Hey all,
My Mum's car (2007 A6 C6.) has always been a bit 'odd' with electronics since she got it; it was my Dad's and he had it remapped (8-9 years ago or more) and it also had the battery indicator in the MMI so obviously someone changed some things at some point (but not sure if that relates to anything else). Then a few months back the Amplifier died (I believe due to water damage; I tried repairing the PCB but no joy so I added a bypass on the loop as a stop gap).
Now it has completely died - it was being driven when it suddenly just lost power and stopped. It went to the garage and they say the engine has seized, and it won't turn over at all now. I thought I'd take a look with VCDS just to see and I can see it had all sorts of voltage warnings before it died. Before I give up on it I was just wondering whether the autoscan might tell a different story. The day it died was 2018.02.13.
If someone can take a look and shed any light that would be great. If it is dead it is dead, but would be nice to be sure it isn't related to the electronics issues.
Thanks!
Thanks!
Chassis Type: 4F (4F0)
Scan: 01 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 56 61
62 72
VIN: WAUZZZ4F36N054742 Mileage: 253900km-157766miles
0E-Media Player 1 -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
Address 01: Engine Labels: 03G-906-016-BLB.clb
Part No SW: 03G 906 016 BF HW: 028 101 185 0
Component: R4 2,0L EDC G000SG 9553
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 66565 257 00032
VCID: 688AB0683E7D2A27F3A-803C
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault
RPM: 945 /min
Torque: 42.0 Nm
Load: 0.0 %
Voltage: 12.77 V
Bin. Bits: 00101100
Temperature: 13.5∞C
Bin. Bits: 10110000
17057 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 000 - Electrical Fault
RPM: 945 /min
Torque: 42.0 Nm
Load: 0.0 %
Voltage: 12.77 V
Bin. Bits: 00101100
Temperature: 13.5∞C
Bin. Bits: 10110000
18049 - Please check DTC Memory of A/C Controller
P1641 - 000 -
RPM: 2646 /min
Torque: 0.0 Nm
Speed: 5.0 km/h
Load: 0.0 %
Voltage: 11.55 V
Bin. Bits: 00101100
Temperature: 45.0∞C
(no units): 154.0
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault
RPM: 1092 /min
Torque: 52.0 Nm
Load: 0.0 %
Voltage: 12.39 V
Bin. Bits: 00101100
Temperature: 0.0∞C
Bin. Bits: 10110000
17055 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 000 - Electrical Fault
RPM: 966 /min
Torque: 48.0 Nm
Load: 0.0 %
Voltage: 12.08 V
Bin. Bits: 00101000
Temperature: 5.4∞C
Bin. Bits: 10110000
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 -
Torque: 98.0 Nm
Load: 0.0 %
Voltage: 10.72 V
Bin. Bits: 00101011
Torque: 0.0 Nm
Bin. Bits: 00000100
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 K HW: 4F0 614 517 K
Component: ESP 8.0 front H04 0090
Coding: 0020855
Shop #: WSC 02327 785 00200
VCID: 2C020C78EA05C607D72-8078
Fault Frequency: 14
Reset counter: 196
Mileage: 253884 km
Date: 2018.02.13
Time: 08:56:46
Hex Value: 0x0000
Hex Value: 0x02A2
Hex Value: 0x0024
Hex Value: 0x0183
Hex Value: 0x00FF
00532 - Supply Voltage B+
Reset counter: 236
Mileage: 253900 km
Date: 2018.02.15
Time: 16:13:46
Hex Value: 0x0000
Hex Value: 0x1306
Hex Value: 0x0003
Hex Value: 0x1669
Hex Value: 0x00FF
Reset counter: 236
Mileage: 253900 km
Date: 2018.02.15
Time: 16:14:18
Hex Value: 0x0000
Hex Value: 0x1082
Hex Value: 0x001B
Hex Value: 0x1068
Hex Value: 0x06FF
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10600600220754
