Results 1 to 5 of 5
Thread: Passat cc 2009 probleme
    Verified VCDS User alinjadi's Avatar
    May 2015
    Morocco
    hi
    i have a problem with my passat cc 2009
    on the road, the dashboard jokes then it does not return mileage and gauge gasoil vibrates
    with a lot of default on vcds
    Saturday,10,March,2018,14:15:13:26370
    VCDS Version: 17.8.0.1
    VIN: WVWZZZ3CZAE506348   License Plate:
    Chassis Type: 3C-VW46 (3C0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 53 56 62 72 77
    VIN: WVWZZZ3CZAE506348   Mileage: 160110km-99487miles
    53-Parking Brake -- Status: Malfunction 1010
    Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 022 QD    HW: 03L 907 309
       Component: R4 2,0L EDC G000AG  3733
       Revision: 13H02---    Serial number: VWZCZ000000000
       Coding: 0000078
       Shop #: WSC 80093 222 71269
       VCID: 77F9BE5406AA46FEBB-8022
    8 Faults Found:
    008213 - Intake Manifold Flap Position Sensor (Bank 1)
                   P2015 - 000 - Implausible Signal - MIL ON
                        Fault Status: 11100000
                        Mileage: 159670 km
                        Date: 2012.07.22
                        Time: 12:28:45
                        Lambda: -5.5 %
                        Lambda: -12.6 %
                        Voltage: 3.800 V
                        Bin. Bits: 10001110
    049682 - Steering Column Control Module
                   U0212 - 000 - No Communications - Intermittent
                        Mileage: 159681 km
                        Temperature: 38.7C
                        Voltage: 12.46 V
                        Bin. Bits: 00000000
                        Torque: 93.0 Nm
                        Temperature: 29.7C
    049478 - No Communication with Diagnostic Gateway
                   U0146 - 000 -  - Intermittent
                        Mileage: 159681 km
                        Temperature: 38.7C
                        Voltage: 12.46 V
                        Bin. Bits: 00000000
                        Torque: 93.0 Nm
                        Temperature: 29.7C
    049508 - No Communications with HVAC Control Module (J301)
                   U0164 - 000 -  - Intermittent
                        Mileage: 159681 km
                        Temperature: 38.7C
                        Voltage: 12.46 V
                        Bin. Bits: 00000000
                        Torque: 93.0 Nm
                        Temperature: 29.7C
    001299 - Incorrect Immobilizer Key
                   P0513 - 000 -  - Intermittent
                        Mileage: 159681 km
                        RPM: 943 /min
                        Voltage: 12.01 V
                        Absolute Pres.: 907.8 mbar
                        Absolute Pres.: 887.4 mbar
                        Temperature: 33.3C
                        Temperature: 35.1C
    008598 - Oxygen (Lambda) Sensor B1 S1
                   P2196 - 000 - Signal too High (Rich) - MIL ON
                        Mileage: 159706 km
                        Date: 2012.07.22
                        Time: 20:21:19
                        RPM: 1426 /min
                        Speed: 30.0 km/h
                        Lambda: 53.7 %
                        Mass Air / Rev.: 500.0 mg/str
                        Voltage: 0.150 V
                        (no units): 16.0
                        Voltage: 0.975 V
    049441 - No Communication with ABS Brake Control Module
                   U0121 - 000 -  - Intermittent
                        Fault Frequency: 7
                        Mileage: 160109 km
                        Date: 2012.07.31
                        Time: 10:48:59
                        Temperature: 16.2C
                        Voltage: 12.54 V
                        Bin. Bits: 00000000
                        Torque: 93.0 Nm
                        Temperature: 20.7C
    049448 - No Communications with Parking Brake Control Module
                   U0128 - 000 -  - Intermittent
                        Fault Frequency: 7
                        Mileage: 160109 km
                        Date: 2012.07.31
                        Time: 10:48:59
                        Temperature: 16.2C
                        Voltage: 12.54 V
                        Bin. Bits: 00000000
                        Torque: 93.0 Nm
                        Temperature: 20.7C
    Readiness: 1 2 0 0 0
       Part No SW: 02E 300 052     HW: 02E 927 770 AJ
       Component: GSG DSG AG6     440 1913
       Revision: 04844002    Serial number: 00000907181181
