2013 Touareg 7P US model retrofitted with Euro tow bar & controller
flyingpenguin
C?ID=259766
Hi all,
When I moved from Texas to the Netherlands I had the good fortune to bring the TREG over. Most functions carry over except for the rear fog light which took some finagling but works fine now. Also swapped out the US receiver hitch style tow bar and control module (7P0-907-383-F) for the electric swiveling euro style tow bar and control module (7P0-907-383-C) that I obtained via a local salvage yard.
After the install (with the tow hook swiveled "in"), I managed to actuate the swiveling mechanism just once and now it is in the "out" position.
This is what I know so far:
- All trailer lights / functions work when connecting to the 13 pin euro style connector, at least with regular style bulbs. Not sure with LED's.
- The swiveling button in the boot lights up as intended when opening the hatch
- When pressing the swiveling button, the tow hook does not move
- Coding for the Euro style control unit 7P0-907-383-C that it came with is 0106040000000000 which seems to be correct according to many VCDS scans that I was able to verify against.
- This coding throws the following error however on my unit:
02588 - Swiveling Trailer Hitch
Fault Status: 11100101
Reset counter: 221
- When I change the coding to 0106000000000000, this error goes away, but the swiveling button in the boot does NOT light up as intended when opening the hatch and the no response when pressing the button either (tow hook does not move).
I am sure that in order for everything to operate as intended, the original coding needs to be reinstated. Just curious for clues as to where to start my fault finding mission.
Attaching full scan for completeness' sake:
Monday,12,March,2018,12:36:43:24496
VCDS Version: 18.2.0.3 (x64)
VIN: WVGEP9BP9DD005238   License Plate: NG-533-P
Mileage: 113952km-70806mi   Repair Order: N/A
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
          62 65 69 6C 6D 72
VIN: WVGEP9BP9DD005238   Mileage: 113952km-70806miles
Address 01: Engine (J623-CNRA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401 K    HW: 7P0 907 401 K
   Component: 3.0TDI EDC17  H19 0003
   Revision: 56H19---
   Coding: 292A4032233600050000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0117P0907401K 001004
   ROD: EV_ECM30TDI0117P0907401K.rod
   VCID: 377D73278E1234FCE9-8062
   Part No SW: 0C8 927 750 AK    HW: 0C8 927 750 AK
   Component: AL1000 AISIN  001 2269
   Coding: 00B168
   Shop #: WSC 25720 002 104857
   ASAM Dataset: EV_TCMAL991031 002114
   ROD: EV_TCMAL991031_002.rod
   VCID: 75E1B92FD49E86EC3B-8020
Address 03: ABS Brakes (J104)       Labels:* None
   Part No SW: 7P0 907 379 M    HW: 7P0 907 379 A
   Component: MK25A         H36 0436
   Revision: --------    Serial number: 420720010EC815
   Coding: 5B7613C349242558DAF6C89692DAA4407300
   ASAM Dataset: EV_MK25AXT 008001
   ROD: EV_ESPMK25A00800.rod
   VCID: 479D03E7FEF2447C99-8012
   Part No SW: 4H0 907 064 CK    HW: 4H0 907 064 CK
   Component: BCM2 2.0      H32 0421
   Coding: 0D860016000000000000
   VCID: 74E7842BD7E49FE40C-8020
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 2312000166468013
   Part No SW: 7P6 907 040 BK    HW: 7P6 907 040 BK
   Component: Klima 2 Zonen H20 1305
   Coding: B686000A80
   VCID: 7EF3A603E1A8C5B46A-802A
   Part No SW: 4H0 907 063 BL    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0111
   Revision: 15012002    Serial number: 00000001587520
   Coding: 26005013D33C5F010021100300005D0C431C660882010361000000020000
   VCID: 73E58737D2EA98DC15-8026
   Component: WWS    120711  31  0020
   Serial number: 90243400120719155436
   Coding: 004DBD
   Component: RLFS  H09 0011
   Serial number: 10422770
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431     HW: 7P6 941 431
   Component: E1 - LDS  H02 X024
   Serial number: 00000000000000000074
   Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0020
   Serial number: 0000001805569R17RD07
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 B    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0021
   Revision: --------    Serial number: 28201221200066
   Coding: 500501
   ASAM Dataset: EV_VW526ParkiAssis2 001011
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 428B12F3D5D061544E-8016
   Part No SW: 7P0 959 655 C    HW: 7P0 959 655 C
   Component: VW10Airbag025 H05 0025
   Revision: --------    Serial number: 003L0004C2FE
   Coding: 000000000000000000000000000000003235
   VCID: 41891DFFD0D67A4C57-8014
   Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
   Component: BF-Gewichtss.  003 0005
   Serial number: 5850000R1242708SQH
   Serial number: 3575LRB405P1G7FCE0IO
   Serial number: 3585LRB405N1G7FAG8N-
   Serial number: 3515RRB40691BBHAG0D5
   Serial number: 3525RRB40631BBHABO5B
   Serial number: 3555NRB405H1GCDMK14M
   Serial number: 3565NRB405H1GCDMEH4X
   Part No SW: 4H0 953 568 H    HW: 7P6 953 507 M
   Revision: --------    Serial number: 90815LHE0001R
   Coding: 000C15
   VCID: 387F701B8B0C3B84E0-806C
   Serial number: 0205586
   Part No SW: 7P6 920 981 F    HW: 7P6 920 981 F
   Component: Kombi         H13 0318
   Revision: 13240077    Serial number: 658100812592034
   Coding: 937F33022B00000D0D0004
   ASAM Dataset: EV_KombiUDSRBVW526 001017
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 408F18FBDBDC734458-8014
   Part No SW: 7P6 907 530 F    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H11 6028
   Revision: --------    Serial number: 00000000640596
   Coding: 0001037500
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod
   VCID: 3B756F17B23A109C0D-806E
   Serial number: 00000000005650870006
   Revision: AA000000    Serial number: 00000036097170
   Coding: 00581B0000004001000001010101202020202121202020
   VCID: 3467442B9764DFE4CC-8060
   Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
   Component: TSG FA        H07 0166
   Revision: --------    Serial number: 0000129654031
   Coding: 011D17205E00453005080000
   VCID: 448714EBC7C46F647C-8010
   Revision: 00002001    Serial number: 0181915902
   Coding: 01061E3A28B9509581A00620210000000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
   Component: GTO BT  H19 0059
   Serial number: 2001216179
   Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
   Component: J245 PS30.055  H01 0008
   Serial number:     WOO17569338
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
   Component: J394 PS30.055  H01 0008
   Serial number:     WOO1760203-
   Coding: 191100
   Part No SW: 7P6 035 466     HW: 7P6 035 466
   Component: DSP Prem      H01 0090
   Revision: 00001001    Serial number: 10811001781006
   VCID: 75E1B92FDC9E86EC3B-8020
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0166
   Revision: --------    Serial number: 0000129631771
   VCID: 3B756F17BA3A109C0D-806E
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1273000265
   Coding: 01040200
   ROD: EV_ParkbA7.rod
   VCID: 36637E238918CDF4F2-8062
   Slave 3:
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Coding: 010A00010F000400
   VCID: 7CF7AC0BF7B4D7A444-8028
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Coding: 130000
   Component: Radio U SIRIU H60 0133
   Revision: AB001007    Serial number: 156G30C7618908
   Coding: 020007010000000001
   VCID: 2447B46B27844F645C-8070
   Part No SW: 7P6 035 664 K    HW: 7P6 035 664
   Component: H-BN-NA       H45 0934
   Revision: --------    Serial number: 445H00C7539290
   Coding: 020100060040E1FF4302BF0E00000003100001000100000000
   VCID: 408F18FBD3DC734458-8014
   Subsystem 1 - Part No: 7P6 060 884 G
   Component: EUR 2017  2402
   Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603 C
   Component: DU8 SV Touch  H26 0045
   Serial number: VWZ8Z9M7900ET9
   Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: CD-Database  1886
03175 - Invalid Data Set
                    Reset counter: 220
                    Mileage: 113896 km
                    Date: 2018.03.11
                    Time: 18:43:56
                    Voltage: 11.90 V
03623 - Invalid Secruity/Release Code
                    Reset counter: 220
                    Mileage: 113896 km
                    Date: 2018.03.11
                    Time: 18:43:57
                    Hex Value: 0x0004
                    Hex Value: 0x0405
                    Count: 7
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0167
   Revision: --------    Serial number: 0000129366151
   Coding: 011C17200000253005080000
   VCID: 3A7B6A13B500299416-806E
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Component: RDKBERU25     H09 0008
   Serial number: 10000000089459
   ROD: EV_RDKBERU25_VW52.rod
   VCID: 3F8D1B07A6220CBC21-806A
Address 69: Trailer (J345)       Labels: None
   Part No SW: 7P0 907 383 C    HW: 7P0 907 383 C
   Component: Anhaenger     H07 0073
   Revision: 5H001003    Serial number: 00000125889014
   Coding: 0106040000000000
                    Reset counter: 221
   Part No SW: 7P6 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0020
   Revision: 00H06000    Serial number: 525 PA8J271159
   Coding: 0130001
   VCID: 377D7327461234FCE9-8062
   Part No SW: 7P6 959 107 A    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0620
   Revision: 22010001    Serial number: 215200467
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202137
   ROD: EV_HeckkTouar.rod
   VCID: 3D71610FAC2E1EAC33-8068
   Component: TSG HR        H09 0167
   Revision: --------    Serial number: 0000129582522
End-------------------------(Elapsed Time: 05:02)--------------------------
GaSelle
C?ID=266649
Haven´t "played" with such a towbar; but to me, it looks like some missing calibration. Are there any options to carry out a calibration?
NEtech
C?ID=56995
Try and download these 2 files:
7P-69.lbl
4H0-907-383-V1.clb
and copy them to:
C:\Ross-Tech\VCDS\Labels\User
Then check in [69] controller, if it is possible to do [Output Test-03] and select the only "Selective Output Tests" that is available
"Swivel Motor: Initialisation"
golfi_vend
Tartu, Estonia
C?ID=195131
Label file says .lbl, but file itself is .clb. Is this a typo?
NEtech
C?ID=56995
Yes it is, I have changed the 7P-69.lbl now.
But it should load correct anyway, if I recall right.
flyingpenguin
C?ID=259766
Thanks for the suggestion.
Only got to it just today and label file that is confirmed to be used is USER\4H0-907-383-V1.clb but "Selective Output Tests" remains greyed out..
Looking forward your continued and valued support.
NEtech
C?ID=56995
Thanks, I just found a bug in VCDS, or it is a "feature" unknown to me :confused:
Try and download the same file again, same name it is updated know and then test again.
Now there should be 2 "Selective Output Tests"
Intern ref.: FS#1495
flyingpenguin
C?ID=259766
Hi NEtech, Thanks much for your help. I feel we are making progress, but not there yet entirely;
- "Swivel Motor: Initialisation" errors out "This output is not supported by control module" with Error code 7F 22 31
- "Dont think this can be used!" actually unlocks the swiveling tow hook (in both in or out position, so kind of useful at this stage where I can now manually swing the hook in or out (the wife and her shins are thankful!).
Curious what else we can try. :-)
RGds, JP
NEtech
C?ID=56995
Maybe try:
Then:
Then move swiveling tow hook, manually out and then back.
flyingpenguin
C?ID=259766
Hi NEtech,
Followed your suggestion and am noting that upon unlocking (with "Dont think this can be used!") the LED in the trunk space button for the towhook is blinking; at least it knows that the unit is unlocked and shows the correct warning.
