Results 1 to 3 of 3
Thread: A6 - Electronics/Voltage warnings and won't turn over
    Nov 2017
    Hey all,
    My Mum's car (2007 A6 C6.) has always been a bit 'odd' with electronics since she got it; it was my Dad's and he had it remapped (8-9 years ago or more) and it also had the battery indicator in the MMI so obviously someone changed some things at some point (but not sure if that relates to anything else). Then a few months back the Amplifier died (I believe due to water damage; I tried repairing the PCB but no joy so I added a bypass on the loop as a stop gap).
    Now it has completely died - it was being driven when it suddenly just lost power and stopped. It went to the garage and they say the engine has seized, and it won't turn over at all now. I thought I'd take a look with VCDS just to see and I can see it had all sorts of voltage warnings before it died. Before I give up on it I was just wondering whether the autoscan might tell a different story. The day it died was 2018.02.13.
    If someone can take a look and shed any light that would be great. If it is dead it is dead, but would be nice to be sure it isn't related to the electronics issues.
    Thanks!
    Chassis Type: 4F (4F0)
    Scan: 01 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 56 61
              62 72
    VIN: WAUZZZ4F36N054742   Mileage: 253900km-157766miles
    0E-Media Player 1 -- Status: Malfunction 0010
    Address 01: Engine        Labels: 03G-906-016-BLB.clb
       Part No SW: 03G 906 016 BF    HW: 028 101 185 0
       Component: R4 2,0L EDC G000SG  9553
       Revision: 12345678    Serial number:
       Coding: 0000072
       Shop #: WSC 66565 257 00032
       VCID: 688AB0683E7D2A27F3A-803C
    6 Faults Found:
    17056 - Cylinder 2 Glow Plug Circuit (Q11)
                P0672 - 000 - Electrical Fault
                        RPM: 945 /min
                        Torque: 42.0 Nm
                        Voltage: 12.77 V
                        Bin. Bits: 00101100
                        Temperature: 13.5∞C
                        Bin. Bits: 10110000
    17057 - Cylinder 3 Glow Plug Circuit (Q12)
                P0673 - 000 - Electrical Fault
                        RPM: 945 /min
                        Torque: 42.0 Nm
                        Voltage: 12.77 V
                        Bin. Bits: 00101100
                        Temperature: 13.5∞C
                        Bin. Bits: 10110000
    18049 - Please check DTC Memory of A/C Controller
                P1641 - 000 -
                        RPM: 2646 /min
                        Torque: 0.0 Nm
                        Speed: 5.0 km/h
                        Voltage: 11.55 V
                        Bin. Bits: 00101100
                        Temperature: 45.0∞C
                        (no units): 154.0
    17058 - Cylinder 4 Glow Plug Circuit (Q13)
                P0674 - 000 - Electrical Fault
                        RPM: 1092 /min
                        Torque: 52.0 Nm
                        Voltage: 12.39 V
                        Bin. Bits: 00101100
                        Temperature: 0.0∞C
                        Bin. Bits: 10110000
    17055 - Cylinder 1 Glow Plug Circuit (Q10)
                P0671 - 000 - Electrical Fault
                        RPM: 966 /min
                        Torque: 48.0 Nm
                        Voltage: 12.08 V
                        Bin. Bits: 00101000
                        Temperature: 5.4∞C
                        Bin. Bits: 10110000
    18255 - Please check DTC Memory of ABS Controller
                P1847 - 000 -
                        Torque: 98.0 Nm
                        Voltage: 10.72 V
                        Bin. Bits: 00101011
                        Torque: 0.0 Nm
                        Bin. Bits: 00000100
       Part No SW: 4F0 910 517 K    HW: 4F0 614 517 K
       Component: ESP 8.0 front   H04 0090
       Coding: 0020855
       Shop #: WSC 02327 785 00200
       VCID: 2C020C78EA05C607D72-8078
                        Fault Frequency: 14
                        Reset counter: 196
                        Mileage: 253884 km
                        Date: 2018.02.13