Coding: 0000145
Shop #: WSC 00031 210 88218
VCID: 6390A744C75B497F268-8036
Subsystem 1 - Part No: 4F0 910 132 F
Component: FBSAUDIC6 EZS H04 0020
Component: FBSAUDIC6 IDG H39 0040
00955 - Key 1
Fault Frequency: 19
Reset counter: 83
Mileage: 246938 km
Date: 2016.09.12
Time: 08:01:42
00166 - Access/Start Authorization Switch (E415)
Fault Status: 00111110
Reset counter: 232
Mileage: 234638 km
Date: 2014.05.02
Time: 09:54:40
Reset counter: 236
Mileage: 253900 km
Date: 2018.02.15
Time: 16:14:46
Reset counter: 236
Mileage: 253900 km
Date: 2018.02.15
Time: 16:13:18
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 731 HW: 4E0 035 729
Component: Interfacebox H43 1200
Revision: 00000000 Serial number: 350GW057582891
Shop #: WSC 02335 785 00200
VCID: 5F98ABB4EB336D9F020-800A
Component: Bedienteil MMIC6H03 0050
Subsystem 2 - Serial number: 00000000198697
Subsystem 3 - Serial number: 0112.07.050000000100010104ˇ
Subsystem 4 - Serial number: 010104ˇ
Fault Frequency: 128
Reset counter: 236
Mileage: 250784 km
Date: 2017.06.26
Time: 17:22:53
Bin. Bits: 10
02244 - Button in Control Head is Stuck
Reset counter: 39
Mileage: 253802 km
Date: 2018.02.09
Time: 16:34:30
Bin. Bits: 00000000
Bin. Bits: 0000000
Bin. Bits: 001
Reset counter: 236
Time Indication: 1
00658 - Control Head
Reset counter: 206
Mileage: 253389 km
Date: 2017.12.20
Time: 09:15:37
Bin. Bits: 001
Part No SW: 4F0 910 043 HW: 4F2 820 043 F
Component: KLIMABETAETIGUNGH05 0160
Revision: 00000027 Serial number: 00000000162447
Coding: 0001300
VCID: 5BE09FA4FF2B71BF6E8-800E
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H15 0080
Coding: 0000101
VCID: 6696BE5034693C57C16-8032
Subsystem 1 - Part No: 4F2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H04 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Coding: 00141886
Shop #: WSC 02335
00003 - Control Module
014 - Defective
Fault Status: 01111110
Reset counter: 196
Mileage: 253836 km
Date: 2018.02.10
Time: 08:45:00
Reset counter: 236
Mileage: 253900 km
Date: 2018.02.15
Time: 16:14:00
Reset counter: 236
Mileage: 253900 km
Date: 2018.02.15
Time: 16:14:00
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
Revision: 00000000 Serial number: AUZ5ZBE7205244
VCID: 1B60DFA4BFAB31BFAE8-804E
Reset counter: 236
Mileage: 253900 km
Date: 2018.02.15
Time: 16:15:08
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4E AIRBAG AUDI8RH29 0260
Revision: 07H29000 Serial number: 0037LD091KG4
Coding: 0013381
VCID: 290CF56CE5F7D32F2C4-807C
Subsystem 1 - Serial number: 6332CSME0B5D47203
Subsystem 2 - Serial number: 6342CSME0B5C5E5BP
Subsystem 3 - Serial number: 6352QSME044E413DK
Subsystem 4 - Serial number: 6362QSME044D3705E
Subsystem 5 - Serial number: 63734SME044D331D%
Subsystem 6 - Serial number: 63834SME023B095B0
002 - Lower Limit Exceeded - Intermittent - MIL ON
004 - No Signal/Communication - Intermittent - MIL ON
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenks‰ulenmodul H07 0230
Revision: 00H07000 Serial number: 90022051890410
Coding: 0102042
Shop #: WSC 02323 785 00200
Component: Lenkradmodul H07 0080
02071 - Local Databus
Fault Status: 00101100
Reset counter: 236
Part No SW: 4F0 910 930 A HW: 4F0 920 980 M
Component: KOMBIINSTR. M73 H15 0630
Revision: 01000000 Serial number: 4SZ35C475
Coding: 2308443
Shop #: WSC 16473 067 57207
VCID: 211CED4C9DC71B6F744-8074
Reset counter: 236
Mileage: 253882 km
Date: 2018.02.13
Time: 08:11:36
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H10 0060