       Shop #: WSC 00028 028 00001
       VCID: 51AD20CCC88E38CE55-8004
    18259 - Powertrain Data Bus
                P1851 - 000 - Missing Message from ABS Controller - Intermittent
                        Fault Frequency: 255
                        Reset counter: 40
                        Mileage: 159808 km
                        Date: 2012.07.24
                        Time: 19:04:39
    18290 - Powertrain Data Bus
                P1882 - 000 - Missing Message from Electric Parking Brake Controller - Intermittent
                        Reset counter: 40
                        Mileage: 159808 km
                        Date: 2012.07.24
                        Time: 19:04:39
    Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 AF    HW: 3C0 614 109 AF
       Component: J104    C4 440 V2   0015
       Revision: --025---    Serial number: 00000795260217
       Coding: 0002326
       Shop #: WSC 20984 146 95584
       VCID: 62CFFF00BD28B356FC-8036
                        Reset counter: 104
                        Mileage: 159808 km
                        Date: 2012.07.24
                        Time: 19:08:16
                        Speed: 6.0 km/h
                        Hex Value: 0x0002
                        Voltage: 13.50 V
                        Bin. Bits: 00011111
                        Count: 220
                        Hex Value: 0x0000
    01312 - Powertrain Data Bus
                        Fault Status: 00101110
                        Reset counter: 104
                        Hex Value: 0x0000
                        Voltage: 14.25 V
                        Bin. Bits: 00011110
                        Count: 148
                        Hex Value: 0x0000
    Address 08: Auto HVAC        Labels:. 5K0-907-044.clb
       Part No SW: 5K0 907 044 BD    HW: 5K0 907 044 BD
       Component: Climatronic   H14 0608
       Revision: 00003001
       Shop #: WSC 05311 115 00000
       ASAM Dataset: EV_Climatronic A01001
       VCID: 6ED79B30B1F0073668-803A
    13701392 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Fault Frequency: 7
                        Reset counter: 144
                        Mileage: 159808 km
                        Date: 2018.03.03
                        Time: 19:04:41
       Revision: 00H54000    Serial number: 00000009654595
       Coding: E4808F8A0004102047970F00170000008008FF475C00017C170000000000
       Shop #: WSC 05124 123 12345
       VCID: 33614A4452526ADE47-8066
       Subsystem 1 - Part No: 3C8 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer 140509 022  0602
       Coding: 00046997
       Shop #: WSC 05124
       Component: RLS     150609 054  0402
       Coding: 00209133
       Shop #: WSC 05124
                        Fault Status: 00101100
                        Fault Frequency: 13
                        Reset counter: 144
                        Mileage: 159879 km
                        Voltage: 13.45 V
                        Fault Status: 00101010
                        Reset counter: 135
                        Mileage: 159742 km
                        Voltage: 12.20 V
    Address 10: Park/Steer Assist (J791)       Labels:. 1T0-919-475.clb
       Part No SW: 1T0 919 475 H    HW: 1T0 919 475
       Component: PARKHILFE PLA H07 0110
       Revision: --------    Serial number: 88530915401178
       Coding: 100107
       Shop #: WSC 05314 000 00000
       VCID: 408B1588D3E4C146CA-8014
                        Reset counter: 144
                        Mileage: 159808 km
                        Date: 2012.07.24
                        Time: 19:04:42
                        Temperature: 13.0C
                        Reset counter: 144
                        Mileage: 159808 km
                        Date: 2012.07.24
                        Time: 19:04:42
                        Temperature: 13.0C
       Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
       Component: J234__300 VW10 HI   1916
       Revision: 20013000    Serial number: 003E2PBHKGWB
       Coding: 0012336
       Shop #: WSC 05311 000 00000
       VCID: 4483199807FCDD66EE-8010
       Subsystem 1 - Serial number: 6332MTS638611349
       Subsystem 2 - Serial number: 6342MTS608791339
       Subsystem 3 - Serial number: 6351HTS6AGFT16KR
       Subsystem 4 - Serial number: 6361HTS6MCN026KR
                        Reset counter: 144
                        Mileage: 159808 km
                        Date: 2012.07.24
                        Time: 19:04:42
    Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
       Part No SW: 3C0 953 549 AJ    HW: 3C0 953 549 AJ
