Results 1 to 4 of 4
Thread: AUDI SPORTSBACK 8P A3 GEARBOX ISSUES
    Jun 2016
    Guyana
    Hey guys whats going on, i have an Audi A3 Gearbox issue and now getting sometime to fix it attached is an autoscan of the vehicle, Issue is no reverse ,and it skips a few gears while driving, so i decided to take it down, and to find the slide bushings on the forks are in pieces fell out from the mechatronic side of the gearbox , now i may have to change the selector forks but i cannot seem to get the Gearbox section apart :
    its the DQ200 0AM DSG 7 gearbox
    so far what ive done :
    UNINSTALLED THE MECHATRONIC UNIT, PULLED THE DRY CLUTCH OUT NOW IM STUCK TRYING TO TAKE THE GEARBOX APART, ANY HELP TO GET IT LOOSE, ALREADY LOOSE THE BOLTS ,TOOK THE C CLIP OUT FROM THE REAR AND ALSO AXLE HUBS, NOW IT JUST SEEMS TO PULL APART BUT ITS NOT!
    THANKS
    Wednesday,30,August,2017,15:10:40:17560
    VCDS Version: 17.8.0.1 (x64)
    VIN: WAUZZZ8P09A123787   License Plate:
    Chassis Type: 8P-AU35 (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 55 62 72
    VIN: WAUZZZ8P09A123787   Mileage: 125780km-78156miles
    Address 01: Engine (CAX)       Labels: None
       Part No SW: 03C 997 016 A    HW: 03C 906 016 F
       Component: MED17.5.5           8016
       Revision: LCH02---    Serial number: AUX7Z0I2FN602Y
       Coding: 0000077
       Shop #: WSC 68800 741 72415
       VCID: 2757D69A96A98C7EEB-8072
    Readiness: 1110 0001
       Part No SW: 0AM 300 048 L    HW: 0AM 927 769 D
       Component: GSG DSG AG7     431 2669
       Revision: 00043014    Serial number: CU501311295635
       Shop #: WSC 44780 000 1048576
       VCID: 397300E2701D0A8E8D-806C
    001835 - Gear R
                   P072B - 000 - Not Selectable - Intermittent
                        Reset counter: 40
                        Mileage: 125788 km
                        Date: 2017.07.01
                        Time: 22:20:40
    001851 - Gear 6
                   P073B - 008 - Not Selectable - Intermittent
                        Reset counter: 40
                        Mileage: 125788 km
                        Date: 2017.07.01
                        Time: 22:34:20
       Part No SW: 1K0 907 379 AE    HW: 1K0 907 379 AE
       Component: ESP MK60EC1   H35 0106
       Revision: 00H35001
       Coding: 13424012512400FDC81202EC8A200080B900
       Shop #: WSC 00066 123 12345
       VCID: 75EBCCD2DC85AEEEA9-8020
       Part No SW: 8P0 820 043 BG    HW: 8P0 820 043 BG
       Component: KlimavollautomatH09 0100
       Revision: 000218      Serial number: 8P0820043BG
       VCID: 72E1F7CE6DEBB9D68C-8026
    Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
       Part No SW: 8P0 907 279 N    HW: 8P0 907 279 N
       Component: Bordnetz-SG     H54 2801
       Revision: 00H54000    Serial number: 00000009443634
       Coding: E18E1F81B0141380EF00000A0000000000094E056406040364A000000000
       Shop #: WSC 06314 123 08192
       VCID: 489575263BF7630602-801C
       Subsystem 1 - Part No: 8P2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer AU350   H10 0040
       Coding: 00056595
       Shop #: WSC 06314
       Coding: 00150573
       Shop #: WSC 06314
    01117 - Generator Terminal DF Load Signal
                        Reset counter: 227
                        Mileage: 125398 km
                        Date: 2017.06.17
                        Time: 16:22:00
                        Voltage: 12.80 V
    02389 - Release Signal Transmission; Position P/N
                        Reset counter: 247
                        Mileage: 125770 km
                        Date: 2017.06.25
                        Time: 14:00:00
                        Voltage: 13.15 V
    Address 15: Airbags (J234)       Labels:| 8P0-959-655-10.clb
       Part No SW: 8P0 959 655 J    HW: 8P0 959 655 J
