Results 1 to 8 of 8
Thread: '16 Bentley CGT W12 Suspension/Infotainment failure
    Sep 2017
    Trinidad and Tobago
    Hey guys,
    Currently dealing with an out of warranty 2016 Bentley CGT doing 1500mi that has dropped down on its front wheels after throwing a "stop, car too low" message on the dash. The car has never been modified or serviced in any way aside from oil changes.
    Also having an issue with the infotainment system constantly rebooting. I can hear the disc drive clicking and the fan on the back spinning, but it never makes it beyond the Bentley logo.
    All fuses in the rear LHS compartment are intact. I have tried pulling the fuses for navigation and the infotainment to perform a "reset," but nothing worked. Tire pressure issues were sorted as well.
    I've attached a log from when the issues started. The only thing that has changed since then was a new auxiliary battery -- the old battery would not hold beyond 12.0v despite charging.
    Sunday,24,December,2017,23:04:58:04491
    VIN: SCBFF63W6GC053891   License Plate:
    Mileage: 2200km-1367mi   Repair Order:
    Chassis Type: 3W-BY62 (3W0)
    Scan: 01 02 03 05 06 07 08 09 11 31 13 15 16 17 19 23 2E 34 36 37
              38 46 47 53 56 65 68 6C 6D 71 76 77
    VIN: SCBFF63W6GC053891   Mileage: 2200km-1367miles
    47-Sound System -- Status: Malfunction 1010
    68-Wiper Electr. -- Status: OK 0000
    71-Battery Charger -- Status: Malfunction 0010
    Address 01: Engine (J623-DBDE)       Labels: None
       Part No SW: 07C 906 023 AT    HW: 07C 907 309
       Component: ME17.1.6      H17 1472
       Revision: MHH17---    Serial number: VWX3Z0P3010795
       Coding: 052A0032436F00010006
       Shop #: WSC 00083 790 00198
       ASAM Dataset: EV_ECM60TMP11107C906023AT 001003
       ROD: EV_ECM60TMP11107C906023AT_001.rod
       VCID: 73B0D7A74B34302F568-8026
    16672 - Please Check DTC Memory of ECU Number 2
              P1923 00 [032] - -
    Address 02: Auto Trans (J217)       Labels:| 0CM-325-025.clb
       Part No SW: 3W3 927 158 E    HW: 0CU 927 760 A
       Component: OBL 60 MPIRdW H19 0003
       Revision: --H19---    Serial number: VWX3Z0P3010795
       Coding: 000001
       Shop #: WSC 00083 790 00188
       ASAM Dataset: EV_TCMAL450211 002010
       ROD: EV_TCMAL450211.rod
       VCID: 42DE4263440EC9A70DE-8016
    12544 - Power Supply Terminal 15
              P3325 00 [040] - Implausible
                        Fault Frequency: 10
                        Mileage: 1956 km
                        Date: 2017.02.27
                        Time: 20:04:31
                        Voltage terminal 30: 11.974 V
                        Transmission input speed: 0.00 /min
                        Transmission output speed: 0.00 /min
                        Engine torque: -88 Nm
                        Transmission fluid temperature: 39 C
                        Accelerator position: 15 %
                        M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
                        M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
                        M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Coasting
                        Engine speed: 0 /min
                        Transfer speed by dash panel insert: 0.00 km/h
                        Transfer speed by dash panel insert: valid
    Address 03: ABS Brakes        Labels: None
       VCID: 55F4893FAD404E1F58C-8000
    No Faults Found
       Part No SW: 3D0 909 137 F    HW: 3D0 909 137 F
       Component: C2 Kessy            6850
       Revision: 00H24072    Serial number: VWX3Z0P3010795
       Coding: 0422125
       Shop #: WSC 00083 790 00192
       VCID: 2A0E0AC3D0BE31E725E-807E
    00087 - Terminal 30 for Starting Relevant Consumers
                        Fault Frequency: 0
                        Reset counter: 122
                        Date: 2017.12.26
                        Time: 18:35:06
                        Fault Frequency: 0
                        Reset counter: 122
                        Date: 2017.12.26
                        Time: 18:35:06
       Part No SW: 4W0 959 760 A    HW: 4W0 959 760
       Component: MEM-BFS       H04 0700
       Revision: AA000000    Serial number: 00000162736721
       Coding: D03A1B2485A70000090001010101010000212727000000
       Shop #: WSC 00083 790 00236
       VCID: 40DA486B4AC2DBB71BA-8014
    Address 07: Control Head        Labels: 3D0-907-048.clb
       Part No SW: 3D0 907 048     HW: 3D0 907 048
       Component: J127 KBT vorn       0100
       Revision: ABH27001    Serial number: VWZ6Z7R0210016
       VCID: 6390A7E7F714A0AF268-8036
       Part No: 3W0 907 040 L
       Component: Climatronic BY624   3019
       Coding: 0000101
       VCID: 3A2E3A83201E816755E-806E
