Results 1 to 5 of 5
Thread: Skoda Octavia 2006 xenon
    Sep 2015
    Sweden
    Hallo, Any easy way to change the front lights(from driving on the left side to the right side?) From UK to Sweden
    Kind regards/Ola
    "Tourist solution"
    But I don't know where it is in your car. Please post an Auto-Scan so we can see exactly what Headlight Range module your car has.
  3. Likes PetrolDave liked this post
    Dec 2016
    DE
    Oct 2014
    It also depends if you want a temporary solution or a permanent one. I assume you've found some inexpensive UK xenons that you want to fit to your Swedish car?
    Tourist mode is only for temporary use as it doesn't change the cutoff, it just lowers the lights to avoid the glare.
    Some xenons may have a lever inside to flatten the cut off, again, only really suitable for temporary use.
    If you actually want to change the beam patten from a ECE RHD (UK) to ECE LHD (Sweden) for permanent use and to meet local regulations, you would need to replace the projectors inside the headlights. Even then you might have issues as the markings on the headlights will claim they are for ECE RHD use.
  6. Likes Uwe liked this post
    Sep 2015
    Sweden
    Later,i got the flu from hell!
