Results 1 to 10 of 12
Thread: 2.0 TFSI Problem
    Feb 2018
    Slovakia
    2.0 TFSI Problem
    Hello !
    I have problem with my engine in Audi A4 2.0 TFSI Quattro 155 KW
    Motor code:CDNC Year:2010
    When the engine is cold it gives a strange sound for a while from exhaust.
    Operating speed its ok..
    VCDS shows nothing..
    https://www.youtube.com/watch?v=0ld1yohnEHo
    Thanks for answer and sorry for my english...
    sounds like its misfiring. Any codes? Have you looked at the misfire counters in the measuring block data?
  3. Likes Uwe, Jack@European_Parts liked this post
    Feb 2018
    Slovakia
    measuring block not working...only adv.meas.values
    Maybe loose ground cable ............
    Feb 2018
    Slovakia
    nope i have original cable...
    on my old golf measuring data working...
    /edit nvm srry
    Feb 2018
    Slovakia
    maybe fuel pump or injection ???
    It is possible and check for fuel contamination into the oil sump from the HPP or sucking vapors for the N80.
    Isolate to verify...........
  9. #8
    Feb 2018
    Slovakia
    new injectors,coil packs,fuel pump and problem persists
  10. #9
    Please post an auto-scan ......more data required even though no DTC's.
    Is ECU FOD tuned?
    Have you overlaid the grounds to block and each coil pack to insure connectivity?
  11. Likes Uwe liked this post
  12. #10
    Feb 2018
    Slovakia
    Hello !
    Problem fixed
    PCV valve https://imgur.com/a/aO2nn
    Thanks for help !
    Ed:
  13. Likes Uwe, Jack@European_Parts liked this post
