Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: Audi A3 2.0T FSI BPY Crank with no start.
    Jul 2014
    Please see thread on vwvortex for full story.: http://forums.vwvortex.com/showthrea...#post110357482
    TL;DR of the thread, My 2007 audi a3 2.0t FSI is cranking but wont start, Only code i get is a P0321 after cranking for a while and it not starting. this code doesn't pop up right away or even after cranking a couple times.
    I've replaced the crank position sensor (Tested Resistance @ 850 ~ohms)
    Tested for timing(GOOD)
    compression (GOOD)
    spark (GOOD, Tested by pulled a plug and coil and grounded plug to block and saw spark)
    Fuel pressure in rail (Measured with VAGCOM) is good, however after cranking for extended periods rail shows 115ish BAR (Is this normal?)
    I just replaced the HPFP, and also suffered bad camfollower failure around 300 miles before all this happened.
    ALL Fuses were checked and non are blown,
    this is how its been crnaking, almost sounds like it wants to fire but cant.
    https://www.youtube.com/watch?v=eKaq...ature=youtu.be
    Saturday,24,February,2018,18:10:51:34933
    VCDS Version: 17.8.1.0 (x64)
    VIN: WAUHF78P87A091838   License Plate: BEFORE
    Mileage: 226700km-140864mi   Repair Order:
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 0F 15 16 17 19 25 37 42 44 46 52 55 56 62 72 77
    VIN: WAUHF78P87A091838   Mileage: 226700km-140864miles
       Part No SW: 8P0 907 115 P    HW: 8P0 907 115 B
       Component: 2.0l R4/4V TFSI     0010
       Revision: 5BH16---    Serial number: AUX7Z0F9FN20E1
       Coding: 0103010A18070160
       Shop #: WSC 03134 067 57207
       VCID: 3FA3B5F56EF5C9BEA8-806A
    Readiness: 0110 0101
       Revision: 00H11001
       Coding: 0021122
       Shop #: WSC 06314 000 00000
       VCID: 73CB29C5123D5DDE9C-8026
       Part No SW: 8P0 820 043 AD    HW: 8P0 820 043 AD
       Component: KlimavollautomatH19 0360
       Revision: 112073      Serial number: 8P0820043AD
       VCID: 6EFD38B1791F703673-803A
                        Reset counter: 247
                        Mileage: 226700 km
                        Date: 2018.02.18
                        Time: 00:05:23
    Address 09: Cent. Elect.        Labels:. 8P0-907-279-23-H.lbl
       Part No SW: 8P0 907 279 F    HW: 8P0 907 279 F
       Component: Bordnetz-SG     H43 1201
       Revision: 00H43000    Serial number: 00000006283303
       Coding: F38C5F81C014100000181800180000000028EE175A1500
       Shop #: WSC 06314 123 08192
       VCID: 40A1B609130BB646D1-8014
       Subsystem 1 - Part No: 8P1 955 119 E  Labels: 1KX-955-119.CLB
       Component: Wischer AU350   H01 0130
       Coding: 00062736
       Shop #: WSC 06314
       Coding: 00150573
       Shop #: WSC 06314
       Part No SW: 8E0 035 593 F    HW: 8E0 035 593 F
       Component: SDAR SIRIUS     H03 0120
       Revision: 00000000    Serial number: AUZ4Z7F1042294
       VCID: 2C79F2B98F8342261D-8078
                        Reset counter: 90
                        Mileage: 214741 km
                        Date: 2017.05.22
                        Time: 16:18:07
    Address 15: Airbags        Labels: 8P0-959-655-94.lbl
       Part No SW: 8P0 959 655 A    HW: 8P0 959 655 A
       Component:    Airbag 9.41  H12 3890
       Revision: 91H12389    Serial number: 0035W0G02WX.
