Results 1 to 10 of 12
Thread: Car wont crank
    Mar 2017
    Car wont crank
     Friday,09,March,2018,18:33:03:39527
    VCDS Version: 18.2.0.3 (x64)  HEX-NET CB: 0.4411.4
    Chassis Type: FR-AU48 (8R0)
    Scan: 01 02 03 05 06 08 09 15 16 17 19 22 36 3C 42 44 46 47 52 53
              56 5F 6C
    VIN: WUAC6AFR5EA90182  Mileage: 13990km-8692miles
    Address 01: Engine (------CFSA)       Labels:. 079-907-560-CFS.clb
       Part No SW: 8T2 907 560 F    HW: 8T1 907 560
       Component: 4.2l V8HDZ /  H04 0003
       Revision: NAH04---
       Coding: 1A25003225A6080D3000
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_ECM42FSI0118T2907560F 001002
       ROD: EV_ECM42FSI0118T2907560F.rod
       VCID: 3FCE8F79A6E7DBBC21-806A
    4527 - Coolant Fan Control Circuit 1
              P0480 00 [036] - Electrical Malfunction
                        Mileage: 13994 km
                        Date: 2018.03.09
                        Time: 19:17:46
                        Coolant temperature: 20 C
                        Intake air temperature: 20 C
                        Voltage terminal 30: 12.086 V
                        selected gear-Bits 0-7: 0
                        Cruise control switch actuation-Bits 0-7: 0
    4528 - Coolant Fan Control Circuit 2
              P0481 00 [036] - Electrical Malfunction
                        Mileage: 13994 km
                        Date: 2018.03.09
                        Time: 19:17:46
    5456 - Starter Will Not Turn
              P3054 00 [167] - Jammed or Electrical Malfunction
                        Mileage: 13994 km
                        Date: 2018.03.09
                        Time: 18:29:50
                        Coolant temperature: 21 C
                        Intake air temperature: 22 C
                        Voltage terminal 30: 11.614 V
                        AFS dm: 0.0 kg/h
    Readiness: 1110 1101
       Part No SW: 8T0 927 156 H    HW: 0B5 927 156 K
       Component: 0B5 42 FSINAR H02 0003
       Revision: --H02---
       Coding: 000001
       ROD: EV_TCMDL501021.rod
       VCID: 42C8868DD515B6544E-8016
       Part No SW: 8T0 907 379 F    HW: 8T0 907 379 F
       Coding: 2C1D1A
       VCID: 45C29D91CC3B816C6B-8010
       Part No SW: 8K0 907 064 JM    HW: 8K0 907 064 JM
       Component: BCM2 2.0      H14 0650
       Coding: 0D804040000000000000
       VCID: 04444095878178643C-8050
       Serial number: 0214000007611006
       Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
       Component: MEM-BFS       H10 0077
       Revision: AA000000    Serial number: 00000089867497
       Coding: 00037025002C00000000
       Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
       Revision: C1000000    Serial number: 01100220140370
       Coding: 4802200000
       VCID: 393AE161B0C3F58C1F-806C
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 27
                        Mileage: 13994 km
                        Date: 2018.03.09
                        Time: 18:36:14
                        Temperature: 21.0C
                        Temperature: 21.0C
                        Absolute Pres.: 1.0 bar
                        Current: 0.000 A
                        Temperature: 31.0C
       Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
       Revision: 09016001    Serial number: 00000058993101
       Coding: 06000091043C9FE0250048C3000039090F9CD388A2090221000008004000010200040034000000
       VCID: 7AB83E6DF5453E9456-802E
       Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 070214  H15 0080
       Serial number: SWF14020075298
       Coding: 00FD11
       Serial number: 22221293
       Coding: 02005D
       Subsystem 3 - Part No SW: 8K0 941 531 AQ    HW: 8K0 941 531 AQ
       Component: E1 - LDS  H03 0031
       Serial number: 00000000002001140470
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R9LA803
       Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
    H01 0031
       Subsystem 6 - Part No SW: 8K5 941 329     HW: 8K5 941 329
    H01 0031
       Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: AA09CD07000000000001
       Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
       Component: AirbagVW-AU10 H47 0610
       Serial number: 003KJDB12CKF
       Coding: 303343334830303030304A55304C38543053
       VCID: 4AD8AEADED256E1486-801E
       Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
       Component: BF-Gewichtss.  H02 0060
       Serial number: 5810000R140000HWUA
       Serial number: 6334MSME417E3649L
       Serial number: 6344MSME417D5312A
       Serial number: 6352QSME443A2E5EX
       Serial number: 6362QSME4C3A2644N
       Serial number: 63732SME1F3C237A9
    9444115 - Front Passenger's Front Airbag Crash Sensor
              B101B 15 [137] - Open or Short to Plus
                        Mileage: 13994 km
                        Date: 2018.03.09
                        Time: 18:30:20
       Revision: --------    Serial number: 90372NB4000VL
       Coding: 000036
       VCID: 44C48095C701B8647C-8010
       Part No SW: 8T0 920 984 H    HW: 8T0 920 984 H
       Component: KOMBIINSTR.   H35 0564
       Revision: 00000000    Serial number: Z9X29PX1F
       Coding: 8BBF01008B03D705020000
       Component: GW-BEM 5CAN-M H11 0060
