- Joined
- Feb 14, 2018
- Messages
- 27
- Reaction score
- 4
- Location
- South Africa
- VCDS Serial number
- C?ID=327780
Dear Fiends,
I have Audi A6 where i cannot select the different modes for suspension positions.Not highlighted
With engine idling the pump does not switch on,as vehicle is completely down.
I have replaced the following -
1.Adaptive control unit.
2.Fitted new air pump with original relay from agents
3.New Valve Block
4.Left side electronic Engine Mounting.
Can anyone please help me as i will really appreciate it.
Attached is the scan i did...cleared faults several times and same faults appear.
N.B WILL ANYONE KNOW WHAT REPAIR PROCEDURE TO CARRY OUT CONCERNING THE ABS FAULT ALSO
Regards
German
3.New Valve Block
VIN: WAUZZZ4F48N013684 License Plate: WJL578
Mileage: 105770km-65722mi Repair Order: Kluas Germany
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 1E 34 36 37 42 46 47
4F 52 53 55 56 61 62 69 6D 72 76
VIN: WAUZZZ4F48N013684 Mileage: 105770km-65722miles
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4F9 910 401 HW: 4F0 907 401 C
Component: 3.0L V6TDI G000AG 0010
Revision: --H04--- Serial number:
Coding: 0011372
Shop #: WSC 02335 758 00200
VCID: 629C5DC6B84495171E1-8036
005715 - Please check DTC Memory of ABS Controller
P1653 - 002 -
Fault Status: 01100010
Fault Frequency: 7
Mileage: 105772 km
Date: 2007.03.02
Time: 12:27:11
Duty Cycle: 1.0 %
Voltage: 11.63 V
Bin. Bits: 00101000
Torque: 109.2 Nm
Bin. Bits: 00000100
005491 - Left Engine Mount Solenoid Valve (N144)
P1573 - 001 - Open Circuit
Fault Status: 01100001
Mileage: 105772 km
Date: 2007.03.02
Time: 12:27:11
Torque: 0.0 Nm
Voltage: 11.63 V
Bin. Bits: 1
Bin. Bits: 1
Bin. Bits: 1
Address 34: Level Control Labels: None
Part No SW: 4F0 910 553 B HW: 4F0 907 553 A
Component: J197 LUFTFEDER H17 0020
Serial number: 00628005008300
Coding: 0001220
VCID: 231218C2E7DEDC1F557-8076
01437 - Control Position not Learned
Fault Status: 11100101
Reset counter: 158
Mileage: 105772 km
Date: 2007.03.02
Time: 12:09:34
Fault Status: 11101101
Reset counter: 158
Mileage: 105772 km
Date: 2007.03.02
Time: 12:09:34
German