       Coding: 0032605
       Subsystem 1 - Part No: 8P0 910 339
       Component: BF-Gewichtsens. 001 0020
       Subsystem 2 - Serial number: 3C78M
       Subsystem 3 - Serial number: 0001.01.000000100000000000† 63
       Subsystem 4 - Serial number: 000000† 6332DRB404088C31J† 63
       Subsystem 5 - Serial number: 88C31J† 6342DRB4040908A0F† 63
       Subsystem 6 - Serial number: 908A0F† 63528RB401BAA6EA%† 63
       Subsystem 7 - Serial number: AA6EA%† 63628RB401B6DCAF6† 63
       Subsystem 8 - Serial number: 6DCAF6† 63729RB401B83BDB+† 63
       Subsystem 9 - Serial number: 83BDB+† 63829RB4007E79E0Z
       Subsystem 10 - Serial number: E79E0Z
    Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
       Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
       Component: J0527           H36 0070
       Coding: 0004042
       VCID: 41A7B30D1801BF4EDE-8014
       Component: E0221           H06 0030
       Part No SW: 8P0 920 981 H    HW: 8P0 920 981 H
       Component: KOMBIINSTR. VDO H19 0570
       Revision: D0H19003    Serial number: 2249F003003839
       Coding: 0036203
       Shop #: WSC 12345 067 57207
       VCID: 3D5FCFFD64F9DBAEBA-8068
       Component: J533  Gateway   H07 0062
       Revision:   H07 01    Serial number: 030608F2001252
       Coding: E9817F064007022102
       Shop #: WSC 06314 321 54231
       VCID: 354FD7DD5CC903EE72-8060
       Revision: D0H19003    Serial number: AUX7Z0F9FN20E1
    Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
       Part No SW: 8P0 035 192 G    HW: 8P0 035 192 G
       Component: RNS-E US        H72 0260
       Revision:      03S    Serial number: AUZBZ7F2372180
       Coding: 0209677
       VCID: 334BE9C552BD1DDE5C-8066
                        Fault Frequency: 7
                        Reset counter: 32
                        Mileage: 226699 km
                        Date: 2018.02.12
                        Time: 19:57:25
                        Voltage: 10.60 V
                        Mileage: 226700 km
                        Count: 1802
                        Clock: 05:09
    00856 - Radio Antenna
                        Fault Status: 00101011
                        Reset counter: 32
                        Mileage: 226699 km
                        Date: 2018.02.11
                        Time: 12:31:12
                        Mileage: 226690 km
                        Count: 1102
                        Clock: 12:39
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN2.lbl
       Part No: 8P0 959 801 H
       Component: Tuer-SG         020 0090
       Coding: 0001209
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.079 H07 1806
       VCID: 3449EAD957B31AE645-8060
                        Mileage: 226680 km
                        Temperature: 13.0C
                        Voltage: 11.50 V
                        Voltage: 11.30 V
       Part No: 8P0 959 433 D
       Component: 02 KSG          H04 0050
       Coding: 9AC003002D2C850FC88F047300
       Shop #: WSC 06314 123 12345
    01134 - Alarm Horn (H12)
    00956 - Key 2
    Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN2.lbl
       Part No: 8P0 959 802 H
       Coding: 0001209
       VCID: 29770BAD8071570EE6-807C
       Subsystem 1 - Part No: 8E0 941 329 A
       Component: AFS-Modul links H03 0020
       Subsystem 2 - Part No: 8E0 941 329 A
       Component: AFS-Modul rechtsH03 0020
                        Reset counter: 40
                        Mileage: 226696 km
                        Date: 2018.01.27
                        Time: 14:27:15
                        Reset counter: 32
                        Mileage: 226696 km
                        Date: 2018.01.28
                        Time: 13:00:41
    Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
       Coding: 0209677
                        Fault Frequency: 7
                        Reset counter: 32
                        Mileage: 226699 km
                        Date: 2018.02.12
                        Time: 19:57:25
                        Voltage: 10.70 V
                        Mileage: 226700 km
                        Count: 1802
                        Clock: 05:10
                        Reset counter: 32
                        Mileage: 226699 km
                        Date: 2018.02.11
                        Time: 12:31:12
                        Mileage: 226690 km
                        Count: 1102
                        Clock: 12:39
    Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
       Part No: 8P4 959 801 D
       Component: Tuer-SG         020 0070
       Coding: 0001176
    01813 - Supply Voltage for Door Controller; Rear Left (J388)
    Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
       Part No: 8P4 959 802 D
       Coding: 0001176
    01814 - Supply Voltage for Door Controller; Rear Right (J389)
       Part No SW: 8P0 862 335 J    HW: 8P0 862 335 J
       Component: DSE_255x BT     H26 0290
       Revision: 00000000    Serial number: 00000005010936
       Coding: 0011477
    00003 - Control Module
                014 - Defective
                        Fault Status: 01101110
                        Mileage: 188176 km
                        Date: 2016.03.08
                        Time: 08:14:50
    End-------------------------(Elapsed Time: 01:21)--------------------------
    Hello OP:
    Welcome to the VCDS forum & are you not glad you came here?
    Have you measured and verified the signal for G28 to the ECU & is correct at ECU and has ECU not taken on water with ingress via inspection?
