Results 1 to 7 of 7
Thread: Programming a Audi s1 from rhd to lhd
    Feb 2018
    NL
    Dear forum members.
    We have a audi s1 year 2016.
    Its rebuild from a right hand drive to a left hand drive.
    The problem and question:
    1- everything works the opposite, like windows/mirrors
    If we swap the control module passenger door to driver door everything is just fine. The problem we get if we swap the control modules is that if we shut down the car and open the left door (the car thinks) the right door is opened. so the dashbord lights stay on and the radio keeps playing.
    2- In the instrument cluster we cant find any coding that resolve this problem, we think the cangateway wil recognize the door positions. If we try to long code the can gateway all the bits are blank and the vag-com tells me to contact ross-tech. After contacting Ross tech they told me to post here and you guys could help me a right coding.
    Thanks for help so far.
    Aug 2016
    Switzerland
    looks like the door modules don't care whether they are LHD or RHD.
    if there is a coding for it, I suspect it's BCM or gateway...
  3. Likes Jetta ,97 liked this post
    Dallas (McKinney) ,TX ,USA
    Post Auto scan.
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  5. Likes Uwe liked this post
  6. #4
    Feb 2018
    NL
    Log file audi s1
    What coding does the can gateway needs, because when i want to recode it i cant see any bits. i cab choose 7 or 8 bits but they are all blank.
    Wednesday,21,February,2018,12:09:34:06058
    VCDS Version: 18.2.0.3 (x64)
    Dealer/Shop Name: Dtslopik
    Workshop Code: 998 00005 034111
    VIN: WAUZZZ8X6FB002610   License Plate: RN-267-S
    Mileage: 20170km-12533mi   Repair Order:
    Chassis Type: 8X-AU21 (8U0)
    Scan: 01 03 05 08 09 10 14 15 16 17 19 20 22 25 2B 42 44 46 47 52
              55 56 5F A9
    VIN: WAUZZZ8X6FB002610   Mileage: 20170km-12533miles
    Address 01: Engine (J623-CWZA)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8X0 906 259     HW: 06K 907 425 B
       Revision: --H13---
       Coding: 0A1900322426010B1002
       Shop #: WSC 00046 412 00000
       ASAM Dataset: EV_ECM20TFS0208X0906259 001006
       ROD: EV_ECM20TFS_AU21.rod
       VCID: 7F070BFCE6EAD6BC61-802A
    Readiness: 1110 0001
       Part No SW: 6C0 907 379 D    HW: 6R0 907 379 BA
       Component: ESP9.0i       H03 0001
       Serial number: 08510530140513
       Coding: 36DF708B8D2333C2491A306A00516C0EB1CC920C0013E3090F00
       ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
       VCID: 306518C06B34F9C4A8-8064
       Revision: 00092000    Serial number: 0335641292
       Coding: 030C0C
       ROD: EV_KESSYPQ35G_A02_AU21.rod
       VCID: 377723DC8E5A2EFCE9-8062
    Address 08: Auto HVAC (J255)       Labels:* Redir Fail!