       Component: J0527               0030
       Revision: 00032000    Serial number: 3C5953507CN
       Coding: 0001711
       VCID: 74E3895817DC2DE69E-8020
       Subsystem 1 - Part No: 3C8 959 537 B  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAP   H4 0021
       Coding: 00000226
    Address 17: Instruments (J285)       Labels:| 3C8-920-xxx-17.clb
       Part No SW: 3C8 920 870 E    HW: 3C8 920 870 E
       Component: KOMBI         H02 0206
       Coding: 060F00
       Shop #: WSC 05314 115 12345
       VCID: 2D555C3C7C763C2E11-8078
    12656896 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 144
                        Mileage: 159808 km
                        Date: 2018.03.03
                        Time: 19:04:37
    12658688 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 144
                        Mileage: 159808 km
                        Date: 2018.03.03
                        Time: 19:04:37
       Part No SW: 3C0 907 530 L    HW: 3C0 907 951
       Component: J533__Gateway   H13 0152
       Revision:   H13       Serial number: 3300P09609091D
       Coding: FDA07F06000602001002
       Shop #: WSC 79774 146 86568
       VCID: 2A5F572085982B16F4-807E
                        Reset counter: 144
                        Mileage: 159808 km
                        Date: 2012.07.24
                        Time: 19:04:39
                        Reset counter: 144
                        Mileage: 159808 km
                        Date: 2012.07.24
                        Time: 19:04:39
       Part No SW: 3C0 959 799 H    HW: 3C0 959 799 H
       Component:    IMMO         070 0383
       VCID: 3E776B706910B7B6B8-806A
       Subsystem 1 - Part No: 3C0 959 799 H
       Subsystem 2 - Part No: 3C0 905 861 G
       Component:    ELV          027 0380
       3C0 959 799 H      IMMO         070 03833C0905861G     ELV          027 0380
    No Faults Found
       Part No SW: 1T0 959 701 L    HW: 1K0 959 793 P
       Component: J386  TUER-SG FT    1533
       Revision: 71009005    Serial number: 00000899498602
       Coding: 0000253
       VCID: 408B158813E4C146CA-8014
       Part No SW: 5N1 909 144 K    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.141 0703
       Revision: 1AH03256    Serial number: 00082980067802
       Coding: 0000258
       VCID: 3A7F676075389B9684-806E
                        Reset counter: 144
                        Mileage: 159808 km
                        Date: 2012.07.24
                        Time: 19:04:41
                        Speed: 50.0 km/h
                        (no units): 6.0
                        Voltage: 12.60 V
                        Reset counter: 144
                        Mileage: 159808 km
                        Date: 2012.07.24
                        Time: 19:04:41
                        Speed: 50.0 km/h
                        (no units): 6.0
                        Voltage: 12.60 V
    Address 46: Central Conv.        Labels:. 3C0-959-799-46.clb
       Component: 09 KESSY PQ46 R 070 0231
       Revision: 00070000    Serial number: VWZCZ000000000
       Coding: 00910A0001C64E763606941570004F0B60780103242498
       Shop #: WSC 05311 123 12345
    00625 - Vehicle Speed Signal
                        Reset counter: 144
                        Mileage: 159808 km
                        Date: 2012.07.24
                        Time: 19:04:39
       Part No SW: 1T0 959 702 L    HW: 1K0 959 792 P
       Component: J387  TUER-SG BT    1533
       Revision: 71009005    Serial number: 00000648398605
       Coding: 0000252
       VCID: 418D108C18EEC84EC5-8014
       Part No SW: 3C8 907 801 C    HW: 3C8 907 801 C
       Component: J540 EPB3  VW-13618 0005
       Revision:   010       Serial number: 00000000027575
       Coding: 0000057
                        Reset counter: 144
                        Mileage: 160005 km
                        Date: 2012.07.29
                        Time: 15:43:18
                        Voltage: 13.60 V
                        Count: 73
                        Hex Value: 0x1271
                        Hex Value: 0x0001
                        Hex Value: 0x1010
                        Reset counter: 142
                        Mileage: 159808 km
                        Date: 2012.07.24
                        Time: 19:05:53
                        Voltage: 13.10 V
                        Count: 76
                        Hex Value: 0x12E0
                        Hex Value: 0x0001
                        Hex Value: 0x0101
                        Reset counter: 140
