Tuesday,20,February,2018,19:57:38:26612
VCDS Version: 18.2.0.3 (x64) HEX-V2 CB: 0.4411.4
VIN: WAUF2BFC8HN11XXXX License Plate:
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 28 36 3B 3C 42 44 46 52
53 55 5F 62 6C 72 85 8B 8E 8F 90
VIN: WAUF2BFC8HN11XXXX Mileage: 15029km-9338miles
Address 01: Engine (J623-CREC) Labels: None
Part No SW: 4G2 907 551 C HW: 4H2 907 551 F
Component: 3.0l V6 TFSI H10 0001
Revision: --H10---
Coding: 0A2A00340566010D3000
ASAM Dataset: EV_ECM30TFS0214G2907551C 001002
ROD: EV_ECM30TFS0214G2907551C.rod
VCID: 2B03FA3F43834F1FF7A-807E
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4G0 927 158 AM HW: 0BK 927 156 AM
Component: 0BK 30TFSIUSA H22 1004
Revision: --H22---
Coding: 000001
VCID: 79AF1077F95F2D8F356-802C
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 44A7964922E569921B00
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 41DFB897D10FB54F3D6-8014
124416 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
[Ldm_ApbFailureState]
Part No SW: 4H0 907 064 HR HW: 4H0 907 064 HR
Component: BCM2 2.0 H61 0825
Coding: 0DA86F4E000000000000
VCID: 00597D939A057C47728-8054
Serial number: 3217000059601005
00955 - Key 1
Reset counter: 161
Mileage: 14199 km
Date: 2018.02.03
Time: 07:56:25
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Serial number: 27031700041863
Coding: 668131B84D0000
VCID: 6393521F6BD3C75F0FA-8036
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 4H0 907 063 GM HW: 4H0 907 063 AM
Component: BCM1 2.0 H20 0368
Revision: 2102003S Serial number: 00001624493601
Coding: 01050011043C9FE2C100488780003800CF9CD208AE08022180000894F10015020060002D0B0000
VCID: 79AF1077F9DF2D8F356-802C
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 170203 H38 0080
Serial number: 170216163238
Coding: 0045F7
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 20157839X81A955547A0
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 AL HW: 4G0 941 531 AL
Component: E1 - LDS H07 0044
Serial number: 15 03 2017 00000944
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 00000000095Z02CA59E1
Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA127128000031311853
Coding: 020300
Subsystem 6 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0006
Serial number: 1F880C9800PAG0MUFU03
03455 - Function Restriction due to Faults in Other Modules
Reset counter: 189
Mileage: 14263 km
Date: 2018.02.06
Time: 20:58:58
Reset counter: 188
Mileage: 14859 km
Date: 2018.02.17
Time: 11:30:44
01229 - A/C Humidity Sensor (G260)
Reset counter: 188
Mileage: 14859 km
Date: 2018.02.17
Time: 11:30:44
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 561 B HW: 4G0 907 561
Component: ACC3 H21 0055
Coding: 7E01010202
ASAM Dataset: EV_AdaptCruisContrAU57X 002015
ROD: EV_AdaptCruisContrAU57X_002.rod
VCID: 290F0037497F5D0F056-807C
Address 15: Airbags (J234) Labels:| 4H0-959-655.clb
Part No SW: 4G0 959 655 B HW: 4G0 959 655 B
Component: Airbag10.43 H62 0092
Revision: -------- Serial number: 003G0003YG7-
Coding: 303331343135303334364A55304C34473053
VCID: 3431E1439EBD10E7A60-8060
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 6940000Y170001L1TG00
Serial number: 3575HRB40634AN7Q7856
Serial number: 3585HRB405F4AN7QF8O2
Serial number: 3515JRB400U599U2PHNA
Serial number: 3525JRB401G59GF0I29
Serial number: 3554VRB400M59GF8G93L
Serial number: 3564VRB400O59GF8GPB5
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H05 0005
Revision: -------- Serial number: 90372QBE000C7
Coding: 0004FC
VCID: 3829D5738255F4878A8-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Serial number: 11 01 2017 D0010788
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 988 F HW: 4G8 920 988 F
Component: TBenUsaAcc H15 0225
Revision: 15001309 Serial number: 658240317596011
Coding: 0BC609040F51D705020000
ASAM Dataset: EV_RBD4K 004060
ROD: EV_RBD4K.rod
VCID: 3D27C467ADF7D1AF59E-8068
Part No SW: 4G8 907 468 H HW: 4G8 907 468
Component: J533--Gateway H15 0096
Revision: -------- Serial number: 00000002560752
Coding: C0CD073010
ROD: EV_GatewPkoUDS_002.rod
Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
Serial number: 0866693304
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F
Component: J532_DCDCStab H23 0022
Serial number: 170115000000000002B0
5701 - High Beam Assistant Control Module
U1070 00 [008] - No Communication
Reset counter: 189
Mileage: 14263 km
Date: 2018.02.06
Time: 20:58:52
Voltage terminal 30: 11.7 V
Voltage terminal 15: 11.7 V
Control Module temperature: 23 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
Address 20: High Beam Assist. (J844) Labels: None
Part No SW: 4H0 857 511 HW: 4H0 857 511
Component: FLA H04 0021
Revision: AA001002
