Results 1 to 4 of 4
Thread: Bit of a newbie question re: Adaptation screen and MMI 3G+
    Feb 2018
    Sorry if this has been posted - I've spent three days looking in here and on the net for something about this. When I plug in my VCDS (car is 2017 A6 Premium Plus, US based) I don't get the option after hitting Adaption that all the "current" videos show to change the channel setting. I did find some stuff that said Audi has made it disabled for VCDS to access this area of the system, but, the path stopped there with some saying a new update would be out soon. The videos show people choosing a field, entering 5F (or other values) and enabling the menu. I instead don't get that option but a long list of "channels" from which I can choose. None seem to match what I'm seeing I should look for in the various online videos.
    My VCDS version is 18.2 and my car was sold new in 5/2017 (I bought it used last week). My MMI software verion is MH12_US_AU57x_P3317
    Thanks in advance!
    I would suppose you have the latest MMI in that car, which is more like the MIB units used in other VAG brands than the older MMI in previous Audis.
    But please post an Auto-Scan so people can see what you actually have.
    Feb 2018
    Admittedly, I think I jumped into the water without checking the depth - I need to get a little more up to speed on everything, MIB, etc. I'll do more to get educated using the site while the kind people here review my scan.
    I'll pull an auto scan when I get home this evening and post it up.
  4. Likes Uwe, GXCars liked this post
    Feb 2018
    Here you go! Also, reading further, I didn't realize there was an evolution from MMI to MIB and that MIB's GEM has limited functionality when compared to the predecessor. This has helped solve some of the mystery for me as I was looking for the wrong stuff.
    Tuesday,20,February,2018,19:57:38:26612
    VCDS Version: 18.2.0.3 (x64)  HEX-V2 CB: 0.4411.4
    VIN: WAUF2BFC8HN11XXXX   License Plate:
    Chassis Type: FC-AU57 (4G8)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 20 28 36 3B 3C 42 44 46 52
              53 55 5F 62 6C 72 85 8B 8E 8F 90
    VIN: WAUF2BFC8HN11XXXX   Mileage: 15029km-9338miles
    Address 01: Engine (J623-CREC)       Labels: None
       Part No SW: 4G2 907 551 C    HW: 4H2 907 551 F
       Component: 3.0l V6 TFSI  H10 0001
       Revision: --H10---
       Coding: 0A2A00340566010D3000
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ECM30TFS0214G2907551C 001002
       ROD: EV_ECM30TFS0214G2907551C.rod
       VCID: 2B03FA3F43834F1FF7A-807E
       Part No SW: 4G0 927 158 AM    HW: 0BK 927 156 AM
       Component: 0BK 30TFSIUSA H22 1004
       Revision: --H22---
       VCID: 79AF1077F95F2D8F356-802C
       Coding: 44A7964922E569921B00
       ROD: EV_ESP9BOSCHAU57X.rod
       VCID: 41DFB897D10FB54F3D6-8014
    124416 - Function Restriction due to Faults in Other Modules
              U1113 00 [032] - -
              [Ldm_ApbFailureState]
       Part No SW: 4H0 907 064 HR    HW: 4H0 907 064 HR
       Component: BCM2 2.0      H61 0825
       Coding: 0DA86F4E000000000000
       VCID: 00597D939A057C47728-8054
       Serial number: 3217000059601005
    00955 - Key 1
                        Reset counter: 161
                        Mileage: 14199 km
                        Date: 2018.02.03
                        Time: 07:56:25
       Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
       Component: KLIMA 4 ZONEN H14 0113
       Serial number: 27031700041863
       Coding: 668131B84D0000
       VCID: 6393521F6BD3C75F0FA-8036
       Part No SW: 4H0 907 063 GM    HW: 4H0 907 063 AM
       Component: BCM1 2.0      H20 0368
       Revision: 2102003S    Serial number: 00001624493601
       Coding: 01050011043C9FE2C100488780003800CF9CD208AE08022180000894F10015020060002D0B0000
       VCID: 79AF1077F9DF2D8F356-802C
       Component: WWS57X 170203  H38 0080
       Serial number:         170216163238
       Coding: 0045F7
       Serial number: 20157839X81A955547A0
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 AL    HW: 4G0 941 531 AL
       Component: E1 - LDS  H07 0044