                        Time: 08:56:46
                        Hex Value: 0x0000
                        Hex Value: 0x02A2
                        Hex Value: 0x0024
                        Hex Value: 0x0183
                        Hex Value: 0x00FF
    00532 - Supply Voltage B+
                        Reset counter: 236
                        Mileage: 253900 km
                        Date: 2018.02.15
                        Time: 16:13:46
                        Hex Value: 0x0000
                        Hex Value: 0x1306
                        Hex Value: 0x0003
                        Hex Value: 0x1669
                        Hex Value: 0x00FF
    00493 - ESP-Sensor Unit (G419)
                        Reset counter: 236
                        Mileage: 253900 km
                        Date: 2018.02.15
                        Time: 16:14:18
                        Hex Value: 0x0000
                        Hex Value: 0x1082
                        Hex Value: 0x001B
                        Hex Value: 0x1068
                        Hex Value: 0x06FF
       Component: FBSAUDIC6 ELV   H31 0220
       Revision: 31050601    Serial number: 10600600220754
       Coding: 0000145
       Shop #: WSC 00031 210 88218
       VCID: 6390A744C75B497F268-8036
       Subsystem 1 - Part No: 4F0 910 132 F
       Component: FBSAUDIC6 EZS   H04 0020
       Component: FBSAUDIC6 IDG   H39 0040
    00955 - Key 1
                        Fault Frequency: 19
                        Reset counter: 83
                        Mileage: 246938 km
                        Date: 2016.09.12
                        Time: 08:01:42
    00166 - Access/Start Authorization Switch (E415)
                        Fault Status: 00111110
                        Reset counter: 232
                        Mileage: 234638 km
                        Date: 2014.05.02
                        Time: 09:54:40
                        Reset counter: 236
                        Mileage: 253900 km
                        Date: 2018.02.15
                        Time: 16:14:46
                        Reset counter: 236
                        Mileage: 253900 km
                        Date: 2018.02.15
                        Time: 16:13:18
       Part No SW: 4F0 910 731     HW: 4E0 035 729
       Component: Interfacebox    H43 1200
       Revision: 00000000    Serial number: 350GW057582891
       Shop #: WSC 02335 785 00200
       VCID: 5F98ABB4EB336D9F020-800A
       Component: Bedienteil MMIC6H03 0050
       Subsystem 2 - Serial number: 00000000198697
       Subsystem 3 - Serial number: 0112.07.050000000100010104ˇ
       Subsystem 4 - Serial number: 010104ˇ
                        Fault Frequency: 128
                        Reset counter: 236
                        Mileage: 250784 km
                        Date: 2017.06.26
                        Time: 17:22:53
                        Bin. Bits:       10
                000 -  -  - Intermittent
                        Reset counter: 39
                        Mileage: 253802 km
                        Date: 2018.02.09
                        Time: 16:34:30
                        Bin. Bits: 00000000
                        Bin. Bits:  0000000
                        Bin. Bits:      001
                        Reset counter: 236
                        Time Indication: 1
    00658 - Control Head
                        Reset counter: 206
                        Mileage: 253389 km
                        Date: 2017.12.20
                        Time: 09:15:37
                        Bin. Bits:      001
       Part No SW: 4F0 910 043     HW: 4F2 820 043 F
       Component: KLIMABETAETIGUNGH05 0160
       Revision: 00000027    Serial number: 00000000162447
       Coding: 0001300
       VCID: 5BE09FA4FF2B71BF6E8-800E
       Part No SW: 4F0 910 279     HW: 4F0 907 279
       Component: ILM Fahrer      H15 0080
       Coding: 0000101
       VCID: 6696BE5034693C57C16-8032
       Subsystem 1 - Part No: 4F2 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H04 0150
       Coding: 00062736
       Shop #: WSC 02335
       Coding: 00141886
       Shop #: WSC 02335
    00003 - Control Module