    Let me know if you find the JPPSG helpful?
    16705/P0321/000801 - Engine Speed Sensor (G28): Implausible Signal Possible Symptoms
    • Engine shuts off
    • Engine doesn't start
    • Speedometer inoperative
    • Glow Plug Indicator Lamp (K29) flashes
    Possible Causes
    • Engine Speed Sensor (G28) loose
    • Engine Speed Sensor (G28) faulty
    Possible Solutions
    • Check Engine Speed Sensor (G28)
    Special Notes
    • The Engine Speed Sensor (G28) is also used as a reference sensor for the crankshaft position and correlates with the Camshaft Position Sensor Bank 1 (G40) and Camshaft Position Sensor Bank 2 (G163).
      • When an engine will not start due to mechanical (spark/fuel/compression/timing) related issues it is not uncommon to set a false G28 fault codes due to extended cranking with a no-start condition.
    • When found in a VW Golf/Jetta (1J/9M) or Audi A3 (8L) with 1.9l TDI-PD (AXR), check TPI 2007067 which explains issues with electro magnetic interference. A modification to the wiring will fix this problem, extensive details can be found in the named TPI. Even though this TPI was originally released for VW Golf/Jetta (1J/9M), a customer of ours came across the same issue on an Audi A3 (8L).
    • When found in a 2004 VW Golf, Jetta, or New Beetle with 1.9l TDI-PD (BEW), check for TSB 2010461 (01-07-45 formerly 97-05-03) or 201463 (01-07-44 formerly 97-05-04) calling for a flash update to the ECU and a secondary ground installation.
    • General note for any engine type: Check the wiring to/from the sensor and engine control module to rule out harness and module damage due to engine oil or coolant from a failed sensor or tensioner. This is an example from a 2012 Tiguan with Coolant in the ECM which resulted in G28 DTCs in addition to intermittent stalling.
    Above Magic!
  3. Likes Uwe liked this post
    Jul 2014
    Hello OP:
    I have not verified the wires to the ECU, I looked at the ECU and externally it looks good but I know that doesn't mean a whole lot.
    I have the wiring diagrams so ill trace that and check everything out for the G28, The only reason I haven't is I was told that if the G28 isnt working then i wouldnt get any spark.
    Nonetheless I will check all that when it stops raining.
    Is your cars ECU FOD tuned?
    Will it run with just carb cleaner sprayed in intake to isolate a fuel condition verse an ignition or timing issue from being out due to setup or oil PSI problem.
    Above Magic!
    Jul 2014
    Yes ECU is tuned Stage 2
    Yes I ran it with starting fluid,sprayed it in short bursts while my friend cranked and it even backfired out of the hole when it died, it didn't run stable but it definitely sputtered a lot more and even idled for about half of a second.
    Timing belt was checked vs the ref marks on the cam gear and crank gear.
    Most stage 2 tunes out there are ignoring the misfire recognition in low rpm range, and which is monitored by g28 in addition they seem to also delete g40 calibrations so it will never report many DTC's.
    There is a good chance chain jumped or adjuster broke key way on back of adjuster of exhaust cam.
    Take apart to inspect.
    Best to start with stock controller with some type of consistent stack.
    Above Magic!
    Jul 2014
    That's good info to know moving forward, I did have the cam chain cover off and valve cover and nothing looked incorrect, chain had tension, wasn't broken.
    I do see the camshaft rotating if I turn the motor. Wish I had another ecm to test with :/
  9. #8
    Stoke on Trent, England
    Jack
    Possible Symptoms
    Engine shuts off
    http://wiki.ross-tech.com/wiki/index...6/P0322/000802
    Tachometer / Rev Counter inoperative
    You say Speedometer inoperative, is that something you've found?
    New User Keith
  10. #9
    Not tensioner OP.
    Adjuster barrel on reverse side where cam bolts on, it shears the pin and still turns just is out of time.
    Above Magic!
  11. #10
    Mar 2014
    Wilkes-Barre, PA
    Jack I sent the guy here because I was lost as to why no codes?
    He had a G68 code went it stalled but no cam code. Don't know if the G68 was bad or just from over cranking with no start?
    He has RPM on VCDS and the tack moves and has spark. Only bad thing I see is he replaced G68 with one from Auto Zone which is a NO NO! But it seems to be working.
    What has me is he said it back fires at times and compression was only 150. But was using an AZ tool loaner tester for compression.
    I said timing but why no cam sensor & RPM sensor correlation code?
    Good Luck
