Results 1 to 7 of 7
Thread: SRI reset: distance & time to service are blanked out and can't adjust
    Feb 2018
    Hi all,
    With the 18.2.0 version of VCDS, I can't start the distance or time countdown to next oil change/service counters in the MFD. They just show as "-----".
    Request: I'd like those fields to be counting down miles & days like they used to. Previous versions of VCDS allowed this.
    Car is a 2014 Jetta GLI base, build date 7/2013, with the gen 3 ea888 (probably a very early build?). My cable is a Hex+Can, and running version 18.2.0.
    I have a screen grab from the SRI reset screen, but don't have a web url to file it for linking to this post...and can't attach JPGs... I can email it.
    The SRI reset screen has a top Operation drop-down with 2 options (reset ESI or Reset ESI and FIX) then 12 rows of channels, each having columns for "Description", "Current Val", "new Val", starting with:
    row 1: ide00342-esi: Resetting ESI / ESI: service reminder status / reset / ---
    row 2: ide00510-esi: distance driven from inspection / ESI: distance since inspection / 300km / ----
    rows 1 to 6 are ESI channels, rows 9-12 are FIX channels.
    Rows 7 & 8 have no channel labels... and have descriptions of:
    row7 : SIA: maximum distance to service / current val: --- / new val: -----
    row8 : SIA:Maximum time to service / current val: ---- / new val: ----
    I can't change any numbers on this SRI reset screen then push the "Do It" button. all I can do is pick one of the 2 operations and accept whatever values it does. That executed operation did reset the ESI and FIX numbers and they are incrementing with time & distance...but this does not show up in the MFD - which is a bummer.
    Here's the advanced ID readout from address 17: Instruments
    Address 17: Instruments
    Control Module Part Number: 5C6 920 973 B
    Component and/or Version: KOMBI H04 0811
    Software Coding: 281E01
    Work Shop Code: WSC 00066
    VCID: 2E53B8DC713FBD34BA-807A
    Advanced Identification/FAZIT
    Identification: ZYS-000
    Date: 26.06.13
    Manufacturer number: 4131
    Test stand number: 2249
    Flash Status
    Programming Attempts(application): 0/0/0
    Successful Attempts(application): 0/0/0
    Programming Status: 00000000
    Software
    BAP: 01.04.01
    OSEK-OS: 03.14.00
    HiSpd Net: 01.12.01
    Misc.
    Hardware number: 5C6 920 973 B
    Workshop System Name: J285
    Equipment/PR Code: 2D2D2D2D2D2D2D2D
    Dataset Number: -----------
    Dataset Version: ----
    End of Line Equipment Level: ------------------
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09
    ASAM Dataset Revision: A04721
    Car Info
    Chassis Number: 3VW5S7AJ3EM3532XX
    VCDS Info:
    Labels: 5K0-920-XXX-17.CLB-SRI1
    ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
    2014 Jetta GLI, base, 6mt
    if i remember correctly, after a reset the values in the mfd will display "----" until you drive the car and put a few miles on it.
  3. Likes Derek liked this post
    Quote Originally Posted by conesmacker View Post
    Go to the SRI screen, let VCDS read the channels, then click [Add to logfile].
    Paste the text from the log file here please.
    FWIW, it's not unusual for clusters to show "----" for a while after an SRI reset.
  6. #4
    Magdeburg, Germany
    In fact it is normal/expected behavior, if a car is set to flexible intervals. The cluster will take approximately 500 km for a basic calculation and before the user/driver gets to see the first values.
  7. Likes DV52, Jetta ,97, Derek, PetrolDave liked this post
  8. #5
    Feb 2018
    Okey Dokey. I did add that to the log on Sunday but forgot about it. On Sunday the counter was at 200km, now it is at 300 km. Maybe I just haven't driven far enough?
    VCDS Release 18.2.0: SRI Reset-SRI1.CLB
    Control Module Part Number: 5C6 920 973 B Labels: .*5K0-920-xxx-17.clb-SRI1
    Component:KOMBI H04 0811, Coding:281E01
    Channel Description Current val. New val.
    IDE00342-ESI: Resetting ESI ESI: Service Reminder Status Reset ---
    IDE00510-ESI: distance driven from inspection ESI: Distance since Inspection 200 km ---
    IDE00511-ESI: time from inspection ESI: Time since Inspection 6 d ---
    IDE00515-ESI: oil quality ESI: Oil Quality good oil quality ---
    IDE00517-ESI: soot entry ESI: Soot Quantity 0 km ---
    IDE00518-ESI: thermal load ESI: Thermal Load 500 km ---
    SIA: Maximum Distance to Service --- ---
    SIA: Maximum Time to Service --- ---
    IDE03349-FIX: Max. distance until next mileage-related inspection FIX: Maximum Distance to Inspection 30000 km ---
    IDE03350-FIX: Maximum time until next time-dependent inspection FIX: Maximum Time to Inspection 0 d ---
    IDE03351-FIX: Distance covered since last mileage-dependent inspection FIX: Distance since Inspection 200 km ---
    IDE03352-FIX: Time since last time-dependent inspection FIX: Time since Inspection 7 d ---
  9. #6
    Magdeburg, Germany
    Just wait 'til you're past 500 km and it will show.
  10. #7
    Feb 2018
    Got any feel for why my compass direction in the MFD stopped working right?
    http://forums.ross-tech.com/showthre...ion-how-to-fix
