Monday,19,February,2018,19:06:01:48203
VCDS Version: 18.2.0.3
VIN: WUAZZZ4F18N901766 License Plate:
Mileage: 146920km-91291mi Repair Order:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 11 31 14 15 16 17 19 1E 36 37 42
46 47 4F 52 53 55 56 61 62 65 6D 72 76 77
VIN: WUAZZZ4F18N901766 Mileage: 146920km-91291miles
01-Engine -- Status: Not registered 0011
11-Engine II -- Status: Not registered 0011
31-Engine other -- Status: Not registered 0011
Address 01: Engine (BUH) Labels:. 07L-910-552-BUH1.clb
Part No SW: 4F1 910 552 D HW: 4F1 907 552 A
Component: 5.0L V10/4V TFSI ª0080
Revision: F1H05--- Serial number:
Coding: 010D0003190F01B0
Shop #: WSC 00000 000 02400
VCID: 254A0143EC5D4D6C4B-8070
049425 - No Communication with Battery Energy Control Module
U0111 - 008 - - Intermittent
Mileage: 146920 km
Date: 2018.02.18
Time: 18:01:53
RPM: 1135 /min
Load: 23.1 %
Temperature: 15.0°C
Temperature: 13.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.589 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Mileage: 146925 km
Date: 2018.02.19
Time: 19:02:59
Temperature: 8.0°C
Temperature: 9.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 11.303 V
Readiness: 0110 1101
Part No SW: 4F5 910 156 P HW: 09E 927 156 D
Component: AG6 09E 5,0TFSI 250 0020
Revision: --H04--- Serial number: 0001778
Shop #: WSC 02152 785 00200
VCID: 356AD1035CFD3DECFB-8060
005913 - Functionality limited due to Engine Control Module
P1719 - 000 - - Intermittent
Mileage: 146920 km
Date: 2018.02.18
Time: 18:02:00
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AJ HW: 4F0 614 517 AR
Component: ESP8 quattro H01 0130
Coding: 0020931
VCID: 6CDC34674F37BC24D4-8038
Part No SW: 4F0 910 852 B HW: 4F0 905 852 D
Component: FBSAUDIC6 ELV H05 0090
Revision: 00H05000 Serial number: 10602401114122
Coding: 0000147
Shop #: WSC 50512 000 1048576
Subsystem 1 - Part No: 4F0 910 132 E
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 220 K
Component: FBSAUDIC6 IDG H01 0040
00955 - Key 1
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 134
Mileage: 146925 km
Date: 2018.02.18
Time: 18:11:35
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 H HW: 4E0 035 729
Component: Interfacebox H43 5140
Revision: 00000000 Serial number: 350F/087888951
Coding: 0031002
Shop #: WSC 02556 785 00200
VCID: 285408779B4F500470-807C
Subsystem 2 - Serial number: 00000001096690
Subsystem 3 - Serial number: 0111.06.080000000100010394ÿ
Subsystem 4 - Serial number: 010394ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F2 820 043 Q
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000053 Serial number: 00000000540282
Coding: 0525578
VCID: 1C3C24A7DF178CA4E4-8048
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H18 0250
Coding: 0015121
VCID: 3162E513A89511CCA7-8064
Subsystem 1 - Part No: 4F2 910 113 B Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H06 0190
Coding: 00064784
Shop #: WSC 02556
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150608
Shop #: WSC 02556
Address 0E: Media Player 1 (R199) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H15 0850
Revision: 00000000
VCID: 2B5EF77B4AB97B1C9D-807E
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1276W7301083
VCID: 244C1C47E767B4645C-8070
Address 11: Engine II Labels:. 07L-910-552-BUH2.clb
Shop #: WSC 79411 154 394822
Mileage: 146920 km
Date: 2018.02.18
Time: 18:01:53
RPM: 1130 /min
Load: 23.1 %
Temperature: 15.0°C
Temperature: 13.0°C
Voltage: 13.589 V
008199 - Intake Manifold Flap; Bank 2
P2007 - 001 - Stuck Closed - Intermittent
Fault Status: 00100001
Mileage: 146920 km
Date: 2018.02.18
Time: 18:02:08
RPM: 805 /min
Load: 32.1 %
Speed: 1.0 km/h
Temperature: 17.0°C
Temperature: 13.0°C
Voltage: 14.224 V
Address 14: Susp. Elect. Labels: None
Part No SW: 4F0 910 376 HW: 4F0 907 376
Component: J250 DRC FahrwerH02 0020
Serial number: 00870000193500
Coding: 0000000
VCID: 64CC5C47A7E7F4649C-8030
8 Faults Found:
Fault Status: 11101010
Reset counter: 133
Mileage: 146920 km
Date: 2018.02.18
Time: 17:59:15
01769 - Sensor for Vehicle Leveling; Front Right (G289)
Reset counter: 133
Mileage: 146920 km
Date: 2018.02.18
Time: 17:59:15
00774 - Level Control System Sensor; Rear Left (G76)
Reset counter: 133
Mileage: 146920 km
Date: 2018.02.18
Time: 17:59:15
00775 - Level Control System Sensor; Rear Right (G77)
Reset counter: 133
Mileage: 146920 km
Date: 2018.02.18
Time: 17:59:15
00142 - Left Front Dampening Adjustment Valve (N336)
011 - Open Circuit - MIL ON
Fault Status: 11101011
Reset counter: 133
Mileage: 146920 km
Date: 2018.02.18
Time: 17:59:21
00143 - Front Right Dampening Adjustment Valve (N337)
Reset counter: 134
Mileage: 146920 km
Date: 2018.02.18
