Change values on Boost reading
Apexmaster33
C?ID=318501
Is it possible to change the millibar to psi or bar reading in ECU boost section?
Trying to see if my turbo is holding boost and the correct amount.
I have a 08 passat 2.0T 6 speed manual car.
Does anyone know what stock boost levels are on the k04 and what RPM it will start building boost?
Is there way to log a graph or do a test pull see how it is running?
Thank you in advance
Zenerdiode
Newcastle, England
C?ID=24330
VCDS will only display what the module sends it. However, millibar to bar is an easy one - just divide by 1,000! :cool:
Also, hit the [Log] button, to, erm, log the MVB you have displayed...
Somehow, I don't think that VW/Audi would provide a spec for the "correct amount" in PSI. :)
Apexmaster33
C?ID=318501
Does vcds offer a test for turbo ? Or wastwgate
The question is not whether VCDS offers such tests, but whether the ECU offers such tests that VCDS can initiate. :)
