Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: 01221 - Crash Sensor Side Airbag; Driver Side (G179) 010 - Open or Short
    Jun 2017
    OK, this is the final thing I've got to fix on my 2005 Mk5 Jetta 2.5 ... Driver's side air bag sensor error. Also, for some reason, the fault says "MIL ON" when in fact the Check engine light is NOT on. Not sure why that is.
    A little history ..
    I've had this fault from the beginning, just figured it was a bad crash sensor in the driver's door. I also had an issue with the interior light not coming on when the driver's door was opened ... which meant the fuel pump was not being energized either ... which gave me long cranking times when starting.
    I replaced the door latch (a known problem with these cars) with a used good one from a 2009 Jetta ... but when I had the door apart, I noticed the red marker light on the bottom of the door would flicker when I moved the wiring harness in the door (I guess wiring harnesses were another known problem with 2005 Jetta's) ... so I replaced the wiring harness too. I also replaced the Airbag Crash Sensor (G179) while I was in there with another used one from the same 2009 Jetta.
    Now everything works as it should ... the interior lights come on, and the fuel pump runs when you open the door. But I'm STILL getting the Airbag Crash Sensor fault!
    Any ideas? ... are there any known issues with these that I don't know about?
    Monday,08,January,2018,18:11:43:23114
    VCDS Version: 17.8.1.0 (x64)  HEX-V2 CB: 0.4401.4
    VIN: 3VWPG71K55M620606   License Plate:
    Mileage: 278790km-173232mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: 3VWPG71K55M620606   Mileage: 278790km-173232miles
    Address 01: Engine        Labels: 06A-906-032-BGQ.lbl
       Part No SW: 06A 906 032 QC    HW: Hardware No
       Component: 2.5l R5/4V      G   6605
       Revision: 00000000    Serial number: VWZ7Z0E1483365
       Coding: 0000003
       VCID: 6FB8DBBF6B98A8DFB3B-803A
    Readiness: 0000 1100
       Part No: 09G 927 750 AS
       Component: AQ 250 6F           0649
       Coding: 0000584
       VCID: 025E820B480AB5B74C5-8056
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
       Part No: 1K0 907 379 P
       Component: ASR FRONT MK70      0105
       Coding: 0017025
       VCID: 3FD84BFF7B78185F63B-806A
       Part No: 1K0 820 047 EM
       Component: Climatic PQ35   084 0404
       VCID: 73B0D7CF07B08C3F573-8026
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
       Part No SW: 1K0 937 049 M    HW: 1K0 937 049 M*
       Component: Bordnetz-SG     H34 0803
       Revision: 00H34000    Serial number: 00000000024936
       Coding: 00050E00000418000014000000140000000073035C
       VCID: 392C25E7655C366F5DF-806C
       Subsystem 1 - Part No: 1K1 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  012  0401
       Coding: 00065493
       Shop #: WSC 12345
       Part No SW: 1K0 909 605 E    HW: 1K0 909 605 E
       Component: 1S AIRBAG VW8R  024 6300
       Revision: 03024000    Serial number: 0037KD011YYR
       Coding: 0012627
       VCID: 2E0606BBAC12E1D7F8D-807A
       Subsystem 1 - Part No: 1K0 959 339 B
       Component: BF-Gewichtsens. 006 0003
       Subsystem 2 - Serial number: 633  SME
       Subsystem 3 - Serial number: 6342MSME08474E5AO
       Subsystem 4 - Serial number: 6351HSME05714A40+
       Subsystem 5 - Serial number: 6361HSME060944191
       Subsystem 6 - Serial number: 63727SME05394844/
       Subsystem 7 - Serial number: 63827SME054A5338%
       Part No SW: 1K0 953 549 AB    HW: 1K0 953 549 AB
       Component: J0527           010 0045
       Coding: 0010021
       VCID: 72BED2CB78AA85375C5-8026
       Part No: 1K0 920 951 C
       Component: KOMBIINSTRUMENT 3HL 0720
       Coding: 0022203
       Shop #: WSC 08305 993 56004
       VCID: 290CF5A795FC86EF2DF-807C
       Part No SW: 1K0 907 530 E    HW: 1K0 907 951
       Component: Gateway         H09 0110
       Revision: 09          Serial number: 2700104C2807B7
       Coding: 3F3F0340071002
       Shop #: WSC 08083 444 59261
       Component: IMMO            3HL 0720
       Part No: 1K0 959 701 K
       Component: Tuer-SG         024 2339
       Coding: 0001269
       VCID: 36362EDB5442D917B0D-8062
       Part No: 1K1 909 144 H
       Component: EPS_ZFLS Kl.2       1502
       VCID: 303A18C3B626F727EA1-8064
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 AM
       Coding: 137803285B09050F880F040011A0
       VCID: 7BA0FFEF2FE0C47F0F3-802E
       Part No: 1K0 959 702 K
       Coding: 0001269
       VCID: 372823DF5348201FABB-8062
    Address 56: Radio        Labels: 1K0-035-161.lbl
       Part No SW: 1K0 035 161 A    HW: 1K0 035 161 A
       Component: Radio DE2       012 0015
       Revision: 00012000    Serial number: VWZ4Z7F6117447
       Coding: 0010400
       Shop #: WSC 05311 000 08193
       VCID: 1D64D177D1B46A4F517-8048
       Part No: 1K0 959 703 D
       Component: Tuer-SG         021 2416
       Coding: 0000144
       VCID: 313C1DC7BD2CFE2FE5F-8064
       Part No: 1K0 959 704 D
       Coding: 0000144
       VCID: 323E12CBB82AC5379C5-8066
    End----------(Elapsed Time: 00:59, VBatt start/end: 14.0V/13.9V)-----------
    Used airbag system parts... It’s a bold strategy Cotton. Let’s see if it pays off for him.