                        Voltage: 13.90 V
                        Count: 77
                        Hex Value: 0x1271
                        Hex Value: 0x0001
                        Hex Value: 0x1010
                        Reset counter: 144
                        Mileage: 159882 km
                        Date: 2012.07.26
                        Time: 11:35:47
                        Voltage: 14.00 V
                        Count: 96
                        Hex Value: 0x1271
                        Hex Value: 0x0001
                        Hex Value: 0x1010
       Part No SW: 6RD 035 187 A    HW: 6RD 035 187 A
       Component: MIB2-S-R-CN   025 0210
       Revision: -----001    Serial number: 06005GD2172800
       Coding: 0000040004000A
       Shop #: WSC 00081 790 00183
       VCID: 4585049CCCC6E46EF9-8010
                        Reset counter: 144
                        Mileage: 159808 km
                        Date: 2012.07.24
                        Time: 19:04:55
       Part No SW: 3C8 959 703 B    HW: 1K0 959 795 Q
       Component: J388   TUER-SG HL   0309
       Revision: 43004101    Serial number: 00000000940976
       Coding: 0000152
       VCID: 316D404CA84E58CE35-8064
       Part No SW: 3C8 959 704 B    HW: 1K0 959 794 Q
       Component: J388   TUER-SG HR   0309
       Revision: 43004101    Serial number: 00000000936079
       Coding: 0000152
       VCID: 326F4F40AD4863D64C-8066
    Address 77: Telephone        Labels: 3C0-035-730.lbl
       Part No SW: 5N0 035 730 B    HW: 5N0 035 730 B
       Component: J412                8502
       Revision: 00015000    Serial number: 0000B7A086038
       Coding: 0020045
       VCID: 2759AE14968A167EEB-8072
    00385 - Positive Output Audio Channel for Speech/Telephone
                        Reset counter: 93
                        Mileage: 159684 km
                        Date: 2012.07.22
                        Time: 17:12:35
    00386 - Negative Output Audio Channel for Speech/Telephone
                        Reset counter: 93
                        Mileage: 159684 km
                        Date: 2012.07.22
                        Time: 17:12:35
    End-------------------------(Elapsed Time: 02:50)--------------------------
    thanks...
    Car is full of CAN communications faults. Wiring problem? Problem with some module on the Powertrain CAN glitching the bus?
    Some of these faults are fairly old. Clear all faults, drive car, see what comes back.
  3. Likes alinjadi liked this post
    In addition to Uwe's questions........
    Don't you think you have a weak battery, poor ground connections, possible bad ignition switch or terminal relay and maybe even a bad ABS module based on scan results?
    Above Magic!
  5. Likes alinjadi liked this post
  6. #4
    Jul 2014
    Tallinn, Estonia
    By any chance, did the fault start after retrofitting RCD330G radio?
  7. Likes alinjadi liked this post
  8. #5
    May 2015
    Morocco
    as soon as the defect appears. I have a lot of defects on vcds with one shot
    this my scan after clear dtc
    Sunday,25,February,2018,13:24:35:26370
    Mileage: 159450km-99077mi   Repair Order:
    VIN: WVWZZZ3CZAE506348   Mileage: 159450km-99077miles
       Coding: 0000078
                        Mileage: 159458 km
                        Date: 2012.07.18
                        Time: 13:15:41
                        Lambda: -6.3 %
                        Lambda: -12.6 %
                        Voltage: 3.800 V
                        Bin. Bits: 10001110
       Coding: 0002326
       Revision: 00003001
       Coding: 0000000000
       Coding: 00046997
       Shop #: WSC 05124
       Coding: 00209133
       Shop #: WSC 05124
       Coding: 100107
       Coding: 0012336
       Coding: 0001711
       Coding: 00000226
       Coding: 060F00
    No Faults Found
       Coding: 0000253
       Coding: 0000258
       Coding: 0000252
       Coding: 0000057
       Coding: 0000152
    No Faults Found
       Coding: 0000152
       Coding: 0020045
                        Reset counter: 88
                        Mileage: 159458 km
                        Date: 2012.07.18
                        Time: 13:09:04
                        Reset counter: 88
                        Mileage: 159458 km
                        Date: 2012.07.18
                        Time: 13:09:04
    End-------------------------(Elapsed Time: 02:48)--------------------------
    for the radio I had the fault before changing
    and for ground connections, I'll try and I'll let you know
    thanks.....