       Part No SW: 8XA 820 043     HW: 8XA 820 043
       Component: Klima 1 Zone  H01 0010
       Serial number: 00000000275506
       Coding: 6420080880
       ASAM Dataset: EV_AirCondiFrontAU210 007002
       ROD: EV_AirCondiFrontAU210_007.rod
       VCID: 020182089518BB540E-8056
    Address 09: Cent. Elect. (J519)       Labels:. 8X0-907-063.clb
       Part No SW: 8X0 907 063 R    HW: 8X0 907 063 R
       Component: BCM PQ35  M   113 0811
       Revision: AD113811
       Coding: 4E000A2CA805F100201843E82104084C53F7620A21EF5DB2E4088787E0C5
       Shop #: WSC 00046 000 00000
       VCID: 4B9F6F2CEAD2BA1CBD-801E
       Subsystem 1 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
       Serial number: 22749013
       Coding: 02005D
       Subsystem 2 - Part No: 8X0 951 177
       Component: DWA-Sensor H0  H01 0020
    Address 10: Park/Steer Assist (J446)       Labels:| 8X0-919-475.clb
       Part No SW: 8X0 919 475 R    HW: 4H0 919 475 C
       Component: PARKHILFE 8K  H07 0050
       Revision: 11001001    Serial number: 55961414601715
       Coding: 040203
       ASAM Dataset: EV_EPHVA18AU21X0000 002005
       ROD: EV_EPHVA18AU21X0000_002.rod
       VCID: 55AB89543416FCEC1B-8000
    Address 14: Susp. Elect. (J250)       Labels:. 6C0-907-359.clb
       Part No SW: 6C0 907 359     HW: 6C0 907 359
       Component: DAEMPFUNGS-SG H04 0007
       Serial number: 17041402000178
       Coding: 82
       ASAM Dataset: EV_SwitcDampeContiTemic 001004
       ROD: EV_SwitcDampeContiTemic.rod
       VCID: 6AD1CAA88D684314A6-803E
    Address 15: Airbags (J234)       Labels:| 8X0-959-655.clb
       Part No SW: 8XA 959 655     HW: 8XA 959 655
       Component: Airbag10.41   H07 0011
       Revision: --------    Serial number: 003NV0001XSX
       Coding: 30314539303430323136554A305238584153
       ASAM Dataset: EV_Airba1041BPAAU210 001018
       ROD: EV_Airba1041BPAAU210.rod
       VCID: 1835C060E3840184C0-804C
       Serial number: 3554VRB404P2G2O8BG5V
       Serial number: 3575HRB405T2LPPI6P7R
       Serial number: 3585HRB405T2LPPIE0UY
       Rear Impact Crash Sensor:
       Serial number: 3515ZRB400652K1QQHK%
    9442587 - Igniter for battery interrupt
              B1015 1B [137] - Resistance Too High
                        Mileage: 20171 km
                        Date: 2018.02.21
                        Time: 12:04:59
    Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
       Part No SW: 8X0 953 521 K    HW: 5K0 953 569 AH
       Revision: FF010018    Serial number: 20140528200891
       Coding: 1004204000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 448D4410CF8C75647C-8010
       Subsystem 1 - Part No SW: 8U0 951 528 G    HW: 8U0 951 528 G
    Address 17: Instruments (J285)       Labels:| 8X0-920-xxx-17.clb-SRI1
       Part No SW: 8XA 920 980 C    HW: 8XA 920 980 C
       Component: KOMBI_MEDIUM  H06 0450
       Coding: 03DE01
       Shop #: WSC 00005 998 34111
       ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
       VCID: 50A578400BF499C4C8-8004
    Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
       Part No SW: 8U0 907 468 AC    HW: 8U0 907 468 G
       Component: GAT 4CAN 1L M H13 0072
       Revision: 1P130039    Serial number: 3941P145170927
       Coding: FBCF1059000100010153
       VCID: 030F870C8202B25C05-8056
       Component: J367-BDM  H07 0190
       Serial number: 41155H03024121350992
       Serial number: 1402110000000000007B
    Address 20: High Beam Assist. (J844)       Labels:| 8X0-857-511.clb
       Part No SW: 8X0 857 511 AA    HW: 8X0 857 511 AA
       Component: FLA           H03 0005
       Revision: AA001001
       Coding: 02020E64747464545425363E00
       Shop #: WSC 60739 001 1048576
       ASAM Dataset: EV_HighBeamAssisAU210 001019
       ROD: EV_HighBeamAssisAU210.rod
       VCID: 7DFBF1F4ECE6C4AC73-8028
       Part No SW: 0AY 907 554 F    HW: 0AY 907 554 F
       Component: Haldex4Motion H52 7521
       Serial number: HA1-00029.03.14
       Coding: 0201
       VCID: 4E99663811C08F34DA-801A
       Component: IMMO          H06 0450
       Coding: 000007
       ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113
       ROD: EV_Immo_UDS_VDD_AU10.rod
    Address 2B: Steer. Col. Lock (J764)       Labels:| 5K0-905-861.clb
       Revision: 00000000    Serial number: 14000137608001
       Coding: 4100000000000000
       ROD: EV_ELVMarquMPVW36X.rod
    Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
       Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
       Component: TSG FA        H10 0415
       Coding: 011E12201C00120102
       VCID: 52A172480DF8EBD4FE-8006
    02111 - Motor for Window Regulator
                        Fault Status: 01100101
                        Reset counter: 146
                        Mileage: 20171 km
                        Date: 2018.02.21
                        Time: 12:04:54
       Part No SW: 6R2 909 144 R    HW: 6R2 909 144 E
       Component: EPS_TRW_ALow  322 3111
       Serial number: CE6C0524
       Coding: 0017
       ASAM Dataset: EV_SteerAssisUDSTRW 011021
       ROD: EV_SteerAssisUDSTRW_011.rod
       VCID: 4797531CFEBA5E7C99-8012
    Address 47: Sound System (J525)       Labels: Redir Fail!
