Results 1 to 7 of 7
Thread: Random no power, like cats plugged and white smoke. 2007 2.0 a4 fwd.
    Feb 2016
    Cornish ME, USA
     Thursday,22,February,2018,21:27:14:18282
    VCDS Version: 18.2.0.3
    VIN: WAUAF78E37A031868   License Plate: TOMS A4
    Mileage: 170720km-106080mi   Repair Order: at home
              67 69 75 76 77
    VIN: WAUAF78E37A031868   Mileage: 170720km-106080miles
       Part No SW: 8E0 910 115 P    HW: 8E0 907 115 D
       Revision: 5EH13---    Serial number:
       Coding: 0104010A02070120
       Shop #: WSC 05140 444 85840
       VCID: 2E536645B9502F34BA-807A
                        Load: 0.0 %
                        Temperature: -40.0░C
                        Absolute Pres.: 0.0 mbar
                        Voltage: 0.000 V
    000665 - Boost Pressure Regulation
                   P0299 - 002 - Control Range Not Reached
                        Fault Status: 01100010
                        Mileage: 170722 km
                        RPM: 3057 /min
                        Load: 69.0 %
                        Speed: 82.0 km/h
                        Temperature: 93.0░C
                        Temperature: 12.0░C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 14.097 V
    Address 02: Auto Trans        Labels: 01J-927-156.lbl
       Part No SW: 8E3 910 155 M    HW: 01J 927 156 HT
       Component: V30 01J 2.0TFSI USA 0020
       Revision: 00000012    Serial number: 00000002098261
       Coding: 0000001
       Shop #: WSC 06335 000 00000
       VCID: 326B7235AD680BD4DE-8066
       Part No SW: 8E0 910 517 H    HW: 8E0 614 517 BF
       Component: ESP8 FRONT      H06 0140
       Coding: 0004525
       VCID: 2C576C4D8F4C5D2494-8078
                000 -  -  - Intermittent
                        Reset counter: 14
                        Hex Value: 0x0000
                        Hex Value: 0x4202
                        Hex Value: 0x0024
                        Hex Value: 0x01A7
                        Hex Value: 0x0000
       Part No: 8E0 820 043 BL
       Component:   A4 Klimaautomat   2833
       Coding: 00000
       VCID: 6CD7AC4D1CCC9D24D4-5106
       Part No: 8E0 907 279 N
       Component: int. Lastmodul  USA 0907
       Coding: 00003
       Shop #: WSC 06335
       VCID: 3D7151093736C4AC33-4B00
       Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
       Component:    Airbag 9.41  H12 3840
       Revision: 91H12384    Serial number: 0036N0G00SUK
       Coding: 0032607
       VCID: 3C775C0D7F2CCDA404-8068
       Subsystem 1 - Part No: 8E0 910 339 B
       Component: BF-Gewichtsens. 002 0070
       Subsystem 2 - Serial number: 3BHZX
       Subsystem 3 - Serial number: 0001.01.000000200000000000 †63
       Subsystem 4 - Serial number: 000000 †6332DRB403824CA0M †63
       Subsystem 5 - Serial number: 24CA0M †6342DRB4035D10A0G †63
       Subsystem 6 - Serial number: D10A0G †6352ARB4015091ABJ †63
       Subsystem 7 - Serial number: 091ABJ †6362ARB4015BFADFA †63
       Subsystem 8 - Serial number: BFADFA †63729RB401658BEA  †63
       Subsystem 9 - Serial number: 58BEA  †63829RB401658BC2T
       Subsystem 10 - Serial number: 58BC2T
       Part No: 8E0 953 549 Q
       Component: Lenksßulenmodul     0701
       Coding: 02021
       Shop #: WSC 06335
       VCID: 41892DF94BCEA04C57-4B00
       Part No SW: 8E0 920 951 G    HW: 8E0 920 951 G
       Component: KOMBI+WFS 4     H14 0110
       Revision: 0110        Serial number: 00000000000000
       Coding: 0022201
       VCID: 2E536645BA502F34BA-5140
       Coding: 0022201
       VCID: 2E536645BA502F34BA-5124
       Part No: 8E0 959 433 CG
       Component: Komfortgerßt T7B    4135
       Coding: 11820
       Shop #: WSC 06335
       VCID: 78FF801D5894218420-4B00
       Component: T§rsteuer.FS BRM 0706
       Subsystem 2 - Part No: 8E1959802G
       Component: T§rsteuer.BF BRM 0706
       Component: T§rsteuer.HL BRM 0606
       Component: T§rsteuer.HR BRM 0606
    00962 - Alarm via. Tilt Sensor
                35-00 -  -
                35-00 -  -
    00914 - Window Regulator Switch; Rear Left; Driver (E53)
    00912 - Window Regulator Switch; Front Left (E40)
    01559 - Drivers Door
                57-10 - Electric Circuit Failure - Intermittent
    Address 56: Radio        Labels: 8J0-035-1xx-56.clb
       Part No SW: 8E0 035 195 AC    HW: 8E0 035 195 AC
       Component: R Symphony2+    H07 0250
       Revision: 00H07000    Serial number: AUZ1Z4G5809358
       Coding: 0000000
       VCID: 68DFD05D5834B104B0-5140
                000 -  -
                        Time Indication: 15
    End-------------------------(Elapsed Time: 06:32)--------------------------
    Feb 2016
    Cornish ME, USA
    drained aprox 1 quart of oil from charge air system. theres an electrical component on turbo. variable vane? i observed oil leaking from one of the pins when i unplugged to look. i also removed valve cover to look for cracks. it doesnt appear to have any
    I would go after the power problem to the ECU first.
    Yup terminal relay or bad wire, but I don't think that is the power cut.
    White smoke huh?
    Sounds like time for a turbo and maybe diverter or so much fuel is in oil by contamination or being over filled it is being remediated into intake of turbo charger and as you aforementioned or by bad bypass possibly PSI positive in the PCV being faulty for check when in boost is entering crankcase as leak and could be the negative deviation DTC.
    Verify compression with leak down and plugs + intake path for oil.
    Time to tear down and measure + clean stuff up to verify.
    JPPSG
    http://forums.ross-tech.com/showthre...uot-JPPSG-quot
    You may find this thread helpful too.
    http://forums.ross-tech.com/showthre...you!-Air-leaks!
    Feb 2016
    Cornish ME, USA
    thank you both for insight. battery voltage drops low under loads at idle but i dont believe its the cause of power loss either cause it climbs off idle! i had to get towed home it was so bad.
  6. #6
    Feb 2016
    Cornish ME, USA
    oil entry appears to be from valve cover. another shop just did gasket my guess is they were looking for cracks too. there is randomly a slight puff back out the intake when idling cold. sounds like valve timings off but marks look on as far as i can see. i know the charging system is a lil weak, perhaps i should start there.
    the owner may have been overfilling with oil, for some reason he thought pan was cracked. ive had for almost a week and level is right where it should be. and no large leaks on floor
  7. #7
    Feb 2016
    Cornish ME, USA
    maybe combustion in crankcase as you talked about in your other thread! dont know why i didnt think of that... i have a vac gauge but none for boost... boosted engines ive worked on far less...time to get a gauge...with fresh oil maybe popping back out of airbox will go away. worth a shot...thanks Jack
  8. Likes Jack@European_Parts liked this post