       Revision: 1Z120030    Serial number: 3041Z1412705D9
       Coding: 80E3031600
       VCID: 4CD4A8B5EF517024B4-8018
       Serial number: 8983742403
                        Reset counter: 27
                        Mileage: 13994 km
                        Date: 2018.03.09
                        Time: 18:37:52
                        Bin. Bits:    10111
                        Voltage: 12.00 V
                        Count: 6
    Address 22: AWD (J492)       Labels: 8K0-907-163.clb
       Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
       Component: 4 Wheel Drive H14 0100
       Serial number: 002501140001599
       ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
       VCID: 2F2EDF3976872B3CB1-807A
       Component: MEM-FS        H10 0077
       Revision: AA000000    Serial number: 00000089930988
       Coding: 001B7B25002C00000000
       Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
       Component: SWA Master    H05 0071
       Serial number: 0324206826
       Coding: 010211
       Shop #: WSC 06324 000 00000
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
       Component: SWA Slave  H05 0071
       Serial number: 0324161859
       Coding: 010211
       Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
       Component: TSG FA        H09 0305
       Coding: 011C13224E00120102
       VCID: 56E04ADD219D3AF412-8002
       Part No SW: 8K0 909 144 G    HW: 8K0 909 144 B
       Component: RCEPS         H40 0508
       Revision: 00001000    Serial number: 0025248314
       Coding: 100000010001
       ASAM Dataset: EV_RCEPSAU48X 008015
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3522ED5194DB11ECFB-8060
       Revision: 00002001    Serial number: 0326763341
       Coding: 0106029A00FAC00580B0003200000000
       Component: GTO BF  H01 0080
       Serial number: 00000000000000792288
       Component: J245EE20SKB13  H05 0220
       Subsystem 4 - Part No SW: 4G8 959 252     HW: 4G8 959 252
       Component: HSP-SG  H11 0029
       Serial number: WA107531000006098953
       Revision: 00005001    Serial number: 94813025485504
       VCID: 2D12C531748B592C83-8078
       Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
       Component: TSG BF        H09 0305
       VCID: 55E24DD13C9B31EC1B-8000
       Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
       Component: EPB-4         H01 0005
       Revision: --------    Serial number: 30000000166863
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3A38FE6DBDC5FE9416-806E
       Component: Radio U SIRIU H60 0133
       Revision: AB001007    Serial number: 156B70E7964578
       Coding: 020007010000000001
       VCID: 24042015274198645C-8070
       Part No SW: 8R1 035 746 E    HW: 8R1 035 746 D
       Component: H-BNT-NA      H41 0756
       Revision: --------    Serial number: 204BU0E7639331
       Coding: 150200020306A1EF55028B5E00000403140000000000000000
       Subsystem 1 - Part No: 8R0 060 884 BL
       Component: NAR 2014  0902
       Component: DU7 High  H42 0104
       Serial number: A130A 0E2936698
       Serial number: 00000001748213
       Component: CD-Database  5571
       Revision: --H09---    Serial number: 525PA8-J3Y92HB
       Coding: 1020008
       VCID: 383CE4654BC9EC84E0-806C
    End----------(Elapsed Time: 01:51, VBatt start/end: 12.3V/12.2V)-----------
    Don't you think you should investigate the starter for connectivity and main bus feed for terminal 30, In addition the terminal 31 chassis ground at unit and solenoid function?
    If all is well don't you think you should change the starter?
    NostraJackASS Has Questioned?
    JPPSG lately?
    http://forums.ross-tech.com/showthre...(final-version)
    Thank you for posting the auto-scan OP
    Mar 2017
    i have power to the jump start. is there a way to test the starter without having to remove the front end of the car and the alternator?
    Don't you think you could grab the solenoid connection further up and jump out using WD or at the starter relay directly and manually bridge to initiate the starter to crank & if it doesn't click or crank change the starter?
    Sometimes things are hard to test but they are needed to be observed right, what if rodent damage?
    Mar 2017
    thank you, for getting back to me. i will try that but do you happen to have a diagram of the wires that go to the solenoid? or the color of the wires i should be looking for?
    Don't you think you will feel much better buying the WD from ERWIN and printing to PDF?
    Mar 2017
    i don't mind you providing as well?
  9. #8
    Don't you think it is morally wrong to request or solicit someone to provide a WD here and when it is frowned upon in the forum collective rules or to engage in acts of copyright infringement & that could hurt others?
    Do you hurt people? Good, glad to hear you don't, now go to ERWIN and get it, "right"?
  10. Likes PetrolDave liked this post
  11. #9
    Mar 2017
    first of all i do not know whats a WD...dude what are you talking about? im just looking for some help here. not asking you to copy right anything.
  12. #10
    WD = Wire Diagram and you can hover your cursor over acronyms such as this to see a brief definition.
    Repair manuals or RTFB can be found here for a subscription in link below.