       Serial number: 15 03 2017  00000944
       Component: USHL4.2  H30 0030
       Serial number: 00000000095Z02CA59E1
       Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA127128000031311853
       Coding: 020300
       Subsystem 6 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Component: AQ_Hum_Sensor  H01 0006
       Serial number: 1F880C9800PAG0MUFU03
    03455 - Function Restriction due to Faults in Other Modules
                000 -  -  - Intermittent
                        Reset counter: 189
                        Mileage: 14263 km
                        Date: 2018.02.06
                        Time: 20:58:58
                        Reset counter: 188
                        Mileage: 14859 km
                        Date: 2018.02.17
                        Time: 11:30:44
    01229 - A/C Humidity Sensor (G260)
                        Reset counter: 188
                        Mileage: 14859 km
                        Date: 2018.02.17
                        Time: 11:30:44
       Component: ACC3          H21 0055
       Coding: 7E01010202
       ASAM Dataset: EV_AdaptCruisContrAU57X 002015
       VCID: 290F0037497F5D0F056-807C
       Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
       Component: Airbag10.43   H62 0092
       Revision: --------    Serial number: 003G0003YG7-
       Coding: 303331343135303334364A55304C34473053
       VCID: 3431E1439EBD10E7A60-8060
       Serial number: 6940000Y170001L1TG00
       Serial number: 3575HRB40634AN7Q7856
       Serial number: 3585HRB405F4AN7QF8O2
       Serial number: 3515JRB400U599U2PHNA
       Serial number: 3525JRB401G59GF0I29
       Serial number: 3554VRB400M59GF8G93L
       Serial number: 3564VRB400O59GF8GPB5
       Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
       Component: Lenks.Modul   H05 0005
       Revision: --------    Serial number: 90372QBE000C7
       Coding: 0004FC
       VCID: 3829D5738255F4878A8-806C
       Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
       Serial number: 11 01 2017  D0010788
       Part No SW: 4G8 920 988 F    HW: 4G8 920 988 F
       Component: TBenUsaAcc    H15 0225
       Revision: 15001309    Serial number: 658240317596011
       Coding: 0BC609040F51D705020000
       ASAM Dataset: EV_RBD4K 004060
       ROD: EV_RBD4K.rod
       VCID: 3D27C467ADF7D1AF59E-8068
       Part No SW: 4G8 907 468 H    HW: 4G8 907 468
       Component: J533--Gateway H15 0096
       Revision: --------    Serial number: 00000002560752
       Coding: C0CD073010
       ASAM Dataset: EV_GatewPkoUDS 002000
       ROD: EV_GatewPkoUDS_002.rod
       Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
       Serial number: 0866693304
       Voltage stabilizer:
       Serial number: 170115000000000002B0
    5701 - High Beam Assistant Control Module
              U1070 00 [008] - No Communication
                        Reset counter: 189
                        Mileage: 14263 km
                        Date: 2018.02.06
                        Time: 20:58:52
                        Voltage terminal 30: 11.7 V
                        Voltage terminal 15: 11.7 V
                        Control Module temperature: 23 C
                        System status: Terminal 15 on
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
    Address 20: High Beam Assist. (J844)       Labels: None
       Part No SW: 4H0 857 511     HW: 4H0 857 511
       Component: FLA           H04 0021
       Revision: AA001002
       Coding: 04018264747464545425363E00
       VCID: 678B460F9F6BAB7FD32-8032
       Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
       Component: KLIMA FOND    H08 0113
       Serial number: 23031700041744
       Coding: 20
       VCID: 3E25C36BA0F1CAB7404-806A
       Revision: AA000000    Serial number: 00000246397339
       VCID: 77AB164FCFCB3BFF432-8022
       Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
       Component: SARA 6D       H04 0056
       Revision: --------    Serial number: EJ1BPA820D8ZR1
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 3635DB4B88C102F7984-8062
       Component: SWA Master    H08 0070
       Serial number: 0435782337
       Coding: 040211
