Results 1 to 10 of 10
Thread: 2001 Beetle 2.0L cranks won't start
    Sep 2014
    engine cranks , won't start. readings of scan. coolant temp group 01 coolant temp G62 -40.C group 6 intake air temp G42 7.0 C. The car setting a day. Ambient temp 50F. Should both temp be close. ??? Group 6 engine speed G28 while cranking no change 0/min.
    I replaced crank sensor by oil filter, coolant sensor 4 term by cyl head in plastic housing.
    Still crank but no start. I scan and here is the reading.
    Saturday,10,March,2018,14:33:41:51465
    VCDS Version: 18.2.0.3 (x64)
    Address 01: Engine Labels: 06A-906-032-AVH.lbl
    Control Module Part Number: 06A 906 032 EB
    Component and/or Version: 2.0l R4/2V G *3667
    Software Coding: 00003
    Work Shop Code: WSC 00066
    VCID: 62CB1FB3EE86B8546E-5142
    16502 - Engine Coolant Temp. Sensor (G62)
    P0118 - 35-00 - Signal too High
    16497 - Intake Air Temp. Sensor (G42)
    P0113 - 35-10 - Signal too High - Intermittent
    16705 - Engine Speed Sensor (G28)
    P0321 - 35-00 - Implausible Signal
    Readiness: 0110 1101
    I cleared codes. and now have coolant sensor G62 7.0 C and air temp 11.0C G42 and seen some reading from engine speed G28, but it didn't stay long during cranking.
    Can I read fuel injectors pulse? what should the reading be? What group #? Is fuel pump pressure given? Can I read a cam sensor? Asking for help. Ross-tech is good scan tool but I'm not utilizing it to it's fullest. I need some guidance. Thanks for your help. Lloyd
    You have replaced the crankshaft position sensor, but you are still getting a fault code for it? Have you checked/tested/verified the wiring to it? Where did you get the sensor itself?
    Aug 2016
    Switzerland
    I'd start with the errors it gives you before looking at the fuel pump pressures.
    The G42 sensor is intermittent, so it could disappear and come as it pleases. the other two are permanent.
    due to emissions, the engine can only consume fuel when a certain engine speed is reached by the starter.
    did you clear the errors? do they come back?
    i'd also have a look at fuses and wiring by WD and RTFB
    basically JPPSG
  6. #4
    Hello OP and welcome to the VCDS forum.
    Please post full auto-scans.
    I see you have a G28 code and a mix of high circuit codes related to temp sensors.
    Does engine start with carb cleaner sprayed in intake to verify fuel vs spark condition?
    Is ground enhancement TSB been performed on coil pack and for G28?
    A review of the WD in RTFB is recommended for shared tracks or isolation of the components by unplugging & logging changes in the G28 output.
    http://wiki.ross-tech.com/wiki/index...ir_Information <<<<<<<<<< PRINT TO PDF!
    Coolant maybe contaminated becoming an electrolyte that results in this type of DTC, in addition to possibly a bad ECT or coolant contamination across the sensor since shared for the ECU and Cluster. Also the color of the sensor for ECT should be green not black as per TSB of this old generation of AZG!
    LOG G28 while cranking and parts shared DTC's unplugged for RPM verification!
    G28 should be inspected for oil contamination that brings fragmented metal with oil & also being conductive to connector to create a corrupt pulse reading & by means as a wick from plain old age of blow by and over filling with oil or gasoline contaminated oil from running fat form IAT and ECT issues.
    Smell sump stick for gas vapor odor!
    Check intake TV for oil residue and pipe!
    JPPSG is advised for process as is the WD section and PCV vapor PSI.
    http://forums.ross-tech.com/showthre...you!-Air-leaks!
    http://forums.ross-tech.com/showthre...(final-version)
    Above Magic!
    Sep 2014
    Thanks for the reply. In the first post above, is a scan after the 2 sensors replaced but "clear codes" was done after the above posted scan.
    codes checked after cranking several times. no codes present, no run either. Will it post a code during cranking? Thanks Lloyd
    Sep 2014
    The crank sensor and coolant sensor not VW OEM.
    Usually yup!
    Oh boy............
    Is G28 seated fully and did you measure compared depth to reluctor?
    Above Magic!
  10. #8
    Sep 2014
    no did not measure, old crank sensor came out in pieces. It look like only one attachment bolt. oring, seat in hole. no adjustment to be made. Thanks for help.
  11. #9
    Sep 2014
    I just watched the viedo on posting scans. Here is the complete scan. Thanks Lloyd
    Mileage:    Repair Order: dan 1
    Chassis Type: 1C - VW New Beetle (1998 > 2010)
    Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
       Mileage: 245870km-152776miles
       Part No: 06A 906 032 EB
       Component: 2.0l R4/2V      G  *3667
       Coding: 00003
       Shop #: WSC 00066
    Address 02: Auto Trans        Labels: 01M-927-733.lbl
       Part No: 01M 927 733 JF
       Component: AG4 Getriebe 01M    4833
       Coding: 00000
       VCID: 7DF14CCF773867AC73-095E
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
       Part No: 1C0 907 379 C
       Component: ABS FRONT MK60      0103
       Coding: 0004097
       VCID: 2A5BB7938636201466-5124
       Part No: 6Q0 909 605 A
       Component: 25 AIRBAG VW5  0E   0004
       Coding: 12853
       Shop #: WSC 00066
       VCID: 356194EF0F887FECFB-4AEC
    00532 - Supply Voltage B+
    Address 17: Instruments        Labels: 1C0-920-xx0.lbl
       Part No: 1C0 920 906
       Component: KOMBI+WEGFAHRS. M73 V03
       Coding: 03232
       VCID: 5EB32B43DAFE9CB44A-4B06
       Subsystem 1 - Part No: Ident
       Component: Nr. Wegfahrs.:VWZ5Z0Y9272217
       Ident.-Nr. Wegfahrs.:VWZ5Z0Y9272217
       Part No: 6N0 909 901
       Component: Gateway K<->CAN    V032
       Coding: 00006
       Shop #: WSC 00066
       VCID: 70EF65FB306A1AC4E8-4B06
    Address 46: Central Conv.        Labels: 1J0-959-799.lbl
       Part No: 1J0 959 799 AR
       Component: 7S Zentral-SG Komf. 0001
       Coding: 00256
       Shop #: WSC 00066
       VCID: 0E131B034A9E6C349A-4B06
       Subsystem 1 - Part No: Steuerger
       Component: t Fahr. antwortet nicht
       Subsystem 2 - Part No: 1J2959801D
       Component: 7S Tőrsteuerger. BF0002r
                49-00 - No Communications
                35-00 -  -
    End-------------------------(Elapsed Time: 03:51)--------------------------
    Address 01: DTCs cleared
  12. Likes Uwe liked this post
  13. #10
    Get that suspect FOD G28 out of that engine or check ECU for water ingress and or harness/rodent damage
    Above Magic!