       Part No SW: 8X0 035 223 D    HW: 8X0 035 223 B
       Component: BOSE-G3-A1Q3  H05 0160
       Revision: CK005201    Serial number: 00000000014954
       Coding: 030000
       VCID: 336F17CC9222C2DCD5-8066
    Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
       Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
       Component: TSG BF        H10 0415
       Coding: 011E12201E00000100
       VCID: 51A37D4408FE90CCC7-8004
    02123 - Door Warning Light / Entry Light
                        Reset counter: 146
                        Mileage: 20171 km
                        Date: 2018.02.21
                        Time: 12:06:58
       Part No SW: 8X0 907 357 E    HW: 8X0 907 357 B
       Component: ****LWR12**** H02 0010
       Serial number: 140520-0002-255
       Coding: 11B1AC1010002500
       ROD: EV_HeadlRegulBasic.rod
       Part No SW: 4G0 035 061 N    HW: 4G0 035 061
       Component: Radio U DAB   H60 0139
       Revision: AB001007    Serial number: 109F.0E7933243
       Coding: 010105010000000002
       VCID: 2855F0A05BE4B10470-807C
       Part No SW: 8XA 035 670 A    HW: 8XA 035 670
       Component: H-BNT-EU      H40 0808
       Revision: --------    Serial number: 466F/0EB000485
       Coding: 0D0101020208E0E90500033600000001040000000000000000
       VCID: 4797531CF6BA5E7C99-8012
       Subsystem 1 - Part No: 8R0 060 884 BT
       Component: EUR 2014  1903
       Subsystem 2 - Part No SW: 8X0 919 604     HW: 8X0 919 604
       Component: DU6 High  H42 0084
       Serial number: 9463F-0E2532583
       Subsystem 3 - Part No: 8R0 060 961 G
       Component: CD-Database  5950
       Part No SW: 8X0 907 159 C    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0005
       Serial number: 140513200607
       VCID: 42814208D5987B544E-8016
    End-------------------------(Elapsed Time: 03:36)--------------------------
    Address 52,8X0 959 792 H,recoded (Long Coding),from,011E12201E00000100,to,011E12201C00000100,(00005/998/34111),
    Address 52,8X0 959 792 H,recoded (Long Coding),from,011E12201C00000100,to,011E12201C00120102,(00005/998/34111),
    Administrator Andy's Avatar
    The CAN-Gateway should use the Installation List function to tell it which items are installed:
    http://www.ross-tech.com/vcds/tour/i...ation-list.php
    Coding should not be needed.
    Well Andy it does matter of coding , at least in MK6 Golf/Jetta ,and I wold assume in A1 will be same, it will have in coding RHD or LHD.
    I thinks this is the key for his problem.
    Immobilizer/ECU
  9. Likes Uwe liked this post
  10. #7
    If it is possible at all, I don't know.
    Looking at coding, with PR code L0R to L0L, for some of the ECU's, I found these:
    [08] Remove Byte 1 Bit 5
    [19] Remove Byte 8 Bit 0
    [55] Activate Byte 5 Bit 1
    [5F] Remove Byte 2 Bit 0
    You can test it.
    Long shot for ABS
    [03] 34DF708B8D2333C2491A306A00512C0EB1CC920C0013E3090F 00
  11. Likes Uwe liked this post