Activating "Swivel Motor: Initialisation" immediately errors out as before with code 7F 22 31. Manually swiveling in and out does not do anything except that the towhook locks into place on full in and full out (requiring unlocking each time).
A full scan does not reveal any errors in 69 - Trailer:
Address 69: Trailer (J345) Labels: User\4H0-907-383-V1.clb
Supp. Codes - 18 on 69 - Trailer reveals the following active fault code though: DTC 02025 / failure mode 007.
I think this points towards a potential wiring problem to the swivel motor. Time to remove bumper cover (again!) and go on a fault finding mission..
flyingpenguin
C?ID=259766
Hello again. Picking up where I left off last year.
Went over the wiring diagram again for the J345 trailer module.
The "V317 Ball hitch swiveling motor" and "G473 Trailer hitch motor position sensor" are connected to the "J345 Towing recognition control module" via a 24 pin connector.
There appear to be 2 types of J345 modules that fit my 2013 7P Touareg:
The 7P0-907-383-C (that I have) with the large connector coming from the towbar being 18 pins:
and the 4H0 907 383 L, with the large connector coming from the towbar being 24 pins (as described in the wiring diagram above):
I am wondering if my troubles are a result of this mix-up. Any comments are welcome.
MartinsX
Riga, Latvia
C?ID=268515
Did You get from junkyard complete set, all parts removed from one car? (Mechanical parts, control module and wiring loom)?
flyingpenguin
C?ID=259766
I did. complete set removed from 2013 7P Touareg...
Also followed Bigbigtom's suggestion over at mytreg.com to use coding 0100000202000000, which was not accepted. As of yet do not know which exact module Bigbigtom actually has installed. I suspect that the older units need 2nd binary location to be 00 instead of 06.
Would be helpful to obtain the correct wiring diagram for the 7P0-907-383-C (based on T16 + T12 + T12 connectors)..
MartinsX
Riga, Latvia
C?ID=268515
If You still can get VIN from donor car, WD in Erwin by this VIN should be correct for Your parts set ;)
flyingpenguin
C?ID=259766
My thought too, but impossible to retrieve donor vehicle VIN. Will try to locate VIN of Trailer equipped 2013 7P and check ERWIN.
Dino20vt
Leicester, UK
I had the same issues with the basic calibration code when i fitted the factory fit Swivelling towbar to an 4F A6 MY2011 which uses what looks like the same control module (Actually Westfalia made). I found the westfalia instructions fairly useful as their own aftermarket kit used the same controller and was wired the same as the factory fitted unit. Not sure if this applies exactly the same as yours but here is the instructions i think for your 7P (https://www.pfjones.co.uk/westfalia_fitting/321765300113.pdf).
I found that I had a microswitch that was stuck on my set up which wasnt registering the towbar as locked in place. Once you get to the point of having the red flashing light on the control you should be able to use Measuring Blocks to observe the microswitch statuses to check wiring and function. Once the switch was working on mine cycling it manually a few times cleared the fault and the light on my control went to a steady green. The towbar release on mine is a manual knob however, i believe yours is electric but hopefully the same principle applies.
Dean
flyingpenguin
C?ID=259766
Thanks Dino20vt! The further I dig, though, the more I am leaning towards incorrect pin-outs from the trailer control unit (J345) to the trailer hitch release button (E754 / part# 7P6 959 511 J). On a Russian site there is mention of section 19 in the Touareg 7P wiring diagram that is missing from my version purchased through erWin. If anyone would be willing to share that particualr section 19 for my perusal, that would be much appreciated..
flyingpenguin
C?ID=259766
Turns out erWin has an option to pay €7 for one hour access. Just enough to download the relevant diagrams.. digging further.
