Results 1 to 9 of 9
Thread: 2006 Jetta 2.5 Sedan Central Locking Problem Dtc 00928
    Apr 2015
    Drivers door can not control any other power windows or locks,
    All other doors can operate windows and locks.
    Found and repaired 3 broken wires under boot.
    Replaced drivers master switch, no change,
    Removed panel found lkq window motor, see old motor on back seat,
    Installed motor, now all windows can be operated from master switch,
    Now just have 00928.
    The drivers lock switch shows on and off on vcds and all ways shows
    locked even though drivers door never locks, even with key fob.
    I assuming the drivers lock module is the problem,
    Is it possible to reuse second hand power window motor and door lock
    module , or are they locked down to the donor car?
    Thank You
    Monday,05,March,2018,16:22:10:39461
    VCDS Version: 17.8.0.1
    VIN: 3VWSF71K26M654842   License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: 3VWSF71K26M654842   Mileage: 190410km-118315miles
    42-Door Elect, Driver -- Status: Malfunction 1010
    Address 01: Engine        Labels: 06A-906-032-BGP.lbl
       Part No SW: 07K 906 032 N    HW: Hardware No
       Component: 2.5l R5/4V      G   6698
       Revision: --------    Serial number: VWZ7Z0E2500996
       Coding: 0000003
       VCID: 346D13B257A14AE65E-8060
       Part No SW: 09G 927 750 EL    HW: 09G 927 750 EL
       Component: AQ 250 6F           0758
       Revision: 00H25000    Serial number:
       Coding: 0000072
       VCID: 7F070C9E2E6759BEF3-802A
       Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
       Revision: 00T12001
       Coding: 0021122
       VCID: 40854F621319E646CA-8014
                002 - Lower Limit Exceeded
       Part No: 1K0 820 047 DL
       Component: Climatic PQ35   090 0505
       VCID: 71E3DAA668333FCE75-8024
    00532 - Supply Voltage B+
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
       Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
       Component: Bordnetz-SG     H37 1002
       Revision: 00H37000    Serial number: 00000000122344
       Coding: 04058E234004180000140000001400000008730B5C
       VCID: 2A510DCA85650C16F4-807E
       Subsystem 1 - Part No: 1K1 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  012  0402
       Coding: 00065493
       Shop #: WSC 00066
                        Fault Status: 01100010
                        Reset counter: 206
                        Mileage: 190417 km
                        Voltage: 6.80 V
    Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
       Part No SW: 8E0 035 593 E    HW: 8E0 035 593 E
       Component: SDAR XM         H03 0080
       Revision: 00000000    Serial number: AUZ4Z7E2030390
       VCID: 2B5F08CE8A9F151E0F-807E
    00003 - Control Module
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 241
                        Mileage: 89571 km
                        Time: 02:12:05
                        Reset counter: 231
                        Mileage: 190042 km
                        Time: 07:35:12
                        Voltage: 8.40 V
                        Fault Frequency: 7
                        Reset counter: 231
                        Mileage: 190042 km
                        Time: 07:35:12
                        Voltage: 8.40 V
    02788 - Internal Communications Error
                000 -  -  - Intermittent
                        Reset counter: 246
                        Mileage: 89571 km
                        Time: 02:12:04
                        Bin. Bits: 00000010
                        Bin. Bits: 00000000
    01304 - Radio
                        Reset counter: 246
                        Mileage: 190042 km
                        Time: 07:54:46
       Part No SW: 1K0 909 605 E    HW: 1K0 909 605 E
       Component: 1S AIRBAG VW8R  024 6300
       Revision: 03024000    Serial number: 0037KD033CEW
       Coding: 0012627
       VCID: 2E5901DAB98D603628-807A
       Subsystem 1 - Component: BF-Gewichtsens.
