I installed the virtual cluster from a Tiguan into my GTI. Everything works, minus the navigation (did not connect optical cable yet). My question is, can I change the car icon in the middle from the Tiguan to a GTI? Also, the speedometer seems to read about 10mph higher than it should. Anyone know which variant or setting is correct for GTI? I did get the fuel level part worked out. Have seen others with a wrong fuel gauge. Mine does read correctly.
The only adaptations I have played with and used i the color change, from the blue background to golden orange.
Copy of my full scan below. Not sure if it's needed or not.
Monday,19,February,2018,15:30:42:59930
VCDS Version: 18.2.0.3 (x64)
VIN: 3VW447AU2GM062648 License Plate: KFE6129
Mileage: 27570mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 14 15 16 17 19 2B 32 3C 42 44 47 52 55 5F
75 A9
VIN: 3VW447AU2GM062648 Mileage: 44369km-27569miles
Address 01: Engine (J623-CXCB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 D HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00124424002F1000
Shop #: WSC 11290 003 1048576
ASAM Dataset: EV_ECM20TFS0205G0906259D 001003
ROD: EV_ECM20TFS0205G0906259D.rod
VCID: 2F6DE07D76F7563CB1-807A
Readiness: 1110 1101
Part No SW: 0D9 300 020 J HW: 02E 927 770 AQ
Component: DQ250-6V MQB H53 4931
Revision: 06253104 Serial number: TFK01602271683
Coding: 0018
Shop #: WSC 01357 011 12345
ROD: EV_TCMDQ250021.rod
VCID: 1C3727B11741DDA4E4-8048
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 T HW: 3Q0 907 379 C
Component: ESC H32 0393
Revision: 00000000 Serial number: 50986000001224
Coding: 01FA6BA15426096E007D020441CB6880D62A9000408216B6004300D1C088
VCID: 4B9594EDE22F0A1CBD-801E
8295 - Tire Diameter Implausible
C10A8 00 [009] - -
Reset counter: 91
Mileage: 44369 km
Date: 2018.02.19
Time: 15:24:15
Revision: 00021000 Serial number: 0395800643
Coding: 030C0C
Shop #: WSC 01383 790 50316
VCID: 3A7BC129BDB5839416-806E
Part No SW: 5GM 907 044 A HW: 5GM 907 044 A
Component: Climatronic H03 1001
Revision: 00001K01
Coding: 00020014100100000005004012111402
VCID: 428BB9C9D565CB544E-8016
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 087 AA HW: 5Q0 937 087 AA
Revision: -------- Serial number: 865818031601HP
Coding: 00111A464041A2F969E44000001407201800000000000000000000000000
Shop #: WSC 62322 002 104857
ROD: EV_BCMBOSCH_015.rod
VCID: 7AFB0129FD35439456-802E
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150907 043 0581
Serial number: 160331010754
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S2Y16M02D26H04M26S56
Coding: 90A8DD
Sun Roof:
Subsystem 3 - Part No SW: 5GD 959 591 HW: 5GD 959 591
Component: J245 PS60.036 H06 0150
Serial number: 03691620011001162045
Coding: 181803
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 A HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0120
Serial number: 02031641350016
ROD: EV_DRCONTITEMIC_VW27.rod
VCID: 377DD81D8EA79EFCE9-8062
Component: AirbagVW20 010 0830
Serial number: 003GCR04J89C
Shop #: WSC 00066 790 00211
VCID: 479DA8DDFE47EE7C99-8012
Occupant Detection:
Component: BF-Gewichtss. H12 0021
Serial number: IBH000000000004XAIN5
Coding: 303131
Subsystem 2 - Part No SW: ----------- HW: 480 002 502 16
Serial number: 35700000000B4224691B
Subsystem 3 - Part No SW: ----------- HW: 480 002 502 16
Serial number: 358000000006FA71591R
Subsystem 4 - Part No SW: ----------- HW: 480 400 603 16
Serial number: 35100029F1F93A03B2AD
Subsystem 5 - Part No SW: ----------- HW: 480 400 603 16
Serial number: 3520002B71F93A01330W
Subsystem 6 - Part No SW: ----------- HW: 480 402 002 16