    01341 - Control Module in Instrument Panel On Comfort CAN (J285)
    Address 09: Cent. Elect.        Labels:. 3D0-937-049-V2.clb
       Part No SW: 3D0 937 049 Q    HW: 3D0 937 049 Q
       Component: J519                7700
       Revision: -4007---    Serial number: --------------
       Coding: 40820000AB2A11802508030000000000
       VCID: 382A208B1E129377A3A-806C
    Address 11: Engine II (J624)       Labels: None
       ASAM Dataset: EV_ECM60TMP21107C906023AT 001003
       ROD: EV_ECM60TMP07C906023AT_A01.rod
    Address 13: Auto Dist. Reg        Labels: None
       Part No SW: 4W0 907 567 B    HW: 4W0 907 567 B
       Component: AC201  RDW BY684   00951
       Revision: 00041000    Serial number: 00000000664060
       Coding: 0010684
       Shop #: WSC 00083 790 00203
       VCID: 3FD84B973B3CA44F620-806A
       Part No SW: 3W3 959 655 A    HW: 3W3 959 655 A
       Component: VW10Airbag20I H01 0004
       Revision: --------    Serial number: 003FW000D63T
       Coding: 000000000000000000000000000000003049
       ASAM Dataset: EV_AirbaVW10BPABY62X 001002
       ROD: EV_AirbaVW10BPABY62X.rod
       VCID: 45D4597F5520FE9F28C-8010
       Serial number: 3572DRB40000F824EB2%
       Serial number: 3582DRB40000F840E1C+
       Serial number: 35128RB4000074337CEP
       Serial number: 35228RB4000074329C8L
       Serial number: 35547RB400007483A68Q
       Serial number: 35647RB400007483A15J
    1110016 - Databus
                        Fault Frequency: 9
                        Reset counter: 178
                        Mileage: 1956 km
                        Date: 2017.02.27
                        Time: 20:04:34
    1112576 - Databus
                        Reset counter: 178
                        Mileage: 1956 km
                        Date: 2017.02.27
                        Time: 20:04:34
       Part No: 7L6 953 549 K
       Component: J527                3601
       Coding: 0000042
       Shop #: WSC 00083 790 00244
       VCID: 47C8537763ECEC8FDA0-8012
    Address 17: Instruments        Labels: 3Wx-920-xxx-17.lbl
       Part No SW: 3W0 920 851 S    HW: 3W0 920 851 S
       Component: J285 KOMBI-INST.    6666
       Revision: KPH10V06
       Coding: 0038414
       Shop #: WSC 38812 001 1048576
       VCID: 46D65E7364A6F587216-8012
                        Reset counter: 179
                        Mileage: 2166 km
                        Date: 2017.12.15
                        Time: 23:44:31
    Address 19: CAN Gateway        Labels: None
       Part No SW: 3W0 909 901     HW: 3W0 920 851 S
       Component: J533  GW-K-CAN TP20 6666
       Revision: KPH10V06
       Coding: DFFBFFAEEB154701
       VCID: 76B6EEB354C62507716-8022
                        Reset counter: 167
                        Mileage: 2059 km
                        Date: 2017.07.20
                        Time: 01:11:08
    Address 23: Brake Booster        Labels: None
       Part No: 3W0 907 563 B
       Component: BREMSBOOSTER    007 0430
       Revision: 00007000    Serial number: 00000000035181
       Revision: A1001003    Serial number: 7666227281
       Coding: 030100
       VCID: 2B000FC7D30428EFDE8-807E
    Address 34: Level Control        Labels: None
       Part No: 3W0 907 553 J
       Component: LUFTFDR.-CDC- 3C3V0 7509
       Coding: 0005531
       VCID: 41DC4D6F4DC8D2BF144-8014
    01598 - Drive Battery Voltage
    01583 - Leak in System Detected
                000 -  -  - Intermittent
    01400 - Suspension Level Control
       Component: MEM-FS        H04 0700
       Revision: AA000000    Serial number: 00000162720782
       Shop #: WSC 00083 790 00242
    03948 - Sensor for Seat Belt Bringer
                        Fault Status: 00101100
                        Reset counter: 178
                        Mileage: 2166 km
                        Date: 2017.12.08
                        Time: 12:48:42
                        Reset counter: 179
                        Mileage: 2182 km
                        Date: 2017.12.26
                        Time: 18:34:30
    Address 37: Navigation (J0506)       Labels: None
       Part No SW: 3W0 035 017 T    HW: 3W0 035 017 T
       Component: RNS-MID       H27 0290
       Revision: AB001001    Serial number: VWZ6Z7R0210016
       Coding: 06070002000000010000
       VCID: 3E2636933076AD47696-806A
       Subsystem 1 - Part No: 3W0 919 859 CB
       Component: EU West V5  8195
                        Reset counter: 179
                        Mileage: 2166 km
                        Date: 2017.12.16
                        Time: 23:31:16
    Address 38: Roof Electronics        Labels: None
       Part No: 3W0 907 135 H
       Component: Dachmodul           0910
       Coding: 0022941
       VCID: 3B203F872F24B86F4E8-806E
    00926 - Terminal 30
    Address 46: Central Conv.