                014 - Defective
                        Fault Status: 01111110
                        Reset counter: 196
                        Mileage: 253836 km
                        Date: 2018.02.10
                        Time: 08:45:00
                        Reset counter: 236
                        Mileage: 253900 km
                        Date: 2018.02.15
                        Time: 16:14:00
                        Reset counter: 236
                        Mileage: 253900 km
                        Date: 2018.02.15
                        Time: 16:14:00
       Part No SW: 4E0 910 111 E    HW: 4E0 035 111 A
       Component: CD-Changer      H44 0430
       Revision: 00000000    Serial number: AUZ5ZBE7205244
       VCID: 1B60DFA4BFAB31BFAE8-804E
                        Reset counter: 236
                        Mileage: 253900 km
                        Date: 2018.02.15
                        Time: 16:15:08
       Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
       Component: 4E AIRBAG AUDI8RH29 0260
       Revision: 07H29000    Serial number: 0037LD091KG4
       Coding: 0013381
       VCID: 290CF56CE5F7D32F2C4-807C
       Subsystem 1 - Serial number: 6332CSME0B5D47203
       Subsystem 2 - Serial number: 6342CSME0B5C5E5BP
       Subsystem 3 - Serial number: 6352QSME044E413DK
       Subsystem 4 - Serial number: 6362QSME044D3705E
       Subsystem 5 - Serial number: 63734SME044D331D%
       Subsystem 6 - Serial number: 63834SME023B095B0
       Component: Lenks‰ulenmodul H07 0230
       Revision: 00H07000    Serial number: 90022051890410
       Coding: 0102042
       Shop #: WSC 02323 785 00200
       Component: Lenkradmodul    H07 0080
    02071 - Local Databus
                        Fault Status: 00101100
                        Reset counter: 236
       Part No SW: 4F0 910 930 A    HW: 4F0 920 980 M
       Component: KOMBIINSTR. M73 H15 0630
       Revision: 01000000    Serial number: 4SZ35C475
       Coding: 2308443
       Shop #: WSC 16473 067 57207
       VCID: 211CED4C9DC71B6F744-8074
                        Reset counter: 236
                        Mileage: 253882 km
                        Date: 2018.02.13
                        Time: 08:11:36
    Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
       Component: Gateway         H10 0060
       Revision: 10          Serial number: 1200805709816C
       Coding: 6CEE53C41B2104
       Shop #: WSC 02325 785 00200
       VCID: 2708F354F3E3E55F3A0-8072
                        Reset counter: 143
                        Mileage: 253100 km
                        Date: 2017.11.11
                        Time: 14:29:59
       Part No SW: 4E0 910 887 L    HW: 4E0 919 887 C
       Component: MNS ECE         H41 0690
       Revision: 00000000    Serial number: 305IL057630128
       Shop #: WSC 00031 210 91012
       VCID: 36362E1024498CD7B16-8062
                014 - Defective
                        Fault Status: 01101110
                        Fault Frequency: 95
                        Reset counter: 0
                        Mileage: 223459 km
                        Date: 2013.09.25
                        Time: 11:28:38
                        Bin. Bits:     0100
    02445 - Disk Drive Initialization Error
                        Reset counter: 0
                        Mileage: 253900 km
                        Date: 2018.02.15
                        Time: 16:15:58
    02444 - Disk Drive Load / Eject Malfunction
                        Reset counter: 20
                        Reset counter: 236
                        Mileage: 253900 km
                        Date: 2018.02.15
                        Time: 16:15:23
       Component: TSG FA          H12 0050
       Revision: 00-00000
       Coding: 0003610
    02111 - Motor for Window Regulator
                        Fault Status: 01100101
                        Reset counter: 196
                        Mileage: 253899 km
                        Date: 2018.02.15
                        Time: 16:03:57
                        Fault Frequency: 63
                        Reset counter: 236
                        Mileage: 252463 km