Time: 17:59:21
00144 - Rear Left Dampening Adjustment Valve (N338)
Reset counter: 134
Mileage: 146920 km
Date: 2018.02.18
Time: 17:59:21
00145 - Rear Right Dampening Adjustment Valve (N339)
Reset counter: 134
Mileage: 146920 km
Date: 2018.02.18
Time: 17:59:21
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4F AIRBAG AUDI8RH30 0280
Revision: 09H30000 Serial number: 0037LD0YNUWY
Coding: 0013382
Shop #: WSC 02325 785 00200
VCID: 29520D738045690C6F-807C
Subsystem 1 - Serial number: 6332CSME3C236144$
Subsystem 2 - Serial number: 6342CSME31626C697
Subsystem 3 - Serial number: 6352QSME744E1E2F
Subsystem 4 - Serial number: 6362QSME74461B4BQ
Subsystem 5 - Serial number: 63734SME647239694
Subsystem 6 - Serial number: 63834SME73475053-
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90025081630032
Coding: 0102142
VCID: 27560B4B96515F7C79-8072
Component: E0221 H06 0030
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 D HW: 4F0 920 983 D
Component: KOMBIINSTR. M73 H23 0020
Revision: 00400000 Serial number: 8CY301268
Coding: 3153458
Shop #: WSC 11374 067 57207
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B0862184E4
Coding: F5D5BE37703A0602
VCID: 2D5AF963B4AD752C83-8078
Reset counter: 134
Mileage: 146925 km
Date: 2018.02.19
Time: 19:02:58
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H47 0390
Revision: 00047003 Serial number: AUZ5ZBH8482420
VCID: 1A3022BFD523F294F6-804E
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0091138
VCID: 61C25553B8F5E14C77-8034
Part No SW: 4E0 910 888 E HW: 4E0 919 887 M
Component: MNS ECE H52 1050
Revision: 00000000 Serial number: 364FT087800168
Shop #: WSC 00586 210 55382
VCID: 3064E017A39F18C4A8-8064
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 P HW: 4F0 959 793 P
Component: TSG FA H12 0230
Revision: 00000000 Serial number: 1s
Coding: 0003838
Shop #: WSC 02327 785 00200
VCID: 3776DB0B46F1CFFCE9-8062
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 K HW: 4F0 907 289 K
Component: Komfortgeraet H27 0220
Revision: 02200027 Serial number: 01124308010000
Coding: 3285755
VCID: 3260EA1FAD932AD4DE-8066
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H10 0240
Revision: PROD_01 Serial number: 00000000100348
Coding: 0000117
Part No SW: 4F0 910 280 HW: 4F0 907 280 G
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000005709
Coding: 0011101
VCID: 5EB86EAF898BDEB44A-800A
Reset counter: 173
Mileage: 146920 km
Date: 2018.02.18
Time: 18:01:00
Voltage: 11.200 V
Temperature: 9.0°C
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 P HW: 4F0 959 792 P
Component: TSG BF H12 0230
Revision: 00000000 Serial number: ySv
Coding: 0003838
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0008021
Shop #: WSC 02197 785 00200
VCID: 20441057F37FA84438-8074
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0040
Coding: 0000016
Shop #: WSC 37487 001 1048576
VCID: 69D24D7340C5A90CAF-803C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H02 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH02 0010
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Revision: 00000000 Serial number: 394FS087912502
VCID: 2E58FE6FB9AB0E34BA-807A
Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
Component: J0644 BEM H12 0760
Revision: 00000000 Serial number: 00000000102162
Component: von VA0 A03C8617NH
Coding: 344630393135313035442056413041303343383631374E48
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0210
Coding: 0003118
Address 65: Tire Pressure Labels: 4F0-910-273-HI.lbl
Part No SW: 4F0 910 273 C HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000700030305
Coding: 0222625
VCID: 234E1F5BE269B35C25-8076
02214 - Tire Pressure Warning
Reset counter: 174
Mileage: 146925 km
Date: 2018.02.18
Time: 18:11:36
(no units): 0.0
Temperature: 7.0°C
Error Code: 0
Pressure: 3.77 bar
Pressure: 0.00 bar
Pressure: 0.00 bar
Pressure: 0.00 bar
Address 6D: Trunk Elect. Labels: Redir Fail!
Part No SW: 4F9 910 591 HW: 4F9 827 851 F
Component: ValeoHeckdeckel H25 0290
Revision: --H25001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
Subsystem 1 - Part No: 4F9 910 592
Subsystem 3 - Serial number: RD19.06.08--H25001001A0195ÿ
Subsystem 4 - Serial number: 1A0195ÿ
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0210
Coding: 0003118
Part No SW: 4F1 910 283 A HW: 4F1 919 283 A
Component: Parkhilfe 8-Kan H12 0110
Revision: 00H12000 Serial number: 64320813100358
Coding: 0201116
Part No SW: 4E0 910 336 L HW: 4E0 862 335
Component: Handyvorb2 H20 1120
Revision: 00000000 Serial number: 00000005185917
Coding: 0010920
VCID: 2B5EF77B8AB97B1C9D-807E
End-------------------------(Elapsed Time: 03:14)--------------------------
