Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: PDC screen on MIB2 - retrofitted mk5 golf.
    Mar 2017
    I'll post up the admaps later today for you guys
    Downtime, i'll try to change the coding when the car is back home today and see if that helps getting the PDC screen showing again
    About the CECM / CCM swap to a BCM.. I've had some thoughts about it and actually already started make a document that tells me the wire swap etc, but I've heard that you also need to change steering rack and some other stuff to before retrofitting the BCM will be a succes?
  2. #12
    May 2017
    I didn't change steering rack, I had the older revision 2 rack and it worked just fine, even with the PLA1.5 module.
    I have the pinout available if you want it. A friend of mine did it and it was originally done for Skoda Octavia 1Z. I had Golf Plus which had a couple pins connected to a bit different location but normal Golf should be exactly the same as Octavia.
    But to make sure, I would suggest buy some time from Erwin and print your model year Golf's CECM + CCM wiring diagrams.
  3. Likes Christiank liked this post
  4. #13
    Mar 2017
    ;SW:1K8-919-472-C   HW:5Q0-919-294-A ---  Park/Steer Assist
    ;Component:PARKHILFE 8K  H03 0480, Coding:0021051001
    ;EV_EPHVA18VW364GP00,001007,EV_EPHVA18VW364GP00_VW32.rod
    ;Saturday,10,March,2018,20:39:23:31035
    ;VCDS Version: Release 18.1.0 (x64)  Data version: 20180122 DS285.1
    ;VCID: 377D792E8E34BFFD44-8062
    IDE00001-Production mode,Deactivating ,3
    IDE01165-Park assist activation tone,On ,1
    IDE01169-Audio reduction request,On ,1
    IDE01170-Visual display for park assist,OPS display ,1
    IDE03782-Switch-off speed for parking assist,15 km/h,1
    MAS01426-Speaker volume for rear park assist,Stage 5 ,1
    MAS01427-Speaker frequency for rear park assist,Stage 4 ,1
    MAS01428-Speaker volume for front park assist,Stage 4 ,1
    MAS01429-Speaker frequency for front park assist,Stage 6 ,1
    ;SW:5C0-035-680-C   HW:5C0-035-680-C ---  Information Electr.
    ;Component:MU-S-ND-ER    H20 0252, Coding:02731201AA0000001111120100880A001F0106D400200100CF
    ;EV_MUStd4CTSAT,001022,EV_MUStd4CTSAT_VW21.rod
    ;Sunday,04,March,2018,10:15:57:31035
    ;VCID: 2149B77630B0D14D9A-8074
    IDE00346-Summertime-automatic,none ,1
    IDE00758-Base volume of telephone,50 %,1
    IDE00769-Number 1 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE00770-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE00845-Wheel circ.,0 mm,2
    IDE02121-CD eject button,Enabled ,1
    IDE02122-Developer mode,not activated ,1
    IDE02330-Number 2 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02331-Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,36 ,49
    IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,36 ,49
    IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,36 ,49
    IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,36 ,49
    IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,36 ,49
    IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,36 ,49
    IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,36 ,49
    IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,36 ,49
    IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,36 ,49
    IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,36 ,49
    IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,36 ,49
    IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,36 ,49
    IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,36 ,49
    IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,36 ,49
    IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,36 ,49
    IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,36 ,49
    IDE02502-Confirmation of installation change,C1 11 ,2
    IDE02607-Wheel pulse,0 ,2
    IDE02699-Number 1 for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02701-Number 1 (roaming) for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE04550-Bluetooth: Sniff mode,OFF ,1
    IDE05111-Fee-based traffic information (TMC),32768 ,2
    IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,OFF ,1
    IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,On ,1
    IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,OFF ,1
    IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,OFF ,1
    IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,OFF ,1
    IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1,OFF ,1
    IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2,OFF ,1
    IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,-128 ,40
    IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,9 ,40
    IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),4 ,40
    IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),7 ,40
    IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),4 ,40
    IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,0 ,40
    IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,0 ,40
    IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128 ,40
    IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,7 ,40
    IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,-128 ,40
    IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,-128 ,40
    IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,10 ,40
    IDE10480-MAS10742-Interface for external media: activation-Connection 2,not activated ,4
    IDE10604-Menu entries for mobile online services,activated ,1
    IDE11122-Country identification: country of sale HMI,EN ,2
    IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21
    IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked ,21
    IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked ,21
    IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked ,21
    IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked ,21
    IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked ,21
    IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked ,21
    IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21
    IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,21
    IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,21
    IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,21
    IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,21
    IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked ,21
    IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked ,21
    IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked ,21
    IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,21
    IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked ,21
    IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,21
    IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,21
    IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked ,21
    IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked ,21
    IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked ,21
    IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked ,21
    IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked ,21
    IDE11502-ENG127643-Locked menu contents-FB_MISC_18,non_blocked ,21
    IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked ,21
    IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked ,21
    IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,21
    IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,21
    IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked ,21
    IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked ,21
    IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked ,21
    IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked ,21
    IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked ,21
    IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked ,21
    IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked ,21
    IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked ,21
    IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,21
    IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked ,21
    IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21
    IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked ,21
    IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
    IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked ,21
    IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked ,21
    IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,21
    IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,21
    IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked ,21
    IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked ,21
    IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked ,21
    IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked ,21
    IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked ,21
    IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,21
    IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,21
    IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked ,21
    IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked ,21
    MAS00950-Audio Parameter,0 ,1
    MAS00951-Bluetooth,On ,1
    MAS03782-WLAN,On ,1
    ENG104140-Bluetooth_Phonebook_Access_Profile,PBAP ,1
    ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not activated ,60
    ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,not activated ,60
    ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer,not activated ,60
    ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off,not activated ,60
    ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,not activated ,60
    ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,not activated ,60
    ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,not activated ,60
    ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,not activated ,60
    ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,not activated ,60
    ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,not activated ,60
    ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,not activated ,60
    ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated ,60
    ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,not activated ,60
    ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not activated ,60
    ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
    ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated ,60
    ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,not activated ,60
    ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,not activated ,60
    ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not activated ,60
    ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,not activated ,60
    ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated ,60
    ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,not activated ,60
    ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,not activated ,60
    ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated ,60
    ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,not activated ,60
    ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,not activated ,60
    ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,not activated ,60
    ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated ,60
    ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,not activated ,60
    ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,not activated ,60
    ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,not activated ,60
    ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,not activated ,60
    ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,not activated ,60
    ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,not activated ,60
    ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,not activated ,60
    ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,not activated ,60
    ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,not activated ,60
    ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,not activated ,60
    ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,not activated ,60
    ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,not activated ,60
    ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,not activated ,60
    ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not activated ,60
    ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,not activated ,60
    ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,not activated ,60
    ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not activated ,60
    ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,not activated ,60
    ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,not activated ,60
    ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,not activated ,60
    ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated ,60
    ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,not activated ,60
    ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,not activated ,60
    ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,not activated ,60
    ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,not activated ,60
    ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated ,60
    ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,not activated ,60
    ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated ,60
    ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,not activated ,60
    ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
    ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,60
    ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,not activated ,60
    ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,not activated ,60
    ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated ,60
    ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not activated ,60
    ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,60
    ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not activated ,60
    ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60
    ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated ,60
    ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,not activated ,60
    ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,not activated ,60
    ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,not activated ,60
    ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated ,60
    ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,60
    ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated ,60
    ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,not activated ,60
    ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,not activated ,60
    ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,not activated ,60
    ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,not activated ,60
    ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated ,60
    ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not activated ,60
    ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,not activated ,60
    ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,not activated ,60
    ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,not activated ,60
    ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,not activated ,60
    ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated ,64
    ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,not activated ,64
    ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated ,64
    ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,not activated ,64
    ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,activated ,64
    ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Comfort data bus ,64
    ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated ,64
    ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,not activated ,64
    ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated ,64
    ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,not activated ,64
    ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated ,64
    ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,not activated ,64
    ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,not activated ,64
    ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated ,64
    ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,not activated ,64
    ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,not activated ,64
    ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,not activated ,64
    ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,not activated ,64
    ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,not activated ,64
    ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,not activated ,64
    ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,not activated ,64
    ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,not activated ,64
    ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,not activated ,64
    ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,not activated ,64
    ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated ,64
    ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,not activated ,64
    ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,not activated ,64
    ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,not activated ,64
    ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not activated ,64
    ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,not activated ,64
    ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,not activated ,64
    ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,not activated ,64
    ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,not activated ,64
    ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,not activated ,64
    ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,not activated ,64
    ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not activated ,64
    ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,not activated ,64
    ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,not activated ,64
    ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38,not activated ,64
    ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,not activated ,64
    ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,not activated ,64
    ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,not activated ,64
    ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated ,64
    ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,not activated ,64
    ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,not activated ,64
    ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,not activated ,64
    ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,not activated ,64
    ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated ,64
    ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,not activated ,64
    ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,not activated ,64
    ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,not activated ,64
    ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated ,64
    ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,not activated ,64
    ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,not activated ,64
    ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,not activated ,64
    ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated ,64
    ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,not activated ,64
    ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated ,64
    ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated ,64
    ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,not activated ,64
    ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,not activated ,64
    ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,not activated ,64
    ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,not activated ,64
    ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,not activated ,64
    ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,not activated ,64
    ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,not activated ,64
    ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not activated ,64
    ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,64
    ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not activated ,64
    ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,64
    ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,not activated ,64
    ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,not activated ,64
    ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,not activated ,64
    ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,not activated ,64
    ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not activated ,64
    ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,not activated ,64
    ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,not activated ,64
    ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,not activated ,64
    ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,not activated ,64
    ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,not activated ,64
    ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,not activated ,64
    ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,not activated ,64
    ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,not activated ,64
    ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,not activated ,64
    ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,not activated ,64
    ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,not activated ,64
    ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,not activated ,64
    ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,not activated ,64
    ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,activated ,64
    ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Terminal 15 ,64
    ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated ,64
    ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,not activated ,64
    ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,not activated ,64
    ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,not activated ,64
    ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Not available ,8
    ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Not available ,8
    ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Not available ,8
    ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Not available ,8
    ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,Available ,8
    ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Databus Infotainment ,8
    ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Not available ,8
    ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Available ,8
    ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Terminal 15 ,8
    ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved,Not available ,8
    ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Not available ,8
    ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Not available ,8
    ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3,Not available ,8
    ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Not available ,8
    ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Not available ,8
    ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,20 ,6
    ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,50 ,6
    ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,20 ,6
    ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,50 ,6
    ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,3 ,12
    ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2,10 ,12
    ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,15 ,12
    ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,60 ,12
    ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,0 ,12
    ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,0 ,12
    ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,2 %,12
    ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,10 %,12
    ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,15 %,12
    ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,90 %,12
    ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,0 %,12
    ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,0 %,12
    ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,00 00 00 00 01 00 00 00 00 01 00 00 00 00 01 00 00 00 00 01 2D 1E 37 28 37 28 2D 1E 07 64 1E 04 10 03 0A 00 00 00 01 03 ,40
    ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
    ENG109862-ENG117847-Vehicle_configuration-advanced_range_display,OFF ,30
    ENG109862-ENG142146-Vehicle_configuration-allow_message_editing,OFF ,30
    ENG109862-ENG130249-Vehicle_configuration-Apple_DIO,On ,30
    ENG109862-ENG152525-Vehicle_configuration-Baidu_Car_Life,OFF ,30
    ENG109862-ENG152559-Vehicle_configuration-Baidu_Car_Life_ios,OFF ,30
    ENG109862-ENG152560-Vehicle_configuration-block_hmi_function_p_epb,blocked ,30
    ENG109862-ENG142151-Vehicle_configuration-conditioning_variant,0 ,30
    ENG109862-ENG125043-Vehicle_configuration-Dtmf_without_active_call,On ,30
    ENG109862-ENG142145-Vehicle_configuration-esim_data_only_sms_support,OFF ,30
    ENG109862-ENG130248-Vehicle_configuration-Google_GAL,On ,30
    ENG109862-ENG117850-Vehicle_configuration-gracenote_local_coverarts,OFF ,30
    ENG109862-ENG117851-Vehicle_configuration-gracenote_local_other,OFF ,30
    ENG109862-ENG117848-Vehicle_configuration-gracenote_online_coverarts,OFF ,30
    ENG109862-ENG117849-Vehicle_configuration-gracenote_online_other,OFF ,30
    ENG109862-ENG152533-Vehicle_configuration-Hybrid_Radio_additional_online_data,not activated ,30
    ENG109862-ENG152534-Vehicle_configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
    ENG109862-ENG125049-Vehicle_configuration-Joker_button_1,Not Present ,30
    ENG109862-ENG125050-Vehicle_configuration-Joker_button_2,Not Present ,30
    ENG109862-ENG127492-Vehicle_configuration-LGI,OFF ,30
    ENG109862-ENG130246-Vehicle_configuration-LTE_modul,activated ,30
    ENG109862-ENG142142-Vehicle_configuration-map_email_support,OFF ,30
    ENG109862-ENG142143-Vehicle_configuration-map_instant_messaging_support,OFF ,30
    ENG109862-ENG142141-Vehicle_configuration-map_sms_support,OFF ,30
    ENG109862-ENG142152-Vehicle_configuration-Map_Style,0 ,30
    ENG109862-ENG152537-Vehicle_configuration-media_control,not activated ,30
    ENG109862-ENG138662-Vehicle_configuration-Mirror_link,OFF ,30
    ENG109862-ENG142148-Vehicle_configuration-MirrorLink_Country_Code,MIB_EU ,30
    ENG109862-ENG142150-Vehicle_configuration-MirrorLink_RGB_Preference,RGB565 ,30
    ENG109862-ENG117843-Vehicle_configuration-my_audi,OFF ,30
    ENG109862-ENG117845-Vehicle_configuration-online_dictation,OFF ,30
    ENG109862-ENG127495-Vehicle_configuration-online_media,OFF ,30
    ENG109862-ENG117840-Vehicle_configuration-online_navigation,OFF ,30
    ENG109862-ENG117837-Vehicle_configuration-online_POI,OFF ,30
    ENG109862-ENG117838-Vehicle_configuration-online_POI_voice,OFF ,30
    ENG109862-ENG117839-Vehicle_configuration-online_portal_browser_services,OFF ,30
    ENG109862-ENG152553-Vehicle_configuration-online_radio,Deactivated ,30
    ENG109862-ENG117841-Vehicle_configuration-online_street_view,OFF ,30
    ENG109862-ENG125048-Vehicle_configuration-OPS_display_in_dash_board_display_unit,On ,30
    ENG109862-ENG167521-Vehicle_configuration-perso_v_threshold,00 ,30
    ENG109862-ENG167522-Vehicle_configuration-perso_v_threshold_hysteresis,00 ,30
    ENG109862-ENG152554-Vehicle_configuration-Phone_HMI_Privacy,0 ,30
    ENG109862-ENG125046-Vehicle_configuration-Phone_module_operation_mode,Data & language service active ,30
    ENG109862-ENG117844-Vehicle_configuration-picture_navi,On ,30
    ENG109862-ENG167523-Vehicle_configuration-Pilot_Parking,not activated ,30
    ENG109862-ENG167525-Vehicle_configuration-Popup_if_GPS_services_in_use,not activated ,30
    ENG109862-ENG152555-Vehicle_configuration-Privacy_WithPINRequest,0 ,30
    ENG109862-ENG127496-Vehicle_configuration-ProbeCar_lgi,OFF ,30
    ENG109862-ENG137646-Vehicle_configuration-ProbeCar_vzo,OFF ,30
    ENG109862-ENG125047-Vehicle_configuration-PSD_Protocol_Version,PSD_1.5 ,30
    ENG109862-ENG117846-Vehicle_configuration-remote_HMI,OFF ,30
    ENG109862-ENG138661-Vehicle_configuration-RSE_software_component,activated ,30
    ENG109862-ENG126143-Vehicle_configuration-RVC_video_input,FBAS ,30
    ENG109862-ENG152556-Vehicle_configuration-scon_telephony,not activated ,30
    ENG109862-ENG142081-Vehicle_configuration-sd_slot_deactivation,no restriction ,30
    ENG109862-ENG138660-Vehicle_configuration-SDS_Region_Flag,no_region ,30
    ENG109862-ENG152557-Vehicle_configuration-show_volte_hmi_switch,not activated ,30
    ENG109862-ENG125045-Vehicle_configuration-Sim_card_mode_switch,Not Present ,30
    ENG109862-ENG142144-Vehicle_configuration-sim_data_only_sms_support,OFF ,30
    ENG109862-ENG138663-Vehicle_configuration-Smartphone_interface_for_rhmi,activated ,30
    ENG109862-ENG126993-Vehicle_configuration-Station_Logo_DB_Mode,1 ,30
    ENG109862-ENG125044-Vehicle_configuration-Support_for_response_and_hold,OFF ,30
    ENG109862-ENG125042-Vehicle_configuration-Support_of_threeway_calling,OFF ,30
    ENG109862-ENG130247-Vehicle_configuration-Support_second_phone,On ,30
    ENG109862-ENG167531-Vehicle_configuration-Tencent_myCar_canceling_share_location,OFF ,30
    ENG109862-ENG126994-Vehicle_configuration-TPEG_availability,OFF ,30
    ENG109862-ENG152571-Vehicle_configuration-unblock_functions_while_piloted_driving,blocked ,30
    ENG109862-ENG137647-Vehicle_configuration-UOTA,OFF ,30
    ENG109862-ENG167532-Vehicle_configuration-UOTA_2,OFF ,30
    ENG109862-ENG117852-Vehicle_configuration-UPnP,OFF ,30
    ENG109862-ENG142149-Vehicle_configuration-vehicle_leaving_sound,not activated ,30
    ENG109862-ENG142147-Vehicle_configuration-vehicle_readiness_sound,not activated ,30
    ENG109862-ENG152558-Vehicle_configuration-voice_over_lte,not activated ,30
    ENG109862-ENG117836-Vehicle_configuration-VZAPro,OFF ,30
    ENG109862-ENG127494-Vehicle_configuration-VZO,OFF ,30
    ENG109862-ENG137648-Vehicle_configuration-WiFi_Client_HMI,OFF ,30
    ENG109862-ENG117842-Vehicle_configuration-WIFI_Hotspot,On ,30
    ENG109862-ENG152572-Vehicle_configuration-wlan_5ghz_switch,not activated ,30
    Elapsed Time: 00:43
    ;SW:5C0-035-680-C   HW:5C0-035-680-C ---  Information Electr.
