
       Revision: --H06---    Serial number: VWZ7Z0H6748741
       Coding: 0000072
       Shop #: WSC 02736 790 00000
       VCID: 55A1B411FFF7B8EC1B-5140
    005662 - Glowplug for Cylinder 5 (Q15)
                   P161E - 000 - Open Circuit
                        Fault Status: 01110000
                        Mileage: 125490 km
                        RPM: 777 /min
                        Voltage: 13.00 V
                        Bin. Bits: 00000000
                        Temperature: 18.0°C
                        Bin. Bits: 10110000
    Readiness: 1 1 0 0 0
    Address 03: ABS Brakes        Labels: 7H0-907-37x-ABS.clb
       Part No SW: 7H0 907 379 S    HW: 7H0 907 379 S
       Component: (M)ABS MK25E        0103
       Revision: 00H21001
       Coding: 0000552
       VCID: 458164510F57086C6B-5106
                        Reset counter: 27
                        Mileage: 145548 km
                        Count: 12289
                        Count: 128
    Address 08: Auto HVAC        Labels: Redir Fail!
       Part No: 7H0 820 045 AM
       Component: CLIMA/AC            0303
       VCID: 70EFE5856055FDC4E8-5124
    Address 09: Cent. Elect.        Labels:. 7H0-937-049.lbl
       Part No: 7H0 937 049 AD
       Component: BORDNETZ SGVER 1.0  2101
       Coding: 0000101
       VCID: 74E7E995144DC1E40C-5124
    01598 - Drive Battery Voltage
    01117 - Generator Terminal DF Load Signal
    00991 - Interior Lights
       Part No: 1C0 909 605 T
       Component: 3C AIRBAG VW51      0015
       Coding: 13123
       VCID: 356114910FB798ECFB-5106
    Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
       Part No: 7H0 920 951 T
       Component: KOMBI+WEGFAHRSP VDO V03
       Coding: 00413
       Shop #: WSC 00001
       VCID: 3D710CB1378740AC33-5124
       WV2ZZZ7HZ9H020288     VWZ7Z0H6748741
    01304 - Radio
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 02736
       VCID: 70EFE5853055FDC4E8-5124
    01304 - Radio
    Address 46: Central Conv.        Labels: 7H0-959-433.lbl
       Part No: 7H0 959 433 B
       Component: C1W Komfortgerát     0004
       Coding: 00031
       Shop #: WSC 02736
       VCID: 326B2F8DFED98FD4DE-4B00
       Part No SW: 7H0 035 152 H    HW: 7H0 035 152 H
       Component: Radio LG3           0014
       Revision: 00008000    Serial number: VWZCZ5H0020485
       Coding: 0010200
       VCID: 275DCED9951BFA7C79-5124
    Address 76: Park Assist        Labels: 7H0-919-283.lbl
       Part No: 7H0 919 283
       Component: Parkingsyst. T5 T5N 401
       Coding: 00137
       Shop #: WSC 02736
       VCID: 6FEDE6F92D6BE23CF1-5140
    01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
                30-00 - Open or Short to Plus
    End-------------------------(Elapsed Time: 05:58)--------------------------
  9. #8
    Feb 2015
    I know about the glowplug, the connector is damaged. Also the rear park assist!
  10. #9
    Feb 2015
    Alternator problem? is the engine trying to compensate?
  11. Likes Jack@European_Parts liked this post
  12. #10
    Feb 2015
    Bump....any any advice please? thanks Sean.