    Unplug the door harness from the A pillar. Unplug the G179 sensor. Short the 2 terminals for the G179 sensor together. Now at the T28 connector at the A pillar, ohm test /12 and /13. What do you get?
    Jef
  3. Likes Uwe, Jack@European_Parts liked this post
    Jun 2017
    By the way ... the door wiring harness is NOT used ... it's new. So there should be no problem there. I would have purchased the one from the 2009 Jetta at Pull-a-Part ... but VW completely changed the door wiring for the 2009 from the 2005 Jetta ... I was FORCED to purchase NEW!
    I also checked the T28 connector at the A-Pillar for corrosion ... it looked good. I even pulled the connector out from inside the car to check the wiring BEHIND the T28 connector ... it looked good too.
    It's going to be a while until I can take the door back apart ... I assume your test would be looking for shorts in the door wiring itself?
    In short, yes. Oh... bad pun. But also, do the wire have continuity? When I had to do testing of wires, I would often unplug both ends of the harness in question, short wires together at one end and then ohm test at the other. If both wires are good, then I'd have a dead short when ohm testing. If a wire was broken, then even though I had them shorted together, my ohm testing would show open circuit. In a door harness, it wouldn't be difficult to just ohm test individual wires since everything is maybe 3ft apart.
    Jef
  6. Likes Uwe liked this post
    Jun 2017
    I was really hoping there was some other known issue with these ... bad crash sensors, etc ... since the door harness is new. I suppose I COULD have two bad crash sensors.
    When I can get back into it, I'll check the two T28/12 and T28/13 wires just to verify they're good.
    Hey Geo
    Very likely air bag module has corrosion from water ingress, especially when short to B+ on a crash sensor is exhibited in DTC & when harness is allegedly new............
    Are there any blown fuses in the car?
    Jun 2017
    OK, I checked the continuity of the two G179 Crash Sensor wires, between the A-Pillar connector and the G179 Crash Sensor connector.
    I took the door harness completely out of the door, connected my probes to both ends of each wire (not simultaneously!) ... then I flexed the harness extensively from one end to the other end ... no problems ... good continuity on both wires.
    So the problem is elsewhere.
    Jack I had checked all the fuses a while back (and I've had the crash sensor fault from the beginning) ... no blown fuses. And are you talking about the Airbag Control Module located in the center console? ... possible corrosion in the connector?
  10. #8
    Yes and the module........check fuses again and be sure the crash sensor is the correct part number to verify all FOD.
  11. #9
    Jun 2017
    Well, for one thing, I noticed that both crash sensors I've tried are Part number: 1K0 955 557 A (for both the 2005 Jetta and 2009 Jetta) ... but when I check on-line VW OEM parts, they list a 1K0 955 557 B as the current Part Number. I might call the VW Dealership tomorrow and give them my VIN and see what they tell my is the current part number.
    I've still got to check the fuses and the module.
  12. #10
    Jun 2017
    No "Airbag" light on dash?
    The car is at the shop getting the A/C serviced right now ... so I haven't had a chance to check the fuses or the Airbag Control Module. I'm going to replace the driver's door crash sensor with the updated "B" sensor (1K0 955 557 B) when I get the car back.
    But ... the other day when I started the car ... I noticed there was NO Airbag light on the dash when the key is on! Is there a way someone could have "disabled" it in the cluster or elsewhere, other than placing a piece of tape over the light within the cluster?
    That's why the scan was saying that the Airbag MIL was "on" ... when in fact I saw nothing on the dash.
    I know when I purchased the car that someone had disconnected the seat belt connectors on the floor under the driver's and passenger's seats ... apparently, they didn't wear seat-belts and didn't like the constant "dinging"! I've reconnected all those and seat belt warning light and chime in the cluster works now.
