Results 1 to 10 of 20
Thread: Mk 4 Jetta Communication down!!
    Mar 2017
    Hey all,
    I am having a ridiculous amount of trouble attempting to get diagnostic communication on this jetta. its an 08-2000 build date, 1.8t with manual trans and power windows and locks. what I have is 11.9v B+ and 10.79v on the k line when grounded using the dlc ground. I have attempted pulling modules off the k line one by one with no success. the vehicle came in having had someone else diagnose it as a bad ECM. the vehicle cranks and starts briefly then sputters similar to an immobilizer issue and the odd thing, there is no key flashing icon while this happens.
    I'm using a hex-net with current vcds software and I cant get any module to register, the interface works effectively on other vehicles. any direction would be appreciated.
    Sounds like a bad gateway or unpowered cluster which contains the gateway for blown fuse maybe?
    Wait, how can you have "10.79v on the k line when grounded using the dlc ground"? That makes no sense. Which pin are you using for DLC ground?
    This is a perfect example of an asshole ground because he has no real ground or power and the meter lies by stray voltage.
    With a fuse blown, a corrosion bridge, water ingress or a bad gateway/any module, he can have that stray voltage.
    Mar 2017
    I'm probing pin 7 (what I believe to be k line) to pin 4/5 (which I believe to be grounds for the dlc connection) and it is the same value while I ground to body. also, I didn't think this vehicle new enough to have a gateway.
    Quote Originally Posted by C.F.Danaher View Post
    Pin 4 is ground on all VAG cars. Pin 5 is sometimes, but not on all of them.
    I think the way you worded things has everyone confused. I'm thinking you have the ground lead of the meter on one of those pins, but you never actually grounded the K-Line?
  7. #7
    Mar 2017
    got that, to rephrase. pin 7 whether it be grounded to the body or pin 4, is reading 10.79v.
  8. #8
    Then it's not being grounded - because a wire connected to ground cannot be at 10.79V, the maximum it can be is a few fractions of a volt.
  9. Likes Uwe, Jack@European_Parts liked this post
  10. #9
    What is grounded? The ground side of the meter? Or Pin 7?
  11. #10
    Well it can, if the supposed ground is no good.
  12. Likes Jack@European_Parts liked this post