VCID: 678B460F9F6BAB7FD32-8032
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 R HW: 4G0 919 158 R
Component: KLIMA FOND H08 0113
Serial number: 23031700041744
Coding: 20
VCID: 3E25C36BA0F1CAB7404-806A
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000246397339
VCID: 77AB164FCFCB3BFF432-8022
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H04 0056
Revision: -------- Serial number: EJ1BPA820D8ZR1
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 3635DB4B88C102F7984-8062
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 4G0 907 566 M HW: 4H0 907 566 F
Component: SWA Master H08 0070
Serial number: 0435782337
Coding: 040211
VCID: 392FD077B9DFED8F756-806C
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 4G0 907 568 M HW: 4H0 907 568 F
Component: SWA Slave H08 0070
Serial number: 0435032157
Coding: 040211
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0511
Coding: 011F17015E00628002000013
VCID: 45D7AC87C5A7996F01E-8010
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H54 0202
Revision: 00000001 Serial number: 0000725536
Coding: 101001010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A2DCF7BBCD9E6977CC-806E
Revision: 00002001 Serial number: 0435602925
Coding: 0106063A00FA418580B0088402070E470000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0081
Serial number: 00000000000000391180
Subsystem 3 - Part No SW: 4G8 959 591 A HW: 8V3 959 591 A
Component: J245 PS40.402 H03 0004
Serial number: 0000FST001IFKDV00000
Coding: 101F02
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Serial number: 0000000AP00031530554
Subsystem 5 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Component: GEB.F.Heckoef H16 0811
Serial number: 66002><=
00216 - Signal EC-mirror Fade Out
Fault Status: 00101100
Reset counter: 189
Mileage: 14263 km
Date: 2018.02.06
Time: 20:58:52
Component: TSG BF H03 0511
Coding: 011F17015E00628002000002
VCID: 46D5AB8BF8A19277084-8012
Part No SW: 4H0 907 801 M HW: 4H0 907 801 M
Component: EPB-4 H01 0018
Revision: -------- Serial number: 00000002149738
ROD: EV_ParkiBrake_VW51.rod
VCID: 323DE75B64A91ED7B4C-8066
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Component: MxB-ECU 001 0100
Coding: 04FA021122600400
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E01E00
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E01E00
13705491 - Databus
[Timeout CAN-Message FLA_01 (0x645)]
Reset counter: 189
Mileage: 14263 km
Date: 2018.02.06
Time: 20:58:55
Address 5F: Information Electr. (J794) Labels:* 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 025 D HW: 4G1 035 025 C
Component: MU-H-LNS-US 053 0902
Serial number: A741C0H7534501
Coding: 017501020000000013220002041A00102F0006E5F17001047E
ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
VCID: 1F1B1EEF073BA3BF6B2-804A
Subsystem 1 - Part No SW: V03 959 801 PS HW: -----------
Component: NAR 2018 --- 0063
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9HY807HX2
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G1 919 610 F HW: 4G1 919 610 F
Serial number: 90349QCF000LH
Component: Gracenote2--- --- 3011
Component: TSG HL H03 0511
VCID: 49CFA0B7E9BF7D0FE56-801C
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4H0 907 428 E HW: 7P6 907 441 G
Component: TopView H09 0380
Revision: 11001001 Serial number: 82330JG0392211
Coding: 0211000001010000000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
ROD: EV_CamerSysteTopViewAUDI_008_AU57.rod
VCID: 2F3BEE2F779B333FDB2-807A
Component: TSG HR H03 0511
Address 85: On Board Cam. (J852) Labels:* None
Part No SW: 4H0 907 217 F HW: 4H0 907 217 A
Component: DPC-SG H28 0081
Revision: -------- Serial number: 262130025421000
Coding: 6A060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2C01F923468D4827FE0-8078
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 541 B HW: 4G0 907 541
Coding: 7E01010202
ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
ROD: EV_AdaptCruisContr2AU57X_002.rod
VCID: 270B060F5F6B6B7F132-8072
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
Part No SW: 4H0 907 107 H HW: 4H0 907 107
Component: BV-SG H34 0090
Serial number: 005002452803177
Coding: 04C1B8180111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Address 8F: Pretens. Frt Left (J854) Labels:. 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H16 0080
Coding: 0066E608031F0376070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313FE85761AF25CFCD6-8064
Address 90: Pretens. Frt Right (J855) Labels:. 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H16 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End----------(Elapsed Time: 02:28, VBatt start/end: 12.2V/12.1V)-----------