    Address 47: Sound System        Labels: None
       Part No SW: 4W0 035 466 A    HW: 4W0 035 466 A
       Component:   PREMIUM AMPLIFIER 0043
       Revision: 00001000    Serial number: 01448336
       VCID: 343214BB023A77178F2-8060
    00459 - Control Module for Display and Input; Front (J523)
                        Fault Status: 00110100
                        Reset counter: 0
                        Raw, Form. N/A: 000 000 000
    Address 53: Parking Brake (J540)       Labels: None
       Part No SW: 4W0 907 801     HW: 4W0 907 801
       Component: EPB-4         H01 0002
       Revision: --------    Serial number: 00000000013387
       ASAM Dataset: EV_BY62XParkiBrake 001008
       ROD: EV_BY62XParkiBrake.rod
       VCID: 74B2D4BB4E3A37174F2-8020
    Address 56: Radio (J0506)       Labels: None
                        Reset counter: 179
                        Mileage: 2166 km
                        Date: 2017.12.16
                        Time: 23:31:16
    Address 65: Tire Pressure        Labels: None
       Part No SW: 3W7 907 273 E    HW: 3W7 907 273 E
       Component: J0502 RDK           0008
       Revision:   004008    Serial number: 00000700002833
       Coding: 30007C63B8FD63FD0063B8FD63FD0063B8FD4B6E4B6E4B6E4B6E4B6E
       Shop #: WSC 00083 790 00211
       VCID: 42DE426348CEC9A70DE-8016
    02214 - Tire Pressure Warning
                        Reset counter: 180
                        (no units): 84.0
    04137 - TPMS Warning: Rear Axle Pressure Difference
                        Fault Frequency: 0
                        Mileage: 2196 km
                        Date: 2017.12.26
                        Time: 21:08:56
                        (no units): 121.0
    Address 68: Wiper Electr.        Labels: 3Wx-955-023.clb
       Part No: 3W2 955 023 L
       Component: Wischermodul       0401
       Shop #: WSC 00000 725 65552
       VCID: 40DA486B46C2DBB71BA-8014
       Part No SW: 3W3 907 441 C    HW: 3W3 907 441 C
       Revision: 00H13000    Serial number: 525 PA8JA70206
       Coding: 2022002
       VCID: 392C258F25588A7F5C4-806C
    Address 6D: Trunk Elect. (----)       Labels:* None
       Part No SW: 3W3 959 108     HW: 3W3 959 108
       Component: HDSG-Modul    H02 0803
       Revision: 00000000    Serial number: 202500152
       Coding: 184006C020
       ASAM Dataset: EV_HDSGBY6245 002001
       ROD: EV_HDSGBY6245_002.rod
       VCID: 7DA4F19F7D70765F30C-8028
    0017 - Hall Sensors in Motor 1 for Rear Lid
              B1211 02 [008] - Signal Failure
                        Reset counter: 172
                        Mileage: 2117 km
                        Date: 2017.09.09
                        Time: 21:11:49
                        11.95 V
    0018 - Hall Sensors in Motor 1 for Rear Lid
                        Reset counter: 172
                        Mileage: 2117 km
                        Date: 2017.09.09
                        Time: 21:11:49
                        11.95 V
    Address 71: Battery Charger (J367)       Labels:* None
       Part No SW: 3W3 915 181 B    HW: 3W3 915 181 B
       Component: EMM Batt Man  H05 0570
       Coding: 5E0100
       ASAM Dataset: EV_BatteChargVaria1 002019
       ROD: EV_BatteChargVaria1_002.rod
       VCID: 382A208B12D29377A3A-806C
       Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
       Component: J367-BDM  H07 0141
       Serial number: 22189D49581041377928
    13705472 - Databus
                        Fault Frequency: 38
                        Reset counter: 180
                        Mileage: 1954 km
                        Date: 2017.02.20
                        Time: 18:59:54
    16777010 - Databus
                        Fault Frequency: 23
                        Reset counter: 180
                        Mileage: 1954 km
                        Date: 2017.02.20
                        Time: 18:59:54
       Part No SW: 3W0 919 283 H    HW: 3W0 919 283 E
       Component: J446  ST Parkhilfe  0115
       Revision: 11H02001    Serial number: 58131519700692
       Coding: 0308076