                        Date: 2017.09.16
                        Time: 09:08:13
                        Reset counter: 236
                        Mileage: 253900 km
                        Date: 2018.02.15
                        Time: 16:14:44
       Component: Komfortgeraet   H19 0140
       Revision: 01400019    Serial number: 01005608740000
       Coding: 0000763
       VCID: 2E060670DC19B417F96-807A
    Address 47: Sound System
       Revision:             Serial number: 00000000115748
       Coding: 0001104
       VCID: 5EE696B0EC396497096-800A
                        Reset counter: 236
                        Mileage: 253884 km
                        Date: 2018.02.13
                        Time: 12:17:00
                        Voltage: 12.100 V
                        Temperature: 8.0∞C
                        Fault Status: 00110010
                        Reset counter: 236
                        Mileage: 253900 km
                        Date: 2018.02.15
                        Time: 16:14:00
                        Voltage: 8.000 V
                        Temperature: 9.0∞C
       Component: TSG BF          H12 0050
       Revision: 00-00000
       Coding: 0003610
                        Reset counter: 236
                        Mileage: 253900 km
                        Date: 2018.02.15
                        Time: 16:14:44
       Part No SW: 4F0 910 801     HW: 4F0 907 801
       Component: EPB  C63C0030   H03 0030
       Revision: C63C0030
       Coding: 0000111
       Shop #: WSC 02334 785 00200
       VCID: 5DE491BCE13F7F8F10C-8008
                        Reset counter: 236
                        Mileage: 253880 km
                        Date: 2018.02.13
                        Time: 08:01:28
                        Voltage: 10.25 V
                        Count: 202
       Part No SW: 4E0 910 541 F    HW: 4F0 035 541 B
       Component: TUNER EU/US/RDW H42 0480
       Revision: 00000000    Serial number: 394GZ057573247
       VCID: 2310E74487DB097F668-8076
                        Reset counter: 236
                        Mileage: 253900 km
                        Date: 2018.02.15
                        Time: 16:07:23
       Component: ENERGIEMANAGER  H12 0490
       Revision: 00000000    Serial number: 00000000076500
       Shop #: WSC 00081 210 04787
       Subsystem 1 - Part No: 4F0 915 105 C
       Component: von VA0  1507110109
       Coding: 344630393135313035432056413031353037313130313039
       Shop #: WSC 00000 384 00290
                        Fault Frequency: 206
                        Mileage: 225935 km
                        Date: 2013.10.28
                        Time: 13:56:20
    02276 - Quiescent Current Stage 5
                        Fault Frequency: 141
                        Mileage: 225935 km
                        Date: 2013.10.28
                        Time: 13:56:31
    02274 - Quiescent Current Stage 3
                        Mileage: 225935 km
                        Date: 2013.10.28
                        Time: 13:56:41
                        Reset counter: 236
                        Mileage: 253900 km
                        Date: 2018.02.15
                        Time: 16:15:25
                        Fault Frequency: 20
                        Mileage: 253038 km
                        Date: 2017.11.05
                        Time: 11:32:03
       Coding: 0003074
       Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
       Coding: 0003074
                        Reset counter: 236
                        Mileage: 253900 km
                        Date: 2018.02.15
                        Time: 16:14:44
    End----(Elapsed Time: 01:33, VBatt start/end: 11.7V/11.6V. VIgn 11.7V)-----
    Hmm.. It has a lot of fault codes but none of them make it apparent (to me at least) why this car lost power and stopped running.
    I would clear all fault codes and see what comes back.
    The 11.6-11.7V shown during the scan is kinda sad. I'd try try charging the battery.
    I would also try putting a wrench on the crankshaft to see if the engine can be turned by hand.
    Nov 2017
    Ok - thanks Uwe. Will try that!