Revision: 10 Serial number: 1200805709816C
Coding: 6CEE53C41B2104
Shop #: WSC 02325 785 00200
VCID: 2708F354F3E3E55F3A0-8072
00463 - Control Module for Digital Sound Package (J525)
Reset counter: 143
Mileage: 253100 km
Date: 2017.11.11
Time: 14:29:59
Part No SW: 4E0 910 887 L HW: 4E0 919 887 C
Component: MNS ECE H41 0690
Revision: 00000000 Serial number: 305IL057630128
Shop #: WSC 00031 210 91012
VCID: 36362E1024498CD7B16-8062
014 - Defective
Fault Status: 01101110
Fault Frequency: 95
Reset counter: 0
Mileage: 223459 km
Date: 2013.09.25
Time: 11:28:38
Bin. Bits: 0100
02445 - Disk Drive Initialization Error
Reset counter: 0
Mileage: 253900 km
Date: 2018.02.15
Time: 16:15:58
02444 - Disk Drive Load / Eject Malfunction
Reset counter: 20
Reset counter: 236
Mileage: 253900 km
Date: 2018.02.15
Time: 16:15:23
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0050
Revision: 00-00000
Coding: 0003610
02111 - Motor for Window Regulator
Fault Status: 01100101
Reset counter: 196
Mileage: 253899 km
Date: 2018.02.15
Time: 16:03:57
Fault Frequency: 63
Reset counter: 236
Mileage: 252463 km
Date: 2017.09.16
Time: 09:08:13
Reset counter: 236
Mileage: 253900 km
Date: 2018.02.15
Time: 16:14:44
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H19 0140
Revision: 01400019 Serial number: 01005608740000
Coding: 0000763
VCID: 2E060670DC19B417F96-807A
Address 47: Sound System
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000115748
Coding: 0001104
VCID: 5EE696B0EC396497096-800A
01316 - ABS Control Module
Reset counter: 236
Mileage: 253884 km
Date: 2018.02.13
Time: 12:17:00
Voltage: 12.100 V
Temperature: 8.0∞C
Fault Status: 00110010
Reset counter: 236
Mileage: 253900 km
Date: 2018.02.15
Time: 16:14:00
Voltage: 8.000 V
Temperature: 9.0∞C
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0050
Revision: 00-00000
Coding: 0003610
Reset counter: 236
Mileage: 253900 km
Date: 2018.02.15
Time: 16:14:44
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0000111
Shop #: WSC 02334 785 00200
VCID: 5DE491BCE13F7F8F10C-8008
Reset counter: 236
Mileage: 253880 km
Date: 2018.02.13
Time: 08:01:28
Voltage: 10.25 V
Count: 202
Part No SW: 4E0 910 541 F HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0480
Revision: 00000000 Serial number: 394GZ057573247
Coding: 0000001
VCID: 2310E74487DB097F668-8076
Reset counter: 236
Mileage: 253900 km
Date: 2018.02.15
Time: 16:07:23
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0490
Revision: 00000000 Serial number: 00000000076500
Shop #: WSC 00081 210 04787
Subsystem 1 - Part No: 4F0 915 105 C
Component: von VA0 1507110109
Coding: 344630393135313035432056413031353037313130313039
Shop #: WSC 00000 384 00290
02273 - Quiescent Current Stage 2
Fault Frequency: 206
Mileage: 225935 km
Date: 2013.10.28
Time: 13:56:20
02276 - Quiescent Current Stage 5
Fault Frequency: 141
Mileage: 225935 km
Date: 2013.10.28
Time: 13:56:31
02274 - Quiescent Current Stage 3
Mileage: 225935 km
Date: 2013.10.28
Time: 13:56:41
Reset counter: 236
Mileage: 253900 km
Date: 2018.02.15
Time: 16:15:25
02277 - Quiescent Current Stage 6
Fault Frequency: 20
Mileage: 253038 km
Date: 2017.11.05
Time: 11:32:03
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0003074
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0003074
Reset counter: 236
Mileage: 253900 km
Date: 2018.02.15
Time: 16:14:44
End----(Elapsed Time: 01:33, VBatt start/end: 11.7V/11.6V. VIgn 11.7V)-----
