Security Code
Dr.Kay
Switzerland
C?ID=324274
Hi Guys,
I need to change the coding of a VW Passat ACC radar sensor with part number 3C0907567
Currently in adaptations channel 2 is locked, to change it I need a security code. please help.
P.S.: I tried the recommended security code 21056 (VCDS says it is for channel 1-8, it is accepted but it is for sure not for channel 2).
Regards,
Dr. Kay
This doesn't really belong in Product Support. Is this another ACC retrofit you're doing?
Dr.Kay
Switzerland
C?ID=324274
Hi Uwe,
Sorry, I realized that late.
It is not a retrofit. It already exists on my wife's passat, but the coding is locked in the adaptation channel 2, and cannot be enabled without a security code.
golfi_vend
Tartu, Estonia
C?ID=195131
This module should be covered under label file. Unless redirection isn't working correctly.
Please post auto-scan.
Dr.Kay
Switzerland
C?ID=324274
Redirection works and the module is covered by label but the security code recommended is not for channel 2 (lock/unlock coding). I desperately need that code.
Sorry for the delayed reply. I am down with a nasty flu :S
Dr.Kay
Switzerland
C?ID=324274
Hi all, just to conclude the thread. I figured it out myself after a painful day.
21056 is the security access code, however to set the adaptation channel from 1 (locked) to 0 (unlocked = coding is allowed), one cannot enter 0. It gets rejected exactly as if the security code doesnt cover this adaptation channel. Input 201 will set the channel from 1 to 0, and then life is good again :)
The label just mentioned 0 and 1, perhaps an update of the label would help fellow users.