    Address 77: Telephone (J412)       Labels:* None
       Part No SW: 3D0 035 730 E    HW: 3D0 035 730 E
       Component: Telefon       026 0983
       Revision: --------    Serial number: 35502105276586
       Coding: 020105010100010000000000
       ASAM Dataset: EV_UHVPremi 002709
       ROD: EV_UHVPremi.rod
       VCID: 1E66D6139036CD47496-804A
    13633792 - No Communication with Diagnostic Gateway
              U0146 00 [008] - -
                        Reset counter: 179
                        Mileage: 2182 km
                        Date: 2017.12.26
                        Time: 18:35:06
    0022 - Radio
              U1066 00 [008] - No Communication
                        Reset counter: 179
                        Mileage: 2182 km
                        Date: 2017.12.26
                        Time: 18:35:06
    End----(Elapsed Time: 02:12, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
    A scan of the level control module tonight reported this:
       Coding: 0005531
       VCID: 41DC4D6F4DC8D2BF27B-8014
    00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
    From the research I've done, i can't find any relation between the two issues. Not sure where to start here.
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Quote Originally Posted by zer0xp View Post
    doing 1500mi
    I'm curious how is it out of warranty then? Is it perhaps wrecked/salvaged, or imported to your country by an unusual route?
    Paging through your scan, except for the suspension and infotainment complaints, most fault codes you have could be explained by historical low voltage issues from your dead battery. I would clear fault codes in each module (or use the clear-all function in the Auto-Scan screen) and see what, if anything returns. This may be important to figure out what's going on with your infotainment.
       Coding: 0005531
    The above indicates a legitimate physical air leak somewhere in the system. It'll take some detective work to find out where. If the front end is on the ground, it'll be a problem with one of the two front air shocks, or the lines to them. Historically speaking, I think it's usually been the air shocks. It's not an unknown problem. There are companies that rebuild them professionally with new air bags.
    Jef @ Ross-Tech posted an interesting tool/method for locating air leaks. I have not personally used it but it looks interesting. You could use it to try to localize which of the air shocks is having trouble.
    Silence gives consent.
  3. Likes Uwe liked this post
    Sep 2017
    Trinidad and Tobago
    No, no salvage title on it. There are no local Bentley dealers, so the car was purchased from a UK dealer in 2016. The warranty ended 12 months after delivery
    Sep 2017
    Trinidad and Tobago
    I contacted Bentley UK who put me onto a technician. His first guess was that the battery was dying. The LHS battery has been replaced with a fresh battery to rule out any low voltage limitations. The car has since been plugged into the OEM supplied battery tender.
    No luck in using Jef's tool to check for the leaks within the struts because it seems as if the compressor itself isn't coming on either. Under no situation will the car lift the suspension. I can't manipulate the level control electronics either because I don't have the security codes, and Bentley won't give them to me
    Cincinnati, OH
    These cars do like to eat LHS batteries, but I don't think that's your problem here, and you've gone ahead and ruled it out anyway.
    Hrm, this will be something of an inconvenience:
       Coding: 0005531
    Your level control looks to be a 3W (Bentley) copy of what's in my Phaeton, ten years newer. But hey, if it ain't broke, don't fix it! And, maybe we can help:
    That will probably work. Even if it doesn't, let's see if we can teach VCDS to fish. It already knows how to find label files for slightly older revisions of your controller, and this new one doesn't look a whole lot different. You'll need to do this to make sense of the measured value block values anyway.
