Results 1 to 6 of 6
Thread: CECM Swap to high
    New User
    Jul 2017
    Spain
    CECM Swap to high
    samebody know if it is posible to swap medium cecm to high cecm (5k0 937 087 ab) manteining the halogens bulbs (instead xenon)? Thanks very much.
    May 2017
    Yes. Record current BCM coding by taking screenshots NOT by just copying the code. Highline BCM has more bytes so coding is different.
    Do the physical swap and code the new BCM manually.
    New User
    Jul 2017
    Spain
    Thank you!! I will code manually.
    New User
    Jul 2017
    Spain
    My car is an european VW Touran (year 2014) with halogen bulbs and 434mHz frecuency. Now I have a BCM Medium 5k0937086Q... According to etka, the high bcm would be 5K0937087AB or other reference? Thanks
    Jun 2014
    Poland
    Quote Originally Posted by Tristan1412 View Post
    Please wait till Rosstech check your VCDS number, and then we can talk
    HOT HOT HOT VW Touran 2005 CCS via MFSW HOT HOT HOT
    Yes, the OP should Get Verified.