Serial number: 3550002BB1F93A3612EF
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 002 16
Serial number: 3560002BB1F93A35B2EP
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20160310500041
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 04077FD18FF105643C-8050
Part No SW: 5NA 920 891 B HW: 5NA 920 891 B
Component: KOMBI 407 3193
Coding: 0BAD091B3988CF0502086A085000000000000000
VCID: 4385BCCDCA7FC25C45-8016
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 24021610800036
Coding: 0101000830085900FB00022B9C0F00000001050000000000000000000000
ROD: EV_GatewConti_013_VW37.rod
VCID: 79F91E25F833488C5F-802C
Subsystem 2 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0103
Serial number: 29160003491200067021
Coding: 31FFFF
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000044893005
Coding: 5D00000000000000
Shop #: WSC 00066 790 00322
ROD: EV_ELVMarquMQB.rod
VCID: 3467EF119FD175E4CC-8060
Address 32: Differential Locks (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 E HW: 0CQ 907 554 E
Component: Quersperre H52 8042
Serial number: HA1-00013.01.16
Coding: 0001
ASAM Dataset: EV_LockElectHA1VW37X 001007
ROD: EV_LockElectHA1VW37X.rod
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H11 0071
Serial number: 0390858946
Coding: 02022103
ROD: EV_HREntryHella_VW37.rod
VCID: 3C77C731B781BDA404-8068
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H11 0071
Serial number: 0390811542
Coding: 020221
337312 - Databus
Reset counter: 91
Mileage: 44369 km
Date: 2018.02.19
Time: 15:24:12
388357 - Databus
Reset counter: 91
Mileage: 44369 km
Date: 2018.02.19
Time: 15:24:12
Component: TSG FS 020 0041
Serial number: 160416060500W3
Coding: 003F13205000020000000000
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000012273761
Coding: 011000
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 8102
Shop #: WSC 00066 790 00149
VCID: 3979DE25B8B3888C1F-806C
20484 - Databus
Reset counter: 91
Mileage: 44369 km
Date: 2018.02.19
Time: 15:24:12
Motor status: 00
Supply voltage: 11.75 V
Temperature: 43.0 °C
KFC: 50
KFA: 00 04
Environmental conditions: 7F
uioUdNotFilt_xdu16: 11.94 V
uAdSensI_SwitchedKl30_xdu16: 11.94 V
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H20 0150
Revision: 00000001 Serial number: VWZ8Z1FBA01K8TL
Coding: 2200000000AAAAAA000000000000
ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 6DD13A75BC7BE42CC3-8038
Component: TSG BFS 020 0041
Serial number: 160416060502PC
Coding: 003F13205C00020000000000
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000012076053
Coding: 091000
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 021203000B000400
VCID: 408FB3C1DB69D94458-8014
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
Part No SW: 3Q0 035 876 HW: 3Q0 035 876
Component: MU-S-NS-US 820 0613
Coding: 027300020000000051220002001808001F0203F401200105C6
ROD: EV_MUStd4CDELP_VW27.rod
VCID: 71E92605A04300CCE7-8024
Subsystem 1 - Part No SW: 5GM 919 605 HW: 5GM 919 605
Component: ABT_Std-2_Nav H53 1031
Serial number: VWZ8Z9SJX0045C
Subsystem 2 - Part No SW: 3G0 919 866 R HW: -----------
Component: NAR 2016 --- 0321
6696 - Instrument Cluster Control Module on Optical Bus
U10C0 00 [009] - No Communication
Reset counter: 91
Mileage: 44369 km
Date: 2018.02.19
Time: 15:24:15
Voltage terminal 30: 12.0 V
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0568
Coding: 02730002C2823A017F1E06000000
ROD: EV_OCULowMQB.rod
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 160131200154
VCID: 6BD5346D826FEA1CDD-803E
End-------------------------(Elapsed Time: 04:49)--------------------------
