Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Audi B7 Parking Sensor Volume Issue
    Mar 2018
    Hi all. I have a 2006 B7 S4 Avant and replaced the faulty OEM rear parking sensor speaker with one that I found on eBay (brand new, Chinese). All is good except for the volume of the speaker. It is quite low so I utilized VCDS in an attempt to increase the volume but the value is just stuck on "4". It will not register a new value. So I'm wondering if the problem lies in the fact that the new speaker is not OEM. Or am I doing something wrong within VCDS? Any insight is greatly appreciated. Thank you!
    Hello and welcome to the VCDS forum OP.
    Not being OEM could be an issue for FOD
    Is it the correct part number?
    Post an auto-scan please.
    Above Magic!
  3. Likes Uwe, parkfoto liked this post
    Mar 2018
    Hi Jack, thanks for your reply. After some more investigating, I've decided to purchase the OEM part from Audi (part # 8E0919279). I'll report back after installing the new one. Hopefully that will allow me to adjust the volume via VCDS or at the very least be louder than the one I bought on eBay.
  5. Likes Jack@European_Parts liked this post
  6. #4
    Mar 2018
    OK. So I replaced the eBay purchased speaker with the Audi OEM part # 8E919279 and the default volume appears to be louder (I'll report back once I've put a little more time in the car). Unfortunately VCDS shows the rear buzzer volume is still stuck on 4. I try to change the value and it flashes N/A then shows the current level of 4. Am I doing something wrong here? Or is it just a value that cannot be changed? Thanks.
    On my previous car, a B7 RS4 Avant, I was able to change both Front and Rear volumes and frequencies (essential when I had a non-resonated exhaust fitted), so it is possible with VCDS.
  8. Likes parkfoto liked this post
  9. #6
    Mar 2018
    So in VCDS 18.2 I go to "Electronics 1" then to module 76 "Park Assist" and check "Rear Buzzer Volume". The value on the left reads "4". When I type in the input box on the upper right a value greater than 4, it flashes "N/A" quickly then resumes the number 4 (on the left). Am I doing something wrong?
  10. #7
    How do you get to "Rear Buzzer Volume"? It's an adaptation channel IIRC, so do you click on that button after going to 76?
    Just a thought, I can't remember for sure if you need to have entered a security code first (I don't THINK I did...) to be able to change settings?
  11. Likes Uwe, parkfoto liked this post
  12. #8
    Mar 2018
    After 76, press "Adv. Meas. Values" and a whole list of values with check boxes comes up on the right. This is where I think I'm making a mistake. I just change the value to something over 4 and less than 8 and nothing happens. Do I need to change some sort of coding instead? And no need for a security code, I believe that you only need that for 01-Engine module.
  13. #9
    Dec 2016
    NL
    Quote Originally Posted by parkfoto View Post
    Measuring values is exactly that.
    If you want to change settings, you go to adaptations or coding.
    Current:
  14. Likes parkfoto, PetrolDave liked this post
  15. #10
    Mar 2018
    Thank you for pointing me in the right direction. Do you have any guidance on how to change volume values in Adaptation or Coding?