       Subsystem 2 - Serial number: 6332MSME0A664707B
       Subsystem 3 - Serial number: 6342MSME0A671E0CM
       Subsystem 4 - Serial number: 6351HSME075A606DE
       Subsystem 5 - Serial number: 6361HSME0768084FG
       Subsystem 6 - Serial number: 63727SME073E1F1CD
       Subsystem 7 - Serial number: 63827SME072B1C622
       Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
       Component: J0527           034 0070
       Coding: 0010021
       VCID: 78F5E7820B496E86B2-802C
       Part No: 1K0 920 952 C
       Component: KOMBIINSTRUMENT 3HL 1212
       Coding: 0023203
       Part No SW: 1K0 907 530 F    HW: 1K0 907 951
       Component: Gateway         H10 0120
       Revision:   H10       Serial number: 28001056108AD9
       Coding: 3F3F0360071002
                        Reset counter: 245
                        Mileage: 190061 km
                        Time: 00:10:25
                        Reset counter: 206
                        Mileage: 190417 km
                        Time: 00:01:01
       Component: IMMO            3HL 1212
       Shop #: WSC 41239 001 1048576
    01176 - Key
       Component: J386  TUER-SG FT    1133
       Revision: 32008001    Serial number: 00000531869219
       Coding: 0001205
       VCID: 3B7F388E7AFF859E9F-806E
    7 Faults Found:
                        Reset counter: 206
                        Mileage: 190417 km
                        Fault Status: 00100101
                        Reset counter: 245
                        Mileage: 190417 km
                        Fault Status: 00111100
                        Reset counter: 246
                        Mileage: 190417 km
                        Fault Status: 01111000
                        Reset counter: 206
                        Mileage: 190417 km
    01706 - Switch for Mirror-Adjust (E43)
                        Reset counter: 206
                        Mileage: 190417 km
    01030 - Central Locking Key Switch; Driver Side; Lock
                        Fault Status: 00111000
                        Reset counter: 246
                        Mileage: 190417 km
    00109 - Left Mirror Turn Signal Lamp (L131)
                        Reset counter: 246
                        Mileage: 190417 km
       Part No: 1K1 909 144 J
       Component: EPS_ZFLS Kl.5   D04 1606
       VCID: 326115AAADB544D64C-8066
                        Mileage: 400 km
                        Temperature: 12.0C
                        Voltage: 4.60 V
                        Voltage: 5.40 V
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 AF
       Coding: 137803281B09050F880F048051A0
       VCID: 74EDD3B217210AE69E-8020
    No Faults Found
       Part No: 1K0 959 702 K
       Component: Tuer-SG         024 2377
       Coding: 0001269
       Shop #: WSC 08305 993 56004
       VCID: 377724BE46D7A1FE7B-8062
       Part No SW: 1K0 035 180 C    HW: 1K0 035 180 C
       Component: Radio DE2       011 0014
       Revision: 00011000    Serial number: VWZ4Z7E2034023
       Coding: 0040400
       VCID: 2045EFE2F359C646AA-8074
    Address 62: Door, Rear Left        Labels: None
       Part No: 1K0
       VCID: 2C5D0BD28F91122606-FFFE
    No Faults Found
       Part No: 1K0 959 704 D
       Component: Tuer-SG         021 2434
       Coding: 0000144
    01814 - Supply Voltage for Door Controller; Rear Right (J389)
    End-------------------------(Elapsed Time: 02:22)--------------------------
    Lotta faults still present in 42: Door Elect, Driver. Have you cleared them yet? Do they come back? The one I would focus on first is: "1811 - Supply Voltage for Door Controller; Drivers Side (J386) - Lower Limit Exceeded".
    However, it also bothers me that 46: Central Conv. is showing:
    "No Faults Found
    What happens if you go directly to 46 and check it for faults?
    Apr 2015
    2005 Jetta
    I disconnected the battery for 30 minutes, 00928 seems to have cleared, all doors except passenger right
    lock-unlock with key fob, passenger right rear door button not lighting up.
    Drivers door lock-unlock key icon shows dim then goes out, doesn't lock or unlock,
    but does sound like it is try to actuate.
    Saturday,10,March,2018,11:39:10:39461
       Coding: 0000003
       Coding: 0000072
       Revision: 00T12001
       Coding: 0021122
       Coding: 00065493
       Shop #: WSC 00066
                        Reset counter: 208
                        Mileage: 190417 km
                        Voltage: 14.15 V
                        Reset counter: 208
                        Mileage: 190417 km
                        Voltage: 14.05 V
                014 - Defective
                        Reset counter: 241
                        Mileage: 89571 km
                        Time: 02:12:05
                        Reset counter: 208
                        Mileage: 190417 km
                        Time: 18:12:15
                        Bin. Bits: 00000010
                        Bin. Bits: 00000000
       Coding: 0012627
       Subsystem 1 - Part No: 1K0 959 339 B
       Component: BF-Gewichtsens. 006 0003
       Coding: 0010021
       Coding: 0023203
       Part No: 1K0 959 701 K
       Coding: 0001269
       VCID: 366929BA41DD58F660-8062
       Coding: 0001269
       Coding: 0040400
       Part No: 1K0 959 703 D
       Coding: 0000144
       VCID: 31631AA6A8B37FCE35-8064
       Coding: 0000144
    End-------------------------(Elapsed Time: 02:10)--------------------------
    Have you considered a bad door harness or lock unit?
    Above Magic!
    Apr 2015
    Can a used driver door lock module with same part number be used, or is it locked to donor vehicle?
    On a 2005 Jetta, I would not expect any problem swapping door control modules, provided of course you get the correct one.
  7. Likes Jack@European_Parts liked this post
    Apr 2015
    This is a 2006 Jetta Sedan 2.5, still o.k.?
  9. #8
    Quote Originally Posted by Carfixr View Post
    Sorry, typo. Let me re-phrase:
    On an Mk.5 Jetta, I would not expect any problem swapping door control modules, provided of course you get the correct one.
  11. #9
    The harness should be toned out, and to be able to carry current, because it doesn't only fail at boot location.
    In addition other faults on shared bus for the other doors will need to be corrected.
    Above Magic!
  12. Likes Uwe liked this post