       Component: Airbag AU1042 H06 0090
       Revision: --------    Serial number: 003CA005GDJZ
       Coding: 303142383038303030384A55305238503053
       Shop #: WSC 06314 000 00000
       ROD: EV_Airba10AURB4.rod
       VCID: 49937022E8FD9A0E1D-801C
       Serial number: 3572DRB400008304518F
       Serial number: 3582DRB4000083549A0Q
       Serial number: 35128RB400004ACF5E0Z
       Serial number: 35228RB400004ACF5DC4
       Serial number: 35547RB400004B8513FR
       Serial number: 35647RB400004B850ECZ
    Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
       Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
       Component: J0527           H36 0070
       Coding: 0012012
       VCID: 4183680218CD524EC5-8014
    01304 - Radio
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
       Part No SW: 8P0 920 931 T    HW: 8P0 920 931 T
       Component: KOMBIINSTR. VDO H19 0860
       Revision: D0H19007    Serial number: 2242I007043985
       Coding: 0000928
       VCID: 448D611607DF4766EE-8010
    00003 - Control Module
                        Fault Status: 01100101
                        Mileage: 117771 km
                        Date: 2017.02.23
                        Time: 03:07:00
       Component: J533__Gateway   H16 0210
       Revision:   H16       Serial number: 3400K0930402F1
       Coding: ED817F06100002002103
       VCID: 377706DA46091CFE7B-8062
       Revision: D0H19007    Serial number: AUX7Z0I2FN602Y
       Shop #: WSC 06402 145 00197
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX3.lbl
       Part No SW: 8P0 959 801 J    HW: 8P0 959 801 J
       Component: Tuer-SG         H03 0060
       Coding: 0004788
       VCID: 4281670E1DCB4956DC-8016
    00105 - Signal Central Locking SAVE/LOCK Drivers Side
       Part No: 1K0 909 144 E
       Component: EPS_ZFLS Kl. 232    2501
       Revision: 00H15000
       VCID: 2C5D29B68F4FAF2606-8078
                000 -  -  - MIL ON
                        Fault Status: 11100000
                        Battery Volts: 12.3 V
                            PD
                        Temperature: 32.0C
                        Count: 2
                        Steering Angle: 0.00
                            SteerAng n.Init
       Part No: 8P0 959 433 K
       Component:    KSG          H11 0080
       Coding: 1880200002186D0985054C9F0167
       Shop #: WSC 00046 412 819200
       Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
       Component: AB2 SUBWOOFERBOXH07 0180
       Revision: 00006       Serial number: 92158948887489
       VCID: 36690BDE4103E5F660-8062
       Part No SW: 8P0 959 802 J    HW: 8P0 959 802 J
       Coding: 0004788
       VCID: 438F620A02D1405ED7-8016
       Part No: 8P3 907 357
       Coding: 0000013
       VCID: 7AF1DFEE359BC196C4-802E
    Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
       Part No SW: 8P4 959 801 E    HW: 8P4 959 801 E
       Component: Tuer-SG         H04 0040
       Coding: 0000144
       Shop #: WSC 06314 000 1012544
    Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
       Part No SW: 8P4 959 802 E    HW: 8P4 959 802 E
       Coding: 0000144
    End-------------------------(Elapsed Time: 02:00)--------------------------
    VCDS can't help you with mechanical disassembly. Moving to General VW/Audi Repair.
  3. Likes Golftwincharged liked this post
    Jun 2016
    Guyana
    thanks much!!
    Spray the case and separation point with a light penitent lubricant and heat the case with a heat gun and tap it all around to help the stuff weep in.
    Then hit with brass hammer or use slide hammer, sometimes I spray with freeze spray on the apposed side to shrink and usually falls right out.
    Be sure that all fasteners are removed first as per the RTFB!
    Above Magic!
  6. Likes Golftwincharged liked this post