    ;Component:MU-S-ND-ER    H20 , Coding:02730001000000001111120100880A001F0106D400200100CF
    ;EV_MUStd4CTSAT,001022,EV_MUStd4CTSAT_VW21.rod
    ;Saturday,10,March,2018,20:41:31:31035
    ;VCDS Version: Release 18.1.0 (x64)  Data version: 20180122 DS285.1
    ;VCID: 2149B77630B0D14D9A-8074
    IDE00346-Summertime-automatic,none ,1
    IDE00758-Base volume of telephone,50 %,1
    IDE00769-Number 1 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE00770-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE00845-Wheel circ.,0 mm,2
    IDE02121-CD eject button,Enabled ,1
    IDE02122-Developer mode,not activated ,1
    IDE02330-Number 2 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02331-Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,36 ,49
    IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,36 ,49
    IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,36 ,49
    IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,36 ,49
    IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,36 ,49
    IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,36 ,49
    IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,36 ,49
    IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,36 ,49
    IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,36 ,49
    IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,36 ,49
    IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,36 ,49
    IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,36 ,49
    IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,36 ,49
    IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,36 ,49
    IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,36 ,49
    IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,36 ,49
    IDE02502-Confirmation of installation change,C1 11 ,2
    IDE02607-Wheel pulse,0 ,2
    IDE02699-Number 1 for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02701-Number 1 (roaming) for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE04550-Bluetooth: Sniff mode,OFF ,1
    IDE05111-Fee-based traffic information (TMC),32768 ,2
    IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,OFF ,1
    IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,On ,1
    IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,OFF ,1
    IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,OFF ,1
    IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,OFF ,1
    IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1,OFF ,1
    IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2,OFF ,1
    IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,-128 ,40
    IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,9 ,40
    IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),4 ,40
    IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),7 ,40
    IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),4 ,40
    IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,0 ,40
    IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,0 ,40
    IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128 ,40
    IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,7 ,40
    IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,-128 ,40
    IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,-128 ,40
    IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,10 ,40
    IDE10480-MAS10742-Interface for external media: activation-Connection 2,not activated ,4
    IDE10604-Menu entries for mobile online services,activated ,1
    IDE11122-Country identification: country of sale HMI,EN ,2
    IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21
    IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked ,21
    IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked ,21
    IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked ,21
    IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked ,21
    IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked ,21
    IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked ,21
    IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21
    IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,21
    IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,21
    IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,21
    IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,21
    IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked ,21
    IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked ,21
    IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked ,21
    IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,21
    IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked ,21
    IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,21
    IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,21
    IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked ,21
    IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked ,21
    IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked ,21
    IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked ,21
    IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked ,21
    IDE11502-ENG127643-Locked menu contents-FB_MISC_18,non_blocked ,21
    IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked ,21
    IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked ,21
    IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,21
    IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,21
    IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked ,21
    IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked ,21
    IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked ,21
    IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked ,21
    IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked ,21
    IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked ,21
    IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked ,21
    IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked ,21
    IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,21
    IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked ,21
    IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21
    IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked ,21
    IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
    IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked ,21
    IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked ,21
    IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,21
    IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,21
    IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked ,21
    IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked ,21
    IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked ,21
    IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked ,21
    IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked ,21
    IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,21
    IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,21
    IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked ,21
    IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked ,21
    MAS00950-Audio Parameter,0 ,1
    MAS00951-Bluetooth,On ,1
    MAS03782-WLAN,On ,1
    ENG104140-Bluetooth_Phonebook_Access_Profile,PBAP ,1
    ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not activated ,60
    ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,not activated ,60
    ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer,not activated ,60
    ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off,not activated ,60
    ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,not activated ,60
    ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,not activated ,60
    ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,not activated ,60
    ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,not activated ,60
    ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,not activated ,60
    ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,not activated ,60
    ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,not activated ,60
    ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated ,60
    ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,not activated ,60
    ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not activated ,60
    ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
    ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated ,60
    ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,not activated ,60
    ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,not activated ,60
    ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not activated ,60
    ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,not activated ,60
    ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated ,60
    ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,not activated ,60
    ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,not activated ,60
    ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated ,60
    ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,not activated ,60
    ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,not activated ,60
    ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,not activated ,60
    ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated ,60
    ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,not activated ,60
    ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,not activated ,60
    ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,not activated ,60
    ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,not activated ,60
    ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,not activated ,60
    ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,not activated ,60
    ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,not activated ,60
    ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,not activated ,60
    ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,not activated ,60
    ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,not activated ,60
    ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,not activated ,60
    ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,not activated ,60
    ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,not activated ,60
    ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not activated ,60
    ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,not activated ,60
    ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,not activated ,60
    ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not activated ,60
    ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,not activated ,60
    ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,not activated ,60
    ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,not activated ,60
    ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated ,60
    ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,not activated ,60
    ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,not activated ,60
    ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,not activated ,60
    ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,not activated ,60
    ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated ,60
    ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,not activated ,60
    ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated ,60
    ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,not activated ,60
    ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
    ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,60
    ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,not activated ,60
    ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,not activated ,60
    ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated ,60
    ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not activated ,60
    ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,60
    ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not activated ,60
    ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60
    ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated ,60
    ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,not activated ,60
    ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,not activated ,60
    ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,not activated ,60
    ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated ,60
    ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,60
    ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated ,60
    ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,not activated ,60
    ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,not activated ,60
    ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,not activated ,60
    ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,not activated ,60
    ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated ,60
    ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not activated ,60
    ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,not activated ,60
    ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,not activated ,60
    ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,not activated ,60
    ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,not activated ,60
    ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated ,64
    ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,not activated ,64
    ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated ,64
    ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,not activated ,64
    ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,activated ,64
    ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Comfort data bus ,64
    ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated ,64
    ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,not activated ,64
    ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated ,64
    ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,not activated ,64
    ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated ,64
    ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,not activated ,64
    ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,not activated ,64
    ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated ,64
    ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,not activated ,64
    ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,not activated ,64
    ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,not activated ,64
    ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,not activated ,64
    ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,not activated ,64
    ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,not activated ,64
    ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,not activated ,64
    ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,not activated ,64
    ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,not activated ,64
    ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,not activated ,64
    ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated ,64
    ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,not activated ,64
    ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,not activated ,64
    ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,not activated ,64
    ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not activated ,64
    ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,not activated ,64
    ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,not activated ,64
    ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,not activated ,64
    ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,not activated ,64
    ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,not activated ,64
    ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,not activated ,64
    ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not activated ,64
    ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,not activated ,64
    ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,not activated ,64
    ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38,not activated ,64
    ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,not activated ,64
    ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,not activated ,64
    ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,not activated ,64
    ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated ,64
    ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,not activated ,64
    ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,not activated ,64
    ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,not activated ,64
    ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,not activated ,64
    ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated ,64
    ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,not activated ,64
    ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,not activated ,64
    ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,not activated ,64
    ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated ,64
    ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,not activated ,64
    ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,not activated ,64
    ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,not activated ,64
    ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated ,64
    ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,not activated ,64
    ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated ,64
    ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated ,64
    ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,not activated ,64
    ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,not activated ,64
    ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,not activated ,64
    ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,not activated ,64
    ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,not activated ,64
    ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,not activated ,64
    ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,not activated ,64
    ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not activated ,64
    ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,64
    ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not activated ,64
    ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,64
    ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,not activated ,64
    ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,not activated ,64
    ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,not activated ,64
    ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,not activated ,64
    ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not activated ,64
    ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,not activated ,64
    ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,not activated ,64
    ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,not activated ,64
    ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,not activated ,64
    ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,not activated ,64
    ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,not activated ,64
    ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,not activated ,64
    ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,not activated ,64
    ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,not activated ,64
    ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,not activated ,64
    ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,not activated ,64
    ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,not activated ,64
    ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,not activated ,64
    ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,activated ,64
    ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Terminal 15 ,64
    ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated ,64
    ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,not activated ,64
    ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,not activated ,64
    ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,not activated ,64
    ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Not available ,8
    ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Not available ,8
    ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Not available ,8
    ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Not available ,8
    ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,Available ,8
    ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Databus Infotainment ,8
    ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Not available ,8
    ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Available ,8
    ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Terminal 15 ,8
    ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved,Not available ,8
    ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Not available ,8
    ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Not available ,8
    ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3,Not available ,8
    ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Not available ,8
    ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Not available ,8
    ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,20 ,6
    ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,50 ,6
    ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,20 ,6
    ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,50 ,6
    ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,3 ,12
    ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2,10 ,12
    ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,15 ,12
    ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,60 ,12
    ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,0 ,12
    ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,0 ,12
    ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,2 %,12
    ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,10 %,12
    ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,15 %,12
    ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,90 %,12
    ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,0 %,12
    ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,0 %,12
    ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,00 00 00 00 01 00 00 00 00 01 00 00 00 00 01 00 00 00 00 01 2D 1E 37 28 37 28 2D 1E 07 64 1E 04 10 03 0A 00 00 00 01 03 ,40
    ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
    ENG109862-ENG117847-Vehicle_configuration-advanced_range_display,OFF ,30
    ENG109862-ENG142146-Vehicle_configuration-allow_message_editing,OFF ,30
    ENG109862-ENG130249-Vehicle_configuration-Apple_DIO,On ,30
    ENG109862-ENG152525-Vehicle_configuration-Baidu_Car_Life,OFF ,30
    ENG109862-ENG152559-Vehicle_configuration-Baidu_Car_Life_ios,OFF ,30
    ENG109862-ENG152560-Vehicle_configuration-block_hmi_function_p_epb,blocked ,30
    ENG109862-ENG142151-Vehicle_configuration-conditioning_variant,0 ,30
    ENG109862-ENG125043-Vehicle_configuration-Dtmf_without_active_call,On ,30
    ENG109862-ENG142145-Vehicle_configuration-esim_data_only_sms_support,OFF ,30
    ENG109862-ENG130248-Vehicle_configuration-Google_GAL,On ,30
    ENG109862-ENG117850-Vehicle_configuration-gracenote_local_coverarts,OFF ,30
    ENG109862-ENG117851-Vehicle_configuration-gracenote_local_other,OFF ,30
    ENG109862-ENG117848-Vehicle_configuration-gracenote_online_coverarts,OFF ,30
    ENG109862-ENG117849-Vehicle_configuration-gracenote_online_other,OFF ,30
    ENG109862-ENG152533-Vehicle_configuration-Hybrid_Radio_additional_online_data,not activated ,30
    ENG109862-ENG152534-Vehicle_configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
    ENG109862-ENG125049-Vehicle_configuration-Joker_button_1,Not Present ,30
    ENG109862-ENG125050-Vehicle_configuration-Joker_button_2,Not Present ,30
    ENG109862-ENG127492-Vehicle_configuration-LGI,OFF ,30
    ENG109862-ENG130246-Vehicle_configuration-LTE_modul,activated ,30
    ENG109862-ENG142142-Vehicle_configuration-map_email_support,OFF ,30
    ENG109862-ENG142143-Vehicle_configuration-map_instant_messaging_support,OFF ,30
    ENG109862-ENG142141-Vehicle_configuration-map_sms_support,OFF ,30
    ENG109862-ENG142152-Vehicle_configuration-Map_Style,0 ,30
    ENG109862-ENG152537-Vehicle_configuration-media_control,not activated ,30
    ENG109862-ENG138662-Vehicle_configuration-Mirror_link,OFF ,30
    ENG109862-ENG142148-Vehicle_configuration-MirrorLink_Country_Code,MIB_EU ,30
    ENG109862-ENG142150-Vehicle_configuration-MirrorLink_RGB_Preference,RGB565 ,30
    ENG109862-ENG117843-Vehicle_configuration-my_audi,OFF ,30
    ENG109862-ENG117845-Vehicle_configuration-online_dictation,OFF ,30
    ENG109862-ENG127495-Vehicle_configuration-online_media,OFF ,30
    ENG109862-ENG117840-Vehicle_configuration-online_navigation,OFF ,30
    ENG109862-ENG117837-Vehicle_configuration-online_POI,OFF ,30
    ENG109862-ENG117838-Vehicle_configuration-online_POI_voice,OFF ,30
    ENG109862-ENG117839-Vehicle_configuration-online_portal_browser_services,OFF ,30
    ENG109862-ENG152553-Vehicle_configuration-online_radio,Deactivated ,30
    ENG109862-ENG117841-Vehicle_configuration-online_street_view,OFF ,30
    ENG109862-ENG125048-Vehicle_configuration-OPS_display_in_dash_board_display_unit,On ,30
    ENG109862-ENG167521-Vehicle_configuration-perso_v_threshold,00 ,30
    ENG109862-ENG167522-Vehicle_configuration-perso_v_threshold_hysteresis,00 ,30
    ENG109862-ENG152554-Vehicle_configuration-Phone_HMI_Privacy,0 ,30
    ENG109862-ENG125046-Vehicle_configuration-Phone_module_operation_mode,Data & language service active ,30
    ENG109862-ENG117844-Vehicle_configuration-picture_navi,On ,30
    ENG109862-ENG167523-Vehicle_configuration-Pilot_Parking,not activated ,30
    ENG109862-ENG167525-Vehicle_configuration-Popup_if_GPS_services_in_use,not activated ,30
    ENG109862-ENG152555-Vehicle_configuration-Privacy_WithPINRequest,0 ,30
    ENG109862-ENG127496-Vehicle_configuration-ProbeCar_lgi,OFF ,30
    ENG109862-ENG137646-Vehicle_configuration-ProbeCar_vzo,OFF ,30
    ENG109862-ENG125047-Vehicle_configuration-PSD_Protocol_Version,PSD_1.5 ,30
    ENG109862-ENG117846-Vehicle_configuration-remote_HMI,OFF ,30
    ENG109862-ENG138661-Vehicle_configuration-RSE_software_component,activated ,30
    ENG109862-ENG126143-Vehicle_configuration-RVC_video_input,FBAS ,30
    ENG109862-ENG152556-Vehicle_configuration-scon_telephony,not activated ,30
    ENG109862-ENG142081-Vehicle_configuration-sd_slot_deactivation,no restriction ,30
    ENG109862-ENG138660-Vehicle_configuration-SDS_Region_Flag,no_region ,30
    ENG109862-ENG152557-Vehicle_configuration-show_volte_hmi_switch,not activated ,30
    ENG109862-ENG125045-Vehicle_configuration-Sim_card_mode_switch,Not Present ,30
    ENG109862-ENG142144-Vehicle_configuration-sim_data_only_sms_support,OFF ,30
    ENG109862-ENG138663-Vehicle_configuration-Smartphone_interface_for_rhmi,activated ,30
    ENG109862-ENG126993-Vehicle_configuration-Station_Logo_DB_Mode,1 ,30
    ENG109862-ENG125044-Vehicle_configuration-Support_for_response_and_hold,OFF ,30
    ENG109862-ENG125042-Vehicle_configuration-Support_of_threeway_calling,OFF ,30
    ENG109862-ENG130247-Vehicle_configuration-Support_second_phone,On ,30
    ENG109862-ENG167531-Vehicle_configuration-Tencent_myCar_canceling_share_location,OFF ,30
    ENG109862-ENG126994-Vehicle_configuration-TPEG_availability,OFF ,30
    ENG109862-ENG152571-Vehicle_configuration-unblock_functions_while_piloted_driving,blocked ,30
    ENG109862-ENG137647-Vehicle_configuration-UOTA,OFF ,30
    ENG109862-ENG167532-Vehicle_configuration-UOTA_2,OFF ,30
    ENG109862-ENG117852-Vehicle_configuration-UPnP,OFF ,30
    ENG109862-ENG142149-Vehicle_configuration-vehicle_leaving_sound,not activated ,30
    ENG109862-ENG142147-Vehicle_configuration-vehicle_readiness_sound,not activated ,30
    ENG109862-ENG152558-Vehicle_configuration-voice_over_lte,not activated ,30
    ENG109862-ENG117836-Vehicle_configuration-VZAPro,OFF ,30
    ENG109862-ENG127494-Vehicle_configuration-VZO,OFF ,30
    ENG109862-ENG137648-Vehicle_configuration-WiFi_Client_HMI,OFF ,30
    ENG109862-ENG117842-Vehicle_configuration-WIFI_Hotspot,On ,30
    ENG109862-ENG152572-Vehicle_configuration-wlan_5ghz_switch,not activated ,30
    Elapsed Time: 00:46
    ;SW:5C0-035-680-C   HW:5C0-035-680-C ---  Information Electr.
    ;Component:MU-S-ND-ER    H20 0252, Coding:02730001000000001111120100880A001F0106D400200100CF
    ;EV_MUStd4CTSAT,001022,EV_MUStd4CTSAT_VW21.rod
    ;Saturday,10,March,2018,20:42:31:31035
    ;VCDS Version: Release 18.1.0 (x64)  Data version: 20180122 DS285.1
    ;VCID: 2149B77630B0D14D9A-8074
    IDE00346-Summertime-automatic,none ,1
    IDE00758-Base volume of telephone,50 %,1
    IDE00769-Number 1 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE00770-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE00845-Wheel circ.,0 mm,2
  5. Likes Uwe liked this post
  6. #14
    Dec 2016
    NL
    What options do you have for this channel in the park assist module?
    IDE01170-Visual display for park assist,OPS display ,1
    And also try setting this one in 5F to OFF and see what happens. This one is usually OFF in MIB units as OPS is shown on the MIB screen:
    Current:
  7. #15
    Apr 2018
    Australia
    Results?
    Did this work?
  8. #16
    Mar 2017
    Still haven't had the time to take the stuff apart to reach my PDC module and swapped it out.. Hopefully I'm able to try this in the weekend