       VCID: 392FD077B9DFED8F756-806C
       Component: SWA Slave  H08 0070
       Serial number: 0435032157
       Coding: 040211
       Component: TSG FA        H04 0511
       Coding: 011F17015E00628002000013
       VCID: 45D7AC87C5A7996F01E-8010
       Part No SW: 4G0 909 144 T    HW: 4G0 909 144 Q
       Component: RCevo         H54 0202
       Revision: 00000001    Serial number: 0000725536
       Coding: 101001010001
       ASAM Dataset: EV_RCEPS 106007
       ROD: EV_RCEPS_106.rod
       VCID: 3A2DCF7BBCD9E6977CC-806E
       Revision: 00002001    Serial number: 0435602925
       Coding: 0106063A00FA418580B0088402070E470000000000000000000000000000
       Component: GTO BF  H01 0081
       Serial number: 00000000000000391180
       Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS40.402  H03 0004
       Serial number: 0000FST001IFKDV00000
       Coding: 101F02
       Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
       Serial number: 0000000AP00031530554
       Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
       Serial number: 66002><=
    00216 - Signal EC-mirror Fade Out
                        Fault Status: 00101100
                        Reset counter: 189
                        Mileage: 14263 km
                        Date: 2018.02.06
                        Time: 20:58:52
       Coding: 011F17015E00628002000002
       VCID: 46D5AB8BF8A19277084-8012
       Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
       Component: EPB-4         H01 0018
       Revision: --------    Serial number: 00000002149738
       ASAM Dataset: EV_ParkiBrake 001033
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 323DE75B64A91ED7B4C-8066
       Coding: 04FA021122600400
       Coding: E01E00
       Coding: E01E00
    13705491 - Databus
              [Timeout CAN-Message FLA_01 (0x645)]
                        Reset counter: 189
                        Mileage: 14263 km
                        Date: 2018.02.06
                        Time: 20:58:55
    Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
       Part No SW: 4G1 035 025 D    HW: 4G1 035 025 C
       Component: MU-H-LNS-US   053 0902
       Serial number: A741C0H7534501
       Coding: 017501020000000013220002041A00102F0006E5F17001047E
       ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
       VCID: 1F1B1EEF073BA3BF6B2-804A
       Subsystem 1 - Part No SW: V03 959 801 PS    HW: -----------
       Component: NAR 2018  --- 0063
       Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
       Serial number: AUZ8Z9HY807HX2
       Multimedia Operating Unit:
       Serial number: 90349QCF000LH
       Component: Gracenote2---  --- 3011
       Component: TSG HL        H03 0511
       VCID: 49CFA0B7E9BF7D0FE56-801C
       Part No SW: 4H0 907 428 E    HW: 7P6 907 441 G
       Component: TopView       H09 0380
       Revision: 11001001    Serial number: 82330JG0392211
       Coding: 0211000001010000000102000000
       ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
       ROD: EV_CamerSysteTopViewAUDI_008_AU57.rod
       VCID: 2F3BEE2F779B333FDB2-807A
       Component: TSG HR        H03 0511
    Address 85: On Board Cam. (J852)       Labels:* None
       Component: DPC-SG        H28 0081
       Coding: 6A060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2C01F923468D4827FE0-8078
       Coding: 7E01010202
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
       VCID: 270B060F5F6B6B7F132-8072
       Component: BV-SG         H34 0090
       Serial number: 005002452803177
       Coding: 04C1B8180111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
    Address 8F: Pretens. Frt Left (J854)       Labels:. 4H0-980-94x-RGS.clb
       Component: RGS-VL        H16 0080
       Coding: 0066E608031F0376070308014240C2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 313FE85761AF25CFCD6-8064
    Address 90: Pretens. Frt Right (J855)       Labels:. 4H0-980-94x-RGS.clb
       Component: RGS-VR        H16 0080
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
    End----------(Elapsed Time: 02:28, VBatt start/end: 12.2V/12.1V)-----------
  6. Likes Derek, Uwe liked this post