    Using a text editor, open the redirect label file "C:\Ross-Tech\VCDS\Labels\3W-34.lbl" and add the new line in RED below:
    ; last modification on 26/Feb/2013
    ; requires VCDS 11.11.5 or newer
    REDIRECT,3D0-907-553-V1.lbl,3W0-907-553
    REDIRECT,3Wx-907-553-34.lbl,3W0-907-553-A
    REDIRECT,3Wx-907-553-34.lbl,3W0-907-553-E
    REDIRECT,3Wx-907-553-34.lbl,3W0-907-553-H
    REDIRECT,3Wx-907-553-34.lbl,3W0-907-553-J
    If that makes VCDS pull up working SA logins and working MVB descriptions for you, drop a note to support@ross-tech.com with a link to this thread and let them know. They can add that redirect to future releases of VCDS so you never have to do this again. Meanwhile, if you haven't already, try clearing fault codes before trying to manipulate the suspension. Some of those faults might effectively disable level control until they're cleared.
    If the compressor still won't come on at all, you may want to try jumping 12V+ to it directly to make sure it works. I trust you have a wiring diagram for this car and can figure out the pinout. Or if you don't want to mess with the compressor, you could look to see if there's any way to pressurize each corner with shop air, just to get some leak testing done. I'm not sure if the connections at the distribution block are easy to undo, but if you were prepared to use Jef's method of leak isolation, you might be prepared to try this as well. Make sure your compressor has a good dryer on it. Moisture in the system is to be avoided, and the onboard compressor has its own mitigation for moisture.
    If you need to research, it will probably be easier to find info on VW Phaetons. Here's a couple links on calibration you might find helpful:
    http://www.ross-tech.com/vag-com/cars/levelcontrol.html
    http://forums.vwvortex.com/showthread.php?2055204
    I can't give you a direct link here in the forum, but I can tell you a Google search for "VW SSP 275" will turn up a lot of educational material you might find helpful.
  7. Likes NEtech, Uwe, D-Dub, zer0xp, Boki Ar liked this post
    Sep 2017
    Trinidad and Tobago
    Thank you for the detailed response. Any additional information really helps. I haven't gotten a chance to check the articles that you've provided, but I just came back from the car after doing what you said, and i can confirm that the SA codes provided are not correct, unfortunately. I'll keep on digging.
    Meanwhile, I'm trying to get in touch with Bentley to gain access to ERWIN, because it keeps rejecting my payment
  9. Likes jyoung8607 liked this post
  10. #7
    Cincinnati, OH
    We Phaeton nerds are always happy for a chance to to talk shop with our Bentley cousins.
    May I ask exactly what happened when you tried the above SA logins? Trying wrong SA logins can put the controller into an enforced lockout period, the timer for which only runs when the ignition is on. During that time it'll refuse even valid logins. But, it should tell you that you're locked out. Hence the question, exactly what error do you see?
    It's still worth making that label redirect update. VCDS has direct label file support for your Bentley controller line, just one or two revisions back, and it's quite likely close enough to support yours as well. You'll want to do this so you have sensible labels for all the Measured Value Block fields, to know what heights and pressures and such are being measured and where. And, if your controller truly used different SA logins, and Ross-Tech has knowledge of them for that older controller, the redirect tweak will make those appear for you like they do for me.
    All that said, it's unclear that you need the SA login right away to troubleshoot. If the level sensors are reading true and correct heights, you don't need to recalibrate. I'm not near my Phaeton right now to check, but this module might support some Output Tests to trigger the compressor and such.
  12. #8
    Sep 2017
    Trinidad and Tobago
    Apparently submitting an edit on my phone automatically deletes the thread lol, anyway.
    So I haven't gotten chance to get back to the car to copy the SA login error that it's presenting, but I did update the label file as you requested. The SA login I used is the one that's given by VCDS after the update, but it refused login and didn't mention anything about lock out.
    Bentley erwin has turned into yet another dead end because they apparently do not support purchases from outside the UK. A few independent shops that I've contacted within North America direct me back to Ross tech as the only people that can help me.
    Really at a loss now, and completely regretting buying this car to begin with.
    I'm starting to think that the issue lies within the unresponsive infotainment unit itself. Would it make sense to start pulling fuses for the separate modules like navigation and tpms to see if I can make it Boot? My thinking is maybe that one of the modules is throwing an error during the power on self test and that it's stuck in a boot loop because of it. Would this make sense or am I overthinking the j523 design?
    Really at a loss here.
