Page 2 of 11 FirstFirst 1234 ... LastLast
Results 11 to 20 of 101
Thread: 2006 jetta tdi no power
    Those are WD related electrical faults from ECU to N75 or a bad N75 or ECU.
    Since you did timing when cam was swapped are you sure is it correct and you are aligned for all base settings and taper or key-way offsets on hub to cam belt sprocket?
    What about cam ramps lash for injectors?
    JPPSG.............. Amendment!
    http://forums.ross-tech.com/showthre...l=1#post123510
  2. #12
    Mar 2018
    Good moring jack. Remember Im a newbie to the vcds and its term. Going from memory (not at the shop yet) but I think the cam timing is "torsion value" ? Its 0.0 which I believe is right.
    Not sure what you mean by taper and keyway offset but the gear is back on the way it came off unless I overlooked something. Can you elaborate ?
    Thanks,joe
  3. #13
    Quote Originally Posted by Boot View Post
    heres a scan prior to tuning:
    Address 01: Engine        Labels: 038-906-016-BEW.lbl
       Part No SW: 03G 906 016 AB    HW: 028 101 223 8
       Component: R4 1,9L EDC G000SG  7550
       Revision: --H02---    Serial number: VWZ7Z0F4474234
       Coding: 0050071
       VCID: 639352942750C76F157-8036
    001031 - EGR Sensor 2
                   P0407 - 000 - Signal too Low
                        Mileage: 264318 km
                        Time: 20:17:23
                        Lambda: -25.0 %
                        Mass Air / Rev.: 1000.0 mg/str
                        Mass Air / Rev.: 0.0 mg/str
                        Bin. Bits: 00000000
    009572 - Turbocharger Boost Control Position Sensor Circuit
                   P2564 - 000 - Signal too Low
                        Mileage: 264318 km
                        Time: 20:17:23
                        Lambda: -3.7 %
                        Absolute Pres.: 1213.8 mbar
                        Absolute Pres.: 1020.0 mbar
                        Duty Cycle: 101.6 %
    So you tuned a car with pre-existing faults and now you're wondering why it doesn't run right after being tuned?
  4. #14
    Hello Joe,
    Yes Torsion value but can still be out, while in, are you looking at corrected values or basic settings? 08 vs 04!
    That is why I ref taper fit pulleys and virtual key-ways then injector cam ramp timing lash.
    To me it sounds like you have an over boost condition or a plugged intake not allowing air made by turbo charger popping the MAP sensor to read higher than expected hence limp mode.
    It is time you ref RTFB please on how hub is fit on cam and then timing gear on hub.
    0x01-08-011 Log Boost...........
    http://forums.ross-tech.com/showthre...ut-0x01-08-000
    UN-PIMP the FOD!
  5. #15
    Mar 2018
    The egr system was in bad shape so I did a delete on it. then had to have it tuned out.
  6. #16
    Mar 2018
    As the money issue of a new cooler and valve.
  7. #17
    So you're telling us you know this car is no longer legal to use on public roads?
    And what about the "Turbocharger Boost Control Position Sensor Circuit" fault? One of the problems with certain "tuner" software is that it plays hide-the-sausage games with fault conditions that would set DTCs in the stock software. This can make it much harder to diagnose and fix problems.
  8. #18
    Mar 2018
    Hello Joe,
    If I clear codes and rescan, the codes are back without starting or driving the car....
    Also the power is not there right off the bat. I would think power would start to build(boost) then fall off when MAP see's too much.
    I am on my way to the shop to watch boost.
    Am I missing something? when I looked at the graph comparing actual boost and requested, it shows the 2 but there is no reference on the graph for the actual value. I see the actual is slightly more but I don't know if its 1psi or 20...
    Joe
  9. #19
    WTF see Uwe this is what I mean?
    That's too funny......... Sausage fest!
    Joe
    A tune is not a tune if it isn't CARB/EPA certified, it is a defeat device!
    You mean to tell me you can pay for a defeat vs this?
    BULLSHIT!
    NEW 150-400
    https://www.ebay.com/itm/New-EGR-COO...sAAOSwsDxZ4ENY
    https://www.ebay.com/itm/New-Oem-VW-...EAAOxyZzlTc-Mq
    https://www.ebay.com/itm/A5-VW-VOLKS...sAAOSwubRXNhHx
    USED 100
    https://www.ebay.com/itm/Volkswagen-...wAAOSwk75anvFI
    Joe
    Which is why I said check timing and lash.........just have a look at the last BRM fiasco related to timing in forum.
  10. #20
    Mar 2018
    Hi Uwe, I'm learning here... Have mercy on me, if not pitty... LOL. My first instinct due to lack of funds was delete. However, before hand, the code shows signal too low. It seams there should be 5volts to the sensor. first I found 2.8 volts.... traced back to ecu and found no problem. when I checked at sensor AGAIN it was 4.8v. the tuner guy "told me" they are problematic but can be tuned out. I assumed that made sense since he does this....
    WHats your experience with this low signal?
    Thanks,Joe
  11. Likes Uwe liked this post
