Results 21 to 30 of 40
Thread: Audi A3 2.0T FSI BPY Crank with no start.
  1. #21
    Mar 2014
    Wilkes-Barre, PA
    Does the inside of that adjuster look normal? 3rd pic.
    Sure looks bad in the pic. Looks like teeth are gone?
    Good Luck
  2. Likes Jack@European_Parts liked this post
  3. #22
    Jul 2014
    That mark in first picture is off........
    The white mark was from a previous owner, i have it timed to the engraving on the gear from the factory and the OT Arrow on the block.
    None the less that much of a difference wouldn't cause the engine to not start, would it? this is how I've had it timed since I did the job about 20K miles ago.
    Quote Originally Posted by vwtech View Post
    Good Luck
    As far as the cam adjuster, it looked okay, the grooves are from the plastic rings off the cam cover. Apparently that's normal for the rings to cause grooves like that from what ive read.
  4. #23
    Yeah Okay but did you check the key-way that is on cam to cam gear and did you check the key-way on adjuster behind the barrel to cam that shears?
    Did you check for over PSI regulation from the oil pump?
    Above Magic!
  5. #24
    Jul 2014
    I can check those tomorrow i have to go deeper and remove the cam cover to see that,
    as far as the PSI regulation, how would i check that?
  6. #25
    A gauge or by draining all oil and filter and starting car with no oil "briefly"!
    If it starts with no oil in it than you know it's a hydro-lock and then know what to fix.
    Did you put a factory G28 in?
    Above Magic!
  7. #26
    Jul 2014
    Okay ill give that one a shot tomorrow, drain the oil and ill try that method.
    I haven't but ill probably just put my factory g28 back in since it tested properly for resistance and i can return the autozone AFAIK.
  8. Likes Jack@European_Parts liked this post
  9. #27
    Jul 2014
    Well, I got a chance to take that top cam cover off, the key ways that you said to look for are all good.
    Just got rained on so i couldn't do anything more, plus i need to buy that cam alignment tool lol
  10. #28
    Please xxplain how you verified the key-ways by mere VC removal and do you have pictures please?
    Above Magic!
  11. Likes vwtech liked this post
  12. #29
    Jul 2014
    Not from valve cover removal, but by the actual camshaft metal cover.
    Here's a picture, also I can rotate the oil adjuster just barely about 1mm without the Cam's turning, I assume this is normal I made a video nonetheless.
    Also as you can see my timing chain tensioner popped up and the Cam's are completely out of time now so I'll have to reset the Cam's before I can even try to crank it again.
    https://youtu.be/hrip0DuAt7g
  13. #30
    What about the belt side key-way?
    Above Magic!
